Date/Time: Wed, 27 Nov 2024 03:24:48 +0000
Customize orders
View Count: 115
[2024-08-19 22:57:52] |
swaggeyg - Posts: 2 |
I’m trying to have it when I place a trade using the attached order window when I buy or sell a specific amount of contracts my stop loss is automatically place for example when I buy or sell 6 lots on nq I want a stop loss of 2 points to be automatically placed is that possible
[2024-08-20 14:30:08] |
John - SC Support - Posts: 36309 |
Absolutely you can do this. Refer to the information for Attached Orders at the following link: Attached Orders For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-20 18:16:43] |
ik you can do it like that if you have it selected I trying to figure out if I just place a regular order for 6 lots could it auto put a stop for 2 points or if I buy 4 lots can you put stop for 3 points I don't want to have to click on a specific oco bracket configuration to do it
[2024-08-20 19:52:54] |
There are Trade Configurations that allow you to specify a particular setup. You can setup Control Bar and/or Keyboard shortcuts to change between them. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations The only way to have the system do what you want in terms of determining the Stop location based on the Quantity would be to create a custom study. Refer to the following: Automated Trading From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
