Date/Time: Wed, 27 Nov 2024 10:30:11 +0000
Weird bars
View Count: 1142
[2014-08-31 09:39:30] |
User11942 - Posts: 298 |
Hello SC, just tried to open my charts. Please see attached screenshot. What are those bars dated Aug 30? How to remove them? Thanks. |
[2014-08-31 10:26:37] |
crazybears - Posts: 314 |
Hi same here , all symbols from CME show bars with date AUG 30 . |
[2014-08-31 19:58:17] |
This is the result of the CME transmitting data late Saturday which is Sunday in UTC. We have to put in a special patch for this. We are going to be working on it today. First time they have done this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-31 20:35:14] |
Yeah... have never seen it before on my trading platforms. But how can I get rid of that now? The data are downloaded and saved in my chartbooks and it's just 90 min to open. |
[2014-08-31 21:12:01] |
Once we put the patch in, will make a posting here and then you can re-download the data from before Saturday and it will be gone.
[2014-08-31 22:10:06] |
This problem is now solved. Right-click on the chart sometime on Friday before and select Delete and Download Data. The late Saturday data will be removed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-31 22:41:12] |
abrown8703 - Posts: 64 |
I'm on TransAct and I've done what you suggested, however, the late Saturday data can not be removed. Please advise.
[2014-08-31 22:51:23] |
OK that comes from another server. We are working on this now.
[2014-08-31 23:13:08] |
Try re-downloading the data from Friday going forward and the early Sunday data should now be gone, when using TransAct.
[2014-09-01 06:39:02] |
Dear SC, Thank you very much for that remarkably swift resolution, really appreciated. Though I didn't come to check SC since my latest post and traded Sun opening through TWS. |
