Date/Time: Wed, 15 Jan 2025 08:48:36 +0000
CHART BOOK NOT WORKING
View Count: 285
[2024-08-14 21:49:07]
DAVID SUDDUTH JR - Posts: 34
Hello
I have an edge clear account. I am having problem with my chart book working. I took a month off.
I also have APEX account.
2024-08-14 17:08:53.272 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:08:53.272 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:08:53.401 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:08:53.401 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:08:53.401 | Historical data download ID 121376 not found when removing ID from outstanding request set.
2024-08-14 17:08:53.401 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:08:53.401 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:08:53.401 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:08:53.401 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:08:53.401 | Historical data download ID 121377 not found when removing ID from outstanding request set.
2024-08-14 17:08:53.401 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:08:53.401 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:08:53.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:08:53.443 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:08:53.443 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:08:53.443 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:08:53.443 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:08:53.443 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:08:53.443 | DTC Client socket (4) | Closed.
2024-08-14 17:08:53.443 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:08:53.444 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:08:53.444 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:08:53.444 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:08:55.443 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:08:55.443 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:08:55.443 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:08:55.443 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:08:55.443 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:08:55.488 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:08:55.488 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:08:55.488 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:08:55.488 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:08:55.612 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:08:55.612 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:08:55.612 | Historical data download ID 121378 not found when removing ID from outstanding request set.
2024-08-14 17:08:55.612 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:08:55.612 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:08:55.612 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:08:55.612 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:08:55.612 | Historical data download ID 121379 not found when removing ID from outstanding request set.
2024-08-14 17:08:55.612 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:08:55.612 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:08:55.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:08:55.651 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:08:55.651 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:08:55.651 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:08:55.651 | DTC Client socket (4) | Closed.
2024-08-14 17:08:55.651 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:08:55.651 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:08:55.651 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:08:55.651 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:08:57.652 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:08:57.652 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:08:57.653 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:08:57.653 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:08:57.653 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:08:57.691 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:08:57.691 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:08:57.692 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:08:57.692 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:08:57.815 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:08:57.815 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:08:57.815 | Historical data download ID 121380 not found when removing ID from outstanding request set.
2024-08-14 17:08:57.815 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:08:57.815 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:08:57.815 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:08:57.815 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:08:57.815 | Historical data download ID 121381 not found when removing ID from outstanding request set.
2024-08-14 17:08:57.815 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:08:57.815 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:08:57.815 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:08:57.856 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:08:57.857 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:08:57.858 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:08:57.858 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:08:57.858 | DTC Client socket (4) | Closed.
2024-08-14 17:08:57.858 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:08:57.858 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:08:57.858 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:08:57.858 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:08:59.852 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:08:59.852 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:08:59.852 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:08:59.853 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:08:59.853 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:08:59.892 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:08:59.892 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:08:59.892 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:08:59.892 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:00.023 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:00.023 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:00.023 | Historical data download ID 121382 not found when removing ID from outstanding request set.
2024-08-14 17:09:00.023 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:00.023 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:00.023 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:00.023 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:00.023 | Historical data download ID 121383 not found when removing ID from outstanding request set.
2024-08-14 17:09:00.023 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:00.023 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:00.023 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:00.065 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:00.066 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:00.067 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:00.067 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:00.067 | DTC Client socket (4) | Closed.
2024-08-14 17:09:00.067 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:00.067 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:00.067 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:00.067 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:02.075 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:02.075 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:02.076 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:02.076 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:02.076 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:02.114 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:02.114 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:02.115 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:02.115 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:02.236 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:02.236 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:02.236 | Historical data download ID 121384 not found when removing ID from outstanding request set.
2024-08-14 17:09:02.236 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:02.236 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:02.236 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:02.236 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:02.236 | Historical data download ID 121385 not found when removing ID from outstanding request set.
2024-08-14 17:09:02.236 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:02.236 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:02.236 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:02.278 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:02.279 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:02.279 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:02.279 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:02.279 | DTC Client socket (4) | Closed.
2024-08-14 17:09:02.280 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:02.280 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:02.280 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:02.280 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:02.814 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:02.814 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:09:02.826 | HD Server | Thread:10696 (4) | Creating socket.
2024-08-14 17:09:02.826 | HD Server | Thread:10696 (4) | New receive buffer size: 262144
2024-08-14 17:09:02.826 | HD Server | Thread:10696 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:02.826 | HD Server | Setting DTC encoding to Binary VLS | Thread:10696
2024-08-14 17:09:02.826 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10696
2024-08-14 17:09:02.826 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10696
2024-08-14 17:09:02.827 | HD Server | HD Request #4197 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4197 | Username: DAVID SUDDUTH JR. | Thread:10696
2024-08-14 17:09:02.827 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4197 | Username: DAVID SUDDUTH JR. | Thread:10696
2024-08-14 17:09:02.827 | HD Server | Thread:10696 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:02.827 | HD Server | Thread:10696 (4) | CloseSocket call.
2024-08-14 17:09:02.827 | HD Server | Thread:10696 (0) | CloseSocket call.
2024-08-14 17:09:02.828 | HD Server | Thread:10696 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:02.828 | HD Server | Thread:10696 (4) | Closed.
2024-08-14 17:09:02.828 | HD Server | Thread:10696 (0) | CloseSocket call.
2024-08-14 17:09:02.832 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:02.832 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:09:02.842 | HD Server | Thread:12960 (4) | Creating socket.
2024-08-14 17:09:02.842 | HD Server | Thread:12960 (4) | New receive buffer size: 262144
2024-08-14 17:09:02.842 | HD Server | Thread:12960 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:02.843 | HD Server | Setting DTC encoding to Binary VLS | Thread:12960
2024-08-14 17:09:02.843 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12960
2024-08-14 17:09:02.843 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12960
2024-08-14 17:09:02.843 | HD Server | HD Request #4198 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4198 | Username: DAVID SUDDUTH JR. | Thread:12960
2024-08-14 17:09:02.844 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4198 | Username: DAVID SUDDUTH JR. | Thread:12960
2024-08-14 17:09:02.844 | HD Server | Thread:12960 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:02.844 | HD Server | Thread:12960 (4) | CloseSocket call.
2024-08-14 17:09:02.845 | HD Server | Thread:12960 (0) | CloseSocket call.
2024-08-14 17:09:02.845 | HD Server | Thread:12960 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:02.845 | HD Server | Thread:12960 (4) | Closed.
2024-08-14 17:09:03.065 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12960
2024-08-14 17:09:03.065 | HD Server Manager | Current server count=1
2024-08-14 17:09:03.065 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10696
2024-08-14 17:09:03.065 | HD Server Manager | Current server count=0
2024-08-14 17:09:04.278 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:04.278 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:04.278 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:04.279 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:04.279 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:04.317 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:04.317 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:04.317 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:04.317 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:04.445 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:04.445 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:04.445 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:04.445 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:04.445 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:04.445 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:04.445 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:04.446 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:04.446 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:04.446 | Historical data download ID 121386 not found when removing ID from outstanding request set.
2024-08-14 17:09:04.446 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:04.446 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:04.446 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:04.446 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:04.446 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:04.446 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:04.446 | Historical data download ID 121387 not found when removing ID from outstanding request set.
2024-08-14 17:09:04.446 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:04.446 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:04.446 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:04.484 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:04.484 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:04.484 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:04.484 | DTC Client socket (4) | Closed.
2024-08-14 17:09:04.484 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:04.485 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:04.485 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:04.485 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:05.303 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:05.303 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:09:05.317 | HD Server | Thread:4192 (4) | Creating socket.
2024-08-14 17:09:05.317 | HD Server | Thread:4192 (4) | New receive buffer size: 262144
2024-08-14 17:09:05.317 | HD Server | Thread:4192 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:05.317 | HD Server | Setting DTC encoding to Binary VLS | Thread:4192
2024-08-14 17:09:05.318 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:4192
2024-08-14 17:09:05.318 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:4192
2024-08-14 17:09:05.319 | HD Server | HD Request #4199 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4199 | Username: DAVID SUDDUTH JR. | Thread:4192
2024-08-14 17:09:05.319 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4199 | Username: DAVID SUDDUTH JR. | Thread:4192
2024-08-14 17:09:05.320 | HD Server | Thread:4192 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:05.320 | HD Server | Thread:4192 (4) | CloseSocket call.
2024-08-14 17:09:05.320 | HD Server | Thread:4192 (0) | CloseSocket call.
2024-08-14 17:09:05.320 | HD Server | Thread:4192 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:05.320 | HD Server | Thread:4192 (4) | Closed.
2024-08-14 17:09:05.322 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:05.323 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:09:05.331 | HD Server | Thread:14708 (4) | Creating socket.
2024-08-14 17:09:05.331 | HD Server | Thread:14708 (4) | New receive buffer size: 262144
2024-08-14 17:09:05.331 | HD Server | Thread:14708 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:05.332 | HD Server | Setting DTC encoding to Binary VLS | Thread:14708
2024-08-14 17:09:05.332 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:4192
2024-08-14 17:09:05.332 | HD Server Manager | Current server count=1
2024-08-14 17:09:05.332 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:14708
2024-08-14 17:09:05.332 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:14708
2024-08-14 17:09:05.333 | HD Server | HD Request #4200 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4200 | Username: DAVID SUDDUTH JR. | Thread:14708
2024-08-14 17:09:05.333 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4200 | Username: DAVID SUDDUTH JR. | Thread:14708
2024-08-14 17:09:05.334 | HD Server | Thread:14708 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:05.334 | HD Server | Thread:14708 (4) | CloseSocket call.
2024-08-14 17:09:05.334 | HD Server | Thread:14708 (0) | CloseSocket call.
2024-08-14 17:09:05.334 | HD Server | Thread:14708 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:05.334 | HD Server | Thread:14708 (4) | Closed.
2024-08-14 17:09:05.583 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:14708
2024-08-14 17:09:05.583 | HD Server Manager | Current server count=0
2024-08-14 17:09:06.481 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:06.481 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:06.482 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:06.482 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:06.482 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:06.520 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:06.520 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:06.521 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:06.521 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:06.645 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:06.645 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:06.645 | Historical data download ID 121388 not found when removing ID from outstanding request set.
2024-08-14 17:09:06.645 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:06.645 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:06.645 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:06.645 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:06.645 | Historical data download ID 121389 not found when removing ID from outstanding request set.
2024-08-14 17:09:06.645 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:06.645 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:06.645 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:06.687 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:06.688 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:06.688 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:06.688 | DTC Client socket (4) | Closed.
2024-08-14 17:09:06.688 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:06.688 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:06.688 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:06.688 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:08.681 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:08.681 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:08.682 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:08.682 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:08.682 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:08.721 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:08.721 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:08.721 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:08.721 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:08.844 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:08.844 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:08.844 | Historical data download ID 121390 not found when removing ID from outstanding request set.
2024-08-14 17:09:08.844 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:08.844 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:08.844 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:08.844 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:08.844 | Historical data download ID 121391 not found when removing ID from outstanding request set.
2024-08-14 17:09:08.844 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:08.844 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:08.844 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:08.884 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:08.884 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:08.884 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:08.884 | DTC Client socket (4) | Closed.
2024-08-14 17:09:08.884 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:08.884 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:08.884 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:08.884 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:10.881 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:10.881 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:10.881 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:10.881 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:10.881 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:10.919 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:10.919 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:10.919 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:10.919 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:11.046 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:11.046 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:11.046 | Historical data download ID 121392 not found when removing ID from outstanding request set.
2024-08-14 17:09:11.046 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:11.046 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:11.046 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:11.046 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:11.046 | Historical data download ID 121393 not found when removing ID from outstanding request set.
2024-08-14 17:09:11.046 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:11.046 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:11.046 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:11.088 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:11.089 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:11.089 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:11.089 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:11.089 | DTC Client socket (4) | Closed.
2024-08-14 17:09:11.089 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:11.090 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:11.090 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:11.090 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:13.084 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:13.084 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:13.085 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:13.085 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:13.085 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:13.130 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:13.130 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:13.130 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:13.130 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:13.252 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:13.252 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:13.252 | Historical data download ID 121394 not found when removing ID from outstanding request set.
2024-08-14 17:09:13.252 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:13.252 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:13.252 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:13.252 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:13.252 | Historical data download ID 121395 not found when removing ID from outstanding request set.
2024-08-14 17:09:13.252 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:13.252 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:13.252 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:13.292 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:13.295 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:13.295 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:13.295 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:13.295 | DTC Client socket (4) | Closed.
2024-08-14 17:09:13.295 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:13.296 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:13.296 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:13.296 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:15.286 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:15.286 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:15.287 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:15.287 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:15.287 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:15.325 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:15.325 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:15.325 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:15.325 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:15.449 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:15.449 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:15.449 | Historical data download ID 121396 not found when removing ID from outstanding request set.
2024-08-14 17:09:15.449 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:15.449 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:15.449 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:15.449 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:15.449 | Historical data download ID 121397 not found when removing ID from outstanding request set.
2024-08-14 17:09:15.449 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:15.449 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:15.449 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:15.492 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:15.492 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:15.492 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:15.492 | DTC Client socket (4) | Closed.
2024-08-14 17:09:15.492 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:15.493 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:15.493 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:15.493 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:17.500 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:17.500 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:17.501 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:17.501 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:17.501 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:17.543 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:17.543 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:17.543 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:17.543 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:17.664 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:17.664 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:17.664 | Historical data download ID 121398 not found when removing ID from outstanding request set.
2024-08-14 17:09:17.664 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:17.664 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:17.664 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:17.664 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:17.664 | Historical data download ID 121399 not found when removing ID from outstanding request set.
2024-08-14 17:09:17.664 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:17.664 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:17.664 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:17.707 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:17.707 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:17.707 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:17.707 | DTC Client socket (4) | Closed.
2024-08-14 17:09:17.707 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:17.707 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:17.707 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:17.707 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:19.712 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:19.712 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:19.712 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:19.713 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:19.713 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:19.751 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:19.751 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:19.751 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:19.751 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:19.873 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:19.873 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:19.873 | Historical data download ID 121400 not found when removing ID from outstanding request set.
2024-08-14 17:09:19.873 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:19.873 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:19.873 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:19.873 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:19.873 | Historical data download ID 121401 not found when removing ID from outstanding request set.
2024-08-14 17:09:19.873 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:19.873 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:19.873 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:19.913 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:19.913 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:19.913 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:19.913 | DTC Client socket (4) | Closed.
2024-08-14 17:09:19.913 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:19.914 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:19.914 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:19.914 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:21.907 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:21.907 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:21.908 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:21.908 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:21.908 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:21.942 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:21.942 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:21.942 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:21.942 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:22.067 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:22.067 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:22.067 | Historical data download ID 121402 not found when removing ID from outstanding request set.
2024-08-14 17:09:22.067 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:22.067 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:22.067 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:22.067 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:22.067 | Historical data download ID 121403 not found when removing ID from outstanding request set.
2024-08-14 17:09:22.067 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:22.067 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:22.067 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:22.108 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:22.109 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:22.109 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:22.109 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:22.109 | DTC Client socket (4) | Closed.
2024-08-14 17:09:22.109 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:22.109 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:22.109 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:22.109 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:24.097 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:24.097 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:24.098 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:24.098 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:24.098 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:24.136 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:24.136 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:24.136 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:24.136 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:24.262 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:24.262 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:24.262 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:24.262 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:24.262 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:24.262 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:24.262 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:24.263 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:24.263 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:24.263 | Historical data download ID 121404 not found when removing ID from outstanding request set.
2024-08-14 17:09:24.263 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:24.263 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:24.263 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:24.263 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:24.263 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:24.263 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:24.263 | Historical data download ID 121405 not found when removing ID from outstanding request set.
2024-08-14 17:09:24.263 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:24.263 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:24.263 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:24.304 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:24.306 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:24.306 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:24.306 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:24.306 | DTC Client socket (4) | Closed.
2024-08-14 17:09:24.306 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:24.306 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:24.306 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:24.306 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:26.308 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:26.308 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:26.308 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:26.309 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:26.309 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:26.347 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:26.347 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:26.347 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:26.347 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:26.470 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:26.470 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:26.470 | Historical data download ID 121406 not found when removing ID from outstanding request set.
2024-08-14 17:09:26.470 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:26.470 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:26.470 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:26.470 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:26.470 | Historical data download ID 121407 not found when removing ID from outstanding request set.
2024-08-14 17:09:26.470 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:26.470 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:26.470 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:26.511 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:26.512 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:26.512 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:26.512 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:26.512 | DTC Client socket (4) | Closed.
2024-08-14 17:09:26.512 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:26.513 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:26.513 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:26.513 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:28.513 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:28.513 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:28.513 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:28.513 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:28.513 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:28.556 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:28.556 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:28.556 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:28.556 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:28.676 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:28.676 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:28.676 | Historical data download ID 121408 not found when removing ID from outstanding request set.
2024-08-14 17:09:28.676 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:28.676 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:28.676 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:28.676 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:28.676 | Historical data download ID 121409 not found when removing ID from outstanding request set.
2024-08-14 17:09:28.676 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:28.676 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:28.676 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:28.717 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:28.717 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:28.717 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:28.718 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:28.718 | DTC Client socket (4) | Closed.
2024-08-14 17:09:28.718 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:28.718 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:28.718 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:28.718 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:30.706 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:30.706 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:30.707 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:30.707 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:30.707 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:30.749 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:30.749 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:30.749 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:30.749 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:30.868 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:30.868 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:30.868 | Historical data download ID 121410 not found when removing ID from outstanding request set.
2024-08-14 17:09:30.868 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:30.868 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:30.868 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:30.868 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:30.868 | Historical data download ID 121411 not found when removing ID from outstanding request set.
2024-08-14 17:09:30.868 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:30.868 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:30.868 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:30.910 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:30.910 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:30.910 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:09:30.910 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:09:30.910 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=96
2024-08-14 17:09:30.910 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:30.911 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:30.911 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:30.911 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:30.949 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:09:30.949 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:30.949 | DTC Client socket (4) | Closed.
2024-08-14 17:09:32.915 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:32.915 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:32.915 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:32.916 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:32.916 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:32.953 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:32.953 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:32.953 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:32.953 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:33.075 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:33.075 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:33.075 | Historical data download ID 121412 not found when removing ID from outstanding request set.
2024-08-14 17:09:33.075 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:33.075 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:33.075 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:33.075 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:33.075 | Historical data download ID 121413 not found when removing ID from outstanding request set.
2024-08-14 17:09:33.075 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:33.075 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:33.075 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:33.118 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:33.119 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:33.119 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:33.119 | DTC Client socket (4) | Closed.
2024-08-14 17:09:33.119 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:33.119 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:33.119 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:33.119 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:33.828 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:33.829 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:09:33.842 | HD Server | Thread:6320 (4) | Creating socket.
2024-08-14 17:09:33.842 | HD Server | Thread:6320 (4) | New receive buffer size: 262144
2024-08-14 17:09:33.842 | HD Server | Thread:6320 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:33.842 | HD Server | Setting DTC encoding to Binary VLS | Thread:6320
2024-08-14 17:09:33.844 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:6320
2024-08-14 17:09:33.844 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:6320
2024-08-14 17:09:33.844 | HD Server | HD Request #4201 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4201 | Username: DAVID SUDDUTH JR. | Thread:6320
2024-08-14 17:09:33.845 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4201 | Username: DAVID SUDDUTH JR. | Thread:6320
2024-08-14 17:09:33.845 | HD Server | Thread:6320 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:33.845 | HD Server | Thread:6320 (4) | CloseSocket call.
2024-08-14 17:09:33.845 | HD Server | Thread:6320 (0) | CloseSocket call.
2024-08-14 17:09:33.845 | HD Server | Thread:6320 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:33.845 | HD Server | Thread:6320 (4) | Closed.
2024-08-14 17:09:33.847 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:33.848 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:09:33.861 | HD Server | Thread:19644 (4) | Creating socket.
2024-08-14 17:09:33.861 | HD Server | Thread:19644 (4) | New receive buffer size: 262144
2024-08-14 17:09:33.861 | HD Server | Thread:19644 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:33.861 | HD Server | Setting DTC encoding to Binary VLS | Thread:19644
2024-08-14 17:09:33.862 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19644
2024-08-14 17:09:33.862 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19644
2024-08-14 17:09:33.862 | HD Server | HD Request #4202 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4202 | Username: DAVID SUDDUTH JR. | Thread:19644
2024-08-14 17:09:33.863 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4202 | Username: DAVID SUDDUTH JR. | Thread:19644
2024-08-14 17:09:33.863 | HD Server | Thread:19644 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:33.863 | HD Server | Thread:19644 (4) | CloseSocket call.
2024-08-14 17:09:33.863 | HD Server | Thread:19644 (0) | CloseSocket call.
2024-08-14 17:09:33.863 | HD Server | Thread:19644 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:33.863 | HD Server | Thread:19644 (4) | Closed.
2024-08-14 17:09:34.094 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19644
2024-08-14 17:09:34.094 | HD Server Manager | Current server count=1
2024-08-14 17:09:34.094 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:6320
2024-08-14 17:09:34.094 | HD Server Manager | Current server count=0
2024-08-14 17:09:35.117 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:35.117 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:35.118 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:35.118 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:35.118 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:35.157 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:35.157 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:35.157 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:35.157 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:35.280 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:35.280 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:35.280 | Historical data download ID 121414 not found when removing ID from outstanding request set.
2024-08-14 17:09:35.280 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:35.280 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:35.280 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:35.280 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:35.280 | Historical data download ID 121415 not found when removing ID from outstanding request set.
2024-08-14 17:09:35.280 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:35.280 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:35.280 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:35.319 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:35.319 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:35.319 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:35.319 | DTC Client socket (4) | Closed.
2024-08-14 17:09:35.319 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:35.319 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:35.319 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:35.319 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:36.354 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:36.355 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:09:36.366 | HD Server | Thread:4232 (4) | Creating socket.
2024-08-14 17:09:36.366 | HD Server | Thread:4232 (4) | New receive buffer size: 262144
2024-08-14 17:09:36.366 | HD Server | Thread:4232 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:36.367 | HD Server | Setting DTC encoding to Binary VLS | Thread:4232
2024-08-14 17:09:36.367 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:4232
2024-08-14 17:09:36.367 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:4232
2024-08-14 17:09:36.368 | HD Server | HD Request #4203 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4203 | Username: DAVID SUDDUTH JR. | Thread:4232
2024-08-14 17:09:36.368 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4203 | Username: DAVID SUDDUTH JR. | Thread:4232
2024-08-14 17:09:36.368 | HD Server | Thread:4232 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:36.368 | HD Server | Thread:4232 (4) | CloseSocket call.
2024-08-14 17:09:36.369 | HD Server | Thread:4232 (0) | CloseSocket call.
2024-08-14 17:09:36.369 | HD Server | Thread:4232 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:36.369 | HD Server | Thread:4232 (4) | Closed.
2024-08-14 17:09:36.371 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:09:36.371 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:09:36.376 | HD Server | Thread:12828 (4) | Creating socket.
2024-08-14 17:09:36.376 | HD Server | Thread:12828 (4) | New receive buffer size: 262144
2024-08-14 17:09:36.376 | HD Server | Thread:12828 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:09:36.376 | HD Server | Setting DTC encoding to Binary VLS | Thread:12828
2024-08-14 17:09:36.377 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12828
2024-08-14 17:09:36.377 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12828
2024-08-14 17:09:36.377 | HD Server | HD Request #4204 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4204 | Username: DAVID SUDDUTH JR. | Thread:12828
2024-08-14 17:09:36.378 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4204 | Username: DAVID SUDDUTH JR. | Thread:12828
2024-08-14 17:09:36.378 | HD Server | Thread:12828 (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:36.378 | HD Server | Thread:12828 (4) | CloseSocket call.
2024-08-14 17:09:36.378 | HD Server | Thread:12828 (0) | CloseSocket call.
2024-08-14 17:09:36.379 | HD Server | Thread:12828 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:36.379 | HD Server | Thread:12828 (4) | Closed.
2024-08-14 17:09:36.379 | HD Server | Thread:12828 (0) | CloseSocket call.
2024-08-14 17:09:36.600 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12828
2024-08-14 17:09:36.601 | HD Server Manager | Current server count=1
2024-08-14 17:09:36.601 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:4232
2024-08-14 17:09:36.601 | HD Server Manager | Current server count=0
2024-08-14 17:09:37.327 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:37.327 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:37.328 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:37.328 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:37.328 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:37.367 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:37.367 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:37.367 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:37.367 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:37.487 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:37.487 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:37.487 | Historical data download ID 121416 not found when removing ID from outstanding request set.
2024-08-14 17:09:37.487 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:37.487 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:37.487 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:37.487 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:37.487 | Historical data download ID 121417 not found when removing ID from outstanding request set.
2024-08-14 17:09:37.487 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:37.487 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:37.487 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:37.528 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:37.530 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:37.530 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:37.530 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:37.530 | DTC Client socket (4) | Closed.
2024-08-14 17:09:37.530 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:37.530 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:37.530 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:37.531 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:39.523 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:39.523 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:39.524 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:39.524 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:39.524 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:39.559 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:39.559 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:39.559 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:39.559 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:39.700 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:39.700 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:39.700 | Historical data download ID 121418 not found when removing ID from outstanding request set.
2024-08-14 17:09:39.700 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:39.700 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:39.700 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:39.700 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:39.700 | Historical data download ID 121419 not found when removing ID from outstanding request set.
2024-08-14 17:09:39.700 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:39.700 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:39.700 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:39.741 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:39.741 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:39.741 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:39.741 | DTC Client socket (4) | Closed.
2024-08-14 17:09:39.741 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:39.742 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:39.742 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:39.742 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:41.736 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:41.736 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:41.737 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:41.737 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:41.737 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:41.775 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:41.775 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:41.775 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:41.775 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:41.901 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:41.901 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:41.901 | Historical data download ID 121420 not found when removing ID from outstanding request set.
2024-08-14 17:09:41.901 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:41.901 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:41.901 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:41.901 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:41.901 | Historical data download ID 121421 not found when removing ID from outstanding request set.
2024-08-14 17:09:41.901 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:41.901 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:41.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:41.942 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:41.943 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:41.943 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:41.943 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:41.943 | DTC Client socket (4) | Closed.
2024-08-14 17:09:41.943 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:41.943 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:41.944 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:41.944 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:43.953 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:43.953 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:43.954 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:43.954 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:43.954 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:43.992 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:43.992 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:43.992 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:43.992 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:44.116 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:44.116 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:44.116 | Historical data download ID 121422 not found when removing ID from outstanding request set.
2024-08-14 17:09:44.116 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:44.116 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:44.116 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:44.116 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:44.116 | Historical data download ID 121423 not found when removing ID from outstanding request set.
2024-08-14 17:09:44.116 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:44.116 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:44.116 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:44.157 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:44.158 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:44.158 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:44.159 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:44.159 | DTC Client socket (4) | Closed.
2024-08-14 17:09:44.159 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:44.159 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:44.159 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:44.159 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:46.173 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:46.173 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:46.173 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:46.173 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:46.173 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:46.211 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:46.211 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:46.211 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:46.211 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:46.334 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:46.334 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:46.334 | Historical data download ID 121424 not found when removing ID from outstanding request set.
2024-08-14 17:09:46.334 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:46.334 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:46.334 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:46.334 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:46.334 | Historical data download ID 121425 not found when removing ID from outstanding request set.
2024-08-14 17:09:46.334 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:46.334 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:46.334 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:46.376 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:46.377 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:46.378 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:46.378 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:46.378 | DTC Client socket (4) | Closed.
2024-08-14 17:09:46.378 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:46.378 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:46.378 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:46.378 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:48.379 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:48.379 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:48.380 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:48.380 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:48.380 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:48.418 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:48.418 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:48.419 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:48.419 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:48.544 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:48.544 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:48.544 | Historical data download ID 121426 not found when removing ID from outstanding request set.
2024-08-14 17:09:48.544 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:48.544 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:48.544 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:48.544 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:48.544 | Historical data download ID 121427 not found when removing ID from outstanding request set.
2024-08-14 17:09:48.544 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:48.544 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:48.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:48.587 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:48.587 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:48.587 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:48.587 | DTC Client socket (4) | Closed.
2024-08-14 17:09:48.587 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:48.587 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:48.587 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:48.587 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:50.579 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:50.579 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:50.580 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:50.580 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:50.580 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:50.620 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:50.620 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:50.620 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:50.620 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:50.743 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:50.743 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:50.743 | Historical data download ID 121428 not found when removing ID from outstanding request set.
2024-08-14 17:09:50.743 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:50.743 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:50.743 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:50.743 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:50.743 | Historical data download ID 121429 not found when removing ID from outstanding request set.
2024-08-14 17:09:50.743 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:50.743 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:50.743 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:50.786 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:50.786 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:50.786 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:50.786 | DTC Client socket (4) | Closed.
2024-08-14 17:09:50.786 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:50.787 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:50.787 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:50.787 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:52.794 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:52.794 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:52.795 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:52.795 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:52.795 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:52.832 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:52.832 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:52.832 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:52.832 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:52.957 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:52.957 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:52.957 | Historical data download ID 121430 not found when removing ID from outstanding request set.
2024-08-14 17:09:52.957 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:52.957 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:52.957 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:52.957 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:52.957 | Historical data download ID 121431 not found when removing ID from outstanding request set.
2024-08-14 17:09:52.957 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:52.957 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:52.957 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:52.997 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:52.998 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:52.998 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:52.998 | DTC Client socket (4) | Closed.
2024-08-14 17:09:52.998 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:52.998 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:52.998 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:52.998 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:54.995 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:54.995 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:54.995 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:54.995 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:54.995 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:55.038 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:55.038 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:55.038 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:55.038 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:55.165 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:55.165 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:55.165 | Historical data download ID 121432 not found when removing ID from outstanding request set.
2024-08-14 17:09:55.165 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:55.165 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:55.165 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:55.165 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:55.165 | Historical data download ID 121433 not found when removing ID from outstanding request set.
2024-08-14 17:09:55.165 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:55.165 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:55.165 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:55.208 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:55.208 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:55.208 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:09:55.208 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:09:55.208 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:55.208 | DTC Client socket (4) | Closed.
2024-08-14 17:09:55.208 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:55.209 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:55.209 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:55.209 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:57.210 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:57.210 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:57.211 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:57.211 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:57.211 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:57.250 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:57.250 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:57.250 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:57.250 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:57.372 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:57.372 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:57.372 | Historical data download ID 121434 not found when removing ID from outstanding request set.
2024-08-14 17:09:57.372 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:57.372 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:57.372 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:57.372 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:57.372 | Historical data download ID 121435 not found when removing ID from outstanding request set.
2024-08-14 17:09:57.372 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:57.372 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:57.372 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:57.413 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:57.414 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:57.414 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:57.414 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:57.414 | DTC Client socket (4) | Closed.
2024-08-14 17:09:57.414 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:57.415 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:57.415 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:57.415 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:09:59.418 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:09:59.418 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:09:59.419 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:09:59.419 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:09:59.419 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:09:59.457 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:09:59.457 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:09:59.457 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:09:59.457 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:09:59.586 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:09:59.586 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:09:59.586 | Historical data download ID 121436 not found when removing ID from outstanding request set.
2024-08-14 17:09:59.586 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:09:59.586 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:09:59.586 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:09:59.586 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:09:59.586 | Historical data download ID 121437 not found when removing ID from outstanding request set.
2024-08-14 17:09:59.586 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:09:59.586 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:09:59.586 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:09:59.626 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:09:59.629 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:09:59.629 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:09:59.629 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:09:59.629 | DTC Client socket (4) | Closed.
2024-08-14 17:09:59.630 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:09:59.630 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:09:59.630 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:09:59.630 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:01.628 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:01.628 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:01.628 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:01.629 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:01.629 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:01.667 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:01.667 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:01.667 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:01.667 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:01.790 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:01.790 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:01.790 | Historical data download ID 121438 not found when removing ID from outstanding request set.
2024-08-14 17:10:01.790 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:01.790 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:01.790 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:01.790 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:01.790 | Historical data download ID 121439 not found when removing ID from outstanding request set.
2024-08-14 17:10:01.790 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:01.790 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:01.790 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:01.828 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:01.828 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:01.828 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:01.828 | DTC Client socket (4) | Closed.
2024-08-14 17:10:01.828 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:01.828 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:01.828 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:01.828 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:03.819 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:03.819 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:03.819 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:03.820 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:03.820 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:03.857 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:03.857 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:03.857 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:03.857 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:03.980 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:03.980 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:03.980 | Historical data download ID 121440 not found when removing ID from outstanding request set.
2024-08-14 17:10:03.980 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:03.980 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:03.980 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:03.980 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:03.980 | Historical data download ID 121441 not found when removing ID from outstanding request set.
