Date/Time: Fri, 20 Sep 2024 00:11:10 +0000
Point and Figure
View Count: 1163
[2014-09-01 09:48:52] |
2garin - Posts: 184 |
Good day. Please tell me how to build a 6tick Point and Figure (P&F) chart (Bid Vol X Ask Vol). Which chart to create? Which indicator to add? Date Time Of Last Edit: 2014-09-01 09:49:37
Private File |
[2014-09-02 02:19:42] |
You need to set the chart Bar Period Type to Reversal Bars with a setting of 6. Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar And you need to add the Numbers Bars study to the chart: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-02 02:19:58
