Date/Time: Thu, 19 Sep 2024 16:48:18 +0000
Horizontal and Vertical cursor
View Count: 2864
[2013-05-08 11:34:37] |
Juriossoy - Posts: 11 |
hi is it possible to implement these things in TOS platform: Select Vertical to amplify the cursor with a vertical line so that placing the cursor over any point of the subgraph will indicate the corresponding date (or time on the intraday charts) in the bubble on the Time Axis. Select Horizontal to amplify the cursor with a horizontal line so that placing the cursor over any point of the subgraph will indicate the corresponding price in the bubble on the Price Axis. More info is here: http://tlc.thinkorswim.com/center/charting/charts/Chart-Style-Settings/appearance.html |
[2013-05-08 17:20:37] |
You will want to use the Chart Values tool for this: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