2024-08-14 17:10:03.980 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:03.980 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:03.980 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:04.023 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:04.023 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:04.024 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:04.024 | DTC Client socket (4) | Closed.
2024-08-14 17:10:04.024 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:04.024 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:04.024 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:04.024 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:05.125 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:05.125 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:10:05.138 | HD Server | Thread:12392 (4) | Creating socket.
2024-08-14 17:10:05.138 | HD Server | Thread:12392 (4) | New receive buffer size: 262144
2024-08-14 17:10:05.138 | HD Server | Thread:12392 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:05.138 | HD Server | Setting DTC encoding to Binary VLS | Thread:12392
2024-08-14 17:10:05.139 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12392
2024-08-14 17:10:05.139 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12392
2024-08-14 17:10:05.139 | HD Server | HD Request #4205 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4205 | Username: DAVID SUDDUTH JR. | Thread:12392
2024-08-14 17:10:05.140 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4205 | Username: DAVID SUDDUTH JR. | Thread:12392
2024-08-14 17:10:05.140 | HD Server | Thread:12392 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:05.141 | HD Server | Thread:12392 (4) | CloseSocket call.
2024-08-14 17:10:05.141 | HD Server | Thread:12392 (0) | CloseSocket call.
2024-08-14 17:10:05.141 | HD Server | Thread:12392 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:05.141 | HD Server | Thread:12392 (4) | Closed.
2024-08-14 17:10:05.147 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:05.147 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:10:05.160 | HD Server | Thread:1608 (4) | Creating socket.
2024-08-14 17:10:05.160 | HD Server | Thread:1608 (4) | New receive buffer size: 262144
2024-08-14 17:10:05.160 | HD Server | Thread:1608 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:05.160 | HD Server | Setting DTC encoding to Binary VLS | Thread:1608
2024-08-14 17:10:05.161 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:1608
2024-08-14 17:10:05.161 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:1608
2024-08-14 17:10:05.161 | HD Server | HD Request #4206 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4206 | Username: DAVID SUDDUTH JR. | Thread:1608
2024-08-14 17:10:05.162 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4206 | Username: DAVID SUDDUTH JR. | Thread:1608
2024-08-14 17:10:05.163 | HD Server | Thread:1608 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:05.163 | HD Server | Thread:1608 (4) | CloseSocket call.
2024-08-14 17:10:05.163 | HD Server | Thread:1608 (0) | CloseSocket call.
2024-08-14 17:10:05.163 | HD Server | Thread:1608 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:05.163 | HD Server | Thread:1608 (4) | Closed.
2024-08-14 17:10:05.376 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:1608
2024-08-14 17:10:05.376 | HD Server Manager | Current server count=1
2024-08-14 17:10:05.376 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12392
2024-08-14 17:10:05.377 | HD Server Manager | Current server count=0
2024-08-14 17:10:06.022 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:06.022 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:06.022 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:06.022 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:06.022 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:06.057 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:06.057 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:06.057 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:06.057 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:06.177 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:06.177 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:06.177 | Historical data download ID 121442 not found when removing ID from outstanding request set.
2024-08-14 17:10:06.177 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:06.177 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:06.177 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:06.178 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:06.178 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:06.178 | Historical data download ID 121443 not found when removing ID from outstanding request set.
2024-08-14 17:10:06.178 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:06.178 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:06.178 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:06.218 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:06.219 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:06.219 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:06.219 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:06.219 | DTC Client socket (4) | Closed.
2024-08-14 17:10:06.219 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:06.220 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:06.220 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:06.220 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:07.708 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:07.708 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:10:07.719 | HD Server | Thread:17896 (4) | Creating socket.
2024-08-14 17:10:07.719 | HD Server | Thread:17896 (4) | New receive buffer size: 262144
2024-08-14 17:10:07.719 | HD Server | Thread:17896 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:07.719 | HD Server | Setting DTC encoding to Binary VLS | Thread:17896
2024-08-14 17:10:07.719 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:17896
2024-08-14 17:10:07.719 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:17896
2024-08-14 17:10:07.720 | HD Server | HD Request #4207 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4207 | Username: DAVID SUDDUTH JR. | Thread:17896
2024-08-14 17:10:07.720 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4207 | Username: DAVID SUDDUTH JR. | Thread:17896
2024-08-14 17:10:07.721 | HD Server | Thread:17896 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:07.721 | HD Server | Thread:17896 (4) | CloseSocket call.
2024-08-14 17:10:07.721 | HD Server | Thread:17896 (0) | CloseSocket call.
2024-08-14 17:10:07.721 | HD Server | Thread:17896 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:07.721 | HD Server | Thread:17896 (4) | Closed.
2024-08-14 17:10:07.723 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:07.723 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:10:07.728 | HD Server | Thread:9460 (4) | Creating socket.
2024-08-14 17:10:07.728 | HD Server | Thread:9460 (4) | New receive buffer size: 262144
2024-08-14 17:10:07.728 | HD Server | Thread:9460 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:07.728 | HD Server | Setting DTC encoding to Binary VLS | Thread:9460
2024-08-14 17:10:07.728 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:9460
2024-08-14 17:10:07.728 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:9460
2024-08-14 17:10:07.729 | HD Server | HD Request #4208 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4208 | Username: DAVID SUDDUTH JR. | Thread:9460
2024-08-14 17:10:07.729 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4208 | Username: DAVID SUDDUTH JR. | Thread:9460
2024-08-14 17:10:07.729 | HD Server | Thread:9460 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:07.729 | HD Server | Thread:9460 (4) | CloseSocket call.
2024-08-14 17:10:07.729 | HD Server | Thread:9460 (0) | CloseSocket call.
2024-08-14 17:10:07.730 | HD Server | Thread:9460 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:07.730 | HD Server | Thread:9460 (4) | Closed.
2024-08-14 17:10:07.730 | HD Server | Thread:9460 (0) | CloseSocket call.
2024-08-14 17:10:07.878 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:9460
2024-08-14 17:10:07.879 | HD Server Manager | Current server count=1
2024-08-14 17:10:07.879 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:17896
2024-08-14 17:10:07.879 | HD Server Manager | Current server count=0
2024-08-14 17:10:08.209 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:08.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:08.210 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:08.210 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:08.210 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:08.248 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:08.248 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:08.248 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:08.248 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:08.367 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:08.367 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:08.367 | Historical data download ID 121444 not found when removing ID from outstanding request set.
2024-08-14 17:10:08.367 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:08.367 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:08.367 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:08.367 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:08.367 | Historical data download ID 121445 not found when removing ID from outstanding request set.
2024-08-14 17:10:08.367 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:08.367 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:08.367 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:08.408 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:08.408 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:08.408 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:08.408 | DTC Client socket (4) | Closed.
2024-08-14 17:10:08.408 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:08.408 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:08.408 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:08.409 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:10.412 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:10.412 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:10.412 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:10.413 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:10.413 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:10.460 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:10.460 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:10.460 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:10.460 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:10.586 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:10.586 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:10.587 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:10.587 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:10.587 | Historical data download ID 121446 not found when removing ID from outstanding request set.
2024-08-14 17:10:10.587 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:10.587 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:10.587 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:10.587 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:10.587 | Historical data download ID 121447 not found when removing ID from outstanding request set.
2024-08-14 17:10:10.587 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:10.587 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:10.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:10.626 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:10.626 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:10.626 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:10:10.626 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:10:10.626 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:10:10.626 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:10.626 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:10.626 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:10.626 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:10.664 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:10:10.664 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:10.664 | DTC Client socket (4) | Closed.
2024-08-14 17:10:12.635 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:12.635 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:12.635 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:12.636 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:12.636 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:12.674 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:12.674 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:12.674 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:12.674 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:12.797 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:12.797 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:12.797 | Historical data download ID 121448 not found when removing ID from outstanding request set.
2024-08-14 17:10:12.797 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:12.797 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:12.797 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:12.797 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:12.797 | Historical data download ID 121449 not found when removing ID from outstanding request set.
2024-08-14 17:10:12.797 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:12.797 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:12.797 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:12.837 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:12.839 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:12.839 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:12.839 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:12.839 | DTC Client socket (4) | Closed.
2024-08-14 17:10:12.840 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:12.840 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:12.840 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:12.840 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:14.838 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:14.838 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:14.838 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:14.838 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:14.838 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:14.879 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:14.879 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:14.879 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:14.879 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:15.004 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:15.004 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:15.004 | Historical data download ID 121450 not found when removing ID from outstanding request set.
2024-08-14 17:10:15.004 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:15.004 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:15.004 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:15.004 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:15.004 | Historical data download ID 121451 not found when removing ID from outstanding request set.
2024-08-14 17:10:15.004 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:15.004 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:15.004 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:15.046 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:15.046 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:15.046 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:15.046 | DTC Client socket (4) | Closed.
2024-08-14 17:10:15.046 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:15.047 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:15.047 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:15.047 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:17.037 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:17.037 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:17.038 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:17.038 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:17.038 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:17.080 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:17.080 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:17.080 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:17.080 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:17.203 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:17.203 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:17.203 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:17.203 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:17.204 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:17.204 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:17.204 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:17.204 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:17.204 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:17.204 | Historical data download ID 121452 not found when removing ID from outstanding request set.
2024-08-14 17:10:17.204 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:17.204 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:17.204 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:17.204 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:17.204 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:17.204 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:17.204 | Historical data download ID 121453 not found when removing ID from outstanding request set.
2024-08-14 17:10:17.204 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:17.204 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:17.204 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:17.245 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:17.245 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:17.245 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:17.245 | DTC Client socket (4) | Closed.
2024-08-14 17:10:17.246 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:17.246 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:17.246 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:17.246 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:19.246 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:19.246 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:19.246 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:19.247 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:19.247 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:19.290 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:19.290 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:19.290 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:19.290 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:19.418 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:19.418 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:19.418 | Historical data download ID 121454 not found when removing ID from outstanding request set.
2024-08-14 17:10:19.418 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:19.418 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:19.418 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:19.418 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:19.418 | Historical data download ID 121455 not found when removing ID from outstanding request set.
2024-08-14 17:10:19.418 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:19.418 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:19.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:19.457 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:19.457 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:19.457 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:19.457 | DTC Client socket (4) | Closed.
2024-08-14 17:10:19.457 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:19.458 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:19.458 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:19.458 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:21.468 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:21.468 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:21.468 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:21.469 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:21.469 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:21.507 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:21.507 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:21.508 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:21.508 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:21.635 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:21.635 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:21.635 | Historical data download ID 121456 not found when removing ID from outstanding request set.
2024-08-14 17:10:21.635 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:21.635 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:21.635 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:21.635 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:21.635 | Historical data download ID 121457 not found when removing ID from outstanding request set.
2024-08-14 17:10:21.635 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:21.635 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:21.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:21.679 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:21.680 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:21.680 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:21.680 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:21.680 | DTC Client socket (4) | Closed.
2024-08-14 17:10:21.680 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:21.681 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:21.681 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:21.681 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:23.677 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:23.677 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:23.678 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:23.678 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:23.678 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:23.718 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:23.718 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:23.719 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:23.719 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:23.849 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:23.849 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:23.849 | Historical data download ID 121458 not found when removing ID from outstanding request set.
2024-08-14 17:10:23.849 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:23.849 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:23.849 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:23.849 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:23.849 | Historical data download ID 121459 not found when removing ID from outstanding request set.
2024-08-14 17:10:23.849 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:23.849 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:23.849 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:23.889 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:23.889 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:23.889 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:23.889 | DTC Client socket (4) | Closed.
2024-08-14 17:10:23.889 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:23.890 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:23.890 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:23.890 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:25.881 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:25.881 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:25.882 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:25.882 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:25.882 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:25.923 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:25.923 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:25.923 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:25.923 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:26.045 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:26.046 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:26.046 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:26.046 | Historical data download ID 121460 not found when removing ID from outstanding request set.
2024-08-14 17:10:26.046 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:26.046 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:26.046 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:26.046 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:26.046 | Historical data download ID 121461 not found when removing ID from outstanding request set.
2024-08-14 17:10:26.046 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:26.046 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:26.046 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:26.086 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:26.088 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:26.088 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:26.088 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:26.088 | DTC Client socket (4) | Closed.
2024-08-14 17:10:26.088 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:26.088 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:26.088 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:26.089 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:28.090 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:28.090 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:28.091 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:28.091 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:28.091 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:28.131 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:28.131 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:28.131 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:28.131 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:28.261 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:28.261 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:28.261 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:28.261 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:28.261 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:28.261 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:28.261 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:28.262 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:28.262 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:28.262 | Historical data download ID 121462 not found when removing ID from outstanding request set.
2024-08-14 17:10:28.262 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:28.262 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:28.262 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:28.262 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:28.262 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:28.262 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:28.262 | Historical data download ID 121463 not found when removing ID from outstanding request set.
2024-08-14 17:10:28.262 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:28.262 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:28.262 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:28.304 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:28.304 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:28.304 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:28.305 | DTC Client socket (4) | Closed.
2024-08-14 17:10:28.305 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:28.305 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:28.305 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:28.305 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:30.303 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:30.303 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:30.304 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:30.304 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:30.304 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:30.346 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:30.346 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:30.347 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:30.347 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:30.479 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:30.479 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:30.479 | Historical data download ID 121464 not found when removing ID from outstanding request set.
2024-08-14 17:10:30.479 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:30.479 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:30.479 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:30.479 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:30.479 | Historical data download ID 121465 not found when removing ID from outstanding request set.
2024-08-14 17:10:30.479 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:30.479 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:30.479 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:30.523 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:30.523 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:30.523 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:30.523 | DTC Client socket (4) | Closed.
2024-08-14 17:10:30.523 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:30.523 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:30.523 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:30.523 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:32.532 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:32.532 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:32.533 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:32.533 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:32.533 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:32.571 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:32.571 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:32.571 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:32.571 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:32.691 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:32.691 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:32.691 | Historical data download ID 121466 not found when removing ID from outstanding request set.
2024-08-14 17:10:32.691 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:32.691 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:32.691 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:32.691 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:32.691 | Historical data download ID 121467 not found when removing ID from outstanding request set.
2024-08-14 17:10:32.691 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:32.691 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:32.691 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:32.730 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:32.730 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:32.730 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:32.730 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:32.730 | DTC Client socket (4) | Closed.
2024-08-14 17:10:32.730 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:32.730 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:32.730 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:34.730 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:34.730 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:34.731 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:34.731 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:34.731 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:34.773 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:34.773 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:34.773 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:34.773 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:34.899 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:34.899 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:34.899 | Historical data download ID 121468 not found when removing ID from outstanding request set.
2024-08-14 17:10:34.899 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:34.899 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:34.899 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:34.900 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:34.900 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:34.900 | Historical data download ID 121469 not found when removing ID from outstanding request set.
2024-08-14 17:10:34.900 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:34.900 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:34.900 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:34.943 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:34.943 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:34.943 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:34.943 | DTC Client socket (4) | Closed.
2024-08-14 17:10:34.943 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:34.944 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:34.944 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:34.944 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:36.456 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:36.457 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:10:36.467 | HD Server | Thread:12816 (4) | Creating socket.
2024-08-14 17:10:36.467 | HD Server | Thread:12816 (4) | New receive buffer size: 262144
2024-08-14 17:10:36.467 | HD Server | Thread:12816 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:36.467 | HD Server | Setting DTC encoding to Binary VLS | Thread:12816
2024-08-14 17:10:36.468 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12816
2024-08-14 17:10:36.468 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12816
2024-08-14 17:10:36.468 | HD Server | HD Request #4209 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4209 | Username: DAVID SUDDUTH JR. | Thread:12816
2024-08-14 17:10:36.469 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4209 | Username: DAVID SUDDUTH JR. | Thread:12816
2024-08-14 17:10:36.469 | HD Server | Thread:12816 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:36.469 | HD Server | Thread:12816 (4) | CloseSocket call.
2024-08-14 17:10:36.469 | HD Server | Thread:12816 (0) | CloseSocket call.
2024-08-14 17:10:36.470 | HD Server | Thread:12816 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:36.470 | HD Server | Thread:12816 (4) | Closed.
2024-08-14 17:10:36.470 | HD Server | Thread:12816 (0) | CloseSocket call.
2024-08-14 17:10:36.471 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:36.472 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:10:36.482 | HD Server | Thread:16260 (4) | Creating socket.
2024-08-14 17:10:36.483 | HD Server | Thread:16260 (4) | New receive buffer size: 262144
2024-08-14 17:10:36.483 | HD Server | Thread:16260 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:36.483 | HD Server | Setting DTC encoding to Binary VLS | Thread:16260
2024-08-14 17:10:36.483 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:16260
2024-08-14 17:10:36.483 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:16260
2024-08-14 17:10:36.483 | HD Server | HD Request #4210 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4210 | Username: DAVID SUDDUTH JR. | Thread:16260
2024-08-14 17:10:36.484 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4210 | Username: DAVID SUDDUTH JR. | Thread:16260
2024-08-14 17:10:36.484 | HD Server | Thread:16260 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:36.485 | HD Server | Thread:16260 (4) | CloseSocket call.
2024-08-14 17:10:36.485 | HD Server | Thread:16260 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:36.485 | HD Server | Thread:16260 (4) | Closed.
2024-08-14 17:10:36.485 | HD Server | Thread:16260 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:10:36.691 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:16260
2024-08-14 17:10:36.691 | HD Server Manager | Current server count=1
2024-08-14 17:10:36.691 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12816
2024-08-14 17:10:36.691 | HD Server Manager | Current server count=0
2024-08-14 17:10:36.942 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:36.942 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:36.942 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:36.942 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:36.942 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:36.981 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:36.981 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:36.981 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:36.981 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:37.103 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:37.103 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:37.103 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:37.103 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:37.103 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:37.103 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:37.103 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:37.103 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:37.103 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:37.103 | Historical data download ID 121470 not found when removing ID from outstanding request set.
2024-08-14 17:10:37.104 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:37.104 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:37.104 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:37.104 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:37.104 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:37.104 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:37.104 | Historical data download ID 121471 not found when removing ID from outstanding request set.
2024-08-14 17:10:37.104 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:37.104 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:37.104 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:37.144 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:37.147 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:37.147 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:37.147 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:37.147 | DTC Client socket (4) | Closed.
2024-08-14 17:10:37.147 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:37.148 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:37.148 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:37.148 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:39.020 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:39.021 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:10:39.034 | HD Server | Thread:15944 (4) | Creating socket.
2024-08-14 17:10:39.034 | HD Server | Thread:15944 (4) | New receive buffer size: 262144
2024-08-14 17:10:39.034 | HD Server | Thread:15944 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:39.034 | HD Server | Setting DTC encoding to Binary VLS | Thread:15944
2024-08-14 17:10:39.035 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15944
2024-08-14 17:10:39.035 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15944
2024-08-14 17:10:39.035 | HD Server | HD Request #4211 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4211 | Username: DAVID SUDDUTH JR. | Thread:15944
2024-08-14 17:10:39.036 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4211 | Username: DAVID SUDDUTH JR. | Thread:15944
2024-08-14 17:10:39.036 | HD Server | Thread:15944 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:39.036 | HD Server | Thread:15944 (4) | CloseSocket call.
2024-08-14 17:10:39.037 | HD Server | Thread:15944 (0) | CloseSocket call.
2024-08-14 17:10:39.037 | HD Server | Thread:15944 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:39.037 | HD Server | Thread:15944 (4) | Closed.
2024-08-14 17:10:39.044 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:10:39.045 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:10:39.058 | HD Server | Thread:11272 (4) | Creating socket.
2024-08-14 17:10:39.058 | HD Server | Thread:11272 (4) | New receive buffer size: 262144
2024-08-14 17:10:39.058 | HD Server | Thread:11272 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:10:39.058 | HD Server | Setting DTC encoding to Binary VLS | Thread:11272
2024-08-14 17:10:39.059 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11272
2024-08-14 17:10:39.059 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11272
2024-08-14 17:10:39.059 | HD Server | HD Request #4212 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4212 | Username: DAVID SUDDUTH JR. | Thread:11272
2024-08-14 17:10:39.060 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4212 | Username: DAVID SUDDUTH JR. | Thread:11272
2024-08-14 17:10:39.060 | HD Server | Thread:11272 (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:39.060 | HD Server | Thread:11272 (4) | CloseSocket call.
2024-08-14 17:10:39.061 | HD Server | Thread:11272 (0) | CloseSocket call.
2024-08-14 17:10:39.061 | HD Server | Thread:11272 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:39.061 | HD Server | Thread:11272 (4) | Closed.
2024-08-14 17:10:39.149 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:39.149 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:39.150 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:39.150 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:39.150 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:39.189 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:39.189 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:39.190 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:39.190 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:39.196 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11272
2024-08-14 17:10:39.197 | HD Server Manager | Current server count=1
2024-08-14 17:10:39.197 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15944
2024-08-14 17:10:39.197 | HD Server Manager | Current server count=0
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:39.317 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:39.317 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:39.317 | Historical data download ID 121472 not found when removing ID from outstanding request set.
2024-08-14 17:10:39.317 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:39.317 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:39.317 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:39.317 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:39.317 | Historical data download ID 121473 not found when removing ID from outstanding request set.
2024-08-14 17:10:39.317 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:39.317 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:39.317 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:39.356 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:39.356 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:39.356 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:10:39.356 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:10:39.356 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:10:39.356 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:39.357 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:39.357 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:39.357 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:39.396 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:10:39.396 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:39.396 | DTC Client socket (4) | Closed.
2024-08-14 17:10:41.351 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:41.351 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:41.352 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:41.352 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:41.352 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:41.391 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:41.391 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:41.392 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:41.392 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:41.516 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:41.516 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:41.516 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:41.516 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:41.516 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:41.516 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:41.516 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:41.517 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:41.517 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:41.517 | Historical data download ID 121474 not found when removing ID from outstanding request set.
2024-08-14 17:10:41.517 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:41.517 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:41.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:41.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:41.517 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:41.517 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:41.517 | Historical data download ID 121475 not found when removing ID from outstanding request set.
2024-08-14 17:10:41.517 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:41.517 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:41.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:41.561 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:41.561 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:41.561 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:41.561 | DTC Client socket (4) | Closed.
2024-08-14 17:10:41.561 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:41.562 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:41.562 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:41.562 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:43.558 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:43.558 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:43.559 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:43.559 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:43.559 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:43.597 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:43.597 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:43.597 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:43.597 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:43.722 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:43.722 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:43.722 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:43.722 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:43.722 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:43.722 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:43.722 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:43.722 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:43.722 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:43.722 | Historical data download ID 121476 not found when removing ID from outstanding request set.
2024-08-14 17:10:43.722 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:43.722 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:43.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:43.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:43.723 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:43.723 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:43.723 | Historical data download ID 121477 not found when removing ID from outstanding request set.
2024-08-14 17:10:43.723 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:43.723 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:43.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:43.764 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:43.764 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:43.764 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:43.764 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:43.765 | DTC Client socket (4) | Closed.
2024-08-14 17:10:43.765 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:43.765 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:43.765 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:43.765 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:45.765 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:45.765 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:45.765 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:45.766 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:45.766 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:45.804 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:45.804 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:45.804 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:45.804 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:45.934 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:45.934 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:45.934 | Historical data download ID 121478 not found when removing ID from outstanding request set.
2024-08-14 17:10:45.934 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:45.934 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:45.934 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:45.934 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:45.934 | Historical data download ID 121479 not found when removing ID from outstanding request set.
2024-08-14 17:10:45.934 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:45.934 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:45.934 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:45.977 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:45.977 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:45.977 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:45.977 | DTC Client socket (4) | Closed.
2024-08-14 17:10:45.977 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:45.977 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:45.977 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:45.977 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:47.975 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:47.975 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:47.976 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:47.976 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:47.976 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:48.016 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:48.016 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:48.016 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:48.016 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:48.143 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:48.143 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:48.143 | Historical data download ID 121480 not found when removing ID from outstanding request set.
2024-08-14 17:10:48.143 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:48.143 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:48.143 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:48.143 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:48.143 | Historical data download ID 121481 not found when removing ID from outstanding request set.
2024-08-14 17:10:48.143 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:48.143 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:48.143 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:48.184 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:48.186 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:48.186 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:48.186 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:48.186 | DTC Client socket (4) | Closed.
2024-08-14 17:10:48.187 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:48.187 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:48.187 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:48.187 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:50.187 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:50.188 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:50.188 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:50.189 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:50.189 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:50.228 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:50.228 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:50.228 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:50.228 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:50.346 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:50.346 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:50.346 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:50.346 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:50.346 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:50.346 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:50.346 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:50.347 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:50.347 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:50.347 | Historical data download ID 121482 not found when removing ID from outstanding request set.
2024-08-14 17:10:50.347 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:50.347 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:50.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:50.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:50.347 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:50.347 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:50.347 | Historical data download ID 121483 not found when removing ID from outstanding request set.
2024-08-14 17:10:50.347 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:50.347 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:50.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:50.387 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:50.390 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:50.390 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:50.390 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:50.390 | DTC Client socket (4) | Closed.
2024-08-14 17:10:50.390 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:50.390 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:50.390 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:50.390 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:52.389 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:52.389 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:52.390 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:52.390 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:52.390 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:52.433 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:52.433 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:52.434 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:52.434 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:52.565 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:52.565 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:52.565 | Historical data download ID 121484 not found when removing ID from outstanding request set.
2024-08-14 17:10:52.565 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:52.565 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:52.565 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:52.565 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:52.565 | Historical data download ID 121485 not found when removing ID from outstanding request set.
2024-08-14 17:10:52.565 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:52.565 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:52.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:52.604 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:52.604 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:52.604 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:52.604 | DTC Client socket (4) | Closed.
2024-08-14 17:10:52.604 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:52.604 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:52.604 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:52.604 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:54.607 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:54.607 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:54.607 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:54.607 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:54.607 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:54.646 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:54.646 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:54.646 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:54.646 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:54.769 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:54.769 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:54.769 | Historical data download ID 121486 not found when removing ID from outstanding request set.
2024-08-14 17:10:54.769 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:54.769 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:54.769 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:54.769 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:54.769 | Historical data download ID 121487 not found when removing ID from outstanding request set.
2024-08-14 17:10:54.769 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:54.769 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:54.769 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:54.812 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:54.812 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:54.812 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:54.812 | DTC Client socket (4) | Closed.
2024-08-14 17:10:54.812 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:54.812 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:54.812 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:54.812 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:56.812 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:56.812 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:56.813 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:56.813 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:56.813 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:56.853 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:56.853 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:56.853 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:56.853 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:56.975 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:56.975 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:56.975 | Historical data download ID 121488 not found when removing ID from outstanding request set.
2024-08-14 17:10:56.975 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:56.975 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:56.975 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:56.975 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:56.975 | Historical data download ID 121489 not found when removing ID from outstanding request set.
2024-08-14 17:10:56.975 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:56.975 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:56.975 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:57.017 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:57.019 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:57.019 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:57.019 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:57.019 | DTC Client socket (4) | Closed.
2024-08-14 17:10:57.019 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:57.019 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:57.019 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:57.019 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:10:59.018 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:10:59.018 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:10:59.019 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:10:59.019 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:10:59.019 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:10:59.057 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:10:59.057 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:10:59.057 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:10:59.057 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:10:59.179 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:10:59.179 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:10:59.179 | Historical data download ID 121490 not found when removing ID from outstanding request set.
2024-08-14 17:10:59.179 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:10:59.179 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:10:59.179 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:10:59.179 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:10:59.179 | Historical data download ID 121491 not found when removing ID from outstanding request set.
2024-08-14 17:10:59.179 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:10:59.179 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:10:59.179 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:10:59.221 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:10:59.223 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:10:59.223 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:10:59.223 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:10:59.223 | DTC Client socket (4) | Closed.
2024-08-14 17:10:59.223 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:10:59.224 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:10:59.224 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:10:59.224 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:01.229 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:01.229 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:01.230 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:01.230 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:01.230 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:01.269 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:01.269 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:01.269 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:01.269 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:01.395 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:01.395 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:01.395 | Historical data download ID 121492 not found when removing ID from outstanding request set.
2024-08-14 17:11:01.395 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:01.395 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:01.395 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:01.395 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:01.395 | Historical data download ID 121493 not found when removing ID from outstanding request set.
2024-08-14 17:11:01.395 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:01.395 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:01.395 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:01.437 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:01.437 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:01.437 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:01.437 | DTC Client socket (4) | Closed.
2024-08-14 17:11:01.437 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:01.437 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:01.437 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:01.437 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:03.427 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:03.427 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:03.427 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:03.427 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:03.427 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:03.466 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:03.466 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:03.466 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:03.466 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:03.587 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:03.587 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:03.587 | Historical data download ID 121494 not found when removing ID from outstanding request set.
2024-08-14 17:11:03.587 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:03.587 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:03.587 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:03.587 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:03.587 | Historical data download ID 121495 not found when removing ID from outstanding request set.
2024-08-14 17:11:03.587 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:03.587 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:03.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:03.628 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:03.629 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:03.629 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:03.629 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:03.629 | DTC Client socket (4) | Closed.
2024-08-14 17:11:03.630 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:03.630 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:03.630 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:03.630 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:05.641 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:05.641 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:05.642 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:05.642 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:05.642 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:05.680 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:05.680 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:05.680 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:05.680 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:05.805 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:05.805 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:05.805 | Historical data download ID 121496 not found when removing ID from outstanding request set.
2024-08-14 17:11:05.805 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:05.805 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:05.805 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:05.805 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:05.805 | Historical data download ID 121497 not found when removing ID from outstanding request set.
2024-08-14 17:11:05.805 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:05.805 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:05.805 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:05.847 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:05.847 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:05.847 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:05.847 | DTC Client socket (4) | Closed.
2024-08-14 17:11:05.848 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:05.848 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:05.848 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:05.848 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:07.502 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:07.503 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:11:07.516 | HD Server | Thread:7584 (4) | Creating socket.
2024-08-14 17:11:07.516 | HD Server | Thread:7584 (4) | New receive buffer size: 262144
2024-08-14 17:11:07.516 | HD Server | Thread:7584 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:07.516 | HD Server | Setting DTC encoding to Binary VLS | Thread:7584
2024-08-14 17:11:07.517 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:7584
2024-08-14 17:11:07.517 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:7584
2024-08-14 17:11:07.517 | HD Server | HD Request #4213 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4213 | Username: DAVID SUDDUTH JR. | Thread:7584
2024-08-14 17:11:07.518 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4213 | Username: DAVID SUDDUTH JR. | Thread:7584
2024-08-14 17:11:07.519 | HD Server | Thread:7584 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:07.519 | HD Server | Thread:7584 (4) | CloseSocket call.
2024-08-14 17:11:07.520 | HD Server | Thread:7584 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:07.520 | HD Server | Thread:7584 (4) | Closed.
2024-08-14 17:11:07.520 | HD Server | Thread:7584 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:11:07.522 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:07.522 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:11:07.533 | HD Server | Thread:18532 (4) | Creating socket.
2024-08-14 17:11:07.533 | HD Server | Thread:18532 (4) | New receive buffer size: 262144
2024-08-14 17:11:07.533 | HD Server | Thread:18532 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:07.533 | HD Server | Setting DTC encoding to Binary VLS | Thread:18532
2024-08-14 17:11:07.534 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18532
2024-08-14 17:11:07.534 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18532
2024-08-14 17:11:07.535 | HD Server | HD Request #4214 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4214 | Username: DAVID SUDDUTH JR. | Thread:18532
2024-08-14 17:11:07.536 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4214 | Username: DAVID SUDDUTH JR. | Thread:18532
2024-08-14 17:11:07.536 | HD Server | Thread:18532 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:07.536 | HD Server | Thread:18532 (4) | CloseSocket call.
2024-08-14 17:11:07.537 | HD Server | Thread:18532 (0) | CloseSocket call.
2024-08-14 17:11:07.537 | HD Server | Thread:18532 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:07.537 | HD Server | Thread:18532 (4) | Closed.
2024-08-14 17:11:07.709 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18532
2024-08-14 17:11:07.710 | HD Server Manager | Current server count=1
2024-08-14 17:11:07.710 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:7584
2024-08-14 17:11:07.710 | HD Server Manager | Current server count=0
2024-08-14 17:11:07.850 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:07.850 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:07.850 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:07.851 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:07.851 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:07.889 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:07.889 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:07.889 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:07.889 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:08.016 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:08.016 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:08.016 | Historical data download ID 121498 not found when removing ID from outstanding request set.
2024-08-14 17:11:08.016 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:08.016 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:08.016 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:08.016 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:08.016 | Historical data download ID 121499 not found when removing ID from outstanding request set.
