Date/Time: Fri, 20 Sep 2024 00:47:08 +0000
Smooth Volume Profile
View Count: 1259
[2014-08-29 22:15:18] |
User76044 - Posts: 11 |
Hi Is it possible to smooth the volume profile by averaging the bars, this provides a clearer view of high and low peaks Thanks, Ben |
[2014-08-29 23:18:07] |
No. This is not supported.
[2014-08-29 23:45:30] |
Are there plans to add this feature?
[2014-08-29 23:48:09] |
No.
[2014-08-30 16:37:21] |
How can I add this as a feature request?
[2014-08-30 20:30:21] |
Unless this were a critical improvement, we cannot take any new feature requests now. We have too many already.
[2014-08-30 20:48:35] |
Okay, it would still be great if you can add this, I believe it makes the Volume Profile significantly easier to use and is offered by competitors. It is just smoothing the volume bars by averaging them with the surrounding bars.
[2014-08-30 20:52:08] |
As a workaround, is it possible to plot a moving average so that it is drawn vertically across the volume bars as this would essentially the same result?
[2014-09-02 18:17:32] |
No, this would not work.
