Date/Time: Fri, 22 Nov 2024 05:59:24 +0000
Copy Trades to Topstep with another instance of Sierrachart
View Count: 256
[2024-08-18 10:27:26]
User395685 - Posts: 33
I have an account with AMP (with Teton) and would like to copy my trades to a Topstep account (with Rithmic data). I imagine it is not possible to do it with one instance of Sierrachart but will it work with two separates instances, using the same credentials for both instances, as described here: Using Multiple Data and Trading Services at the Same Time ?
Thanks.
Date Time Of Last Edit: 2024-08-18 10:30:48
[2024-08-18 14:40:48]
Sierra_Chart Engineering - Posts: 17143
No, this is not supported.
[2024-08-18 15:37:22]
Sorry, I didn't make myself clear. By copying I mean taking a trade on the Sierrachart instance for AMP, and then taking the same trade on the Sierrachart instance for Topstep, with the two instances opened at the same time. So, same credentials for both instances, but different data/trading services.
Surely this is supported as this is what the page is describing?
[2024-08-18 15:52:04]
No this is definitively not supported at all. And never would be.
Date Time Of Last Edit: 2024-08-18 15:52:17
[2024-08-18 16:13:09]
Isn't it what this page is explaining exactly? Or is there something I am missing?
Date Time Of Last Edit: 2024-08-18 16:13:27
[2024-08-18 18:07:17]
No, it definitely does not explain anything about copying orders between instances. Each instance, is independently controlled.
There is no information on that page at all about this.
Date Time Of Last Edit: 2024-08-18 18:07:37
[2024-08-18 18:39:41]
Again I think there is a misunderstanding, what I am asking has nothing to do with "copying" orders. I used the wrong term.
Here is what I want to do.
- I manually put a buy stop order at 5000.00 (ES futures) on my AMP/Teton Sierrachart instance.
- Just after that, I put another buy stop order at 5000.00 (ES futures) on a second instance of Sierrachart which I use for my Topstep/Rithmic account.
So there are two different trades, one for AMP, one for Topstep. It just turns out they have the same entry price.
I'm 99% sure this is possible reading your documentation but I just wanted confirmation.
[2024-08-18 20:33:19]
ForgivingComputers.com - Posts: 959
Now that it is clear: Manually Entering the same trade in both instances is supported, Automatically copying them between instances is not.
FYI: Around these parts "Trade Copying" implies automated copying.
[2024-10-18 19:50:42]
tomas262 - Posts: 141
Use ChatGPT to make an ASCIL study that copy a position data to a pipe file. Another version (in the other instance) would read it an open corresponding position.
Same for closing a position. It can only copy PositionQuantity +/-/0.
What is the problem?
