Date/Time: Fri, 22 Nov 2024 21:06:34 +0000
Feature Request. DOM Midpoint
View Count: 179
[2024-08-17 05:02:35]
barzay.bavno - Posts: 3
Feature Request.
I am currently looking at multiple DOMs with the midline feature on to help me gauge spreading and how a certain market performs compared to another correlated one. The tricky thing is that for whatever reason the midlines across the DOMs sometimes misalign by a tick or two, even though I have set the exact same constant range across all of them.
A simple solution would be an "anchored" midline, with the idea of the midline staying cemented, once i set it in the desired spot.
Additionally, to be used for the recentering process.
It would be much appreciated if you include this feature for a Trade DOM as well as a Chart DOM.
Looking forward to hearing from you.
Kind regards
Date Time Of Last Edit: 2024-08-17 05:04:37
[2024-08-19 14:43:20]
John - SC Support - Posts: 36236
Are you using the "Chart/Trade DOM Recenter Line" or the "Chart/Trade DOM Middle Line"? It sounds like the Middle Line does what you want. It sits at the middle of the chart and shows where the chart will recenter to when you reset/recenter the DOM.
[2024-08-27 08:21:52]
I am uploading an example of how the midlines across two DOMs are misaligned, for whatever reason. The screenshot is taken immediately after recentering them.
Simple solution is to provide an option to "anchor" them in a desired constant place.
It is worth noting that scales across those DOMs are set at the exactly same constant range and that I am aware of the recenter line feature, and the ones on the picture are midlines
Cheers.
https://www.sierrachart.com/image.php?Image=1724746716481.png
[2024-09-25 04:27:38]
User839162 - Posts: 87
+1 for this. It's rather annoying when recentering DOMs and some are misaligned by a tick. The DOM midline should be between the best bid and ask every time they are recentered.