2024-08-14 17:11:08.016 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:08.016 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:08.016 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:08.054 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:08.054 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:08.054 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:08.054 | DTC Client socket (4) | Closed.
2024-08-14 17:11:08.054 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:08.054 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:08.054 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:08.054 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:10.013 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:10.014 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:11:10.020 | HD Server | Thread:18392 (4) | Creating socket.
2024-08-14 17:11:10.020 | HD Server | Thread:18392 (4) | New receive buffer size: 262144
2024-08-14 17:11:10.020 | HD Server | Thread:18392 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:10.020 | HD Server | Setting DTC encoding to Binary VLS | Thread:18392
2024-08-14 17:11:10.021 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18392
2024-08-14 17:11:10.021 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18392
2024-08-14 17:11:10.021 | HD Server | HD Request #4215 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4215 | Username: DAVID SUDDUTH JR. | Thread:18392
2024-08-14 17:11:10.022 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4215 | Username: DAVID SUDDUTH JR. | Thread:18392
2024-08-14 17:11:10.022 | HD Server | Thread:18392 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:10.022 | HD Server | Thread:18392 (4) | CloseSocket call.
2024-08-14 17:11:10.023 | HD Server | Thread:18392 (0) | CloseSocket call.
2024-08-14 17:11:10.023 | HD Server | Thread:18392 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:10.023 | HD Server | Thread:18392 (4) | Closed.
2024-08-14 17:11:10.027 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:10.028 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:11:10.035 | HD Server | Thread:21316 (4) | Creating socket.
2024-08-14 17:11:10.035 | HD Server | Thread:21316 (4) | New receive buffer size: 262144
2024-08-14 17:11:10.035 | HD Server | Thread:21316 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:10.036 | HD Server | Setting DTC encoding to Binary VLS | Thread:21316
2024-08-14 17:11:10.036 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:21316
2024-08-14 17:11:10.036 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:21316
2024-08-14 17:11:10.036 | HD Server | HD Request #4216 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4216 | Username: DAVID SUDDUTH JR. | Thread:21316
2024-08-14 17:11:10.037 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4216 | Username: DAVID SUDDUTH JR. | Thread:21316
2024-08-14 17:11:10.038 | HD Server | Thread:21316 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:10.038 | HD Server | Thread:21316 (4) | CloseSocket call.
2024-08-14 17:11:10.038 | HD Server | Thread:21316 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:11:10.038 | HD Server | Thread:21316 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:10.038 | HD Server | Thread:21316 (4) | Closed.
2024-08-14 17:11:10.064 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:10.064 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:10.064 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:10.064 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:10.064 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:10.104 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:10.104 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:10.104 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:10.104 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:10.207 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:21316
2024-08-14 17:11:10.208 | HD Server Manager | Current server count=1
2024-08-14 17:11:10.208 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18392
2024-08-14 17:11:10.208 | HD Server Manager | Current server count=0
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:10.225 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:10.225 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:10.225 | Historical data download ID 121500 not found when removing ID from outstanding request set.
2024-08-14 17:11:10.225 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:10.225 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:10.225 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:10.225 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:10.225 | Historical data download ID 121501 not found when removing ID from outstanding request set.
2024-08-14 17:11:10.225 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:10.225 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:10.225 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:10.264 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:10.264 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:10.264 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:10.264 | DTC Client socket (4) | Closed.
2024-08-14 17:11:10.264 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:10.265 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:10.265 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:10.265 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:12.262 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:12.262 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:12.263 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:12.263 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:12.263 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:12.297 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:12.297 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:12.297 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:12.297 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:12.417 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:12.417 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:12.417 | Historical data download ID 121502 not found when removing ID from outstanding request set.
2024-08-14 17:11:12.417 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:12.417 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:12.417 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:12.417 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:12.417 | Historical data download ID 121503 not found when removing ID from outstanding request set.
2024-08-14 17:11:12.417 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:12.417 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:12.417 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:12.460 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:12.460 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:12.461 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:12.461 | DTC Client socket (4) | Closed.
2024-08-14 17:11:12.461 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:12.461 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:12.461 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:12.461 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:14.457 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:14.457 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:14.458 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:14.458 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:14.458 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:14.496 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:14.496 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:14.496 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:14.496 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:14.622 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:14.622 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:14.622 | Historical data download ID 121504 not found when removing ID from outstanding request set.
2024-08-14 17:11:14.622 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:14.622 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:14.622 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:14.622 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:14.622 | Historical data download ID 121505 not found when removing ID from outstanding request set.
2024-08-14 17:11:14.622 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:14.622 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:14.622 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:14.664 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:14.664 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:14.664 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:14.664 | DTC Client socket (4) | Closed.
2024-08-14 17:11:14.664 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:14.664 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:14.664 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:14.664 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:16.672 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:16.672 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:16.672 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:16.673 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:16.673 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:16.711 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:16.711 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:16.711 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:16.711 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:16.832 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:16.832 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:16.832 | Historical data download ID 121506 not found when removing ID from outstanding request set.
2024-08-14 17:11:16.832 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:16.832 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:16.832 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:16.832 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:16.832 | Historical data download ID 121507 not found when removing ID from outstanding request set.
2024-08-14 17:11:16.832 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:16.832 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:16.832 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:16.873 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:16.874 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:16.874 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:16.874 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:16.874 | DTC Client socket (4) | Closed.
2024-08-14 17:11:16.874 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:16.875 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:16.875 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:16.875 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:18.862 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:18.862 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:18.862 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:18.862 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:18.862 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:18.900 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:18.900 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:18.900 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:18.900 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:19.024 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:19.024 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:19.024 | Historical data download ID 121508 not found when removing ID from outstanding request set.
2024-08-14 17:11:19.024 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:19.024 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:19.024 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:19.024 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:19.024 | Historical data download ID 121509 not found when removing ID from outstanding request set.
2024-08-14 17:11:19.024 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:19.024 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:19.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:19.062 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:19.062 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:19.062 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:11:19.062 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:19.063 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:19.063 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:19.063 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:19.320 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:11:19.320 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:19.320 | DTC Client socket (4) | Closed.
2024-08-14 17:11:21.048 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:21.048 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:21.049 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:21.049 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:21.049 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:21.087 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:21.087 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:21.087 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:21.087 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:21.206 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:21.206 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:21.206 | Historical data download ID 121510 not found when removing ID from outstanding request set.
2024-08-14 17:11:21.206 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:21.206 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:21.206 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:21.206 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:21.206 | Historical data download ID 121511 not found when removing ID from outstanding request set.
2024-08-14 17:11:21.206 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:21.206 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:21.206 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:21.246 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:21.247 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:21.248 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:21.248 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:21.248 | DTC Client socket (4) | Closed.
2024-08-14 17:11:21.248 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:21.248 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:21.248 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:21.248 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:23.247 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:23.247 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:23.248 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:23.248 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:23.248 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:23.287 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:23.287 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:23.287 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:23.287 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:23.418 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:23.418 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:23.418 | Historical data download ID 121512 not found when removing ID from outstanding request set.
2024-08-14 17:11:23.418 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:23.418 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:23.418 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:23.418 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:23.418 | Historical data download ID 121513 not found when removing ID from outstanding request set.
2024-08-14 17:11:23.418 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:23.418 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:23.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:23.460 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:23.460 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:23.460 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:11:23.460 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:11:23.460 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:23.460 | DTC Client socket (4) | Closed.
2024-08-14 17:11:23.460 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:23.461 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:23.461 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:23.461 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:25.464 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:25.464 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:25.464 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:25.464 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:25.464 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:25.502 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:25.502 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:25.503 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:25.503 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:25.625 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:25.625 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:25.625 | Historical data download ID 121514 not found when removing ID from outstanding request set.
2024-08-14 17:11:25.625 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:25.625 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:25.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:25.626 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:25.626 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:25.626 | Historical data download ID 121515 not found when removing ID from outstanding request set.
2024-08-14 17:11:25.626 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:25.626 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:25.626 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:25.664 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:25.664 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:25.664 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:25.665 | DTC Client socket (4) | Closed.
2024-08-14 17:11:25.665 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:25.665 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:25.665 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:25.665 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:27.670 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:27.670 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:27.670 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:27.670 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:27.670 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:27.709 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:27.709 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:27.709 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:27.709 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:27.833 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:27.833 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:27.833 | Historical data download ID 121516 not found when removing ID from outstanding request set.
2024-08-14 17:11:27.833 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:27.833 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:27.833 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:27.833 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:27.833 | Historical data download ID 121517 not found when removing ID from outstanding request set.
2024-08-14 17:11:27.833 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:27.833 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:27.833 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:27.873 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:27.876 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:27.876 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:27.876 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:27.876 | DTC Client socket (4) | Closed.
2024-08-14 17:11:27.876 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:27.876 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:27.876 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:27.876 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:29.877 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:29.877 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:29.878 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:29.878 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:29.878 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:29.917 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:29.917 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:29.917 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:29.917 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:30.037 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:30.037 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:30.037 | Historical data download ID 121518 not found when removing ID from outstanding request set.
2024-08-14 17:11:30.037 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:30.037 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:30.037 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:30.037 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:30.037 | Historical data download ID 121519 not found when removing ID from outstanding request set.
2024-08-14 17:11:30.037 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:30.037 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:30.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:30.075 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:30.075 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:30.075 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:30.075 | DTC Client socket (4) | Closed.
2024-08-14 17:11:30.076 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:30.076 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:30.076 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:30.076 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:32.067 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:32.067 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:32.067 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:32.068 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:32.068 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:32.105 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:32.105 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:32.105 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:32.105 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:32.234 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:32.234 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:32.234 | Historical data download ID 121520 not found when removing ID from outstanding request set.
2024-08-14 17:11:32.234 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:32.234 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:32.234 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:32.234 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:32.235 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:32.235 | Historical data download ID 121521 not found when removing ID from outstanding request set.
2024-08-14 17:11:32.235 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:32.235 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:32.235 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:32.276 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:32.277 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:32.277 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:32.277 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:32.277 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:32.277 | DTC Client socket (4) | Closed.
2024-08-14 17:11:32.277 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:32.277 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:32.278 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:34.274 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:34.274 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:34.275 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:34.275 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:34.275 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:34.313 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:34.313 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:34.313 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:34.313 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:34.438 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:34.438 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:34.438 | Historical data download ID 121522 not found when removing ID from outstanding request set.
2024-08-14 17:11:34.438 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:34.438 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:34.438 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:34.438 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:34.438 | Historical data download ID 121523 not found when removing ID from outstanding request set.
2024-08-14 17:11:34.438 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:34.438 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:34.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:34.481 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:34.481 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:34.481 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:34.481 | DTC Client socket (4) | Closed.
2024-08-14 17:11:34.481 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:34.482 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:34.482 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:34.482 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:36.474 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:36.474 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:36.475 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:36.475 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:36.475 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:36.512 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:36.512 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:36.512 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:36.512 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:36.632 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:36.632 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:36.632 | Historical data download ID 121524 not found when removing ID from outstanding request set.
2024-08-14 17:11:36.632 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:36.632 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:36.632 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:36.632 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:36.632 | Historical data download ID 121525 not found when removing ID from outstanding request set.
2024-08-14 17:11:36.632 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:36.632 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:36.632 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:36.673 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:36.674 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:36.674 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:36.674 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:36.675 | DTC Client socket (4) | Closed.
2024-08-14 17:11:36.675 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:36.675 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:36.675 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:36.675 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:38.530 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:38.530 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:11:38.544 | HD Server | Thread:20052 (4) | Creating socket.
2024-08-14 17:11:38.544 | HD Server | Thread:20052 (4) | New receive buffer size: 262144
2024-08-14 17:11:38.544 | HD Server | Thread:20052 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:38.544 | HD Server | Setting DTC encoding to Binary VLS | Thread:20052
2024-08-14 17:11:38.545 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:20052
2024-08-14 17:11:38.545 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:20052
2024-08-14 17:11:38.545 | HD Server | HD Request #4217 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4217 | Username: DAVID SUDDUTH JR. | Thread:20052
2024-08-14 17:11:38.546 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4217 | Username: DAVID SUDDUTH JR. | Thread:20052
2024-08-14 17:11:38.546 | HD Server | Thread:20052 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:38.546 | HD Server | Thread:20052 (4) | CloseSocket call.
2024-08-14 17:11:38.546 | HD Server | Thread:20052 (0) | CloseSocket call.
2024-08-14 17:11:38.546 | HD Server | Thread:20052 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:38.546 | HD Server | Thread:20052 (4) | Closed.
2024-08-14 17:11:38.571 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:38.572 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:11:38.577 | HD Server | Thread:12516 (4) | Creating socket.
2024-08-14 17:11:38.577 | HD Server | Thread:12516 (4) | New receive buffer size: 262144
2024-08-14 17:11:38.578 | HD Server | Thread:12516 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:38.578 | HD Server | Setting DTC encoding to Binary VLS | Thread:12516
2024-08-14 17:11:38.578 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12516
2024-08-14 17:11:38.578 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12516
2024-08-14 17:11:38.578 | HD Server | HD Request #4218 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4218 | Username: DAVID SUDDUTH JR. | Thread:12516
2024-08-14 17:11:38.579 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4218 | Username: DAVID SUDDUTH JR. | Thread:12516
2024-08-14 17:11:38.579 | HD Server | Thread:12516 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:38.579 | HD Server | Thread:12516 (4) | CloseSocket call.
2024-08-14 17:11:38.579 | HD Server | Thread:12516 (0) | CloseSocket call.
2024-08-14 17:11:38.579 | HD Server | Thread:12516 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:38.579 | HD Server | Thread:12516 (4) | Closed.
2024-08-14 17:11:38.673 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:38.674 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:38.674 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:38.674 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:38.674 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:38.714 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:38.714 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:38.714 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:38.714 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:38.753 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12516
2024-08-14 17:11:38.753 | HD Server Manager | Current server count=1
2024-08-14 17:11:38.753 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:20052
2024-08-14 17:11:38.754 | HD Server Manager | Current server count=0
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:38.835 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:38.835 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:38.835 | Historical data download ID 121526 not found when removing ID from outstanding request set.
2024-08-14 17:11:38.835 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:38.835 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:38.835 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:38.835 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:38.835 | Historical data download ID 121527 not found when removing ID from outstanding request set.
2024-08-14 17:11:38.835 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:38.835 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:38.835 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:38.838 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:38.838 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:11:38.851 | HD Server | Thread:15916 (5) | Creating socket.
2024-08-14 17:11:38.851 | HD Server | Thread:15916 (5) | New receive buffer size: 262144
2024-08-14 17:11:38.851 | HD Server | Thread:15916 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:38.852 | HD Server | Setting DTC encoding to Binary VLS | Thread:15916
2024-08-14 17:11:38.852 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15916
2024-08-14 17:11:38.852 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15916
2024-08-14 17:11:38.853 | HD Server | HD Request #4219 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4219 | Username: DAVID SUDDUTH JR. | Thread:15916
2024-08-14 17:11:38.853 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4219 | Username: DAVID SUDDUTH JR. | Thread:15916
2024-08-14 17:11:38.854 | HD Server | Thread:15916 (5) | Socket gracefully closed by remote side.
2024-08-14 17:11:38.854 | HD Server | Thread:15916 (5) | CloseSocket call.
2024-08-14 17:11:38.854 | HD Server | Thread:15916 (0) | CloseSocket call.
2024-08-14 17:11:38.854 | HD Server | Thread:15916 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:38.854 | HD Server | Thread:15916 (5) | Closed.
2024-08-14 17:11:38.857 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:38.857 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:11:38.870 | HD Server | Thread:11340 (5) | Creating socket.
2024-08-14 17:11:38.870 | HD Server | Thread:11340 (5) | New receive buffer size: 262144
2024-08-14 17:11:38.870 | HD Server | Thread:11340 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:38.870 | HD Server | Setting DTC encoding to Binary VLS | Thread:11340
2024-08-14 17:11:38.871 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11340
2024-08-14 17:11:38.871 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11340
2024-08-14 17:11:38.871 | HD Server | HD Request #4220 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4220 | Username: DAVID SUDDUTH JR. | Thread:11340
2024-08-14 17:11:38.872 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4220 | Username: DAVID SUDDUTH JR. | Thread:11340
2024-08-14 17:11:38.872 | HD Server | Thread:11340 (5) | Socket gracefully closed by remote side.
2024-08-14 17:11:38.872 | HD Server | Thread:11340 (5) | CloseSocket call.
2024-08-14 17:11:38.872 | HD Server | Thread:11340 (0) | CloseSocket call.
2024-08-14 17:11:38.873 | HD Server | Thread:11340 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:38.873 | HD Server | Thread:11340 (5) | Closed.
2024-08-14 17:11:38.873 | HD Server | Thread:11340 (0) | CloseSocket call.
2024-08-14 17:11:38.876 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:38.878 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:38.878 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:38.879 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:38.879 | DTC Client socket (4) | Closed.
2024-08-14 17:11:38.879 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:38.879 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:38.879 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:38.879 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:39.004 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11340
2024-08-14 17:11:39.004 | HD Server Manager | Current server count=1
2024-08-14 17:11:39.004 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15916
2024-08-14 17:11:39.004 | HD Server Manager | Current server count=0
2024-08-14 17:11:40.887 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:40.887 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:40.888 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:40.888 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:40.888 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:40.926 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:40.926 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:40.926 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:40.926 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:41.056 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:41.056 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:41.056 | Historical data download ID 121528 not found when removing ID from outstanding request set.
2024-08-14 17:11:41.056 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:41.056 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:41.056 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:41.056 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:41.056 | Historical data download ID 121529 not found when removing ID from outstanding request set.
2024-08-14 17:11:41.056 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:41.056 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:41.056 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:41.097 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:41.098 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:41.098 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:41.098 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:41.098 | DTC Client socket (4) | Closed.
2024-08-14 17:11:41.099 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:41.099 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:41.099 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:41.099 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:41.882 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:41.883 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:11:41.894 | HD Server | Thread:2868 (4) | Creating socket.
2024-08-14 17:11:41.894 | HD Server | Thread:2868 (4) | New receive buffer size: 262144
2024-08-14 17:11:41.895 | HD Server | Thread:2868 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:41.895 | HD Server | Setting DTC encoding to Binary VLS | Thread:2868
2024-08-14 17:11:41.896 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:2868
2024-08-14 17:11:41.896 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:2868
2024-08-14 17:11:41.896 | HD Server | HD Request #4221 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4221 | Username: DAVID SUDDUTH JR. | Thread:2868
2024-08-14 17:11:41.897 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4221 | Username: DAVID SUDDUTH JR. | Thread:2868
2024-08-14 17:11:41.897 | HD Server | Thread:2868 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:41.897 | HD Server | Thread:2868 (4) | CloseSocket call.
2024-08-14 17:11:41.897 | HD Server | Thread:2868 (0) | CloseSocket call.
2024-08-14 17:11:41.898 | HD Server | Thread:2868 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:41.898 | HD Server | Thread:2868 (4) | Closed.
2024-08-14 17:11:41.898 | HD Server | Thread:2868 (0) | CloseSocket call.
2024-08-14 17:11:41.919 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:11:41.919 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:11:41.931 | HD Server | Thread:10164 (4) | Creating socket.
2024-08-14 17:11:41.931 | HD Server | Thread:10164 (4) | New receive buffer size: 262144
2024-08-14 17:11:41.931 | HD Server | Thread:10164 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:11:41.932 | HD Server | Setting DTC encoding to Binary VLS | Thread:10164
2024-08-14 17:11:41.932 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10164
2024-08-14 17:11:41.932 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10164
2024-08-14 17:11:41.933 | HD Server | HD Request #4222 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4222 | Username: DAVID SUDDUTH JR. | Thread:10164
2024-08-14 17:11:41.934 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4222 | Username: DAVID SUDDUTH JR. | Thread:10164
2024-08-14 17:11:41.935 | HD Server | Thread:10164 (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:41.935 | HD Server | Thread:10164 (4) | CloseSocket call.
2024-08-14 17:11:41.936 | HD Server | Thread:10164 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:41.936 | HD Server | Thread:10164 (4) | Closed.
2024-08-14 17:11:41.936 | HD Server | Thread:10164 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:11:42.021 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10164
2024-08-14 17:11:42.021 | HD Server Manager | Current server count=1
2024-08-14 17:11:42.021 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:2868
2024-08-14 17:11:42.021 | HD Server Manager | Current server count=0
2024-08-14 17:11:43.109 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:43.109 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:43.109 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:43.109 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:43.109 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:43.149 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:43.149 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:43.149 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:43.149 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:43.281 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:43.281 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:43.281 | Historical data download ID 121530 not found when removing ID from outstanding request set.
2024-08-14 17:11:43.281 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:43.281 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:43.281 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:43.281 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:43.281 | Historical data download ID 121531 not found when removing ID from outstanding request set.
2024-08-14 17:11:43.281 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:43.281 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:43.281 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:43.323 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:43.323 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:43.323 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:43.323 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:43.323 | DTC Client socket (4) | Closed.
2024-08-14 17:11:43.323 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:43.324 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:43.324 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:43.324 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:45.322 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:45.322 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:45.323 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:45.323 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:45.323 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:45.361 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:45.361 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:45.361 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:45.361 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:45.485 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:45.485 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:45.485 | Historical data download ID 121532 not found when removing ID from outstanding request set.
2024-08-14 17:11:45.485 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:45.485 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:45.485 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:45.485 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:45.485 | Historical data download ID 121533 not found when removing ID from outstanding request set.
2024-08-14 17:11:45.485 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:45.485 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:45.485 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:45.523 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:45.523 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:45.523 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:45.523 | DTC Client socket (4) | Closed.
2024-08-14 17:11:45.523 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:45.524 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:45.524 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:45.524 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:47.532 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:47.532 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:47.533 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:47.533 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:47.533 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:47.572 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:47.572 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:47.572 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:47.572 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:47.695 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:47.695 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:47.695 | Historical data download ID 121534 not found when removing ID from outstanding request set.
2024-08-14 17:11:47.695 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:47.695 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:47.695 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:47.695 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:47.695 | Historical data download ID 121535 not found when removing ID from outstanding request set.
2024-08-14 17:11:47.695 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:47.695 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:47.695 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:47.737 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:47.737 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:47.737 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:47.737 | DTC Client socket (4) | Closed.
2024-08-14 17:11:47.738 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:47.738 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:47.738 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:47.738 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:49.739 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:49.739 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:49.739 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:49.740 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:49.740 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:49.777 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:49.777 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:49.778 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:49.778 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:49.897 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:49.898 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:49.898 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:49.898 | Historical data download ID 121536 not found when removing ID from outstanding request set.
2024-08-14 17:11:49.898 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:49.898 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:49.898 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:49.898 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:49.898 | Historical data download ID 121537 not found when removing ID from outstanding request set.
2024-08-14 17:11:49.898 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:49.898 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:49.898 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:49.939 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:49.940 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:49.941 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:49.941 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:49.941 | DTC Client socket (4) | Closed.
2024-08-14 17:11:49.941 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:49.941 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:49.941 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:49.941 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:51.950 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:51.950 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:51.950 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:51.950 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:51.950 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:51.990 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:51.990 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:51.990 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:51.990 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:52.115 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:52.115 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:52.115 | Historical data download ID 121538 not found when removing ID from outstanding request set.
2024-08-14 17:11:52.115 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:52.115 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:52.115 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:52.115 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:52.115 | Historical data download ID 121539 not found when removing ID from outstanding request set.
2024-08-14 17:11:52.115 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:52.115 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:52.115 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:52.157 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:52.158 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:52.158 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:52.158 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:52.158 | DTC Client socket (4) | Closed.
2024-08-14 17:11:52.158 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:52.159 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:52.159 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:52.159 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:54.159 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:54.159 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:54.160 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:54.160 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:54.160 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:54.199 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:54.199 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:54.199 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:54.199 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:54.339 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:54.339 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:54.339 | Historical data download ID 121540 not found when removing ID from outstanding request set.
2024-08-14 17:11:54.339 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:54.339 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:54.339 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:54.339 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:54.339 | Historical data download ID 121541 not found when removing ID from outstanding request set.
2024-08-14 17:11:54.339 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:54.339 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:54.339 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:54.379 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:54.379 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:54.379 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:54.379 | DTC Client socket (4) | Closed.
2024-08-14 17:11:54.379 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:54.380 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:54.380 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:54.380 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:56.382 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:56.382 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:56.383 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:56.383 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:56.383 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:56.422 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:56.422 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:56.422 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:56.422 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:56.544 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:56.544 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:56.544 | Historical data download ID 121542 not found when removing ID from outstanding request set.
2024-08-14 17:11:56.544 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:56.544 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:56.544 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:56.544 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:56.544 | Historical data download ID 121543 not found when removing ID from outstanding request set.
2024-08-14 17:11:56.544 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:56.544 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:56.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:56.585 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:56.587 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:56.587 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:56.587 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:56.587 | DTC Client socket (4) | Closed.
2024-08-14 17:11:56.587 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:56.587 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:56.587 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:56.587 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:11:58.590 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:11:58.590 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:11:58.590 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:11:58.591 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:11:58.591 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:11:58.630 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:11:58.630 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:11:58.630 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:11:58.630 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:11:58.752 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:11:58.752 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:11:58.752 | Historical data download ID 121544 not found when removing ID from outstanding request set.
2024-08-14 17:11:58.752 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:11:58.752 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:11:58.752 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:11:58.752 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:11:58.752 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:11:58.752 | Historical data download ID 121545 not found when removing ID from outstanding request set.
2024-08-14 17:11:58.752 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:11:58.753 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:11:58.753 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:11:58.793 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:11:58.796 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:11:58.796 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:11:58.796 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:11:58.796 | DTC Client socket (4) | Closed.
2024-08-14 17:11:58.796 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:11:58.797 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:11:58.797 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:11:58.797 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:00.782 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:00.782 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:00.783 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:00.783 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:00.783 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:00.821 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:00.821 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:00.821 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:00.821 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:00.945 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:00.945 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:00.945 | Historical data download ID 121546 not found when removing ID from outstanding request set.
2024-08-14 17:12:00.945 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:00.945 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:00.945 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:00.946 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:00.946 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:00.946 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:00.946 | Historical data download ID 121547 not found when removing ID from outstanding request set.
2024-08-14 17:12:00.946 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:00.946 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:00.946 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:00.986 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:00.988 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:00.988 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:00.988 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:00.988 | DTC Client socket (4) | Closed.
2024-08-14 17:12:00.989 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:00.989 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:00.989 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:00.989 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:02.992 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:02.992 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:02.993 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:02.993 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:02.993 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:03.032 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:03.032 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:03.032 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:03.032 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:03.158 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:03.158 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:03.158 | Historical data download ID 121548 not found when removing ID from outstanding request set.
2024-08-14 17:12:03.158 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:03.158 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:03.158 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:03.158 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:03.158 | Historical data download ID 121549 not found when removing ID from outstanding request set.
2024-08-14 17:12:03.158 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:03.158 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:03.158 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:03.202 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:03.203 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:03.203 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:03.203 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:03.203 | DTC Client socket (4) | Closed.
2024-08-14 17:12:03.203 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:03.204 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:03.204 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:03.204 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:05.201 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:05.201 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:05.202 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:05.202 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:05.202 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:05.240 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:05.240 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:05.240 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:05.240 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:05.364 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:05.364 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:05.364 | Historical data download ID 121550 not found when removing ID from outstanding request set.
2024-08-14 17:12:05.364 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:05.364 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:05.364 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:05.364 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:05.364 | Historical data download ID 121551 not found when removing ID from outstanding request set.
2024-08-14 17:12:05.364 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:05.364 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:05.364 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:05.406 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:05.406 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:05.406 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:05.406 | DTC Client socket (4) | Closed.
2024-08-14 17:12:05.406 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:05.407 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:05.407 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:05.407 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:07.421 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:07.421 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:07.422 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:07.422 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:07.422 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:07.460 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:07.460 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:07.460 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:07.460 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:07.587 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:07.587 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:07.587 | Historical data download ID 121552 not found when removing ID from outstanding request set.
2024-08-14 17:12:07.587 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:07.587 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:07.587 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:07.587 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:07.587 | Historical data download ID 121553 not found when removing ID from outstanding request set.
2024-08-14 17:12:07.587 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:07.587 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:07.587 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:07.631 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:07.631 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:07.631 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:07.631 | DTC Client socket (4) | Closed.
2024-08-14 17:12:07.632 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:07.632 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:07.632 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:07.632 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:09.639 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:09.639 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:09.639 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:09.640 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:09.640 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:09.675 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:09.675 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:09.675 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:09.675 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:09.807 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:09.807 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:09.807 | Historical data download ID 121554 not found when removing ID from outstanding request set.
2024-08-14 17:12:09.807 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:09.807 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:09.807 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:09.807 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:09.807 | Historical data download ID 121555 not found when removing ID from outstanding request set.
2024-08-14 17:12:09.807 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:09.807 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:09.807 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:09.847 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:09.847 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:09.847 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:09.847 | DTC Client socket (4) | Closed.
2024-08-14 17:12:09.847 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:09.848 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:09.848 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:09.848 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:09.863 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:09.863 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:12:09.876 | HD Server | Thread:14240 (4) | Creating socket.
2024-08-14 17:12:09.876 | HD Server | Thread:14240 (4) | New receive buffer size: 262144
2024-08-14 17:12:09.876 | HD Server | Thread:14240 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:09.876 | HD Server | Setting DTC encoding to Binary VLS | Thread:14240
2024-08-14 17:12:09.877 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:14240
2024-08-14 17:12:09.877 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:14240
2024-08-14 17:12:09.879 | HD Server | HD Request #4223 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4223 | Username: DAVID SUDDUTH JR. | Thread:14240
2024-08-14 17:12:09.879 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4223 | Username: DAVID SUDDUTH JR. | Thread:14240
2024-08-14 17:12:09.880 | HD Server | Thread:14240 (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:09.880 | HD Server | Thread:14240 (4) | CloseSocket call.
2024-08-14 17:12:09.880 | HD Server | Thread:14240 (0) | CloseSocket call.
2024-08-14 17:12:09.880 | HD Server | Thread:14240 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:09.880 | HD Server | Thread:14240 (4) | Closed.
2024-08-14 17:12:09.927 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:09.928 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:12:09.941 | HD Server | Thread:11944 (4) | Creating socket.
2024-08-14 17:12:09.941 | HD Server | Thread:11944 (4) | New receive buffer size: 262144
2024-08-14 17:12:09.941 | HD Server | Thread:11944 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:09.941 | HD Server | Setting DTC encoding to Binary VLS | Thread:11944
2024-08-14 17:12:09.942 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11944
2024-08-14 17:12:09.942 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11944
2024-08-14 17:12:09.942 | HD Server | HD Request #4224 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4224 | Username: DAVID SUDDUTH JR. | Thread:11944
2024-08-14 17:12:09.943 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4224 | Username: DAVID SUDDUTH JR. | Thread:11944
2024-08-14 17:12:09.943 | HD Server | Thread:11944 (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:09.943 | HD Server | Thread:11944 (4) | CloseSocket call.
2024-08-14 17:12:09.944 | HD Server | Thread:11944 (0) | CloseSocket call.
2024-08-14 17:12:09.944 | HD Server | Thread:11944 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:09.944 | HD Server | Thread:11944 (4) | Closed.
2024-08-14 17:12:10.032 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11944
2024-08-14 17:12:10.033 | HD Server Manager | Current server count=1
2024-08-14 17:12:10.033 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:14240
2024-08-14 17:12:10.033 | HD Server Manager | Current server count=0
2024-08-14 17:12:11.846 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:11.846 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:11.846 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:11.847 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:11.847 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:11.884 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:11.884 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:11.884 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:11.884 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:12.010 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:12.010 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:12.010 | Historical data download ID 121556 not found when removing ID from outstanding request set.
2024-08-14 17:12:12.010 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:12.010 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:12.010 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:12.010 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:12.010 | Historical data download ID 121557 not found when removing ID from outstanding request set.
2024-08-14 17:12:12.010 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:12.010 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:12.010 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:12.053 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:12.053 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:12.053 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:12.053 | DTC Client socket (4) | Closed.
2024-08-14 17:12:12.054 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:12.054 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:12.054 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:12.054 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:12.779 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:12.780 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:12:12.789 | HD Server | Thread:13192 (4) | Creating socket.
2024-08-14 17:12:12.789 | HD Server | Thread:13192 (4) | New receive buffer size: 262144
2024-08-14 17:12:12.789 | HD Server | Thread:13192 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:12.789 | HD Server | Setting DTC encoding to Binary VLS | Thread:13192
2024-08-14 17:12:12.790 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:13192
2024-08-14 17:12:12.790 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:13192
2024-08-14 17:12:12.790 | HD Server | HD Request #4225 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4225 | Username: DAVID SUDDUTH JR. | Thread:13192
2024-08-14 17:12:12.791 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4225 | Username: DAVID SUDDUTH JR. | Thread:13192
2024-08-14 17:12:12.791 | HD Server | Thread:13192 (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:12.791 | HD Server | Thread:13192 (4) | CloseSocket call.
