Date/Time: Wed, 27 Nov 2024 04:03:03 +0000
[User Discussion] - SEND TRADES FROM TRADINGVIEW TO SIERRACHART
View Count: 209
[2024-08-21 03:41:38] |
User346587 - Posts: 19 |
Hi, is there a way to send trades from tradingview (alerts) to sierrachart? automated trading Thank you |
[2024-08-21 15:59:37] |
Sierra_Chart Engineering - Posts: 17190 |
You would have to work out your own custom solution to this. Refer to: Advanced Custom Study Interface and Language (ACSIL) So it is possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-21 16:30:37
