Date/Time: Fri, 22 Nov 2024 22:23:17 +0000
Chart Live data lagging behind .
View Count: 215
[2024-08-21 09:28:07]
User838995 - Posts: 16
1. My chart window is more to the right and I can't see or operate the arrow on right corner since it is not visible. I can not drag the chart to the left or place it correctly. I must have pressed some wrong option. Full screen image is attached. Thank you for your help.
2. Live data is running 1-2 minutes behind. My computer clock is correctly synced. (Stated in other post also. (Apologize for repeating)
Thank you
Private File
[2024-08-21 18:38:38]
Sierra_Chart Engineering - Posts: 17145
1. Activate that chart and then use one of the Window >> Tile* commands to reposition it. Another thing you can do is add the title bar.:
Chart Menu: Show Title Bar (Chart menu)
And then you can move the window with the title bar.
[2024-08-29 09:40:07]
I have a Bill Williams Fractal as Diamonds on Support and Resistance on my chart.. I further, want to add/attach Price Label to these Diamonds and also to dotted lines of for support and Resistance. The attached chart image shows these price labels attached to the Pink and green Diamonds.
No 1& 2 chart image is sample of Price labels on Diamonds & dotted lines.
No3 Chart is mine with Diamonds where I want to add Price labels.
Hope it Is clear.
image1.IMG_39971.jpg PRICE Lables On Diamonds Bill William Fracta.jpg / V - Attached On 2024-08-29 09:34:32 UTC - Size: 198.67 KB - 29 views
image2.IMG_39681.jpg Price labels on Diamonds & dotted Support Re.jpg / V - Attached On 2024-08-29 09:34:38 UTC - Size: 206.03 KB - 31 views
Private File
[2024-08-29 14:22:31]
To us, it appears those prices are just displayed as numbers above/below the candle. To do this, use the "Study Subgraph Above/Below Bar as Text" study. Refer to the following:
For the dotted lines, those appear to be something built into the study since they have a price value displayed at the end of line, so we can not help with that in particular. But you can create the lines themselves by following these instructions:
Color Bar Based on Alert Condition: Creating Extension Lines for Another Study
[2024-09-02 06:27:59]
Couldn't do it.
Yes I have Swing highs and lows in the study as you can see into my above chart image no 3 but I want to add Price value displayed at the end of line as shown in the Chart Image 1 & 2.
How and what settings I need to go into to add these price value at the end of swing high and low dotted lines.
Thank you for your help. K.A
[2024-09-04 17:57:58]
There is not a built-in way to get the prices shown at the end of the extension lines as they are in images 1 and 2.
Whomever you are copying that from must be using a custom study to do this. Refer to the following:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].LineLabel
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2024-09-19 15:05:11]
I have completed the CME Non-Professional Certification agreement in Aug.2024 when I registered with Sierra and CME.
Am I supposed to do something each month 0r no need to further do anything. I get the $2 LIVE DATA via Danali.
Thank you
KA
[2024-09-19 15:27:53]
If you are always connected to your live trading account, then there is nothing you need to do. Your "Verified Until" date will automatically update.
You only need to do the connection once a month if you are NOT connected to your live trading account.