2024-08-14 17:12:12.791 | HD Server | Thread:13192 (0) | CloseSocket call.
2024-08-14 17:12:12.792 | HD Server | Thread:13192 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:12.792 | HD Server | Thread:13192 (4) | Closed.
2024-08-14 17:12:12.792 | HD Server | Thread:13192 (0) | CloseSocket call.
2024-08-14 17:12:12.794 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:12.795 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:12:12.807 | HD Server | Thread:5500 (4) | Creating socket.
2024-08-14 17:12:12.807 | HD Server | Thread:5500 (4) | New receive buffer size: 262144
2024-08-14 17:12:12.808 | HD Server | Thread:5500 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:12.808 | HD Server | Setting DTC encoding to Binary VLS | Thread:5500
2024-08-14 17:12:12.808 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:5500
2024-08-14 17:12:12.808 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:5500
2024-08-14 17:12:12.809 | HD Server | HD Request #4226 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4226 | Username: DAVID SUDDUTH JR. | Thread:5500
2024-08-14 17:12:12.809 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4226 | Username: DAVID SUDDUTH JR. | Thread:5500
2024-08-14 17:12:12.810 | HD Server | Thread:5500 (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:12.810 | HD Server | Thread:5500 (4) | CloseSocket call.
2024-08-14 17:12:12.810 | HD Server | Thread:5500 (0) | CloseSocket call.
2024-08-14 17:12:12.810 | HD Server | Thread:5500 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:12.810 | HD Server | Thread:5500 (4) | Closed.
2024-08-14 17:12:13.033 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:5500
2024-08-14 17:12:13.033 | HD Server Manager | Current server count=1
2024-08-14 17:12:13.033 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:13192
2024-08-14 17:12:13.033 | HD Server Manager | Current server count=0
2024-08-14 17:12:14.061 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:14.062 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:14.062 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:14.062 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:14.062 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:14.102 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:14.102 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:14.103 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:14.103 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:14.226 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:14.226 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:14.226 | Historical data download ID 121558 not found when removing ID from outstanding request set.
2024-08-14 17:12:14.226 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:14.226 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:14.226 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:14.226 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:14.226 | Historical data download ID 121559 not found when removing ID from outstanding request set.
2024-08-14 17:12:14.226 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:14.226 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:14.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:14.266 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:14.268 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:14.268 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:14.268 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:14.268 | DTC Client socket (4) | Closed.
2024-08-14 17:12:14.268 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:14.268 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:14.268 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:14.268 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:16.280 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:16.280 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:16.281 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:16.281 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:16.281 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:16.319 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:16.319 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:16.319 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:16.319 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:16.443 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:16.443 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:16.443 | Historical data download ID 121560 not found when removing ID from outstanding request set.
2024-08-14 17:12:16.443 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:16.443 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:16.443 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:16.443 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:16.443 | Historical data download ID 121561 not found when removing ID from outstanding request set.
2024-08-14 17:12:16.443 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:16.443 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:16.443 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:16.485 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:16.485 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:16.485 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:16.485 | DTC Client socket (4) | Closed.
2024-08-14 17:12:16.485 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:16.486 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:16.486 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:16.486 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:18.498 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:18.498 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:18.499 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:18.499 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:18.499 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:18.536 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:18.536 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:18.536 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:18.536 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:18.659 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:18.659 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:18.659 | Historical data download ID 121562 not found when removing ID from outstanding request set.
2024-08-14 17:12:18.659 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:18.659 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:18.659 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:18.659 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:18.659 | Historical data download ID 121563 not found when removing ID from outstanding request set.
2024-08-14 17:12:18.659 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:18.659 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:18.659 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:18.701 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:18.702 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:18.702 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:18.702 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:18.702 | DTC Client socket (4) | Closed.
2024-08-14 17:12:18.702 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:18.702 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:18.702 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:18.702 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:20.689 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:20.689 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:20.689 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:20.689 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:20.689 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:20.734 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:20.734 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:20.734 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:20.734 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:20.860 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:20.860 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:20.860 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:20.860 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:20.860 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:20.860 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:20.860 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:20.860 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:20.861 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:20.861 | Historical data download ID 121564 not found when removing ID from outstanding request set.
2024-08-14 17:12:20.861 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:20.861 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:20.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:20.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:20.861 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:20.861 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:20.861 | Historical data download ID 121565 not found when removing ID from outstanding request set.
2024-08-14 17:12:20.861 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:20.861 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:20.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:20.900 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:20.900 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:20.900 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:20.900 | DTC Client socket (4) | Closed.
2024-08-14 17:12:20.900 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:20.901 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:20.901 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:20.901 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:22.898 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:22.898 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:22.899 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:22.899 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:22.899 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:22.937 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:22.937 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:22.937 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:22.937 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:23.061 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:23.061 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:23.061 | Historical data download ID 121566 not found when removing ID from outstanding request set.
2024-08-14 17:12:23.061 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:23.061 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:23.061 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:23.061 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:23.061 | Historical data download ID 121567 not found when removing ID from outstanding request set.
2024-08-14 17:12:23.061 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:23.061 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:23.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:23.103 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:23.103 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:23.103 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:12:23.103 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:12:23.103 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:12:23.103 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:23.104 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:23.104 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:23.104 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:23.146 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:12:23.146 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:23.146 | DTC Client socket (4) | Closed.
2024-08-14 17:12:25.107 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:25.107 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:25.108 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:25.108 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:25.108 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:25.147 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:25.147 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:25.147 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:25.147 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:25.272 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:25.272 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:25.272 | Historical data download ID 121568 not found when removing ID from outstanding request set.
2024-08-14 17:12:25.272 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:25.272 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:25.272 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:25.272 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:25.272 | Historical data download ID 121569 not found when removing ID from outstanding request set.
2024-08-14 17:12:25.272 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:25.272 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:25.272 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:25.313 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:25.313 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:25.313 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:25.313 | DTC Client socket (4) | Closed.
2024-08-14 17:12:25.313 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:25.314 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:25.314 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:25.314 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:27.323 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:27.323 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:27.324 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:27.324 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:27.324 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:27.365 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:27.365 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:27.365 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:27.365 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:27.493 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:27.494 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:27.494 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:27.494 | Historical data download ID 121570 not found when removing ID from outstanding request set.
2024-08-14 17:12:27.494 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:27.494 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:27.494 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:27.494 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:27.494 | Historical data download ID 121571 not found when removing ID from outstanding request set.
2024-08-14 17:12:27.494 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:27.494 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:27.494 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:27.534 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:27.535 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:27.535 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:27.535 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:27.535 | DTC Client socket (4) | Closed.
2024-08-14 17:12:27.536 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:27.536 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:27.536 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:27.536 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:29.535 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:29.535 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:29.536 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:29.536 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:29.536 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:29.574 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:29.574 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:29.574 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:29.574 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:29.697 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:29.697 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:29.697 | Historical data download ID 121572 not found when removing ID from outstanding request set.
2024-08-14 17:12:29.697 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:29.697 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:29.697 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:29.697 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:29.697 | Historical data download ID 121573 not found when removing ID from outstanding request set.
2024-08-14 17:12:29.697 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:29.697 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:29.697 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:29.738 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:29.739 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:29.739 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:29.739 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:29.739 | DTC Client socket (4) | Closed.
2024-08-14 17:12:29.739 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:29.739 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:29.739 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:29.739 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:31.740 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:31.740 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:31.740 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:31.741 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:31.741 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:31.779 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:31.779 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:31.779 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:31.779 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:31.899 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:31.899 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:31.900 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:31.900 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:31.900 | Historical data download ID 121574 not found when removing ID from outstanding request set.
2024-08-14 17:12:31.900 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:31.900 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:31.900 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:31.900 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:31.900 | Historical data download ID 121575 not found when removing ID from outstanding request set.
2024-08-14 17:12:31.900 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:31.900 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:31.900 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:31.940 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:31.941 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:31.941 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:31.942 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:31.942 | DTC Client socket (4) | Closed.
2024-08-14 17:12:31.942 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:31.942 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:31.942 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:31.942 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:33.939 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:33.939 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:33.939 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:33.939 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:33.939 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:33.978 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:33.978 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:33.978 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:33.978 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:34.108 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:34.108 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:34.108 | Historical data download ID 121576 not found when removing ID from outstanding request set.
2024-08-14 17:12:34.108 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:34.108 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:34.108 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:34.108 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:34.108 | Historical data download ID 121577 not found when removing ID from outstanding request set.
2024-08-14 17:12:34.108 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:34.108 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:34.108 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:34.150 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:34.150 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:34.150 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:34.150 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:34.150 | DTC Client socket (4) | Closed.
2024-08-14 17:12:34.151 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:34.151 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:34.151 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:36.147 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:36.147 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:36.148 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:36.148 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:36.148 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:36.190 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:36.190 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:36.190 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:36.190 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:36.314 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:36.314 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:36.314 | Historical data download ID 121578 not found when removing ID from outstanding request set.
2024-08-14 17:12:36.314 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:36.314 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:36.314 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:36.314 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:36.314 | Historical data download ID 121579 not found when removing ID from outstanding request set.
2024-08-14 17:12:36.314 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:36.314 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:36.314 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:36.354 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:36.357 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:36.357 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:36.357 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:36.357 | DTC Client socket (4) | Closed.
2024-08-14 17:12:36.357 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:36.358 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:36.358 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:36.358 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:38.349 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:38.349 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:38.350 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:38.350 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:38.350 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:38.391 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:38.391 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:38.392 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:38.392 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:38.514 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:38.514 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:38.514 | Historical data download ID 121580 not found when removing ID from outstanding request set.
2024-08-14 17:12:38.514 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:38.514 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:38.514 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:38.514 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:38.514 | Historical data download ID 121581 not found when removing ID from outstanding request set.
2024-08-14 17:12:38.514 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:38.514 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:38.514 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:38.556 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:38.556 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:38.556 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:38.556 | DTC Client socket (4) | Closed.
2024-08-14 17:12:38.556 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:38.557 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:38.557 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:38.557 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:40.122 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:40.122 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:12:40.135 | HD Server | Thread:14528 (4) | Creating socket.
2024-08-14 17:12:40.135 | HD Server | Thread:14528 (4) | New receive buffer size: 262144
2024-08-14 17:12:40.135 | HD Server | Thread:14528 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:40.135 | HD Server | Setting DTC encoding to Binary VLS | Thread:14528
2024-08-14 17:12:40.136 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:14528
2024-08-14 17:12:40.136 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:14528
2024-08-14 17:12:40.136 | HD Server | HD Request #4227 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4227 | Username: DAVID SUDDUTH JR. | Thread:14528
2024-08-14 17:12:40.137 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4227 | Username: DAVID SUDDUTH JR. | Thread:14528
2024-08-14 17:12:40.137 | HD Server | Thread:14528 (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:40.137 | HD Server | Thread:14528 (4) | CloseSocket call.
2024-08-14 17:12:40.138 | HD Server | Thread:14528 (0) | CloseSocket call.
2024-08-14 17:12:40.138 | HD Server | Thread:14528 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:40.138 | HD Server | Thread:14528 (4) | Closed.
2024-08-14 17:12:40.140 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:40.140 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:12:40.151 | HD Server | Thread:12228 (4) | Creating socket.
2024-08-14 17:12:40.151 | HD Server | Thread:12228 (4) | New receive buffer size: 262144
2024-08-14 17:12:40.151 | HD Server | Thread:12228 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:40.151 | HD Server | Setting DTC encoding to Binary VLS | Thread:12228
2024-08-14 17:12:40.152 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12228
2024-08-14 17:12:40.152 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12228
2024-08-14 17:12:40.152 | HD Server | HD Request #4228 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4228 | Username: DAVID SUDDUTH JR. | Thread:12228
2024-08-14 17:12:40.152 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4228 | Username: DAVID SUDDUTH JR. | Thread:12228
2024-08-14 17:12:40.153 | HD Server | Thread:12228 (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:40.153 | HD Server | Thread:12228 (4) | CloseSocket call.
2024-08-14 17:12:40.153 | HD Server | Thread:12228 (0) | CloseSocket call.
2024-08-14 17:12:40.153 | HD Server | Thread:12228 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:40.153 | HD Server | Thread:12228 (4) | Closed.
2024-08-14 17:12:40.328 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12228
2024-08-14 17:12:40.328 | HD Server Manager | Current server count=1
2024-08-14 17:12:40.328 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:14528
2024-08-14 17:12:40.329 | HD Server Manager | Current server count=0
2024-08-14 17:12:40.563 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:40.563 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:40.563 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:40.564 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:40.564 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:40.601 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:40.601 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:40.602 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:40.602 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:40.727 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:40.727 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:40.727 | Historical data download ID 121582 not found when removing ID from outstanding request set.
2024-08-14 17:12:40.727 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:40.727 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:40.727 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:40.727 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:40.727 | Historical data download ID 121583 not found when removing ID from outstanding request set.
2024-08-14 17:12:40.727 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:40.727 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:40.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:40.766 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:40.766 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:40.766 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:40.766 | DTC Client socket (4) | Closed.
2024-08-14 17:12:40.767 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:40.767 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:40.767 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:40.767 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:42.773 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:42.773 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:42.774 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:42.774 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:42.774 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:42.813 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:42.813 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:42.813 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:42.813 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:42.863 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:42.864 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:12:42.874 | HD Server | Thread:14472 (5) | Creating socket.
2024-08-14 17:12:42.874 | HD Server | Thread:14472 (5) | New receive buffer size: 262144
2024-08-14 17:12:42.874 | HD Server | Thread:14472 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:42.874 | HD Server | Setting DTC encoding to Binary VLS | Thread:14472
2024-08-14 17:12:42.875 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:14472
2024-08-14 17:12:42.875 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:14472
2024-08-14 17:12:42.875 | HD Server | HD Request #4229 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4229 | Username: DAVID SUDDUTH JR. | Thread:14472
2024-08-14 17:12:42.875 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4229 | Username: DAVID SUDDUTH JR. | Thread:14472
2024-08-14 17:12:42.876 | HD Server | Thread:14472 (5) | Socket gracefully closed by remote side.
2024-08-14 17:12:42.876 | HD Server | Thread:14472 (5) | CloseSocket call.
2024-08-14 17:12:42.876 | HD Server | Thread:14472 (0) | CloseSocket call.
2024-08-14 17:12:42.876 | HD Server | Thread:14472 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:42.876 | HD Server | Thread:14472 (5) | Closed.
2024-08-14 17:12:42.880 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:42.880 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:12:42.888 | HD Server | Thread:13460 (5) | Creating socket.
2024-08-14 17:12:42.888 | HD Server | Thread:13460 (5) | New receive buffer size: 262144
2024-08-14 17:12:42.889 | HD Server | Thread:13460 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:42.889 | HD Server | Setting DTC encoding to Binary VLS | Thread:13460
2024-08-14 17:12:42.889 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:13460
2024-08-14 17:12:42.889 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:13460
2024-08-14 17:12:42.889 | HD Server | HD Request #4230 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4230 | Username: DAVID SUDDUTH JR. | Thread:13460
2024-08-14 17:12:42.890 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4230 | Username: DAVID SUDDUTH JR. | Thread:13460
2024-08-14 17:12:42.890 | HD Server | Thread:13460 (5) | Socket gracefully closed by remote side.
2024-08-14 17:12:42.890 | HD Server | Thread:13460 (5) | CloseSocket call.
2024-08-14 17:12:42.890 | HD Server | Thread:13460 (0) | CloseSocket call.
2024-08-14 17:12:42.890 | HD Server | Thread:13460 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:42.890 | HD Server | Thread:13460 (5) | Closed.
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:42.939 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:42.939 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:42.939 | Historical data download ID 121584 not found when removing ID from outstanding request set.
2024-08-14 17:12:42.939 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:42.939 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:42.939 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:42.939 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:42.939 | Historical data download ID 121585 not found when removing ID from outstanding request set.
2024-08-14 17:12:42.939 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:42.939 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:42.939 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:42.950 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:42.951 | HD Server Manager | Started new historical data server. Count=3
2024-08-14 17:12:42.964 | HD Server | Thread:9948 (5) | Creating socket.
2024-08-14 17:12:42.964 | HD Server | Thread:9948 (5) | New receive buffer size: 262144
2024-08-14 17:12:42.964 | HD Server | Thread:9948 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:42.964 | HD Server | Setting DTC encoding to Binary VLS | Thread:9948
2024-08-14 17:12:42.965 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:9948
2024-08-14 17:12:42.965 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:9948
2024-08-14 17:12:42.965 | HD Server | HD Request #4231 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4231 | Username: DAVID SUDDUTH JR. | Thread:9948
2024-08-14 17:12:42.966 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4231 | Username: DAVID SUDDUTH JR. | Thread:9948
2024-08-14 17:12:42.966 | HD Server | Thread:9948 (5) | Socket gracefully closed by remote side.
2024-08-14 17:12:42.966 | HD Server | Thread:9948 (5) | CloseSocket call.
2024-08-14 17:12:42.966 | HD Server | Thread:9948 (0) | CloseSocket call.
2024-08-14 17:12:42.967 | HD Server | Thread:9948 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:42.967 | HD Server | Thread:9948 (5) | Closed.
2024-08-14 17:12:42.967 | HD Server | Thread:9948 (0) | CloseSocket call.
2024-08-14 17:12:42.972 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:12:42.972 | HD Server Manager | Started new historical data server. Count=4
2024-08-14 17:12:42.981 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:42.984 | HD Server | Thread:13132 (5) | Creating socket.
2024-08-14 17:12:42.984 | HD Server | Thread:13132 (5) | New receive buffer size: 262144
2024-08-14 17:12:42.984 | HD Server | Thread:13132 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:12:42.984 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:42.984 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:42.984 | DTC Client socket (4) | Closed.
2024-08-14 17:12:42.985 | HD Server | Setting DTC encoding to Binary VLS | Thread:13132
2024-08-14 17:12:42.985 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:42.985 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:42.985 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:42.985 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:13132
2024-08-14 17:12:42.985 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:13132
2024-08-14 17:12:42.985 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:42.986 | HD Server | HD Request #4232 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4232 | Username: DAVID SUDDUTH JR. | Thread:13132
2024-08-14 17:12:42.987 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4232 | Username: DAVID SUDDUTH JR. | Thread:13132
2024-08-14 17:12:42.987 | HD Server | Thread:13132 (5) | Socket gracefully closed by remote side.
2024-08-14 17:12:42.987 | HD Server | Thread:13132 (5) | CloseSocket call.
2024-08-14 17:12:42.987 | HD Server | Thread:13132 (0) | CloseSocket call.
2024-08-14 17:12:42.987 | HD Server | Thread:13132 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:42.987 | HD Server | Thread:13132 (5) | Closed.
2024-08-14 17:12:43.072 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:13132
2024-08-14 17:12:43.073 | HD Server Manager | Current server count=3
2024-08-14 17:12:43.073 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:9948
2024-08-14 17:12:43.073 | HD Server Manager | Current server count=2
2024-08-14 17:12:43.073 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:13460
2024-08-14 17:12:43.073 | HD Server Manager | Current server count=1
2024-08-14 17:12:43.073 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:14472
2024-08-14 17:12:43.073 | HD Server Manager | Current server count=0
2024-08-14 17:12:44.992 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:44.992 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:44.993 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:44.993 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:44.993 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:45.034 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:45.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:45.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:45.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:45.157 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:45.157 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:45.157 | Historical data download ID 121586 not found when removing ID from outstanding request set.
2024-08-14 17:12:45.157 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:45.157 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:45.157 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:45.157 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:45.157 | Historical data download ID 121587 not found when removing ID from outstanding request set.
2024-08-14 17:12:45.157 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:45.157 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:45.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:45.198 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:45.199 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:45.200 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:45.200 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:45.200 | DTC Client socket (4) | Closed.
2024-08-14 17:12:45.200 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:45.200 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:45.200 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:45.200 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:47.203 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:47.203 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:47.204 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:47.204 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:47.204 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:47.241 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:47.241 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:47.241 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:47.241 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:47.365 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:47.365 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:47.365 | Historical data download ID 121588 not found when removing ID from outstanding request set.
2024-08-14 17:12:47.365 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:47.365 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:47.365 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:47.365 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:47.365 | Historical data download ID 121589 not found when removing ID from outstanding request set.
2024-08-14 17:12:47.365 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:47.365 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:47.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:47.407 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:47.408 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:47.408 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:47.408 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:47.408 | DTC Client socket (4) | Closed.
2024-08-14 17:12:47.409 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:47.409 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:47.409 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:47.409 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:49.408 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:49.408 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:49.408 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:49.408 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:49.408 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:49.448 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:49.448 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:49.449 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:49.449 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:49.569 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:49.569 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:49.569 | Historical data download ID 121590 not found when removing ID from outstanding request set.
2024-08-14 17:12:49.569 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:49.569 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:49.569 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:49.569 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:49.569 | Historical data download ID 121591 not found when removing ID from outstanding request set.
2024-08-14 17:12:49.569 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:49.569 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:49.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:49.612 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:49.612 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:49.612 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:49.612 | DTC Client socket (4) | Closed.
2024-08-14 17:12:49.612 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:49.613 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:49.613 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:49.613 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:51.623 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:51.623 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:51.624 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:51.624 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:51.624 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:51.662 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:51.662 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:51.662 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:51.662 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:51.785 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:51.785 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:51.785 | Historical data download ID 121592 not found when removing ID from outstanding request set.
2024-08-14 17:12:51.785 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:51.785 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:51.785 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:51.785 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:51.785 | Historical data download ID 121593 not found when removing ID from outstanding request set.
2024-08-14 17:12:51.785 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:51.785 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:51.785 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:51.826 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:51.827 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:51.827 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:51.828 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:51.828 | DTC Client socket (4) | Closed.
2024-08-14 17:12:51.828 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:51.828 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:51.828 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:51.828 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:53.825 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:53.825 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:53.826 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:53.826 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:53.826 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:53.864 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:53.864 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:53.864 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:53.864 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:53.986 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:53.986 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:53.986 | Historical data download ID 121594 not found when removing ID from outstanding request set.
2024-08-14 17:12:53.986 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:53.986 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:53.986 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:53.986 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:53.986 | Historical data download ID 121595 not found when removing ID from outstanding request set.
2024-08-14 17:12:53.986 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:53.986 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:53.986 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:54.026 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:54.029 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:54.029 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:54.029 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:54.029 | DTC Client socket (4) | Closed.
2024-08-14 17:12:54.029 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:54.030 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:54.030 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:54.030 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:56.028 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:56.028 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:56.028 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:56.029 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:56.029 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:56.064 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:56.064 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:56.064 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:56.064 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:56.197 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:56.197 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:56.197 | Historical data download ID 121596 not found when removing ID from outstanding request set.
2024-08-14 17:12:56.197 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:56.197 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:56.197 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:56.197 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:56.197 | Historical data download ID 121597 not found when removing ID from outstanding request set.
2024-08-14 17:12:56.197 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:56.197 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:56.197 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:56.245 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:12:56.246 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:56.246 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:56.246 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:56.246 | DTC Client socket (4) | Closed.
2024-08-14 17:12:56.246 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:56.247 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:56.247 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:56.247 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:12:58.246 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:12:58.246 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:12:58.246 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:12:58.246 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:12:58.246 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:12:58.285 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:12:58.285 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:12:58.286 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:12:58.286 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:12:58.410 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:12:58.410 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:12:58.410 | Historical data download ID 121598 not found when removing ID from outstanding request set.
2024-08-14 17:12:58.410 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:12:58.410 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:12:58.410 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:12:58.410 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:12:58.410 | Historical data download ID 121599 not found when removing ID from outstanding request set.
2024-08-14 17:12:58.410 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:12:58.410 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:12:58.410 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:12:58.448 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:12:58.448 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:12:58.449 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:12:58.449 | DTC Client socket (4) | Closed.
2024-08-14 17:12:58.449 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:12:58.449 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:12:58.449 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:12:58.449 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:00.452 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:00.452 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:00.453 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:00.453 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:00.453 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:00.491 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:00.491 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:00.491 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:00.491 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:00.614 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:00.614 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:00.614 | Historical data download ID 121600 not found when removing ID from outstanding request set.
2024-08-14 17:13:00.614 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:00.614 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:00.614 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:00.614 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:00.614 | Historical data download ID 121601 not found when removing ID from outstanding request set.
2024-08-14 17:13:00.614 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:00.614 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:00.614 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:00.655 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:00.657 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:00.657 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:00.657 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:00.657 | DTC Client socket (4) | Closed.
2024-08-14 17:13:00.657 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:00.658 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:00.658 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:00.658 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:02.670 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:02.670 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:02.671 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:02.671 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:02.671 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:02.710 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:02.710 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:02.710 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:02.711 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:02.829 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:02.829 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:02.829 | Historical data download ID 121602 not found when removing ID from outstanding request set.
2024-08-14 17:13:02.829 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:02.829 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:02.829 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:02.829 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:02.829 | Historical data download ID 121603 not found when removing ID from outstanding request set.
2024-08-14 17:13:02.829 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:02.829 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:02.829 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:02.874 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:02.875 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:02.875 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:02.875 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:02.875 | DTC Client socket (4) | Closed.
2024-08-14 17:13:02.875 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:02.876 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:02.876 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:02.876 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:04.877 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:04.877 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:04.877 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:04.878 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:04.878 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:04.916 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:04.916 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:04.916 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:04.916 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:05.037 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:05.037 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:05.037 | Historical data download ID 121604 not found when removing ID from outstanding request set.
2024-08-14 17:13:05.037 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:05.037 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:05.037 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:05.037 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:05.037 | Historical data download ID 121605 not found when removing ID from outstanding request set.
2024-08-14 17:13:05.037 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:05.037 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:05.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:05.079 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:05.079 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:05.079 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:05.079 | DTC Client socket (4) | Closed.
2024-08-14 17:13:05.080 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:05.080 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:05.080 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:05.080 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:07.083 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:07.083 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:07.083 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:07.083 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:07.083 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:07.125 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:07.125 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:07.125 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:07.125 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:07.251 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:07.251 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:07.251 | Historical data download ID 121606 not found when removing ID from outstanding request set.
2024-08-14 17:13:07.251 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:07.251 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:07.251 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:07.251 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:07.251 | Historical data download ID 121607 not found when removing ID from outstanding request set.
2024-08-14 17:13:07.251 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:07.251 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:07.251 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:07.292 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:07.292 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:07.293 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:07.293 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:07.293 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:07.293 | DTC Client socket (4) | Closed.
2024-08-14 17:13:07.293 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:07.293 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:07.293 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:07.293 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:09.291 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:09.291 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:09.292 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:09.292 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:09.292 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:09.330 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:09.330 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:09.330 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:09.330 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:09.452 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:09.452 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:09.452 | Historical data download ID 121608 not found when removing ID from outstanding request set.
2024-08-14 17:13:09.452 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:09.452 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:09.452 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:09.452 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:09.452 | Historical data download ID 121609 not found when removing ID from outstanding request set.
2024-08-14 17:13:09.452 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:09.452 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:09.452 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:09.493 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:09.494 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:09.494 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:09.494 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:09.494 | DTC Client socket (4) | Closed.
2024-08-14 17:13:09.494 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:09.495 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:09.495 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:09.495 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:10.114 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:10.114 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:13:10.128 | HD Server | Thread:14704 (4) | Creating socket.
2024-08-14 17:13:10.128 | HD Server | Thread:14704 (4) | New receive buffer size: 262144
2024-08-14 17:13:10.128 | HD Server | Thread:14704 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:10.128 | HD Server | Setting DTC encoding to Binary VLS | Thread:14704
2024-08-14 17:13:10.128 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:14704
2024-08-14 17:13:10.128 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:14704
2024-08-14 17:13:10.129 | HD Server | HD Request #4233 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4233 | Username: DAVID SUDDUTH JR. | Thread:14704
2024-08-14 17:13:10.130 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4233 | Username: DAVID SUDDUTH JR. | Thread:14704
2024-08-14 17:13:10.131 | HD Server | Thread:14704 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:10.131 | HD Server | Thread:14704 (4) | CloseSocket call.
2024-08-14 17:13:10.132 | HD Server | Thread:14704 (0) | CloseSocket call.
2024-08-14 17:13:10.132 | HD Server | Thread:14704 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:10.132 | HD Server | Thread:14704 (4) | Closed.
2024-08-14 17:13:10.150 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:10.150 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:13:10.159 | HD Server | Thread:15400 (4) | Creating socket.
2024-08-14 17:13:10.159 | HD Server | Thread:15400 (4) | New receive buffer size: 262144
2024-08-14 17:13:10.159 | HD Server | Thread:15400 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:10.159 | HD Server | Setting DTC encoding to Binary VLS | Thread:15400
2024-08-14 17:13:10.159 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15400
2024-08-14 17:13:10.159 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15400
2024-08-14 17:13:10.161 | HD Server | HD Request #4234 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4234 | Username: DAVID SUDDUTH JR. | Thread:15400
2024-08-14 17:13:10.162 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4234 | Username: DAVID SUDDUTH JR. | Thread:15400
2024-08-14 17:13:10.162 | HD Server | Thread:15400 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:10.163 | HD Server | Thread:15400 (4) | CloseSocket call.
2024-08-14 17:13:10.164 | HD Server | Thread:15400 (0) | CloseSocket call.
2024-08-14 17:13:10.164 | HD Server | Thread:15400 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:10.164 | HD Server | Thread:15400 (4) | Closed.
2024-08-14 17:13:10.350 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15400
2024-08-14 17:13:10.351 | HD Server Manager | Current server count=1
2024-08-14 17:13:10.351 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:14704
2024-08-14 17:13:10.351 | HD Server Manager | Current server count=0
2024-08-14 17:13:11.490 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:11.490 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:11.491 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:11.491 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:11.491 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:11.530 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:11.530 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:11.530 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:11.530 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:11.655 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:11.655 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:11.655 | Historical data download ID 121610 not found when removing ID from outstanding request set.
2024-08-14 17:13:11.655 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:11.655 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:11.655 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:11.655 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:11.655 | Historical data download ID 121611 not found when removing ID from outstanding request set.
2024-08-14 17:13:11.655 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:11.655 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:11.655 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:11.698 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:11.698 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:11.698 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:11.698 | DTC Client socket (4) | Closed.
2024-08-14 17:13:11.698 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:11.698 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:11.698 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:11.698 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:12.957 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:12.957 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:13:12.969 | HD Server | Thread:15648 (4) | Creating socket.
2024-08-14 17:13:12.969 | HD Server | Thread:15648 (4) | New receive buffer size: 262144
2024-08-14 17:13:12.969 | HD Server | Thread:15648 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:12.970 | HD Server | Setting DTC encoding to Binary VLS | Thread:15648
2024-08-14 17:13:12.970 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15648
2024-08-14 17:13:12.970 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15648
2024-08-14 17:13:12.970 | HD Server | HD Request #4235 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4235 | Username: DAVID SUDDUTH JR. | Thread:15648
2024-08-14 17:13:12.970 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4235 | Username: DAVID SUDDUTH JR. | Thread:15648
2024-08-14 17:13:12.971 | HD Server | Thread:15648 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:12.971 | HD Server | Thread:15648 (4) | CloseSocket call.
2024-08-14 17:13:12.971 | HD Server | Thread:15648 (0) | CloseSocket call.
2024-08-14 17:13:12.971 | HD Server | Thread:15648 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:12.971 | HD Server | Thread:15648 (4) | Closed.
2024-08-14 17:13:12.977 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:12.978 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:13:12.988 | HD Server | Thread:3256 (4) | Creating socket.
2024-08-14 17:13:12.988 | HD Server | Thread:3256 (4) | New receive buffer size: 262144
2024-08-14 17:13:12.988 | HD Server | Thread:3256 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:12.988 | HD Server | Setting DTC encoding to Binary VLS | Thread:3256
2024-08-14 17:13:12.989 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:3256
2024-08-14 17:13:12.989 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:3256
2024-08-14 17:13:12.989 | HD Server | HD Request #4236 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4236 | Username: DAVID SUDDUTH JR. | Thread:3256
2024-08-14 17:13:12.990 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4236 | Username: DAVID SUDDUTH JR. | Thread:3256
2024-08-14 17:13:12.991 | HD Server | Thread:3256 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:12.991 | HD Server | Thread:3256 (4) | CloseSocket call.
2024-08-14 17:13:12.991 | HD Server | Thread:3256 (0) | CloseSocket call.
