Date/Time: Wed, 27 Nov 2024 04:03:38 +0000
message log
View Count: 125
[2024-08-23 15:53:20] |
User282298 - Posts: 9 |
Hi his morning i login and all my drawing is gone doesnt get saved, how do i properly save them? when i try ti put in any draw like line or horizontal ray, this message pops up thanks Jack |
[2024-08-26 13:31:15] |
John - SC Support - Posts: 36309 |
There is nothing in that log that shows any issues with Drawings. If drawings are not showing immediately after you draw them, then this would mean that you have one of the options to "Hide Chart Drawings" enabled. Refer to the following and the item below it: Chart Menu: Hide Chart Drawings (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
