Date/Time: Fri, 22 Nov 2024 07:38:54 +0000
target/stop prices are not created correctly with acsil
View Count: 2669
[2013-05-08 12:12:57] |
User32496 - Posts: 26 |
i took that example from tradingsystem.cpp if (sc.CrossOver(Last, SimpMovAvgSubgraph) == CROSS_FROM_BOTTOM && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED) { NewOrder.Target1Price = sc.Ask + 8*sc.TickSize ; NewOrder.Stop1Price = sc.Ask - 8*sc.TickSize; int Result = sc.BuyEntry(NewOrder); if (Result > 0) //If there has been a successful order entry, then draw an arrow at the low of the bar. { BuyEntrySubgraph[sc.Index] = sc.Low[sc.Index]; // Remember the order IDs for subsequent modification and cancellation Target1OrderID = NewOrder.Target1InternalOrderID; Stop1OrderID = NewOrder.Stop1InternalOrderID; } } when i compiled it and run it as an indicator (on the dax futures) to sent orders i get this error on the trade service log Trade Order Error: Parent price (8226.500000) is more than 25% different than original Attached order price (-1.000000). Attached Order not modified. Internal order ID: 117 | 2013-05-08 08:09:52 Trade Order Error: Parent price (8226.500000) is more than 25% different than original Attached order price (16452.000000). Attached Order not modified. Internal order ID: 118 | 2013-05-08 08:09:52 what should be the correct acsil ? thanks |
[2013-05-08 16:44:30] |
Not quite sure what the problem is. Use this code to set the prices: NewOrder.Target1Price =sc.Close[sc.Index] + 8*sc.TickSize ; NewOrder.Stop1Price = sc.Close[sc.Index]- 8*sc.TickSize; Is the chart Tick Size set correctly. This is set in Chart >> Chart Settings >> Tick Size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-08 16:47:34