2024-08-14 17:13:12.991 | HD Server | Thread:3256 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:12.991 | HD Server | Thread:3256 (4) | Closed.
2024-08-14 17:13:13.097 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:3256
2024-08-14 17:13:13.097 | HD Server Manager | Current server count=1
2024-08-14 17:13:13.097 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15648
2024-08-14 17:13:13.097 | HD Server Manager | Current server count=0
2024-08-14 17:13:13.699 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:13.699 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:13.700 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:13.700 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:13.700 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:13.738 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:13.738 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:13.738 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:13.738 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:13.867 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:13.867 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:13.867 | Historical data download ID 121612 not found when removing ID from outstanding request set.
2024-08-14 17:13:13.867 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:13.867 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:13.867 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:13.867 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:13.867 | Historical data download ID 121613 not found when removing ID from outstanding request set.
2024-08-14 17:13:13.867 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:13.867 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:13.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:13.911 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:13.911 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:13.911 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:13.911 | DTC Client socket (4) | Closed.
2024-08-14 17:13:13.911 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:13.911 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:13.911 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:13.911 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:15.912 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:15.912 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:15.912 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:15.913 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:15.913 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:15.951 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:15.951 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:15.951 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:15.951 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:16.073 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:16.073 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:16.073 | Historical data download ID 121614 not found when removing ID from outstanding request set.
2024-08-14 17:13:16.073 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:16.073 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:16.073 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:16.073 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:16.073 | Historical data download ID 121615 not found when removing ID from outstanding request set.
2024-08-14 17:13:16.073 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:16.073 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:16.073 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:16.114 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:16.114 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:16.114 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:16.114 | DTC Client socket (4) | Closed.
2024-08-14 17:13:16.114 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:16.114 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:16.114 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:16.114 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:18.121 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:18.121 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:18.121 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:18.121 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:18.121 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:18.160 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:18.160 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:18.160 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:18.160 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:18.288 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:18.288 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:18.288 | Historical data download ID 121616 not found when removing ID from outstanding request set.
2024-08-14 17:13:18.288 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:18.288 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:18.288 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:18.288 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:18.288 | Historical data download ID 121617 not found when removing ID from outstanding request set.
2024-08-14 17:13:18.288 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:18.288 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:18.288 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:18.329 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:18.330 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:18.330 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:18.330 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:18.330 | DTC Client socket (4) | Closed.
2024-08-14 17:13:18.331 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:18.331 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:18.331 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:18.331 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:20.340 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:20.340 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:20.341 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:20.341 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:20.341 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:20.379 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:20.379 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:20.380 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:20.380 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:20.503 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:20.503 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:20.503 | Historical data download ID 121618 not found when removing ID from outstanding request set.
2024-08-14 17:13:20.503 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:20.503 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:20.503 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:20.503 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:20.503 | Historical data download ID 121619 not found when removing ID from outstanding request set.
2024-08-14 17:13:20.503 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:20.503 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:20.503 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:20.545 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:20.545 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:20.545 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:20.545 | DTC Client socket (4) | Closed.
2024-08-14 17:13:20.546 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:20.546 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:20.546 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:20.546 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:22.539 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:22.539 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:22.540 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:22.540 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:22.540 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:22.579 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:22.579 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:22.579 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:22.579 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:22.702 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:22.702 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:22.702 | Historical data download ID 121620 not found when removing ID from outstanding request set.
2024-08-14 17:13:22.702 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:22.702 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:22.702 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:22.702 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:22.702 | Historical data download ID 121621 not found when removing ID from outstanding request set.
2024-08-14 17:13:22.702 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:22.702 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:22.702 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:22.743 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:22.744 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:22.744 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:22.744 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:22.744 | DTC Client socket (4) | Closed.
2024-08-14 17:13:22.745 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:22.745 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:22.745 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:22.745 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:24.756 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:24.756 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:24.757 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:24.757 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:24.757 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:24.796 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:24.796 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:24.797 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:24.797 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:24.923 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:24.923 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:24.923 | Historical data download ID 121622 not found when removing ID from outstanding request set.
2024-08-14 17:13:24.923 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:24.923 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:24.923 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:24.923 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:24.923 | Historical data download ID 121623 not found when removing ID from outstanding request set.
2024-08-14 17:13:24.923 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:24.923 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:24.923 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:24.966 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:24.966 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:24.966 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:24.966 | DTC Client socket (4) | Closed.
2024-08-14 17:13:24.966 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:24.966 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:24.966 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:24.966 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:26.961 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:26.961 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:26.961 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:26.962 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:26.962 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:27.001 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:27.001 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:27.001 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:27.001 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:27.123 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:27.123 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:27.123 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:27.123 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:27.123 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:27.123 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:27.123 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:27.123 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:27.123 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:27.124 | Historical data download ID 121624 not found when removing ID from outstanding request set.
2024-08-14 17:13:27.124 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:27.124 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:27.124 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:27.124 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:27.124 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:27.124 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:27.124 | Historical data download ID 121625 not found when removing ID from outstanding request set.
2024-08-14 17:13:27.124 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:27.124 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:27.124 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:27.168 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:27.168 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:27.168 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:27.168 | DTC Client socket (4) | Closed.
2024-08-14 17:13:27.168 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:27.169 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:27.169 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:27.169 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:29.165 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:29.165 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:29.205 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:29.205 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:29.205 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:29.244 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:29.244 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:29.244 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:29.244 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:29.363 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:29.363 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:29.363 | Historical data download ID 121626 not found when removing ID from outstanding request set.
2024-08-14 17:13:29.363 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:29.363 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:29.363 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:29.363 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:29.363 | Historical data download ID 121627 not found when removing ID from outstanding request set.
2024-08-14 17:13:29.363 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:29.363 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:29.363 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:29.403 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:29.404 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:29.405 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:29.405 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:29.405 | DTC Client socket (4) | Closed.
2024-08-14 17:13:29.405 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:29.405 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:29.405 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:29.405 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:31.398 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:31.398 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:31.504 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:31.504 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:31.504 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:31.542 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:31.542 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:31.542 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:31.542 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:31.665 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:31.665 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:31.665 | Historical data download ID 121628 not found when removing ID from outstanding request set.
2024-08-14 17:13:31.665 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:31.665 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:31.665 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:31.665 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:31.665 | Historical data download ID 121629 not found when removing ID from outstanding request set.
2024-08-14 17:13:31.665 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:31.665 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:31.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:31.710 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:31.710 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:31.710 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:31.710 | DTC Client socket (4) | Closed.
2024-08-14 17:13:31.710 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:31.711 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:31.711 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:31.711 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:33.718 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:33.718 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:33.718 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:33.719 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:33.719 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:33.758 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:33.758 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:33.758 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:33.758 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:33.884 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:33.884 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:33.884 | Historical data download ID 121630 not found when removing ID from outstanding request set.
2024-08-14 17:13:33.884 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:33.884 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:33.884 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:33.884 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:33.884 | Historical data download ID 121631 not found when removing ID from outstanding request set.
2024-08-14 17:13:33.884 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:33.884 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:33.884 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:33.926 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:33.927 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:33.927 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:33.927 | DTC Client socket (4) | Closed.
2024-08-14 17:13:33.927 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:33.927 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:33.927 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:33.927 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:35.928 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:35.928 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:35.928 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:35.928 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:35.928 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:35.967 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:35.967 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:35.967 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:35.967 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:36.095 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:36.095 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:36.095 | Historical data download ID 121632 not found when removing ID from outstanding request set.
2024-08-14 17:13:36.095 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:36.095 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:36.095 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:36.095 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:36.095 | Historical data download ID 121633 not found when removing ID from outstanding request set.
2024-08-14 17:13:36.095 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:36.095 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:36.095 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:36.137 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:36.137 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:36.137 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:36.137 | DTC Client socket (4) | Closed.
2024-08-14 17:13:36.137 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:36.138 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:36.138 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:36.138 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:38.130 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:38.130 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:38.131 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:38.131 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:38.131 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:38.169 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:38.169 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:38.169 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:38.169 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:38.293 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:38.293 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:38.293 | Historical data download ID 121634 not found when removing ID from outstanding request set.
2024-08-14 17:13:38.293 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:38.293 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:38.293 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:38.293 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:38.293 | Historical data download ID 121635 not found when removing ID from outstanding request set.
2024-08-14 17:13:38.293 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:38.293 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:38.293 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:38.331 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:38.331 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:38.331 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:13:38.331 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:38.332 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:38.332 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:38.332 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:38.588 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:13:38.588 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:38.588 | DTC Client socket (4) | Closed.
2024-08-14 17:13:40.335 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:40.335 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:40.336 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:40.336 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:40.336 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:40.375 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:40.375 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:40.375 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:40.375 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:40.497 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:40.497 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:40.497 | Historical data download ID 121636 not found when removing ID from outstanding request set.
2024-08-14 17:13:40.497 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:40.497 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:40.497 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:40.497 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:40.497 | Historical data download ID 121637 not found when removing ID from outstanding request set.
2024-08-14 17:13:40.497 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:40.497 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:40.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:40.540 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:40.540 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:40.540 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:40.540 | DTC Client socket (4) | Closed.
2024-08-14 17:13:40.540 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:40.541 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:40.541 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:40.541 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:40.955 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:40.956 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:13:40.971 | HD Server | Thread:10752 (4) | Creating socket.
2024-08-14 17:13:40.971 | HD Server | Thread:10752 (4) | New receive buffer size: 262144
2024-08-14 17:13:40.971 | HD Server | Thread:10752 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:40.971 | HD Server | Setting DTC encoding to Binary VLS | Thread:10752
2024-08-14 17:13:40.972 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10752
2024-08-14 17:13:40.972 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10752
2024-08-14 17:13:40.972 | HD Server | HD Request #4237 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4237 | Username: DAVID SUDDUTH JR. | Thread:10752
2024-08-14 17:13:40.973 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4237 | Username: DAVID SUDDUTH JR. | Thread:10752
2024-08-14 17:13:40.974 | HD Server | Thread:10752 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:40.974 | HD Server | Thread:10752 (4) | CloseSocket call.
2024-08-14 17:13:40.975 | HD Server | Thread:10752 (0) | CloseSocket call.
2024-08-14 17:13:40.975 | HD Server | Thread:10752 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:40.975 | HD Server | Thread:10752 (4) | Closed.
2024-08-14 17:13:41.148 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:41.149 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:13:41.160 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10752
2024-08-14 17:13:41.162 | HD Server Manager | Current server count=1
2024-08-14 17:13:41.165 | HD Server | Thread:2392 (4) | Creating socket.
2024-08-14 17:13:41.165 | HD Server | Thread:2392 (4) | New receive buffer size: 262144
2024-08-14 17:13:41.165 | HD Server | Thread:2392 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:41.165 | HD Server | Setting DTC encoding to Binary VLS | Thread:2392
2024-08-14 17:13:41.165 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:2392
2024-08-14 17:13:41.165 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:2392
2024-08-14 17:13:41.165 | HD Server | HD Request #4238 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4238 | Username: DAVID SUDDUTH JR. | Thread:2392
2024-08-14 17:13:41.166 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4238 | Username: DAVID SUDDUTH JR. | Thread:2392
2024-08-14 17:13:41.167 | HD Server | Thread:2392 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:41.167 | HD Server | Thread:2392 (4) | CloseSocket call.
2024-08-14 17:13:41.167 | HD Server | Thread:2392 (0) | CloseSocket call.
2024-08-14 17:13:41.167 | HD Server | Thread:2392 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:41.167 | HD Server | Thread:2392 (4) | Closed.
2024-08-14 17:13:41.393 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:2392
2024-08-14 17:13:41.394 | HD Server Manager | Current server count=0
2024-08-14 17:13:42.534 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:42.534 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:42.535 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:42.535 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:42.535 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:42.578 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:42.578 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:42.578 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:42.578 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:42.701 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:42.701 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:42.701 | Historical data download ID 121638 not found when removing ID from outstanding request set.
2024-08-14 17:13:42.701 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:42.701 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:42.701 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:42.701 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:42.701 | Historical data download ID 121639 not found when removing ID from outstanding request set.
2024-08-14 17:13:42.701 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:42.701 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:42.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:42.748 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:42.748 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:42.748 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:42.748 | DTC Client socket (4) | Closed.
2024-08-14 17:13:42.748 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:42.748 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:42.748 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:42.749 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:43.968 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:43.969 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:13:43.981 | HD Server | Thread:10296 (4) | Creating socket.
2024-08-14 17:13:43.981 | HD Server | Thread:10296 (4) | New receive buffer size: 262144
2024-08-14 17:13:43.982 | HD Server | Thread:10296 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:43.982 | HD Server | Setting DTC encoding to Binary VLS | Thread:10296
2024-08-14 17:13:43.982 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10296
2024-08-14 17:13:43.982 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10296
2024-08-14 17:13:43.983 | HD Server | HD Request #4239 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4239 | Username: DAVID SUDDUTH JR. | Thread:10296
2024-08-14 17:13:43.983 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4239 | Username: DAVID SUDDUTH JR. | Thread:10296
2024-08-14 17:13:43.984 | HD Server | Thread:10296 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:43.984 | HD Server | Thread:10296 (4) | CloseSocket call.
2024-08-14 17:13:43.984 | HD Server | Thread:10296 (0) | CloseSocket call.
2024-08-14 17:13:43.984 | HD Server | Thread:10296 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:43.984 | HD Server | Thread:10296 (4) | Closed.
2024-08-14 17:13:43.987 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:13:43.987 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:13:44.000 | HD Server | Thread:10756 (4) | Creating socket.
2024-08-14 17:13:44.000 | HD Server | Thread:10756 (4) | New receive buffer size: 262144
2024-08-14 17:13:44.000 | HD Server | Thread:10756 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:13:44.000 | HD Server | Setting DTC encoding to Binary VLS | Thread:10756
2024-08-14 17:13:44.001 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10756
2024-08-14 17:13:44.001 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10756
2024-08-14 17:13:44.001 | HD Server | HD Request #4240 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4240 | Username: DAVID SUDDUTH JR. | Thread:10756
2024-08-14 17:13:44.002 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4240 | Username: DAVID SUDDUTH JR. | Thread:10756
2024-08-14 17:13:44.002 | HD Server | Thread:10756 (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:44.002 | HD Server | Thread:10756 (4) | CloseSocket call.
2024-08-14 17:13:44.002 | HD Server | Thread:10756 (0) | CloseSocket call.
2024-08-14 17:13:44.002 | HD Server | Thread:10756 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:44.002 | HD Server | Thread:10756 (4) | Closed.
2024-08-14 17:13:44.003 | HD Server | Thread:10756 (0) | CloseSocket call.
2024-08-14 17:13:44.181 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10756
2024-08-14 17:13:44.182 | HD Server Manager | Current server count=1
2024-08-14 17:13:44.182 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10296
2024-08-14 17:13:44.182 | HD Server Manager | Current server count=0
2024-08-14 17:13:44.751 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:44.751 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:44.751 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:44.752 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:44.752 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:44.790 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:44.790 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:44.790 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:44.790 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:44.912 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:44.912 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:44.912 | Historical data download ID 121640 not found when removing ID from outstanding request set.
2024-08-14 17:13:44.912 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:44.912 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:44.912 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:44.912 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:44.912 | Historical data download ID 121641 not found when removing ID from outstanding request set.
2024-08-14 17:13:44.912 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:44.912 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:44.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:44.955 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:44.955 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:44.955 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:44.955 | DTC Client socket (4) | Closed.
2024-08-14 17:13:44.955 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:44.956 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:44.956 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:44.956 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:46.957 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:46.957 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:46.957 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:46.957 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:46.957 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:46.995 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:46.995 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:46.995 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:46.995 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:47.118 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:47.118 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:47.118 | Historical data download ID 121642 not found when removing ID from outstanding request set.
2024-08-14 17:13:47.118 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:47.118 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:47.118 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:47.118 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:47.118 | Historical data download ID 121643 not found when removing ID from outstanding request set.
2024-08-14 17:13:47.118 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:47.118 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:47.118 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:47.157 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:47.157 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:47.157 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:47.157 | DTC Client socket (4) | Closed.
2024-08-14 17:13:47.157 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:47.157 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:47.157 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:47.157 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:49.169 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:49.169 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:49.170 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:49.170 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:49.170 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:49.211 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:49.211 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:49.211 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:49.211 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:49.338 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:49.338 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:49.338 | Historical data download ID 121644 not found when removing ID from outstanding request set.
2024-08-14 17:13:49.338 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:49.338 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:49.338 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:49.338 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:49.338 | Historical data download ID 121645 not found when removing ID from outstanding request set.
2024-08-14 17:13:49.338 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:49.338 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:49.338 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:49.378 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:49.380 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:49.380 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:49.380 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:49.380 | DTC Client socket (4) | Closed.
2024-08-14 17:13:49.380 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:49.381 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:49.381 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:49.381 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:51.377 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:51.377 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:51.378 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:51.378 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:51.378 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:51.416 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:51.416 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:51.416 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:51.416 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:51.539 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:51.539 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:51.539 | Historical data download ID 121646 not found when removing ID from outstanding request set.
2024-08-14 17:13:51.539 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:51.539 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:51.539 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:51.539 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:51.539 | Historical data download ID 121647 not found when removing ID from outstanding request set.
2024-08-14 17:13:51.539 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:51.539 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:51.539 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:51.579 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:51.582 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:51.582 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:51.582 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:51.582 | DTC Client socket (4) | Closed.
2024-08-14 17:13:51.582 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:51.583 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:51.583 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:51.583 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:53.587 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:53.587 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:53.587 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:53.588 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:53.588 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:53.626 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:53.626 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:53.626 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:53.626 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:53.745 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:53.745 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:53.745 | Historical data download ID 121648 not found when removing ID from outstanding request set.
2024-08-14 17:13:53.745 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:53.745 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:53.745 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:53.745 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:53.745 | Historical data download ID 121649 not found when removing ID from outstanding request set.
2024-08-14 17:13:53.745 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:53.745 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:53.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:53.788 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:53.788 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:53.788 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:53.788 | DTC Client socket (4) | Closed.
2024-08-14 17:13:53.788 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:53.789 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:53.789 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:53.789 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:55.783 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:55.783 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:55.783 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:55.784 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:55.784 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:55.821 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:55.821 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:55.821 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:55.821 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:55.943 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:55.943 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:55.943 | Historical data download ID 121650 not found when removing ID from outstanding request set.
2024-08-14 17:13:55.943 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:55.943 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:55.943 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:55.943 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:55.943 | Historical data download ID 121651 not found when removing ID from outstanding request set.
2024-08-14 17:13:55.943 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:55.943 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:55.943 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:55.984 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:13:55.985 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:55.985 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:55.985 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:55.985 | DTC Client socket (4) | Closed.
2024-08-14 17:13:55.986 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:55.986 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:55.986 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:55.986 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:13:57.995 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:13:57.995 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:13:57.996 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:13:57.996 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:13:57.996 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:13:58.034 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:13:58.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:13:58.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:13:58.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:13:58.155 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:13:58.155 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:13:58.155 | Historical data download ID 121652 not found when removing ID from outstanding request set.
2024-08-14 17:13:58.155 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:13:58.155 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:13:58.155 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:13:58.155 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:13:58.155 | Historical data download ID 121653 not found when removing ID from outstanding request set.
2024-08-14 17:13:58.155 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:13:58.155 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:13:58.155 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:13:58.197 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:13:58.197 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:13:58.197 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:13:58.197 | DTC Client socket (4) | Closed.
2024-08-14 17:13:58.198 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:13:58.198 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:13:58.198 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:13:58.198 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:00.189 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:00.189 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:00.190 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:00.190 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:00.190 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:00.224 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:00.224 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:00.224 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:00.224 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:00.346 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:00.346 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:00.346 | Historical data download ID 121654 not found when removing ID from outstanding request set.
2024-08-14 17:14:00.346 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:00.346 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:00.346 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:00.346 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:00.346 | Historical data download ID 121655 not found when removing ID from outstanding request set.
2024-08-14 17:14:00.346 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:00.346 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:00.346 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:00.386 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:00.386 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:00.386 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:00.386 | DTC Client socket (4) | Closed.
2024-08-14 17:14:00.386 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:00.386 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:00.387 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:00.387 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:02.378 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:02.378 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:02.379 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:02.379 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:02.379 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:02.417 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:02.417 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:02.417 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:02.417 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:02.542 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:02.542 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:02.542 | Historical data download ID 121656 not found when removing ID from outstanding request set.
2024-08-14 17:14:02.542 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:02.542 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:02.542 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:02.542 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:02.542 | Historical data download ID 121657 not found when removing ID from outstanding request set.
2024-08-14 17:14:02.542 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:02.542 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:02.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:02.583 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:02.584 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:02.584 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:02.584 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:02.584 | DTC Client socket (4) | Closed.
2024-08-14 17:14:02.584 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:02.585 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:02.585 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:02.585 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:04.589 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:04.589 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:04.589 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:04.589 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:04.589 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:04.627 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:04.627 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:04.627 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:04.627 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:04.751 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:04.751 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:04.751 | Historical data download ID 121658 not found when removing ID from outstanding request set.
2024-08-14 17:14:04.751 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:04.751 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:04.751 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:04.751 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:04.751 | Historical data download ID 121659 not found when removing ID from outstanding request set.
2024-08-14 17:14:04.751 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:04.751 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:04.751 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:04.795 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:04.795 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:04.795 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:04.795 | DTC Client socket (4) | Closed.
2024-08-14 17:14:04.795 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:04.796 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:04.796 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:04.796 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:06.796 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:06.796 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:06.797 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:06.797 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:06.797 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:06.836 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:06.836 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:06.836 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:06.836 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:06.962 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:06.962 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:06.962 | Historical data download ID 121660 not found when removing ID from outstanding request set.
2024-08-14 17:14:06.962 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:06.962 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:06.962 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:06.962 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:06.962 | Historical data download ID 121661 not found when removing ID from outstanding request set.
2024-08-14 17:14:06.962 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:06.962 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:06.962 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:07.001 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:07.001 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:07.001 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:07.001 | DTC Client socket (4) | Closed.
2024-08-14 17:14:07.001 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:07.001 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:07.001 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:07.001 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:09.007 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:09.007 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:09.008 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:09.008 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:09.008 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:09.046 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:09.046 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:09.046 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:09.046 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:09.167 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:09.167 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:09.167 | Historical data download ID 121662 not found when removing ID from outstanding request set.
2024-08-14 17:14:09.167 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:09.167 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:09.167 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:09.167 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:09.167 | Historical data download ID 121663 not found when removing ID from outstanding request set.
2024-08-14 17:14:09.167 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:09.167 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:09.167 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:09.211 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:09.211 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:09.211 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:14:09.211 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:14:09.211 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:14:09.211 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:09.212 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:09.212 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:09.212 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:09.253 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:14:09.253 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:09.253 | DTC Client socket (4) | Closed.
2024-08-14 17:14:11.217 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:11.217 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:11.218 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:11.218 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:11.218 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:11.262 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:11.262 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:11.262 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:11.262 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:11.321 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:11.322 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:14:11.338 | HD Server | Thread:10716 (5) | Creating socket.
2024-08-14 17:14:11.338 | HD Server | Thread:10716 (5) | New receive buffer size: 262144
2024-08-14 17:14:11.338 | HD Server | Thread:10716 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:11.338 | HD Server | Setting DTC encoding to Binary VLS | Thread:10716
2024-08-14 17:14:11.339 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10716
2024-08-14 17:14:11.339 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10716
2024-08-14 17:14:11.340 | HD Server | HD Request #4241 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4241 | Username: DAVID SUDDUTH JR. | Thread:10716
2024-08-14 17:14:11.341 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4241 | Username: DAVID SUDDUTH JR. | Thread:10716
2024-08-14 17:14:11.341 | HD Server | Thread:10716 (5) | Socket gracefully closed by remote side.
2024-08-14 17:14:11.341 | HD Server | Thread:10716 (5) | CloseSocket call.
2024-08-14 17:14:11.342 | HD Server | Thread:10716 (0) | CloseSocket call.
2024-08-14 17:14:11.342 | HD Server | Thread:10716 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:11.342 | HD Server | Thread:10716 (5) | Closed.
2024-08-14 17:14:11.351 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:11.351 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:14:11.359 | HD Server | Thread:2540 (5) | Creating socket.
2024-08-14 17:14:11.359 | HD Server | Thread:2540 (5) | New receive buffer size: 262144
2024-08-14 17:14:11.359 | HD Server | Thread:2540 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:11.359 | HD Server | Setting DTC encoding to Binary VLS | Thread:2540
2024-08-14 17:14:11.359 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:2540
2024-08-14 17:14:11.359 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:2540
2024-08-14 17:14:11.360 | HD Server | HD Request #4242 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4242 | Username: DAVID SUDDUTH JR. | Thread:2540
2024-08-14 17:14:11.360 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4242 | Username: DAVID SUDDUTH JR. | Thread:2540
2024-08-14 17:14:11.361 | HD Server | Thread:2540 (5) | Socket gracefully closed by remote side.
2024-08-14 17:14:11.361 | HD Server | Thread:2540 (5) | CloseSocket call.
2024-08-14 17:14:11.361 | HD Server | Thread:2540 (0) | CloseSocket call.
2024-08-14 17:14:11.361 | HD Server | Thread:2540 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:11.361 | HD Server | Thread:2540 (5) | Closed.
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:11.388 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:11.388 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:11.388 | Historical data download ID 121664 not found when removing ID from outstanding request set.
2024-08-14 17:14:11.388 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:11.388 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:11.388 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:11.388 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:11.388 | Historical data download ID 121665 not found when removing ID from outstanding request set.
2024-08-14 17:14:11.388 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:11.388 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:11.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:11.426 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:11.426 | HD Server Manager | Started new historical data server. Count=3
2024-08-14 17:14:11.430 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:11.431 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:11.432 | HD Server | Thread:10660 (5) | Creating socket.
2024-08-14 17:14:11.432 | HD Server | Thread:10660 (5) | New receive buffer size: 262144
2024-08-14 17:14:11.432 | HD Server | Thread:10660 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:11.432 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:11.432 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:11.432 | DTC Client socket (4) | Closed.
2024-08-14 17:14:11.432 | HD Server | Setting DTC encoding to Binary VLS | Thread:10660
2024-08-14 17:14:11.433 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:11.433 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:11.433 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:11.433 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:11.433 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10660
2024-08-14 17:14:11.433 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10660
2024-08-14 17:14:11.433 | HD Server | HD Request #4243 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4243 | Username: DAVID SUDDUTH JR. | Thread:10660
2024-08-14 17:14:11.434 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4243 | Username: DAVID SUDDUTH JR. | Thread:10660
2024-08-14 17:14:11.434 | HD Server | Thread:10660 (5) | Socket gracefully closed by remote side.
2024-08-14 17:14:11.434 | HD Server | Thread:10660 (5) | CloseSocket call.
2024-08-14 17:14:11.434 | HD Server | Thread:10660 (0) | CloseSocket call.
2024-08-14 17:14:11.435 | HD Server | Thread:10660 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:11.435 | HD Server | Thread:10660 (5) | Closed.
2024-08-14 17:14:11.435 | HD Server | Thread:10660 (0) | CloseSocket call.
2024-08-14 17:14:11.439 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:11.439 | HD Server Manager | Started new historical data server. Count=4
2024-08-14 17:14:11.449 | HD Server | Thread:18808 (4) | Creating socket.
2024-08-14 17:14:11.449 | HD Server | Thread:18808 (4) | New receive buffer size: 262144
2024-08-14 17:14:11.450 | HD Server | Thread:18808 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:11.450 | HD Server | Setting DTC encoding to Binary VLS | Thread:18808
2024-08-14 17:14:11.450 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18808
2024-08-14 17:14:11.450 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18808
2024-08-14 17:14:11.450 | HD Server | HD Request #4244 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4244 | Username: DAVID SUDDUTH JR. | Thread:18808
2024-08-14 17:14:11.451 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4244 | Username: DAVID SUDDUTH JR. | Thread:18808
2024-08-14 17:14:11.452 | HD Server | Thread:18808 (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:11.452 | HD Server | Thread:18808 (4) | CloseSocket call.
2024-08-14 17:14:11.452 | HD Server | Thread:18808 (0) | CloseSocket call.
2024-08-14 17:14:11.452 | HD Server | Thread:18808 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:11.452 | HD Server | Thread:18808 (4) | Closed.
2024-08-14 17:14:11.503 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18808
2024-08-14 17:14:11.504 | HD Server Manager | Current server count=3
2024-08-14 17:14:11.504 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10660
2024-08-14 17:14:11.504 | HD Server Manager | Current server count=2
2024-08-14 17:14:11.504 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:2540
2024-08-14 17:14:11.504 | HD Server Manager | Current server count=1
2024-08-14 17:14:11.504 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10716
2024-08-14 17:14:11.504 | HD Server Manager | Current server count=0
2024-08-14 17:14:13.424 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:13.424 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:13.425 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:13.425 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:13.425 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:13.464 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:13.464 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:13.464 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:13.464 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:13.584 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:13.584 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:13.584 | Historical data download ID 121666 not found when removing ID from outstanding request set.
2024-08-14 17:14:13.584 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:13.584 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:13.584 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:13.584 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:13.584 | Historical data download ID 121667 not found when removing ID from outstanding request set.
2024-08-14 17:14:13.584 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:13.584 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:13.584 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:13.626 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:13.627 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:13.627 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:13.627 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:13.627 | DTC Client socket (4) | Closed.
2024-08-14 17:14:13.627 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:13.627 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:13.627 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:13.627 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:14.367 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:14.367 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:14:14.379 | HD Server | Thread:3304 (4) | Creating socket.
2024-08-14 17:14:14.379 | HD Server | Thread:3304 (4) | New receive buffer size: 262144
2024-08-14 17:14:14.379 | HD Server | Thread:3304 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:14.379 | HD Server | Setting DTC encoding to Binary VLS | Thread:3304
2024-08-14 17:14:14.379 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:3304
2024-08-14 17:14:14.379 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:3304
2024-08-14 17:14:14.379 | HD Server | HD Request #4245 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4245 | Username: DAVID SUDDUTH JR. | Thread:3304
2024-08-14 17:14:14.380 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4245 | Username: DAVID SUDDUTH JR. | Thread:3304
2024-08-14 17:14:14.380 | HD Server | Thread:3304 (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:14.380 | HD Server | Thread:3304 (4) | CloseSocket call.
2024-08-14 17:14:14.380 | HD Server | Thread:3304 (0) | CloseSocket call.
2024-08-14 17:14:14.380 | HD Server | Thread:3304 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:14.380 | HD Server | Thread:3304 (4) | Closed.
2024-08-14 17:14:14.381 | HD Server | Thread:3304 (0) | CloseSocket call.
2024-08-14 17:14:14.384 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:14.384 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:14:14.397 | HD Server | Thread:8676 (4) | Creating socket.
2024-08-14 17:14:14.397 | HD Server | Thread:8676 (4) | New receive buffer size: 262144
2024-08-14 17:14:14.397 | HD Server | Thread:8676 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:14.397 | HD Server | Setting DTC encoding to Binary VLS | Thread:8676
2024-08-14 17:14:14.398 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:8676
2024-08-14 17:14:14.398 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:8676
2024-08-14 17:14:14.398 | HD Server | HD Request #4246 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4246 | Username: DAVID SUDDUTH JR. | Thread:8676
2024-08-14 17:14:14.399 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4246 | Username: DAVID SUDDUTH JR. | Thread:8676
2024-08-14 17:14:14.399 | HD Server | Thread:8676 (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:14.399 | HD Server | Thread:8676 (4) | CloseSocket call.
2024-08-14 17:14:14.399 | HD Server | Thread:8676 (0) | CloseSocket call.
2024-08-14 17:14:14.399 | HD Server | Thread:8676 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:14.400 | HD Server | Thread:8676 (4) | Closed.
2024-08-14 17:14:14.400 | HD Server | Thread:8676 (0) | CloseSocket call.
2024-08-14 17:14:14.513 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:8676
2024-08-14 17:14:14.513 | HD Server Manager | Current server count=1
2024-08-14 17:14:14.513 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:3304
2024-08-14 17:14:14.514 | HD Server Manager | Current server count=0
2024-08-14 17:14:15.637 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:15.637 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:15.638 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:15.638 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:15.638 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:15.677 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:15.677 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:15.677 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:15.677 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:15.799 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:15.799 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:15.799 | Historical data download ID 121668 not found when removing ID from outstanding request set.
2024-08-14 17:14:15.799 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:15.799 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:15.799 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:15.799 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:15.799 | Historical data download ID 121669 not found when removing ID from outstanding request set.
