Date/Time: Wed, 27 Nov 2024 04:01:15 +0000
atr study not showing in main graph
View Count: 148
[2024-08-19 20:19:00]
User775804 - Posts: 3
hello i have been trying to add a study of atr to my chart but it does not seem to show in section 1 the main section. i can see it when i move it to sections 2,3 but not in my main display unless i select as main graph , could you tell me please of there is a setting i am missing
imageshot 3.png / V - Attached On 2024-08-19 20:18:44 UTC - Size: 115.46 KB - 32 views
[2024-08-19 20:23:16]
John - SC Support - Posts: 36309
With the study set to display in Region 1, you would need to change the scale for the study to "Independent". If it is set to "Automatic", then this will cause the main graph to compress, as the values of the ATR are no where near the values of the main price graph. Refer to the following:
Chart Scale and Scale Adjusting: Displaying Multiple Graphs in Chart Region
[2024-08-19 23:36:06]
thats awesome thank you , is there a way for it to move /attach to current graph. im using renko and want the study to move with the current graph/renko blocks
[2024-08-20 15:09:05]
We are not understanding the question.
[2024-08-21 01:55:16]
apologies. im trying to set the renko blocks to average true range rather than traditional , is there a setting for this i cant find it
[2024-08-22 15:34:23]
There is not a built in way to do what you are asking for. You could create a custom study to do this by either creating custom bars, or by adjusting the settings for the Renko bar size. Refer to the following:
ACSIL Interface - Custom Chart Bars
sc.SetBarPeriodParameters()
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