2024-08-14 17:14:15.799 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:15.799 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:15.799 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:15.841 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:15.842 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:15.842 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:15.842 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:15.842 | DTC Client socket (4) | Closed.
2024-08-14 17:14:15.843 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:15.843 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:15.843 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:15.843 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:17.830 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:17.830 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:17.831 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:17.831 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:14:17.831 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:17.869 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:17.869 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:17.869 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:17.869 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:17.992 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:17.992 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:17.992 | Historical data download ID 121670 not found when removing ID from outstanding request set.
2024-08-14 17:14:17.992 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:17.992 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:17.992 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:17.992 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:17.992 | Historical data download ID 121671 not found when removing ID from outstanding request set.
2024-08-14 17:14:17.992 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:17.992 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:17.992 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:18.037 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:14:18.037 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:14:18.037 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:18.037 | DTC Client socket (5) | Closed.
2024-08-14 17:14:18.037 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:18.038 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:18.038 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:18.038 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:20.038 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:20.038 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:20.038 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:20.038 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:20.038 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:20.076 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:20.076 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:20.076 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:20.076 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:20.195 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:20.195 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:20.195 | Historical data download ID 121672 not found when removing ID from outstanding request set.
2024-08-14 17:14:20.195 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:20.195 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:20.195 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:20.195 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:20.195 | Historical data download ID 121673 not found when removing ID from outstanding request set.
2024-08-14 17:14:20.195 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:20.195 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:20.195 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:20.238 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:20.238 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:20.238 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:20.239 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:20.239 | DTC Client socket (4) | Closed.
2024-08-14 17:14:20.239 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:20.239 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:20.239 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:20.239 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:22.246 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:22.246 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:22.247 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:22.247 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:22.247 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:22.287 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:22.287 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:22.287 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:22.287 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:22.415 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:22.415 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:22.415 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:22.416 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:22.416 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:22.416 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:22.416 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:22.416 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:22.416 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:22.416 | Historical data download ID 121674 not found when removing ID from outstanding request set.
2024-08-14 17:14:22.416 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:22.416 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:22.416 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:22.416 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:22.416 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:22.416 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:22.416 | Historical data download ID 121675 not found when removing ID from outstanding request set.
2024-08-14 17:14:22.416 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:22.416 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:22.416 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:22.454 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:22.454 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:22.454 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:22.455 | DTC Client socket (4) | Closed.
2024-08-14 17:14:22.455 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:22.455 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:22.455 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:22.455 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:24.464 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:24.464 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:24.465 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:24.465 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:24.465 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:24.503 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:24.503 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:24.503 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:24.503 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:24.632 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:24.632 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:24.632 | Historical data download ID 121676 not found when removing ID from outstanding request set.
2024-08-14 17:14:24.632 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:24.632 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:24.632 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:24.632 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:24.632 | Historical data download ID 121677 not found when removing ID from outstanding request set.
2024-08-14 17:14:24.632 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:24.632 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:24.632 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:24.673 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:24.674 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:24.674 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:24.674 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:24.674 | DTC Client socket (4) | Closed.
2024-08-14 17:14:24.674 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:24.675 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:24.675 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:24.675 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:26.674 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:26.674 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:26.674 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:26.675 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:26.675 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:26.713 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:26.713 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:26.713 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:26.713 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:26.837 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:26.837 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:26.837 | Historical data download ID 121678 not found when removing ID from outstanding request set.
2024-08-14 17:14:26.837 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:26.837 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:26.837 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:26.837 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:26.837 | Historical data download ID 121679 not found when removing ID from outstanding request set.
2024-08-14 17:14:26.837 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:26.837 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:26.837 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:26.879 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:26.879 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:26.879 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:26.879 | DTC Client socket (4) | Closed.
2024-08-14 17:14:26.879 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:26.880 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:26.880 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:26.880 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:28.887 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:28.887 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:28.887 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:28.888 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:28.888 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:28.926 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:28.926 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:28.926 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:28.926 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:29.053 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:29.053 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:29.053 | Historical data download ID 121680 not found when removing ID from outstanding request set.
2024-08-14 17:14:29.053 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:29.053 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:29.053 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:29.053 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:29.053 | Historical data download ID 121681 not found when removing ID from outstanding request set.
2024-08-14 17:14:29.053 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:29.053 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:29.053 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:29.096 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:29.096 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:29.096 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:29.096 | DTC Client socket (4) | Closed.
2024-08-14 17:14:29.097 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:29.097 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:29.097 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:29.097 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:31.098 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:31.098 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:31.099 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:31.099 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:31.099 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:31.138 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:31.138 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:31.138 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:31.138 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:31.263 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:31.263 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:31.263 | Historical data download ID 121682 not found when removing ID from outstanding request set.
2024-08-14 17:14:31.263 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:31.263 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:31.263 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:31.263 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:31.263 | Historical data download ID 121683 not found when removing ID from outstanding request set.
2024-08-14 17:14:31.263 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:31.263 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:31.263 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:31.307 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:31.307 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:31.307 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:31.307 | DTC Client socket (4) | Closed.
2024-08-14 17:14:31.307 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:31.308 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:31.308 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:31.308 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:33.309 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:33.310 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:33.310 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:33.310 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:33.310 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:33.348 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:33.348 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:33.348 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:33.348 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:33.468 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:33.468 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:33.468 | Historical data download ID 121684 not found when removing ID from outstanding request set.
2024-08-14 17:14:33.468 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:33.468 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:33.468 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:33.468 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:33.468 | Historical data download ID 121685 not found when removing ID from outstanding request set.
2024-08-14 17:14:33.468 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:33.468 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:33.468 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:33.509 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:33.510 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:33.510 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:33.510 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:33.510 | DTC Client socket (4) | Closed.
2024-08-14 17:14:33.510 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:33.511 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:33.511 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:33.511 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:35.508 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:35.508 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:35.509 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:35.509 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:35.509 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:35.545 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:35.545 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:35.545 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:35.545 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:35.668 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:35.668 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:35.668 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:35.668 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:35.668 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:35.668 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:35.668 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:35.669 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:35.669 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:35.669 | Historical data download ID 121686 not found when removing ID from outstanding request set.
2024-08-14 17:14:35.669 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:35.669 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:35.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:35.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:35.669 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:35.669 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:35.669 | Historical data download ID 121687 not found when removing ID from outstanding request set.
2024-08-14 17:14:35.669 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:35.669 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:35.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:35.711 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:35.712 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:35.712 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:35.712 | DTC Client socket (4) | Closed.
2024-08-14 17:14:35.712 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:35.712 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:35.712 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:35.712 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:37.711 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:37.711 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:37.711 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:37.712 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:37.712 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:37.750 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:37.750 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:37.751 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:37.751 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:37.874 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:37.874 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:37.874 | Historical data download ID 121688 not found when removing ID from outstanding request set.
2024-08-14 17:14:37.874 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:37.874 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:37.874 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:37.874 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:37.874 | Historical data download ID 121689 not found when removing ID from outstanding request set.
2024-08-14 17:14:37.874 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:37.874 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:37.874 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:37.917 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:37.917 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:37.917 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:37.917 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:37.917 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:37.917 | DTC Client socket (4) | Closed.
2024-08-14 17:14:37.918 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:37.918 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:37.918 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:39.913 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:39.913 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:39.913 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:39.914 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:39.914 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:39.953 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:39.953 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:39.954 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:39.954 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:40.077 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:40.077 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:40.077 | Historical data download ID 121690 not found when removing ID from outstanding request set.
2024-08-14 17:14:40.077 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:40.077 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:40.077 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:40.077 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:40.077 | Historical data download ID 121691 not found when removing ID from outstanding request set.
2024-08-14 17:14:40.077 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:40.077 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:40.077 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:40.118 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:40.118 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:40.118 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:40.118 | DTC Client socket (4) | Closed.
2024-08-14 17:14:40.118 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:40.118 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:40.118 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:40.118 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:42.121 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:42.121 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:42.122 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:42.122 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:42.122 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:42.161 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:42.161 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:42.161 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:42.161 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:42.284 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:42.284 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:42.284 | Historical data download ID 121692 not found when removing ID from outstanding request set.
2024-08-14 17:14:42.284 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:42.284 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:42.284 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:42.284 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:42.284 | Historical data download ID 121693 not found when removing ID from outstanding request set.
2024-08-14 17:14:42.284 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:42.284 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:42.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:42.325 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:42.326 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:42.327 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:42.327 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:42.327 | DTC Client socket (4) | Closed.
2024-08-14 17:14:42.327 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:42.327 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:42.327 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:42.327 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:42.717 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:42.717 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:14:42.726 | HD Server | Thread:5316 (4) | Creating socket.
2024-08-14 17:14:42.726 | HD Server | Thread:5316 (4) | New receive buffer size: 262144
2024-08-14 17:14:42.726 | HD Server | Thread:5316 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:42.726 | HD Server | Setting DTC encoding to Binary VLS | Thread:5316
2024-08-14 17:14:42.727 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:5316
2024-08-14 17:14:42.727 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:5316
2024-08-14 17:14:42.727 | HD Server | HD Request #4247 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4247 | Username: DAVID SUDDUTH JR. | Thread:5316
2024-08-14 17:14:42.728 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4247 | Username: DAVID SUDDUTH JR. | Thread:5316
2024-08-14 17:14:42.728 | HD Server | Thread:5316 (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:42.728 | HD Server | Thread:5316 (4) | CloseSocket call.
2024-08-14 17:14:42.728 | HD Server | Thread:5316 (0) | CloseSocket call.
2024-08-14 17:14:42.728 | HD Server | Thread:5316 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:42.728 | HD Server | Thread:5316 (4) | Closed.
2024-08-14 17:14:42.737 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:42.737 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:14:42.743 | HD Server | Thread:7152 (4) | Creating socket.
2024-08-14 17:14:42.743 | HD Server | Thread:7152 (4) | New receive buffer size: 262144
2024-08-14 17:14:42.743 | HD Server | Thread:7152 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:42.743 | HD Server | Setting DTC encoding to Binary VLS | Thread:7152
2024-08-14 17:14:42.744 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:7152
2024-08-14 17:14:42.744 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:7152
2024-08-14 17:14:42.744 | HD Server | HD Request #4248 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4248 | Username: DAVID SUDDUTH JR. | Thread:7152
2024-08-14 17:14:42.744 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4248 | Username: DAVID SUDDUTH JR. | Thread:7152
2024-08-14 17:14:42.745 | HD Server | Thread:7152 (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:42.745 | HD Server | Thread:7152 (4) | CloseSocket call.
2024-08-14 17:14:42.745 | HD Server | Thread:7152 (0) | CloseSocket call.
2024-08-14 17:14:42.745 | HD Server | Thread:7152 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:42.745 | HD Server | Thread:7152 (4) | Closed.
2024-08-14 17:14:42.768 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:7152
2024-08-14 17:14:42.769 | HD Server Manager | Current server count=1
2024-08-14 17:14:42.769 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:5316
2024-08-14 17:14:42.769 | HD Server Manager | Current server count=0
2024-08-14 17:14:44.322 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:44.322 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:44.323 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:44.323 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:44.323 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:44.364 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:44.364 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:44.364 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:44.364 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:44.491 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:44.491 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:44.491 | Historical data download ID 121694 not found when removing ID from outstanding request set.
2024-08-14 17:14:44.491 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:44.491 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:44.491 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:44.491 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:44.491 | Historical data download ID 121695 not found when removing ID from outstanding request set.
2024-08-14 17:14:44.491 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:44.491 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:44.491 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:44.533 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:44.533 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:44.533 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:44.533 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:44.533 | DTC Client socket (4) | Closed.
2024-08-14 17:14:44.533 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:44.534 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:44.534 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:44.534 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:45.270 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:45.270 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:14:45.284 | HD Server | Thread:5980 (4) | Creating socket.
2024-08-14 17:14:45.284 | HD Server | Thread:5980 (4) | New receive buffer size: 262144
2024-08-14 17:14:45.284 | HD Server | Thread:5980 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:45.284 | HD Server | Setting DTC encoding to Binary VLS | Thread:5980
2024-08-14 17:14:45.285 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:5980
2024-08-14 17:14:45.285 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:5980
2024-08-14 17:14:45.285 | HD Server | HD Request #4249 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4249 | Username: DAVID SUDDUTH JR. | Thread:5980
2024-08-14 17:14:45.286 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4249 | Username: DAVID SUDDUTH JR. | Thread:5980
2024-08-14 17:14:45.286 | HD Server | Thread:5980 (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:45.286 | HD Server | Thread:5980 (4) | CloseSocket call.
2024-08-14 17:14:45.287 | HD Server | Thread:5980 (0) | CloseSocket call.
2024-08-14 17:14:45.287 | HD Server | Thread:5980 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:45.287 | HD Server | Thread:5980 (4) | Closed.
2024-08-14 17:14:45.294 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:14:45.294 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:14:45.309 | HD Server | Thread:15368 (4) | Creating socket.
2024-08-14 17:14:45.309 | HD Server | Thread:15368 (4) | New receive buffer size: 262144
2024-08-14 17:14:45.309 | HD Server | Thread:15368 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:14:45.309 | HD Server | Setting DTC encoding to Binary VLS | Thread:15368
2024-08-14 17:14:45.310 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15368
2024-08-14 17:14:45.310 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15368
2024-08-14 17:14:45.310 | HD Server | HD Request #4250 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4250 | Username: DAVID SUDDUTH JR. | Thread:15368
2024-08-14 17:14:45.311 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4250 | Username: DAVID SUDDUTH JR. | Thread:15368
2024-08-14 17:14:45.311 | HD Server | Thread:15368 (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:45.311 | HD Server | Thread:15368 (4) | CloseSocket call.
2024-08-14 17:14:45.312 | HD Server | Thread:15368 (0) | CloseSocket call.
2024-08-14 17:14:45.312 | HD Server | Thread:15368 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:45.312 | HD Server | Thread:15368 (4) | Closed.
2024-08-14 17:14:45.522 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15368
2024-08-14 17:14:45.522 | HD Server Manager | Current server count=1
2024-08-14 17:14:45.522 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:5980
2024-08-14 17:14:45.523 | HD Server Manager | Current server count=0
2024-08-14 17:14:46.540 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:46.540 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:46.541 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:46.541 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:46.541 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:46.580 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:46.580 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:46.580 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:46.580 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:46.701 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:46.701 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:46.701 | Historical data download ID 121696 not found when removing ID from outstanding request set.
2024-08-14 17:14:46.701 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:46.701 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:46.701 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:46.701 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:46.701 | Historical data download ID 121697 not found when removing ID from outstanding request set.
2024-08-14 17:14:46.701 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:46.701 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:46.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:46.742 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:46.743 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:46.744 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:46.744 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:46.744 | DTC Client socket (4) | Closed.
2024-08-14 17:14:46.744 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:46.744 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:46.744 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:46.744 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:48.751 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:48.751 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:48.752 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:48.752 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:48.752 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:48.790 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:48.790 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:48.790 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:48.790 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:48.914 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:48.914 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:48.914 | Historical data download ID 121698 not found when removing ID from outstanding request set.
2024-08-14 17:14:48.914 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:48.914 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:48.914 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:48.914 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:48.914 | Historical data download ID 121699 not found when removing ID from outstanding request set.
2024-08-14 17:14:48.914 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:48.914 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:48.914 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:48.955 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:48.955 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:48.955 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:48.955 | DTC Client socket (4) | Closed.
2024-08-14 17:14:48.955 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:48.956 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:48.956 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:48.956 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:50.964 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:50.964 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:50.964 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:50.965 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:50.965 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:51.004 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:51.004 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:51.004 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:51.004 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:51.126 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:51.126 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:51.126 | Historical data download ID 121700 not found when removing ID from outstanding request set.
2024-08-14 17:14:51.126 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:51.126 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:51.126 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:51.126 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:51.126 | Historical data download ID 121701 not found when removing ID from outstanding request set.
2024-08-14 17:14:51.126 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:51.126 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:51.126 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:51.166 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:51.166 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:51.166 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:51.166 | DTC Client socket (4) | Closed.
2024-08-14 17:14:51.166 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:51.166 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:51.166 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:51.166 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:53.171 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:53.171 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:53.171 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:53.172 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:53.172 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:53.209 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:53.209 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:53.209 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:53.209 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:53.332 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:53.332 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:53.332 | Historical data download ID 121702 not found when removing ID from outstanding request set.
2024-08-14 17:14:53.332 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:53.332 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:53.332 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:53.332 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:53.332 | Historical data download ID 121703 not found when removing ID from outstanding request set.
2024-08-14 17:14:53.332 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:53.332 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:53.332 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:53.374 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:53.374 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:53.374 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:53.374 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:53.374 | DTC Client socket (4) | Closed.
2024-08-14 17:14:53.374 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:53.375 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:53.375 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:53.375 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:55.372 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:55.372 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:55.373 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:55.373 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:55.373 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:55.411 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:55.411 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:55.411 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:55.411 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:55.534 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:55.534 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:55.534 | Historical data download ID 121704 not found when removing ID from outstanding request set.
2024-08-14 17:14:55.534 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:55.534 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:55.534 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:55.534 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:55.534 | Historical data download ID 121705 not found when removing ID from outstanding request set.
2024-08-14 17:14:55.534 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:55.534 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:55.534 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:55.575 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:55.577 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:55.577 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:55.577 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:55.577 | DTC Client socket (4) | Closed.
2024-08-14 17:14:55.577 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:55.577 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:55.577 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:55.577 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:57.575 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:57.575 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:57.576 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:57.576 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:57.576 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:57.618 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:57.618 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:57.619 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:57.619 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:57.743 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:57.743 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:57.743 | Historical data download ID 121706 not found when removing ID from outstanding request set.
2024-08-14 17:14:57.743 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:57.743 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:57.743 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:57.743 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:57.743 | Historical data download ID 121707 not found when removing ID from outstanding request set.
2024-08-14 17:14:57.743 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:57.743 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:57.743 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:14:57.784 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:14:57.786 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:14:57.786 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:14:57.786 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:14:57.786 | DTC Client socket (4) | Closed.
2024-08-14 17:14:57.786 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:14:57.787 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:14:57.787 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:14:57.787 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:14:59.786 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:14:59.786 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:14:59.786 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:14:59.787 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:14:59.787 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:14:59.824 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:14:59.824 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:14:59.824 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:14:59.824 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:14:59.960 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:14:59.960 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:14:59.960 | Historical data download ID 121708 not found when removing ID from outstanding request set.
2024-08-14 17:14:59.960 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:14:59.960 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:14:59.960 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:14:59.960 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:14:59.960 | Historical data download ID 121709 not found when removing ID from outstanding request set.
2024-08-14 17:14:59.960 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:14:59.960 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:14:59.960 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:00.002 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:00.003 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:00.003 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:00.003 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:00.003 | DTC Client socket (4) | Closed.
2024-08-14 17:15:00.003 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:00.003 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:00.003 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:00.003 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:02.012 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:02.012 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:02.013 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:02.013 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:02.013 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:02.052 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:02.052 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:02.052 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:02.052 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:02.177 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:02.178 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:02.178 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:02.178 | Historical data download ID 121710 not found when removing ID from outstanding request set.
2024-08-14 17:15:02.178 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:02.178 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:02.178 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:02.178 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:02.178 | Historical data download ID 121711 not found when removing ID from outstanding request set.
2024-08-14 17:15:02.178 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:02.178 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:02.178 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:02.219 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:02.220 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:02.220 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:02.220 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:02.220 | DTC Client socket (4) | Closed.
2024-08-14 17:15:02.220 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:02.221 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:02.221 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:02.221 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:04.227 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:04.227 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:04.228 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:04.228 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:04.228 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:04.267 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:04.267 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:04.267 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:04.267 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:04.397 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:04.397 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:04.397 | Historical data download ID 121712 not found when removing ID from outstanding request set.
2024-08-14 17:15:04.397 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:04.397 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:04.397 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:04.397 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:04.397 | Historical data download ID 121713 not found when removing ID from outstanding request set.
2024-08-14 17:15:04.397 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:04.397 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:04.397 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:04.439 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:04.439 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:04.439 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:04.439 | DTC Client socket (4) | Closed.
2024-08-14 17:15:04.439 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:04.439 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:04.439 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:04.439 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:06.446 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:06.446 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:06.447 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:06.447 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:06.447 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:06.485 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:06.485 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:06.485 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:06.485 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:06.610 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:06.610 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:06.610 | Historical data download ID 121714 not found when removing ID from outstanding request set.
2024-08-14 17:15:06.610 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:06.610 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:06.610 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:06.610 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:06.610 | Historical data download ID 121715 not found when removing ID from outstanding request set.
2024-08-14 17:15:06.610 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:06.610 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:06.610 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:06.651 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:06.651 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:06.651 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:06.651 | DTC Client socket (4) | Closed.
2024-08-14 17:15:06.651 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:06.652 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:06.652 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:06.652 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:08.643 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:08.643 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:08.643 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:08.644 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:08.644 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:08.682 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:08.682 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:08.682 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:08.682 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:08.800 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:08.800 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:08.800 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:08.800 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:08.800 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:08.800 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:08.800 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:08.800 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:08.800 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:08.800 | Historical data download ID 121716 not found when removing ID from outstanding request set.
2024-08-14 17:15:08.800 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:08.801 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:08.801 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:08.801 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:08.801 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:08.801 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:08.801 | Historical data download ID 121717 not found when removing ID from outstanding request set.
2024-08-14 17:15:08.801 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:08.801 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:08.801 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:08.841 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:08.843 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:08.843 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:08.843 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:08.843 | DTC Client socket (4) | Closed.
2024-08-14 17:15:08.843 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:08.844 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:08.844 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:08.844 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:10.830 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:10.830 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:10.831 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:10.831 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:10.831 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:10.869 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:10.869 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:10.869 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:10.869 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:10.995 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:10.995 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:10.995 | Historical data download ID 121718 not found when removing ID from outstanding request set.
2024-08-14 17:15:10.995 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:10.995 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:10.995 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:10.995 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:10.995 | Historical data download ID 121719 not found when removing ID from outstanding request set.
2024-08-14 17:15:10.995 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:10.995 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:10.995 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:11.036 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:11.037 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:11.037 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:11.037 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:11.037 | DTC Client socket (4) | Closed.
2024-08-14 17:15:11.037 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:11.038 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:11.038 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:11.038 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:13.040 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:13.040 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:13.041 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:13.041 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:13.041 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:13.080 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:13.080 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:13.080 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:13.080 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:13.200 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:13.200 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:13.200 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:13.200 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:13.200 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:13.200 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:13.200 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:13.200 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:13.201 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:13.201 | Historical data download ID 121720 not found when removing ID from outstanding request set.
2024-08-14 17:15:13.201 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:13.201 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:13.201 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:13.201 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:13.201 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:13.201 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:13.201 | Historical data download ID 121721 not found when removing ID from outstanding request set.
2024-08-14 17:15:13.201 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:13.201 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:13.201 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:13.242 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:13.243 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:13.243 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:13.243 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:13.243 | DTC Client socket (4) | Closed.
2024-08-14 17:15:13.243 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:13.244 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:13.244 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:13.244 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:13.807 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:13.807 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:15:13.820 | HD Server | Thread:968 (4) | Creating socket.
2024-08-14 17:15:13.820 | HD Server | Thread:968 (4) | New receive buffer size: 262144
2024-08-14 17:15:13.820 | HD Server | Thread:968 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:13.820 | HD Server | Setting DTC encoding to Binary VLS | Thread:968
2024-08-14 17:15:13.821 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:968
2024-08-14 17:15:13.821 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:968
2024-08-14 17:15:13.821 | HD Server | HD Request #4251 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4251 | Username: DAVID SUDDUTH JR. | Thread:968
2024-08-14 17:15:13.822 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4251 | Username: DAVID SUDDUTH JR. | Thread:968
2024-08-14 17:15:13.822 | HD Server | Thread:968 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:13.822 | HD Server | Thread:968 (4) | CloseSocket call.
2024-08-14 17:15:13.822 | HD Server | Thread:968 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:13.822 | HD Server | Thread:968 (4) | Closed.
2024-08-14 17:15:13.822 | HD Server | Thread:968 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:15:13.825 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:13.825 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:15:13.836 | HD Server | Thread:6400 (4) | Creating socket.
2024-08-14 17:15:13.836 | HD Server | Thread:6400 (4) | New receive buffer size: 262144
2024-08-14 17:15:13.836 | HD Server | Thread:6400 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:13.837 | HD Server | Setting DTC encoding to Binary VLS | Thread:6400
2024-08-14 17:15:13.837 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:6400
2024-08-14 17:15:13.837 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:6400
2024-08-14 17:15:13.837 | HD Server | HD Request #4252 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4252 | Username: DAVID SUDDUTH JR. | Thread:6400
2024-08-14 17:15:13.838 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4252 | Username: DAVID SUDDUTH JR. | Thread:6400
2024-08-14 17:15:13.838 | HD Server | Thread:6400 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:13.838 | HD Server | Thread:6400 (4) | CloseSocket call.
2024-08-14 17:15:13.838 | HD Server | Thread:6400 (0) | CloseSocket call.
2024-08-14 17:15:13.838 | HD Server | Thread:6400 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:13.838 | HD Server | Thread:6400 (4) | Closed.
2024-08-14 17:15:14.065 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:6400
2024-08-14 17:15:14.065 | HD Server Manager | Current server count=1
2024-08-14 17:15:14.065 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:968
2024-08-14 17:15:14.066 | HD Server Manager | Current server count=0
2024-08-14 17:15:15.249 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:15.249 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:15.250 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:15.250 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:15.250 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:15.288 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:15.288 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:15.288 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:15.288 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:15.411 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:15.411 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:15.411 | Historical data download ID 121722 not found when removing ID from outstanding request set.
2024-08-14 17:15:15.411 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:15.411 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:15.411 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:15.411 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:15.411 | Historical data download ID 121723 not found when removing ID from outstanding request set.
2024-08-14 17:15:15.411 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:15.411 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:15.411 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:15.449 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:15.450 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:15.450 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:15.450 | DTC Client socket (4) | Closed.
2024-08-14 17:15:15.450 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:15.450 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:15.450 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:15.450 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:16.413 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:16.413 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:15:16.425 | HD Server | Thread:14008 (4) | Creating socket.
2024-08-14 17:15:16.425 | HD Server | Thread:14008 (4) | New receive buffer size: 262144
2024-08-14 17:15:16.425 | HD Server | Thread:14008 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:16.425 | HD Server | Setting DTC encoding to Binary VLS | Thread:14008
2024-08-14 17:15:16.426 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:14008
2024-08-14 17:15:16.426 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:14008
2024-08-14 17:15:16.426 | HD Server | HD Request #4253 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4253 | Username: DAVID SUDDUTH JR. | Thread:14008
2024-08-14 17:15:16.426 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4253 | Username: DAVID SUDDUTH JR. | Thread:14008
2024-08-14 17:15:16.427 | HD Server | Thread:14008 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:16.427 | HD Server | Thread:14008 (4) | CloseSocket call.
2024-08-14 17:15:16.427 | HD Server | Thread:14008 (0) | CloseSocket call.
2024-08-14 17:15:16.427 | HD Server | Thread:14008 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:16.427 | HD Server | Thread:14008 (4) | Closed.
2024-08-14 17:15:16.433 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:16.434 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:15:16.443 | HD Server | Thread:17168 (4) | Creating socket.
2024-08-14 17:15:16.443 | HD Server | Thread:17168 (4) | New receive buffer size: 262144
2024-08-14 17:15:16.443 | HD Server | Thread:17168 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:16.444 | HD Server | Setting DTC encoding to Binary VLS | Thread:17168
2024-08-14 17:15:16.444 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:17168
2024-08-14 17:15:16.444 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:17168
2024-08-14 17:15:16.444 | HD Server | HD Request #4254 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4254 | Username: DAVID SUDDUTH JR. | Thread:17168
2024-08-14 17:15:16.445 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4254 | Username: DAVID SUDDUTH JR. | Thread:17168
2024-08-14 17:15:16.445 | HD Server | Thread:17168 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:16.445 | HD Server | Thread:17168 (4) | CloseSocket call.
2024-08-14 17:15:16.445 | HD Server | Thread:17168 (0) | CloseSocket call.
2024-08-14 17:15:16.446 | HD Server | Thread:17168 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:16.446 | HD Server | Thread:17168 (4) | Closed.
2024-08-14 17:15:16.446 | HD Server | Thread:17168 (0) | CloseSocket call.
2024-08-14 17:15:16.576 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:17168
2024-08-14 17:15:16.576 | HD Server Manager | Current server count=1
2024-08-14 17:15:16.576 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:14008
2024-08-14 17:15:16.576 | HD Server Manager | Current server count=0
2024-08-14 17:15:17.441 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:17.441 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:17.441 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:17.442 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:17.442 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:17.481 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:17.481 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:17.481 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:17.481 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:17.603 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:17.603 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:17.603 | Historical data download ID 121724 not found when removing ID from outstanding request set.
2024-08-14 17:15:17.603 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:17.603 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:17.603 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:17.603 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:17.603 | Historical data download ID 121725 not found when removing ID from outstanding request set.
2024-08-14 17:15:17.603 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:17.603 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:17.603 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:17.645 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:17.646 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:17.646 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:17.646 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:17.646 | DTC Client socket (4) | Closed.
2024-08-14 17:15:17.646 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:17.647 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:17.647 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:17.647 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:19.642 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:19.642 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:19.643 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:19.643 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:19.643 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:19.681 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:19.681 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:19.681 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:19.681 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:19.805 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:19.805 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:19.805 | Historical data download ID 121726 not found when removing ID from outstanding request set.
2024-08-14 17:15:19.805 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:19.805 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:19.805 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:19.806 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:19.806 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:19.806 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:19.806 | Historical data download ID 121727 not found when removing ID from outstanding request set.
2024-08-14 17:15:19.806 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:19.806 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:19.806 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:19.848 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:19.848 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:19.848 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:19.848 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:19.848 | DTC Client socket (4) | Closed.
2024-08-14 17:15:19.848 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:19.849 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:19.849 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:19.849 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:21.852 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:21.852 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:21.853 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:21.853 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:21.853 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:21.890 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:21.890 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:21.891 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:21.891 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:22.017 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:22.017 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:22.017 | Historical data download ID 121728 not found when removing ID from outstanding request set.
2024-08-14 17:15:22.017 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:22.017 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:22.017 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:22.017 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:22.017 | Historical data download ID 121729 not found when removing ID from outstanding request set.
2024-08-14 17:15:22.017 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:22.017 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:22.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:22.059 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:22.062 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:22.062 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:22.062 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:22.062 | DTC Client socket (4) | Closed.
2024-08-14 17:15:22.062 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:22.062 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:22.062 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:22.062 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:24.052 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:24.052 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:24.053 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:24.053 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:24.053 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:24.091 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:24.091 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:24.091 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:24.091 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:24.215 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:24.215 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:24.215 | Historical data download ID 121730 not found when removing ID from outstanding request set.
2024-08-14 17:15:24.215 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:24.215 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:24.215 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:24.215 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:24.215 | Historical data download ID 121731 not found when removing ID from outstanding request set.
2024-08-14 17:15:24.215 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:24.215 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:24.215 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:24.256 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:24.258 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:24.258 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:24.258 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:24.258 | DTC Client socket (4) | Closed.
2024-08-14 17:15:24.258 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:24.259 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:24.259 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:24.259 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:26.260 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:26.260 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:26.260 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:26.261 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:26.261 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:26.299 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:26.299 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:26.299 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:26.299 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:26.420 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:26.420 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:26.420 | Historical data download ID 121732 not found when removing ID from outstanding request set.
2024-08-14 17:15:26.420 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:26.420 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:26.420 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:26.420 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:26.420 | Historical data download ID 121733 not found when removing ID from outstanding request set.
2024-08-14 17:15:26.420 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:26.420 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:26.420 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:26.462 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:26.463 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:26.463 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:26.463 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:26.463 | DTC Client socket (4) | Closed.
2024-08-14 17:15:26.463 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:26.463 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:26.463 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:26.463 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:28.455 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:28.455 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:28.455 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:28.455 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:28.455 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:28.493 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:28.493 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:28.493 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:28.493 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:28.617 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:28.617 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:28.617 | Historical data download ID 121734 not found when removing ID from outstanding request set.
2024-08-14 17:15:28.617 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:28.617 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:28.617 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:28.617 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:28.617 | Historical data download ID 121735 not found when removing ID from outstanding request set.
2024-08-14 17:15:28.617 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:28.617 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:28.617 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:28.658 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:28.658 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:28.658 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:28.658 | DTC Client socket (4) | Closed.
2024-08-14 17:15:28.658 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:28.659 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:28.659 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:28.659 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:30.661 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:30.661 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:30.662 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:30.662 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:30.662 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:30.702 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:30.702 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:30.702 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:30.702 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:30.826 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:30.826 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:30.826 | Historical data download ID 121736 not found when removing ID from outstanding request set.
2024-08-14 17:15:30.826 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:30.826 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:30.826 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:30.826 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:30.826 | Historical data download ID 121737 not found when removing ID from outstanding request set.
2024-08-14 17:15:30.826 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:30.826 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:30.826 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:30.869 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:30.869 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:30.869 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:30.869 | DTC Client socket (4) | Closed.
2024-08-14 17:15:30.869 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:30.870 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:30.870 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:30.870 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:32.875 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:32.875 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:32.876 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:32.876 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:32.876 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:32.915 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:32.915 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:32.915 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:32.915 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:33.040 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:33.040 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:33.040 | Historical data download ID 121738 not found when removing ID from outstanding request set.
2024-08-14 17:15:33.040 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:33.040 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:33.040 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:33.040 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:33.040 | Historical data download ID 121739 not found when removing ID from outstanding request set.
2024-08-14 17:15:33.040 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:33.040 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:33.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:33.082 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:33.082 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:33.082 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:33.082 | DTC Client socket (4) | Closed.
2024-08-14 17:15:33.083 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:33.083 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:33.083 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:33.083 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:35.080 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:35.080 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:35.080 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:35.080 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:35.080 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:35.119 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:35.119 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:35.119 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:35.119 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:35.248 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:35.248 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:35.248 | Historical data download ID 121740 not found when removing ID from outstanding request set.
2024-08-14 17:15:35.248 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:35.248 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:35.248 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:35.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:35.249 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:35.249 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:35.249 | Historical data download ID 121741 not found when removing ID from outstanding request set.
2024-08-14 17:15:35.249 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:35.249 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:35.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:35.289 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:35.291 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:35.291 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:35.291 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:35.291 | DTC Client socket (4) | Closed.
2024-08-14 17:15:35.291 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:35.291 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:35.291 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:35.291 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:37.292 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:37.292 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:37.292 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:37.292 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:37.292 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:37.332 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:37.332 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:37.332 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:37.332 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:37.458 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:37.458 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:37.458 | Historical data download ID 121742 not found when removing ID from outstanding request set.
2024-08-14 17:15:37.458 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:37.458 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:37.458 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:37.458 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:37.458 | Historical data download ID 121743 not found when removing ID from outstanding request set.
2024-08-14 17:15:37.458 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:37.458 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:37.458 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:37.500 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:37.500 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:37.500 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:37.500 | DTC Client socket (4) | Closed.
2024-08-14 17:15:37.500 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:37.500 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:37.500 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:37.500 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:39.488 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:39.488 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:39.489 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:39.489 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:39.489 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:39.527 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:39.527 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:39.527 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:39.527 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:39.648 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:39.648 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:39.648 | Historical data download ID 121744 not found when removing ID from outstanding request set.
2024-08-14 17:15:39.648 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:39.648 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:39.648 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:39.648 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:39.648 | Historical data download ID 121745 not found when removing ID from outstanding request set.
2024-08-14 17:15:39.648 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:39.648 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:39.648 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:39.686 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:39.686 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:39.686 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:39.686 | DTC Client socket (4) | Closed.
2024-08-14 17:15:39.686 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:39.687 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:39.687 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:39.687 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:41.681 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:41.681 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:41.682 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:41.682 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:41.682 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:41.719 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:41.719 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:41.719 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:41.719 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:41.840 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:41.840 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:41.840 | Historical data download ID 121746 not found when removing ID from outstanding request set.
2024-08-14 17:15:41.840 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:41.840 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:41.840 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:41.840 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:41.840 | Historical data download ID 121747 not found when removing ID from outstanding request set.
2024-08-14 17:15:41.840 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:41.840 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:41.840 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:41.880 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:41.880 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:41.880 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:41.880 | DTC Client socket (4) | Closed.
2024-08-14 17:15:41.880 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:41.880 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:41.880 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:41.880 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:43.878 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:43.878 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:43.878 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:43.878 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:43.878 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:43.917 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:43.917 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:43.917 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:43.917 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:44.039 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:44.040 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:44.040 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:44.040 | Historical data download ID 121748 not found when removing ID from outstanding request set.
2024-08-14 17:15:44.040 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:44.040 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:44.040 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:44.040 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:44.040 | Historical data download ID 121749 not found when removing ID from outstanding request set.
2024-08-14 17:15:44.040 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:44.040 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:44.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:44.083 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:44.083 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:44.083 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:15:44.083 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:15:44.083 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:15:44.084 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:44.084 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:44.084 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:44.084 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:44.124 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:15:44.124 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:44.124 | DTC Client socket (4) | Closed.
2024-08-14 17:15:44.304 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:44.304 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:15:44.323 | HD Server | Thread:12956 (4) | Creating socket.
2024-08-14 17:15:44.323 | HD Server | Thread:12956 (4) | New receive buffer size: 262144
2024-08-14 17:15:44.323 | HD Server | Thread:12956 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:44.323 | HD Server | Setting DTC encoding to Binary VLS | Thread:12956
2024-08-14 17:15:44.324 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12956
2024-08-14 17:15:44.324 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12956
2024-08-14 17:15:44.325 | HD Server | HD Request #4255 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4255 | Username: DAVID SUDDUTH JR. | Thread:12956
2024-08-14 17:15:44.326 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4255 | Username: DAVID SUDDUTH JR. | Thread:12956
2024-08-14 17:15:44.326 | HD Server | Thread:12956 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:44.326 | HD Server | Thread:12956 (4) | CloseSocket call.
2024-08-14 17:15:44.326 | HD Server | Thread:12956 (0) | CloseSocket call.
2024-08-14 17:15:44.326 | HD Server | Thread:12956 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:44.326 | HD Server | Thread:12956 (4) | Closed.
2024-08-14 17:15:44.329 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:44.330 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:15:44.342 | HD Server | Thread:12924 (4) | Creating socket.
2024-08-14 17:15:44.342 | HD Server | Thread:12924 (4) | New receive buffer size: 262144
2024-08-14 17:15:44.342 | HD Server | Thread:12924 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:44.342 | HD Server | Setting DTC encoding to Binary VLS | Thread:12924
2024-08-14 17:15:44.343 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12924
2024-08-14 17:15:44.343 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12924
2024-08-14 17:15:44.344 | HD Server | HD Request #4256 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4256 | Username: DAVID SUDDUTH JR. | Thread:12924
2024-08-14 17:15:44.345 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4256 | Username: DAVID SUDDUTH JR. | Thread:12924
2024-08-14 17:15:44.345 | HD Server | Thread:12924 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:44.346 | HD Server | Thread:12924 (4) | CloseSocket call.
2024-08-14 17:15:44.346 | HD Server | Thread:12924 (0) | CloseSocket call.
2024-08-14 17:15:44.346 | HD Server | Thread:12924 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:44.346 | HD Server | Thread:12924 (4) | Closed.
2024-08-14 17:15:44.398 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12924
2024-08-14 17:15:44.398 | HD Server Manager | Current server count=1
2024-08-14 17:15:44.398 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12956
2024-08-14 17:15:44.399 | HD Server Manager | Current server count=0
2024-08-14 17:15:46.090 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:46.090 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:46.091 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:46.091 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:46.091 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:46.129 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:46.129 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:46.129 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:46.129 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:46.258 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:46.258 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:46.258 | Historical data download ID 121750 not found when removing ID from outstanding request set.
2024-08-14 17:15:46.258 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:46.258 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:46.258 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:46.258 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:46.258 | Historical data download ID 121751 not found when removing ID from outstanding request set.
2024-08-14 17:15:46.258 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:46.258 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:46.258 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:46.300 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:46.300 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:46.300 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:46.300 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:46.300 | DTC Client socket (4) | Closed.
2024-08-14 17:15:46.300 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:46.301 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:46.301 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:46.301 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:46.759 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:46.760 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:15:46.774 | HD Server | Thread:18788 (4) | Creating socket.
2024-08-14 17:15:46.774 | HD Server | Thread:18788 (4) | New receive buffer size: 262144
2024-08-14 17:15:46.774 | HD Server | Thread:18788 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:46.774 | HD Server | Setting DTC encoding to Binary VLS | Thread:18788
2024-08-14 17:15:46.775 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18788
2024-08-14 17:15:46.775 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18788
2024-08-14 17:15:46.775 | HD Server | HD Request #4257 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4257 | Username: DAVID SUDDUTH JR. | Thread:18788
2024-08-14 17:15:46.776 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4257 | Username: DAVID SUDDUTH JR. | Thread:18788
2024-08-14 17:15:46.776 | HD Server | Thread:18788 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:46.776 | HD Server | Thread:18788 (4) | CloseSocket call.
2024-08-14 17:15:46.776 | HD Server | Thread:18788 (0) | CloseSocket call.
2024-08-14 17:15:46.777 | HD Server | Thread:18788 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:46.777 | HD Server | Thread:18788 (4) | Closed.
2024-08-14 17:15:46.777 | HD Server | Thread:18788 (0) | CloseSocket call.
2024-08-14 17:15:46.779 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:15:46.779 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:15:46.786 | HD Server | Thread:7216 (4) | Creating socket.
2024-08-14 17:15:46.786 | HD Server | Thread:7216 (4) | New receive buffer size: 262144
2024-08-14 17:15:46.786 | HD Server | Thread:7216 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:15:46.786 | HD Server | Setting DTC encoding to Binary VLS | Thread:7216
2024-08-14 17:15:46.787 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:7216
2024-08-14 17:15:46.787 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:7216
2024-08-14 17:15:46.787 | HD Server | HD Request #4258 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4258 | Username: DAVID SUDDUTH JR. | Thread:7216
2024-08-14 17:15:46.787 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4258 | Username: DAVID SUDDUTH JR. | Thread:7216
2024-08-14 17:15:46.788 | HD Server | Thread:7216 (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:46.788 | HD Server | Thread:7216 (4) | CloseSocket call.
2024-08-14 17:15:46.788 | HD Server | Thread:7216 (0) | CloseSocket call.
2024-08-14 17:15:46.788 | HD Server | Thread:7216 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:46.788 | HD Server | Thread:7216 (4) | Closed.
2024-08-14 17:15:46.893 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:7216
2024-08-14 17:15:46.893 | HD Server Manager | Current server count=1
2024-08-14 17:15:46.893 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18788
2024-08-14 17:15:46.893 | HD Server Manager | Current server count=0
2024-08-14 17:15:48.308 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:48.308 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:48.309 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:48.309 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:48.309 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:48.349 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:48.349 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:48.349 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:48.349 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:48.470 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:48.470 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:48.470 | Historical data download ID 121752 not found when removing ID from outstanding request set.
2024-08-14 17:15:48.470 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:48.470 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:48.470 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:48.470 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:48.470 | Historical data download ID 121753 not found when removing ID from outstanding request set.
2024-08-14 17:15:48.470 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:48.470 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:48.470 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:48.508 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:48.508 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:48.508 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:48.508 | DTC Client socket (4) | Closed.
2024-08-14 17:15:48.508 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:48.508 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:48.508 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:48.508 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:50.503 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:50.503 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:50.504 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:50.504 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:50.504 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:50.542 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:50.542 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:50.542 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:50.542 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:50.667 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:50.667 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:50.667 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:50.667 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:50.667 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:50.667 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:50.667 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:50.668 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:50.668 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:50.668 | Historical data download ID 121754 not found when removing ID from outstanding request set.
2024-08-14 17:15:50.668 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:50.668 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:50.668 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:50.668 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:50.668 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:50.668 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:50.668 | Historical data download ID 121755 not found when removing ID from outstanding request set.
2024-08-14 17:15:50.668 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:50.668 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:50.668 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:50.708 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:50.709 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:50.709 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:50.709 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:50.709 | DTC Client socket (4) | Closed.
2024-08-14 17:15:50.709 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:50.710 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:50.710 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:50.710 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:52.714 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:52.714 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:52.714 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:52.714 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:52.714 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:52.752 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:52.752 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:52.752 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:52.752 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:52.878 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:52.878 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:52.878 | Historical data download ID 121756 not found when removing ID from outstanding request set.
2024-08-14 17:15:52.878 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:52.878 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:52.878 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:52.878 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:52.878 | Historical data download ID 121757 not found when removing ID from outstanding request set.
2024-08-14 17:15:52.878 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:52.878 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:52.878 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:52.921 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:52.921 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:52.921 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:52.921 | DTC Client socket (4) | Closed.
2024-08-14 17:15:52.921 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:52.922 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:52.922 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:52.922 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:54.916 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:54.916 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:54.917 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:54.917 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:54.917 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:54.956 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:54.956 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:54.956 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:54.956 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:55.079 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:55.079 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:55.079 | Historical data download ID 121758 not found when removing ID from outstanding request set.
2024-08-14 17:15:55.079 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:55.079 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:55.079 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:55.079 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:55.079 | Historical data download ID 121759 not found when removing ID from outstanding request set.
2024-08-14 17:15:55.079 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:55.079 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:55.079 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:55.122 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:55.122 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:55.122 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:55.122 | DTC Client socket (4) | Closed.
2024-08-14 17:15:55.122 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:55.123 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:55.123 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:55.123 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:57.121 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:57.121 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:57.122 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:57.122 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:57.122 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:57.164 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:57.164 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:57.164 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:57.164 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:57.290 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:57.290 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:57.290 | Historical data download ID 121760 not found when removing ID from outstanding request set.
2024-08-14 17:15:57.290 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:57.290 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:57.290 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:57.290 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:57.290 | Historical data download ID 121761 not found when removing ID from outstanding request set.
2024-08-14 17:15:57.290 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:57.290 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:57.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:57.331 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:15:57.332 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:57.332 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:57.332 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:57.332 | DTC Client socket (4) | Closed.
2024-08-14 17:15:57.333 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:57.333 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:57.333 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:57.333 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:15:59.339 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:15:59.339 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:15:59.340 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:15:59.340 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:15:59.340 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:15:59.378 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:15:59.378 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:15:59.378 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:15:59.378 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:15:59.501 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:15:59.501 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:15:59.501 | Historical data download ID 121762 not found when removing ID from outstanding request set.
2024-08-14 17:15:59.501 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:15:59.501 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:15:59.501 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:15:59.501 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:15:59.501 | Historical data download ID 121763 not found when removing ID from outstanding request set.
2024-08-14 17:15:59.501 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:15:59.501 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:15:59.501 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:15:59.542 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:15:59.542 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:15:59.543 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:15:59.543 | DTC Client socket (4) | Closed.
2024-08-14 17:15:59.543 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:15:59.543 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:15:59.543 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:15:59.543 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:01.546 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:01.546 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:01.546 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:01.546 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:01.546 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:01.584 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:01.584 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:01.584 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:01.584 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:01.706 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:01.706 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:01.706 | Historical data download ID 121764 not found when removing ID from outstanding request set.
2024-08-14 17:16:01.706 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:01.706 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:01.706 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:01.706 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:01.706 | Historical data download ID 121765 not found when removing ID from outstanding request set.
2024-08-14 17:16:01.706 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:01.706 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:01.706 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:01.749 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:01.749 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:01.749 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:01.749 | DTC Client socket (4) | Closed.
2024-08-14 17:16:01.749 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:01.749 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:01.749 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:01.749 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:03.743 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:03.743 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:03.744 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:03.744 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:03.744 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:03.782 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:03.782 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:03.782 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:03.782 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:03.907 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:03.907 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:03.907 | Historical data download ID 121766 not found when removing ID from outstanding request set.
2024-08-14 17:16:03.907 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:03.907 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:03.907 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:03.907 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:03.907 | Historical data download ID 121767 not found when removing ID from outstanding request set.
2024-08-14 17:16:03.907 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:03.907 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:03.907 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:03.950 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:03.950 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:03.950 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:03.950 | DTC Client socket (4) | Closed.
2024-08-14 17:16:03.950 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:03.950 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:03.950 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:03.950 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:05.941 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:05.941 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:05.942 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:05.942 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:05.942 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:05.980 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:05.980 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:05.980 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:05.980 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:06.098 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:06.098 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:06.098 | Historical data download ID 121768 not found when removing ID from outstanding request set.
2024-08-14 17:16:06.098 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:06.098 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:06.098 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:06.098 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:06.098 | Historical data download ID 121769 not found when removing ID from outstanding request set.
2024-08-14 17:16:06.098 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:06.098 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:06.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:06.140 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:06.140 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:06.140 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:06.140 | DTC Client socket (4) | Closed.
2024-08-14 17:16:06.140 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:06.140 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:06.140 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:06.140 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:08.141 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:08.141 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:08.142 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:08.142 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:08.142 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:08.180 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:08.180 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:08.180 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:08.180 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:08.303 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:08.303 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:08.303 | Historical data download ID 121770 not found when removing ID from outstanding request set.
2024-08-14 17:16:08.303 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:08.303 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:08.303 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:08.303 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:08.303 | Historical data download ID 121771 not found when removing ID from outstanding request set.
2024-08-14 17:16:08.303 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:08.303 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:08.303 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:08.344 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:08.348 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:08.348 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:08.348 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:08.348 | DTC Client socket (4) | Closed.
2024-08-14 17:16:08.349 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:08.349 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:08.349 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:08.349 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:10.346 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:10.346 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:10.346 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:10.347 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:10.347 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:10.386 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:10.386 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:10.386 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:10.386 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:10.510 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:10.510 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:10.510 | Historical data download ID 121772 not found when removing ID from outstanding request set.
2024-08-14 17:16:10.510 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:10.510 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:10.510 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:10.510 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:10.510 | Historical data download ID 121773 not found when removing ID from outstanding request set.
2024-08-14 17:16:10.510 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:10.510 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:10.510 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:10.552 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:10.553 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:10.553 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:16:10.553 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:16:10.553 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:16:10.553 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:10.553 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:10.553 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:10.553 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:10.594 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:16:10.594 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:10.594 | DTC Client socket (4) | Closed.
2024-08-14 17:16:12.555 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:12.555 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:12.556 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:12.556 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:12.556 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:12.594 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:12.594 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:12.595 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:12.595 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:12.715 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:12.715 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:12.715 | Historical data download ID 121774 not found when removing ID from outstanding request set.
2024-08-14 17:16:12.715 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:12.715 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:12.715 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:12.715 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:12.715 | Historical data download ID 121775 not found when removing ID from outstanding request set.
2024-08-14 17:16:12.715 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:12.715 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:12.715 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:12.756 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:12.758 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:12.758 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:12.758 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:12.758 | DTC Client socket (4) | Closed.
2024-08-14 17:16:12.758 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:12.758 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:12.758 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:12.758 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:14.600 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:14.600 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:16:14.613 | HD Server | Thread:11548 (4) | Creating socket.
2024-08-14 17:16:14.613 | HD Server | Thread:11548 (4) | New receive buffer size: 262144
2024-08-14 17:16:14.613 | HD Server | Thread:11548 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:14.613 | HD Server | Setting DTC encoding to Binary VLS | Thread:11548
2024-08-14 17:16:14.614 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11548
2024-08-14 17:16:14.614 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11548
2024-08-14 17:16:14.614 | HD Server | HD Request #4259 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4259 | Username: DAVID SUDDUTH JR. | Thread:11548
2024-08-14 17:16:14.615 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4259 | Username: DAVID SUDDUTH JR. | Thread:11548
2024-08-14 17:16:14.615 | HD Server | Thread:11548 (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:14.615 | HD Server | Thread:11548 (4) | CloseSocket call.
2024-08-14 17:16:14.615 | HD Server | Thread:11548 (0) | CloseSocket call.
2024-08-14 17:16:14.616 | HD Server | Thread:11548 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:14.616 | HD Server | Thread:11548 (4) | Closed.
2024-08-14 17:16:14.616 | HD Server | Thread:11548 (0) | CloseSocket call.
2024-08-14 17:16:14.617 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:14.618 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:16:14.624 | HD Server | Thread:19492 (4) | Creating socket.
2024-08-14 17:16:14.624 | HD Server | Thread:19492 (4) | New receive buffer size: 262144
2024-08-14 17:16:14.624 | HD Server | Thread:19492 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:14.624 | HD Server | Setting DTC encoding to Binary VLS | Thread:19492
2024-08-14 17:16:14.625 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19492
2024-08-14 17:16:14.625 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19492
2024-08-14 17:16:14.625 | HD Server | HD Request #4260 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4260 | Username: DAVID SUDDUTH JR. | Thread:19492
2024-08-14 17:16:14.625 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4260 | Username: DAVID SUDDUTH JR. | Thread:19492
2024-08-14 17:16:14.626 | HD Server | Thread:19492 (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:14.626 | HD Server | Thread:19492 (4) | CloseSocket call.
2024-08-14 17:16:14.626 | HD Server | Thread:19492 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:16:14.626 | HD Server | Thread:19492 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:14.626 | HD Server | Thread:19492 (4) | Closed.
2024-08-14 17:16:14.676 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19492
2024-08-14 17:16:14.677 | HD Server Manager | Current server count=1
2024-08-14 17:16:14.677 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11548
2024-08-14 17:16:14.677 | HD Server Manager | Current server count=0
2024-08-14 17:16:14.756 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:14.756 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:14.757 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:14.757 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:14.757 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:14.795 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:14.795 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:14.795 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:14.795 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:14.918 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:14.918 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:14.918 | Historical data download ID 121776 not found when removing ID from outstanding request set.
2024-08-14 17:16:14.918 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:14.918 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:14.918 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:14.918 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:14.918 | Historical data download ID 121777 not found when removing ID from outstanding request set.
2024-08-14 17:16:14.918 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:14.918 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:14.918 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:14.960 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:14.962 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:14.962 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:14.963 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:14.963 | DTC Client socket (4) | Closed.
2024-08-14 17:16:14.963 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:14.963 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:14.963 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:14.963 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:16.960 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:16.960 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:16.961 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:16.961 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:16.961 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:16.999 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:16.999 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:16.999 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:16.999 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:17.067 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:17.068 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:16:17.081 | HD Server | Thread:11080 (5) | Creating socket.
2024-08-14 17:16:17.081 | HD Server | Thread:11080 (5) | New receive buffer size: 262144
2024-08-14 17:16:17.081 | HD Server | Thread:11080 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:17.081 | HD Server | Setting DTC encoding to Binary VLS | Thread:11080
2024-08-14 17:16:17.082 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11080
2024-08-14 17:16:17.082 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11080
2024-08-14 17:16:17.082 | HD Server | HD Request #4261 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4261 | Username: DAVID SUDDUTH JR. | Thread:11080
2024-08-14 17:16:17.083 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4261 | Username: DAVID SUDDUTH JR. | Thread:11080
2024-08-14 17:16:17.083 | HD Server | Thread:11080 (5) | Socket gracefully closed by remote side.
2024-08-14 17:16:17.083 | HD Server | Thread:11080 (5) | CloseSocket call.
2024-08-14 17:16:17.084 | HD Server | Thread:11080 (0) | CloseSocket call.
2024-08-14 17:16:17.084 | HD Server | Thread:11080 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:17.084 | HD Server | Thread:11080 (5) | Closed.
2024-08-14 17:16:17.086 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:17.095 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:16:17.106 | HD Server | Thread:20504 (5) | Creating socket.
2024-08-14 17:16:17.106 | HD Server | Thread:20504 (5) | New receive buffer size: 262144
2024-08-14 17:16:17.106 | HD Server | Thread:20504 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:17.106 | HD Server | Setting DTC encoding to Binary VLS | Thread:20504
2024-08-14 17:16:17.107 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:20504
2024-08-14 17:16:17.107 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:20504
2024-08-14 17:16:17.107 | HD Server | HD Request #4262 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4262 | Username: DAVID SUDDUTH JR. | Thread:20504
2024-08-14 17:16:17.107 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4262 | Username: DAVID SUDDUTH JR. | Thread:20504
2024-08-14 17:16:17.108 | HD Server | Thread:20504 (5) | Socket gracefully closed by remote side.
2024-08-14 17:16:17.108 | HD Server | Thread:20504 (5) | CloseSocket call.
2024-08-14 17:16:17.108 | HD Server | Thread:20504 (0) | CloseSocket call.
2024-08-14 17:16:17.108 | HD Server | Thread:20504 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:17.108 | HD Server | Thread:20504 (5) | Closed.
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:17.122 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:17.122 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:17.122 | Historical data download ID 121778 not found when removing ID from outstanding request set.
2024-08-14 17:16:17.122 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:17.122 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:17.122 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:17.122 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:17.122 | Historical data download ID 121779 not found when removing ID from outstanding request set.
2024-08-14 17:16:17.122 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:17.122 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:17.122 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:17.141 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:17.141 | HD Server Manager | Started new historical data server. Count=3
2024-08-14 17:16:17.156 | HD Server | Thread:9888 (5) | Creating socket.
2024-08-14 17:16:17.156 | HD Server | Thread:9888 (5) | New receive buffer size: 262144
2024-08-14 17:16:17.156 | HD Server | Thread:9888 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:17.156 | HD Server | Setting DTC encoding to Binary VLS | Thread:9888
2024-08-14 17:16:17.157 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:9888
2024-08-14 17:16:17.157 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:9888
2024-08-14 17:16:17.157 | HD Server | HD Request #4263 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4263 | Username: DAVID SUDDUTH JR. | Thread:9888
2024-08-14 17:16:17.158 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4263 | Username: DAVID SUDDUTH JR. | Thread:9888
2024-08-14 17:16:17.158 | HD Server | Thread:9888 (5) | Socket gracefully closed by remote side.
2024-08-14 17:16:17.158 | HD Server | Thread:9888 (5) | CloseSocket call.
2024-08-14 17:16:17.159 | HD Server | Thread:9888 (0) | CloseSocket call.
2024-08-14 17:16:17.159 | HD Server | Thread:9888 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:17.159 | HD Server | Thread:9888 (5) | Closed.
2024-08-14 17:16:17.162 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:17.164 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:17.168 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:17.168 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:17.168 | DTC Client socket (4) | Closed.
2024-08-14 17:16:17.169 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:17.169 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:17.169 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:17.169 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:17.182 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:9888
2024-08-14 17:16:17.182 | HD Server Manager | Current server count=2
2024-08-14 17:16:17.182 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:20504
2024-08-14 17:16:17.182 | HD Server Manager | Current server count=1
2024-08-14 17:16:17.182 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11080
2024-08-14 17:16:17.183 | HD Server Manager | Current server count=0
2024-08-14 17:16:19.160 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:19.160 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:19.160 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:19.160 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:19.161 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:19.200 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:19.200 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:19.200 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:19.200 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:19.339 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:19.339 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:19.339 | Historical data download ID 121780 not found when removing ID from outstanding request set.
2024-08-14 17:16:19.339 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:19.339 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:19.339 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:19.339 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:19.339 | Historical data download ID 121781 not found when removing ID from outstanding request set.
2024-08-14 17:16:19.339 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:19.339 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:19.339 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:19.380 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:19.380 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:19.380 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:19.380 | DTC Client socket (4) | Closed.
2024-08-14 17:16:19.380 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:19.380 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:19.380 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:19.380 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:21.384 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:21.384 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:21.385 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:21.385 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:21.385 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:21.423 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:21.423 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:21.424 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:21.424 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:21.547 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:21.547 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:21.547 | Historical data download ID 121782 not found when removing ID from outstanding request set.
2024-08-14 17:16:21.547 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:21.547 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:21.547 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:21.547 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:21.547 | Historical data download ID 121783 not found when removing ID from outstanding request set.
2024-08-14 17:16:21.547 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:21.547 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:21.547 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:21.590 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:21.590 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:21.590 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:21.590 | DTC Client socket (4) | Closed.
2024-08-14 17:16:21.591 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:21.591 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:21.591 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:21.591 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:23.584 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:23.584 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:23.585 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:23.585 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:23.585 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:23.623 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:23.623 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:23.623 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:23.623 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:23.746 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:23.746 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:23.746 | Historical data download ID 121784 not found when removing ID from outstanding request set.
2024-08-14 17:16:23.746 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:23.746 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:23.746 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:23.746 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:23.746 | Historical data download ID 121785 not found when removing ID from outstanding request set.
2024-08-14 17:16:23.746 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:23.746 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:23.746 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:23.787 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:23.788 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:23.788 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:23.788 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:23.788 | DTC Client socket (4) | Closed.
2024-08-14 17:16:23.788 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:23.789 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:23.789 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:23.789 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:25.784 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:25.784 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:25.784 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:25.784 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:25.784 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:25.822 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:25.822 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:25.822 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:25.822 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:25.951 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:25.951 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:25.951 | Historical data download ID 121786 not found when removing ID from outstanding request set.
2024-08-14 17:16:25.951 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:25.951 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:25.951 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:25.951 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:25.951 | Historical data download ID 121787 not found when removing ID from outstanding request set.
2024-08-14 17:16:25.951 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:25.951 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:25.951 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:25.991 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:25.992 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:25.992 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:25.992 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:25.992 | DTC Client socket (4) | Closed.
2024-08-14 17:16:25.993 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:25.993 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:25.993 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:25.993 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:27.991 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:27.991 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:27.991 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:27.992 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:27.992 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:28.029 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:28.029 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:28.029 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:28.029 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:28.152 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:28.152 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:28.152 | Historical data download ID 121788 not found when removing ID from outstanding request set.
2024-08-14 17:16:28.152 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:28.152 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:28.152 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:28.152 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:28.152 | Historical data download ID 121789 not found when removing ID from outstanding request set.
2024-08-14 17:16:28.152 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:28.152 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:28.152 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:28.194 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:28.194 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:28.194 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:28.195 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:28.195 | DTC Client socket (4) | Closed.
2024-08-14 17:16:28.195 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:28.196 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:28.196 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:28.196 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:30.192 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:30.192 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:30.193 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:30.193 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:30.193 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:30.232 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:30.232 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:30.232 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:30.232 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:30.356 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:30.356 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:30.356 | Historical data download ID 121790 not found when removing ID from outstanding request set.
2024-08-14 17:16:30.356 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:30.356 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:30.356 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:30.356 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:30.356 | Historical data download ID 121791 not found when removing ID from outstanding request set.
2024-08-14 17:16:30.356 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:30.356 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:30.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:30.399 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:30.399 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:30.399 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:30.399 | DTC Client socket (4) | Closed.
2024-08-14 17:16:30.399 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:30.399 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:30.399 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:30.399 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:32.403 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:32.403 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:32.404 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:32.404 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:32.404 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:32.443 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:32.443 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:32.443 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:32.443 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:32.569 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:32.569 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:32.569 | Historical data download ID 121792 not found when removing ID from outstanding request set.
2024-08-14 17:16:32.569 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:32.569 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:32.569 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:32.569 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:32.569 | Historical data download ID 121793 not found when removing ID from outstanding request set.
2024-08-14 17:16:32.569 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:32.569 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:32.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:32.611 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:32.611 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:32.611 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:32.611 | DTC Client socket (4) | Closed.
2024-08-14 17:16:32.611 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:32.612 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:32.612 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:32.612 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:34.615 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:34.615 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:34.615 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:34.616 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:34.616 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:34.655 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:34.655 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:34.655 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:34.655 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:34.779 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:34.779 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:34.779 | Historical data download ID 121794 not found when removing ID from outstanding request set.
2024-08-14 17:16:34.779 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:34.779 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:34.779 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:34.779 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:34.779 | Historical data download ID 121795 not found when removing ID from outstanding request set.
2024-08-14 17:16:34.779 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:34.779 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:34.779 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:34.823 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:34.823 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:34.823 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:34.823 | DTC Client socket (4) | Closed.
2024-08-14 17:16:34.823 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:34.824 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:34.824 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:34.824 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:36.815 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:36.815 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:36.815 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:36.816 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:36.816 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:36.859 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:36.859 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:36.860 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:36.860 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:36.985 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:36.985 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:36.985 | Historical data download ID 121796 not found when removing ID from outstanding request set.
2024-08-14 17:16:36.985 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:36.985 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:36.985 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:36.985 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:36.985 | Historical data download ID 121797 not found when removing ID from outstanding request set.
2024-08-14 17:16:36.985 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:36.985 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:36.985 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:37.027 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:37.027 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:37.027 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:37.027 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:37.027 | DTC Client socket (4) | Closed.
2024-08-14 17:16:37.027 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:37.028 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:37.028 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:37.028 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:39.018 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:39.018 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:39.019 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:39.019 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:39.019 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:39.057 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:39.057 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:39.057 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:39.057 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:39.176 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:39.176 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:39.176 | Historical data download ID 121798 not found when removing ID from outstanding request set.
2024-08-14 17:16:39.176 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:39.176 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:39.176 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:39.177 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:39.177 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:39.177 | Historical data download ID 121799 not found when removing ID from outstanding request set.
2024-08-14 17:16:39.177 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:39.177 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:39.177 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:39.218 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:39.219 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:39.219 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:39.219 | DTC Client socket (4) | Closed.
2024-08-14 17:16:39.219 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:39.219 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:39.219 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:39.219 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:41.210 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:41.210 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:41.211 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:41.211 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:41.211 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:41.252 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:41.252 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:41.252 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:41.252 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:41.374 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:41.374 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:41.374 | Historical data download ID 121800 not found when removing ID from outstanding request set.
2024-08-14 17:16:41.374 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:41.374 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:41.374 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:41.374 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:41.374 | Historical data download ID 121801 not found when removing ID from outstanding request set.
2024-08-14 17:16:41.374 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:41.374 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:41.374 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:41.414 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:41.416 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:41.416 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:41.416 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:41.416 | DTC Client socket (4) | Closed.
2024-08-14 17:16:41.416 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:41.417 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:41.417 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:41.417 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:43.413 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:43.413 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:43.414 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:43.414 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:43.414 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:43.452 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:43.452 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:43.452 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:43.452 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:43.577 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:43.577 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:43.577 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:43.577 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:43.577 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:43.577 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:43.577 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:43.577 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:43.577 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:43.577 | Historical data download ID 121802 not found when removing ID from outstanding request set.
2024-08-14 17:16:43.578 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:43.578 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:43.578 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:43.578 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:43.578 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:43.578 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:43.578 | Historical data download ID 121803 not found when removing ID from outstanding request set.
2024-08-14 17:16:43.578 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:43.578 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:43.578 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:43.618 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:43.619 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:43.619 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:43.620 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:43.620 | DTC Client socket (4) | Closed.
2024-08-14 17:16:43.620 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:43.620 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:43.620 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:43.620 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:45.268 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:45.269 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:16:45.280 | HD Server | Thread:16300 (4) | Creating socket.
2024-08-14 17:16:45.280 | HD Server | Thread:16300 (4) | New receive buffer size: 262144
2024-08-14 17:16:45.280 | HD Server | Thread:16300 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:45.280 | HD Server | Setting DTC encoding to Binary VLS | Thread:16300
2024-08-14 17:16:45.280 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:16300
2024-08-14 17:16:45.280 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:16300
2024-08-14 17:16:45.281 | HD Server | HD Request #4264 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4264 | Username: DAVID SUDDUTH JR. | Thread:16300
2024-08-14 17:16:45.282 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4264 | Username: DAVID SUDDUTH JR. | Thread:16300
2024-08-14 17:16:45.282 | HD Server | Thread:16300 (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:45.282 | HD Server | Thread:16300 (4) | CloseSocket call.
2024-08-14 17:16:45.282 | HD Server | Thread:16300 (0) | CloseSocket call.
2024-08-14 17:16:45.282 | HD Server | Thread:16300 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:45.282 | HD Server | Thread:16300 (4) | Closed.
2024-08-14 17:16:45.285 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:45.286 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:16:45.296 | HD Server | Thread:8664 (4) | Creating socket.
2024-08-14 17:16:45.296 | HD Server | Thread:8664 (4) | New receive buffer size: 262144
2024-08-14 17:16:45.297 | HD Server | Thread:8664 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:45.297 | HD Server | Setting DTC encoding to Binary VLS | Thread:8664
2024-08-14 17:16:45.297 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:8664
2024-08-14 17:16:45.297 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:8664
2024-08-14 17:16:45.298 | HD Server | HD Request #4265 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4265 | Username: DAVID SUDDUTH JR. | Thread:8664
2024-08-14 17:16:45.298 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4265 | Username: DAVID SUDDUTH JR. | Thread:8664
2024-08-14 17:16:45.298 | HD Server | Thread:8664 (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:45.299 | HD Server | Thread:8664 (4) | CloseSocket call.
2024-08-14 17:16:45.299 | HD Server | Thread:8664 (0) | CloseSocket call.
2024-08-14 17:16:45.299 | HD Server | Thread:8664 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:45.299 | HD Server | Thread:8664 (4) | Closed.
2024-08-14 17:16:45.451 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:8664
2024-08-14 17:16:45.451 | HD Server Manager | Current server count=1
2024-08-14 17:16:45.451 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:16300
2024-08-14 17:16:45.451 | HD Server Manager | Current server count=0
2024-08-14 17:16:45.624 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:45.624 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:45.625 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:45.625 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:45.625 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:45.663 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:45.663 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:45.663 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:45.663 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:45.790 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:45.790 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:45.790 | Historical data download ID 121804 not found when removing ID from outstanding request set.
2024-08-14 17:16:45.790 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:45.790 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:45.790 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:45.790 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:45.790 | Historical data download ID 121805 not found when removing ID from outstanding request set.
2024-08-14 17:16:45.790 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:45.790 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:45.790 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:45.845 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:45.845 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:45.846 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:45.846 | DTC Client socket (4) | Closed.
2024-08-14 17:16:45.846 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:45.846 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:45.846 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:45.847 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:45.847 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:45.847 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:47.815 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:47.815 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:16:47.826 | HD Server | Thread:17024 (4) | Creating socket.
2024-08-14 17:16:47.826 | HD Server | Thread:17024 (4) | New receive buffer size: 262144
2024-08-14 17:16:47.826 | HD Server | Thread:17024 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:47.827 | HD Server | Setting DTC encoding to Binary VLS | Thread:17024
2024-08-14 17:16:47.827 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:17024
2024-08-14 17:16:47.827 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:17024
2024-08-14 17:16:47.827 | HD Server | HD Request #4266 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4266 | Username: DAVID SUDDUTH JR. | Thread:17024
2024-08-14 17:16:47.828 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4266 | Username: DAVID SUDDUTH JR. | Thread:17024
2024-08-14 17:16:47.828 | HD Server | Thread:17024 (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:47.828 | HD Server | Thread:17024 (4) | CloseSocket call.
2024-08-14 17:16:47.828 | HD Server | Thread:17024 (0) | CloseSocket call.
2024-08-14 17:16:47.828 | HD Server | Thread:17024 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:47.828 | HD Server | Thread:17024 (4) | Closed.
2024-08-14 17:16:47.836 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:16:47.837 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:16:47.843 | HD Server | Thread:12560 (4) | Creating socket.
2024-08-14 17:16:47.843 | HD Server | Thread:12560 (4) | New receive buffer size: 262144
2024-08-14 17:16:47.843 | HD Server | Thread:12560 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:16:47.843 | HD Server | Setting DTC encoding to Binary VLS | Thread:12560
2024-08-14 17:16:47.844 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12560
2024-08-14 17:16:47.844 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12560
2024-08-14 17:16:47.844 | HD Server | HD Request #4267 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4267 | Username: DAVID SUDDUTH JR. | Thread:12560
2024-08-14 17:16:47.844 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4267 | Username: DAVID SUDDUTH JR. | Thread:12560
2024-08-14 17:16:47.845 | HD Server | Thread:12560 (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:47.845 | HD Server | Thread:12560 (4) | CloseSocket call.
2024-08-14 17:16:47.845 | HD Server | Thread:12560 (0) | CloseSocket call.
2024-08-14 17:16:47.845 | HD Server | Thread:12560 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:47.845 | HD Server | Thread:12560 (4) | Closed.
2024-08-14 17:16:47.853 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:47.853 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:47.854 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:47.854 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:47.854 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:47.892 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:47.892 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:47.892 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:47.892 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:47.947 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12560
2024-08-14 17:16:47.947 | HD Server Manager | Current server count=1
2024-08-14 17:16:47.947 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:17024
2024-08-14 17:16:47.947 | HD Server Manager | Current server count=0
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:48.012 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:48.012 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:48.012 | Historical data download ID 121806 not found when removing ID from outstanding request set.
2024-08-14 17:16:48.012 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:48.012 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:48.012 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:48.012 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:48.012 | Historical data download ID 121807 not found when removing ID from outstanding request set.
2024-08-14 17:16:48.012 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:48.012 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:48.012 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:48.054 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:48.054 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:48.055 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:48.055 | DTC Client socket (4) | Closed.
2024-08-14 17:16:48.055 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:48.055 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:48.055 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:48.055 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:50.061 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:50.061 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:50.062 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:50.062 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:50.062 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:50.100 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:50.100 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:50.100 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:50.100 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:50.221 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:50.221 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:50.221 | Historical data download ID 121808 not found when removing ID from outstanding request set.
2024-08-14 17:16:50.221 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:50.221 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:50.221 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:50.221 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:50.221 | Historical data download ID 121809 not found when removing ID from outstanding request set.
2024-08-14 17:16:50.221 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:50.221 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:50.221 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:50.262 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:50.264 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:50.264 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:50.265 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:50.265 | DTC Client socket (4) | Closed.
2024-08-14 17:16:50.265 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:50.265 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:50.265 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:50.265 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:52.256 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:52.256 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:52.256 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:52.257 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:52.257 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:52.295 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:52.295 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:52.295 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:52.295 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:52.420 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:52.420 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:52.420 | Historical data download ID 121810 not found when removing ID from outstanding request set.
2024-08-14 17:16:52.420 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:52.420 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:52.420 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:52.420 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:52.420 | Historical data download ID 121811 not found when removing ID from outstanding request set.
2024-08-14 17:16:52.420 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:52.420 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:52.420 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:52.459 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:52.459 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:52.459 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:52.459 | DTC Client socket (4) | Closed.
2024-08-14 17:16:52.459 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:52.460 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:52.460 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:52.460 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:54.456 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:54.456 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:54.456 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:54.456 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:54.456 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:54.492 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:54.492 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:54.492 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:54.492 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:54.615 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:54.615 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:54.615 | Historical data download ID 121812 not found when removing ID from outstanding request set.
2024-08-14 17:16:54.615 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:54.615 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:54.615 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:54.615 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:54.615 | Historical data download ID 121813 not found when removing ID from outstanding request set.
2024-08-14 17:16:54.615 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:54.615 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:54.615 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:54.656 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:54.658 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:54.658 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:54.658 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:54.658 | DTC Client socket (4) | Closed.
2024-08-14 17:16:54.658 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:54.659 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:54.659 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:54.659 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:56.661 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:56.661 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:56.662 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:56.662 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:56.662 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:56.701 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:56.701 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:56.701 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:56.701 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:56.823 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:56.823 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:56.823 | Historical data download ID 121814 not found when removing ID from outstanding request set.
2024-08-14 17:16:56.823 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:56.823 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:56.823 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:56.823 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:56.823 | Historical data download ID 121815 not found when removing ID from outstanding request set.
2024-08-14 17:16:56.823 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:56.823 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:56.823 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:56.865 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:16:56.866 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:56.866 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:56.866 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:56.866 | DTC Client socket (4) | Closed.
2024-08-14 17:16:56.866 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:56.867 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:56.867 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:56.867 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:16:58.872 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:16:58.872 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:16:58.872 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:16:58.872 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:16:58.873 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:16:58.912 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:16:58.912 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:16:58.912 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:16:58.912 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:16:59.036 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:16:59.036 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:16:59.036 | Historical data download ID 121816 not found when removing ID from outstanding request set.
2024-08-14 17:16:59.036 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:16:59.036 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:16:59.036 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:16:59.036 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:16:59.036 | Historical data download ID 121817 not found when removing ID from outstanding request set.
2024-08-14 17:16:59.036 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:16:59.036 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:16:59.036 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:16:59.082 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:16:59.082 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:16:59.082 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:16:59.082 | DTC Client socket (4) | Closed.
2024-08-14 17:16:59.083 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:16:59.083 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:16:59.083 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:16:59.083 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:01.088 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:01.088 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:01.088 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:01.089 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:01.089 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:01.127 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:01.127 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:01.127 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:01.127 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:01.252 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:01.252 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:01.252 | Historical data download ID 121818 not found when removing ID from outstanding request set.
2024-08-14 17:17:01.252 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:01.252 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:01.252 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:01.252 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:01.252 | Historical data download ID 121819 not found when removing ID from outstanding request set.
2024-08-14 17:17:01.252 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:01.252 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:01.252 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:01.294 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:01.295 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:01.295 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:01.295 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:01.295 | DTC Client socket (4) | Closed.
2024-08-14 17:17:01.296 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:01.296 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:01.296 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:01.296 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:03.284 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:03.284 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:03.285 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:03.285 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:03.285 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:03.324 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:03.324 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:03.324 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:03.324 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:03.447 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:03.447 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:03.447 | Historical data download ID 121820 not found when removing ID from outstanding request set.
2024-08-14 17:17:03.447 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:03.447 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:03.447 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:03.447 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:03.447 | Historical data download ID 121821 not found when removing ID from outstanding request set.
2024-08-14 17:17:03.447 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:03.447 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:03.447 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:03.488 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:03.492 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:03.492 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:03.492 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:03.492 | DTC Client socket (4) | Closed.
2024-08-14 17:17:03.492 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:03.493 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:03.493 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:03.493 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:05.497 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:05.497 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:05.498 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:05.498 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:05.498 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:05.539 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:05.539 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:05.539 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:05.539 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:05.673 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:05.673 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:05.673 | Historical data download ID 121822 not found when removing ID from outstanding request set.
2024-08-14 17:17:05.673 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:05.673 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:05.673 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:05.673 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:05.673 | Historical data download ID 121823 not found when removing ID from outstanding request set.
2024-08-14 17:17:05.673 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:05.673 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:05.673 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:05.716 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:05.716 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:05.716 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:05.716 | DTC Client socket (4) | Closed.
2024-08-14 17:17:05.716 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:05.717 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:05.717 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:05.717 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:07.718 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:07.718 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:07.719 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:07.719 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:07.719 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:07.758 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:07.758 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:07.758 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:07.758 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:07.880 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:07.880 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:07.880 | Historical data download ID 121824 not found when removing ID from outstanding request set.
2024-08-14 17:17:07.880 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:07.880 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:07.880 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:07.880 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:07.880 | Historical data download ID 121825 not found when removing ID from outstanding request set.
2024-08-14 17:17:07.880 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:07.880 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:07.880 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:07.921 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:07.922 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:07.922 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:07.922 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:07.922 | DTC Client socket (4) | Closed.
2024-08-14 17:17:07.923 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:07.923 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:07.923 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:07.923 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:09.934 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:09.934 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:09.934 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:09.934 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:09.934 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:09.973 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:09.973 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:09.973 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:09.973 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:10.100 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:10.100 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:10.100 | Historical data download ID 121826 not found when removing ID from outstanding request set.
2024-08-14 17:17:10.100 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:10.100 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:10.100 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:10.100 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:10.100 | Historical data download ID 121827 not found when removing ID from outstanding request set.
2024-08-14 17:17:10.100 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:10.100 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:10.100 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:10.143 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:10.143 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:10.143 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:10.143 | DTC Client socket (4) | Closed.
2024-08-14 17:17:10.143 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:10.144 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:10.144 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:10.144 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:12.144 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:12.144 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:12.145 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:12.145 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:12.145 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:12.184 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:12.184 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:12.184 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:12.184 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:12.310 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:12.310 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:12.310 | Historical data download ID 121828 not found when removing ID from outstanding request set.
2024-08-14 17:17:12.310 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:12.310 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:12.310 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:12.310 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:12.310 | Historical data download ID 121829 not found when removing ID from outstanding request set.
2024-08-14 17:17:12.310 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:12.310 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:12.310 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:12.350 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:12.354 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:12.355 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:12.355 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:12.355 | DTC Client socket (4) | Closed.
2024-08-14 17:17:12.355 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:12.355 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:12.355 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:12.355 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:14.347 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:14.347 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:14.348 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:14.348 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:14.348 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:14.386 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:14.386 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:14.386 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:14.386 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:14.510 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:14.510 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:14.510 | Historical data download ID 121830 not found when removing ID from outstanding request set.
2024-08-14 17:17:14.510 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:14.510 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:14.510 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:14.510 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:14.510 | Historical data download ID 121831 not found when removing ID from outstanding request set.
2024-08-14 17:17:14.510 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:14.510 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:14.510 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:14.554 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:14.554 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:14.554 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:14.554 | DTC Client socket (4) | Closed.
2024-08-14 17:17:14.554 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:14.554 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:14.554 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:14.554 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:15.616 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:15.616 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:17:15.625 | HD Server | Thread:11796 (4) | Creating socket.
2024-08-14 17:17:15.625 | HD Server | Thread:11796 (4) | New receive buffer size: 262144
2024-08-14 17:17:15.625 | HD Server | Thread:11796 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:15.625 | HD Server | Setting DTC encoding to Binary VLS | Thread:11796
2024-08-14 17:17:15.626 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11796
2024-08-14 17:17:15.626 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11796
2024-08-14 17:17:15.626 | HD Server | HD Request #4268 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4268 | Username: DAVID SUDDUTH JR. | Thread:11796
2024-08-14 17:17:15.626 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4268 | Username: DAVID SUDDUTH JR. | Thread:11796
2024-08-14 17:17:15.627 | HD Server | Thread:11796 (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:15.627 | HD Server | Thread:11796 (4) | CloseSocket call.
2024-08-14 17:17:15.627 | HD Server | Thread:11796 (0) | CloseSocket call.
2024-08-14 17:17:15.627 | HD Server | Thread:11796 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:15.627 | HD Server | Thread:11796 (4) | Closed.
2024-08-14 17:17:15.637 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:15.637 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:17:15.650 | HD Server | Thread:11164 (4) | Creating socket.
2024-08-14 17:17:15.650 | HD Server | Thread:11164 (4) | New receive buffer size: 262144
2024-08-14 17:17:15.650 | HD Server | Thread:11164 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:15.650 | HD Server | Setting DTC encoding to Binary VLS | Thread:11164
2024-08-14 17:17:15.651 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11164
2024-08-14 17:17:15.651 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11164
2024-08-14 17:17:15.651 | HD Server | HD Request #4269 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4269 | Username: DAVID SUDDUTH JR. | Thread:11164
2024-08-14 17:17:15.652 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4269 | Username: DAVID SUDDUTH JR. | Thread:11164
2024-08-14 17:17:15.652 | HD Server | Thread:11164 (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:15.652 | HD Server | Thread:11164 (4) | CloseSocket call.
2024-08-14 17:17:15.653 | HD Server | Thread:11164 (0) | CloseSocket call.
2024-08-14 17:17:15.653 | HD Server | Thread:11164 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:15.653 | HD Server | Thread:11164 (4) | Closed.
2024-08-14 17:17:15.748 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11164
2024-08-14 17:17:15.749 | HD Server Manager | Current server count=1
2024-08-14 17:17:15.749 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11796
2024-08-14 17:17:15.749 | HD Server Manager | Current server count=0
2024-08-14 17:17:16.553 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:16.553 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:16.553 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:16.553 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:16.553 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:16.593 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:16.593 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:16.593 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:16.593 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:16.713 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:16.713 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:16.713 | Historical data download ID 121832 not found when removing ID from outstanding request set.
2024-08-14 17:17:16.713 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:16.713 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:16.713 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:16.713 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:16.713 | Historical data download ID 121833 not found when removing ID from outstanding request set.
2024-08-14 17:17:16.713 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:16.713 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:16.713 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:16.754 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:16.755 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:16.755 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:16.756 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:16.756 | DTC Client socket (4) | Closed.
2024-08-14 17:17:16.756 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:16.756 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:16.756 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:16.756 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:18.106 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:18.107 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:17:18.120 | HD Server | Thread:15476 (5) | Creating socket.
2024-08-14 17:17:18.120 | HD Server | Thread:15476 (5) | New receive buffer size: 262144
2024-08-14 17:17:18.120 | HD Server | Thread:15476 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:18.120 | HD Server | Setting DTC encoding to Binary VLS | Thread:15476
2024-08-14 17:17:18.121 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15476
2024-08-14 17:17:18.121 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15476
2024-08-14 17:17:18.121 | HD Server | HD Request #4270 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4270 | Username: DAVID SUDDUTH JR. | Thread:15476
2024-08-14 17:17:18.121 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4270 | Username: DAVID SUDDUTH JR. | Thread:15476
2024-08-14 17:17:18.122 | HD Server | Thread:15476 (5) | Socket gracefully closed by remote side.
2024-08-14 17:17:18.122 | HD Server | Thread:15476 (5) | CloseSocket call.
2024-08-14 17:17:18.122 | HD Server | Thread:15476 (0) | CloseSocket call.
2024-08-14 17:17:18.123 | HD Server | Thread:15476 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:18.123 | HD Server | Thread:15476 (5) | Closed.
2024-08-14 17:17:18.123 | HD Server | Thread:15476 (0) | CloseSocket call.
2024-08-14 17:17:18.124 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:18.125 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:17:18.138 | HD Server | Thread:16748 (5) | Creating socket.
2024-08-14 17:17:18.138 | HD Server | Thread:16748 (5) | New receive buffer size: 262144
2024-08-14 17:17:18.138 | HD Server | Thread:16748 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:18.138 | HD Server | Setting DTC encoding to Binary VLS | Thread:16748
2024-08-14 17:17:18.138 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:16748
2024-08-14 17:17:18.138 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:16748
2024-08-14 17:17:18.138 | HD Server | HD Request #4271 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4271 | Username: DAVID SUDDUTH JR. | Thread:16748
2024-08-14 17:17:18.139 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4271 | Username: DAVID SUDDUTH JR. | Thread:16748
2024-08-14 17:17:18.140 | HD Server | Thread:16748 (5) | Socket gracefully closed by remote side.
2024-08-14 17:17:18.140 | HD Server | Thread:16748 (5) | CloseSocket call.
2024-08-14 17:17:18.140 | HD Server | Thread:16748 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:18.140 | HD Server | Thread:16748 (5) | Closed.
2024-08-14 17:17:18.140 | HD Server | Thread:16748 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:17:18.242 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:16748
2024-08-14 17:17:18.242 | HD Server Manager | Current server count=1
2024-08-14 17:17:18.242 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15476
2024-08-14 17:17:18.243 | HD Server Manager | Current server count=0
2024-08-14 17:17:18.762 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:18.762 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:18.763 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:18.763 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:17:18.763 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:18.801 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:18.801 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:18.801 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:18.801 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:18.923 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:18.923 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:18.923 | Historical data download ID 121834 not found when removing ID from outstanding request set.
2024-08-14 17:17:18.923 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:18.923 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:18.923 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:18.923 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:18.923 | Historical data download ID 121835 not found when removing ID from outstanding request set.
2024-08-14 17:17:18.923 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:18.923 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:18.923 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:18.966 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:17:18.966 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:17:18.966 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:18.966 | DTC Client socket (5) | Closed.
2024-08-14 17:17:18.967 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:18.967 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:18.967 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:18.967 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:20.962 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:20.962 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:20.963 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:20.963 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:20.963 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:20.999 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:20.999 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:20.999 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:20.999 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:21.123 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:21.123 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:21.123 | Historical data download ID 121836 not found when removing ID from outstanding request set.
2024-08-14 17:17:21.123 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:21.123 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:21.123 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:21.123 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:21.123 | Historical data download ID 121837 not found when removing ID from outstanding request set.
2024-08-14 17:17:21.123 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:21.123 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:21.123 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:21.166 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:21.166 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:21.166 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:21.166 | DTC Client socket (4) | Closed.
2024-08-14 17:17:21.166 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:21.166 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:21.166 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:21.166 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:23.170 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:23.170 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:23.170 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:23.171 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:23.171 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:23.209 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:23.209 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:23.209 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:23.209 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:23.331 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:23.331 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:23.331 | Historical data download ID 121838 not found when removing ID from outstanding request set.
2024-08-14 17:17:23.331 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:23.331 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:23.331 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:23.331 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:23.331 | Historical data download ID 121839 not found when removing ID from outstanding request set.
2024-08-14 17:17:23.331 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:23.331 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:23.331 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:23.372 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:23.374 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:23.374 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:23.374 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:23.374 | DTC Client socket (4) | Closed.
2024-08-14 17:17:23.374 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:23.375 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:23.375 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:23.375 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:25.375 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:25.375 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:25.376 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:25.376 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:25.376 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:25.421 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:25.421 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:25.421 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:25.421 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:25.547 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:25.547 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:25.547 | Historical data download ID 121840 not found when removing ID from outstanding request set.
2024-08-14 17:17:25.547 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:25.547 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:25.547 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:25.547 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:25.547 | Historical data download ID 121841 not found when removing ID from outstanding request set.
2024-08-14 17:17:25.547 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:25.547 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:25.547 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:25.591 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:25.591 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:25.591 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:25.591 | DTC Client socket (4) | Closed.
2024-08-14 17:17:25.591 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:25.592 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:25.592 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:25.592 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:27.584 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:27.584 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:27.585 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:27.585 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:27.585 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:27.623 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:27.623 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:27.624 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:27.624 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:27.745 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:27.745 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:27.745 | Historical data download ID 121842 not found when removing ID from outstanding request set.
2024-08-14 17:17:27.745 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:27.745 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:27.745 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:27.745 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:27.745 | Historical data download ID 121843 not found when removing ID from outstanding request set.
2024-08-14 17:17:27.745 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:27.745 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:27.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:27.787 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:27.788 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:27.788 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:27.788 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:27.788 | DTC Client socket (4) | Closed.
2024-08-14 17:17:27.789 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:27.789 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:27.789 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:27.789 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:29.794 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:29.794 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:29.795 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:29.795 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:29.795 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:29.837 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:29.837 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:29.837 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:29.837 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:29.962 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:29.962 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:29.962 | Historical data download ID 121844 not found when removing ID from outstanding request set.
2024-08-14 17:17:29.962 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:29.962 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:29.962 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:29.962 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:29.962 | Historical data download ID 121845 not found when removing ID from outstanding request set.
2024-08-14 17:17:29.962 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:29.962 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:29.962 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:30.002 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:30.002 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:30.002 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:30.003 | DTC Client socket (4) | Closed.
2024-08-14 17:17:30.003 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:30.003 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:30.003 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:30.003 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:32.008 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:32.008 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:32.008 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:32.008 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:32.008 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:32.047 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:32.047 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:32.047 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:32.047 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:32.171 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:32.171 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:32.171 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:32.171 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:32.171 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:32.171 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:32.171 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:32.171 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:32.171 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:32.171 | Historical data download ID 121846 not found when removing ID from outstanding request set.
2024-08-14 17:17:32.171 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:32.171 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:32.172 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:32.172 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:32.172 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:32.172 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:32.172 | Historical data download ID 121847 not found when removing ID from outstanding request set.
2024-08-14 17:17:32.172 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:32.172 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:32.172 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:32.214 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:32.216 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:32.216 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:32.216 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:32.216 | DTC Client socket (4) | Closed.
2024-08-14 17:17:32.217 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:32.217 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:32.217 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:32.217 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:34.216 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:34.216 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:34.216 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:34.216 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:34.216 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:34.255 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:34.255 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:34.255 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:34.255 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:34.387 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:34.387 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:34.387 | Historical data download ID 121848 not found when removing ID from outstanding request set.
2024-08-14 17:17:34.387 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:34.387 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:34.387 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:34.387 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:34.387 | Historical data download ID 121849 not found when removing ID from outstanding request set.
2024-08-14 17:17:34.387 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:34.387 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:34.387 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:34.430 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:34.430 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:34.430 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:34.430 | DTC Client socket (4) | Closed.
2024-08-14 17:17:34.430 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:34.431 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:34.431 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:34.431 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:36.431 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:36.431 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:36.432 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:36.432 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:36.432 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:36.471 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:36.471 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:36.471 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:36.472 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:36.595 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:36.595 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:36.595 | Historical data download ID 121850 not found when removing ID from outstanding request set.
2024-08-14 17:17:36.595 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:36.595 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:36.595 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:36.595 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:36.595 | Historical data download ID 121851 not found when removing ID from outstanding request set.
2024-08-14 17:17:36.595 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:36.595 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:36.595 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:36.636 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:36.636 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:36.636 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:36.636 | DTC Client socket (4) | Closed.
2024-08-14 17:17:36.636 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:36.637 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:36.637 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:36.637 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:38.628 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:38.628 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:38.629 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:38.629 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:38.629 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:38.668 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:38.668 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:38.668 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:38.668 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:38.791 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:38.791 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:38.791 | Historical data download ID 121852 not found when removing ID from outstanding request set.
2024-08-14 17:17:38.791 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:38.791 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:38.791 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:38.791 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:38.791 | Historical data download ID 121853 not found when removing ID from outstanding request set.
2024-08-14 17:17:38.791 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:38.791 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:38.791 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:38.833 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:38.833 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:38.833 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:38.833 | DTC Client socket (4) | Closed.
2024-08-14 17:17:38.834 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:38.834 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:38.834 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:38.834 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:40.830 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:40.830 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:40.830 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:40.831 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:40.831 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:40.868 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:40.868 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:40.869 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:40.869 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:40.991 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:40.991 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:40.991 | Historical data download ID 121854 not found when removing ID from outstanding request set.
2024-08-14 17:17:40.991 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:40.991 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:40.991 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:40.991 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:40.991 | Historical data download ID 121855 not found when removing ID from outstanding request set.
2024-08-14 17:17:40.991 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:40.991 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:40.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:41.033 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:41.034 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:41.034 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:41.034 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:41.034 | DTC Client socket (4) | Closed.
2024-08-14 17:17:41.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:41.035 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:41.035 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:41.035 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:43.039 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:43.039 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:43.039 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:43.039 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:43.039 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:43.077 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:43.077 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:43.077 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:43.077 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:43.200 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:43.200 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:43.200 | Historical data download ID 121856 not found when removing ID from outstanding request set.
2024-08-14 17:17:43.200 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:43.200 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:43.200 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:43.200 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:43.200 | Historical data download ID 121857 not found when removing ID from outstanding request set.
2024-08-14 17:17:43.200 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:43.200 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:43.200 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:43.242 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:43.243 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:43.243 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:43.243 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:43.243 | DTC Client socket (4) | Closed.
2024-08-14 17:17:43.243 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:43.244 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:43.244 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:43.244 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:45.241 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:45.241 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:45.242 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:45.242 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:45.242 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:45.283 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:45.283 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:45.283 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:45.283 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:45.405 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:45.405 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:45.405 | Historical data download ID 121858 not found when removing ID from outstanding request set.
2024-08-14 17:17:45.405 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:45.405 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:45.405 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:45.406 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:45.406 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:45.406 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:45.406 | Historical data download ID 121859 not found when removing ID from outstanding request set.
2024-08-14 17:17:45.406 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:45.406 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:45.406 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:45.446 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:45.446 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:45.446 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:45.447 | DTC Client socket (4) | Closed.
2024-08-14 17:17:45.447 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:45.447 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:45.447 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:45.447 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:46.330 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:46.331 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:17:46.345 | HD Server | Thread:9192 (4) | Creating socket.
2024-08-14 17:17:46.345 | HD Server | Thread:9192 (4) | New receive buffer size: 262144
2024-08-14 17:17:46.345 | HD Server | Thread:9192 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:46.345 | HD Server | Setting DTC encoding to Binary VLS | Thread:9192
2024-08-14 17:17:46.346 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:9192
2024-08-14 17:17:46.346 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:9192
2024-08-14 17:17:46.347 | HD Server | HD Request #4272 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4272 | Username: DAVID SUDDUTH JR. | Thread:9192
2024-08-14 17:17:46.348 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4272 | Username: DAVID SUDDUTH JR. | Thread:9192
2024-08-14 17:17:46.348 | HD Server | Thread:9192 (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:46.348 | HD Server | Thread:9192 (4) | CloseSocket call.
2024-08-14 17:17:46.349 | HD Server | Thread:9192 (0) | CloseSocket call.
2024-08-14 17:17:46.350 | HD Server | Thread:9192 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:46.350 | HD Server | Thread:9192 (4) | Closed.
2024-08-14 17:17:46.350 | HD Server | Thread:9192 (0) | CloseSocket call.
2024-08-14 17:17:46.384 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:46.384 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:17:46.395 | HD Server | Thread:14108 (4) | Creating socket.
2024-08-14 17:17:46.395 | HD Server | Thread:14108 (4) | New receive buffer size: 262144
2024-08-14 17:17:46.395 | HD Server | Thread:14108 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:46.395 | HD Server | Setting DTC encoding to Binary VLS | Thread:14108
2024-08-14 17:17:46.395 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:14108
2024-08-14 17:17:46.395 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:14108
2024-08-14 17:17:46.396 | HD Server | HD Request #4273 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4273 | Username: DAVID SUDDUTH JR. | Thread:14108
2024-08-14 17:17:46.397 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4273 | Username: DAVID SUDDUTH JR. | Thread:14108
2024-08-14 17:17:46.397 | HD Server | Thread:14108 (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:46.397 | HD Server | Thread:14108 (4) | CloseSocket call.
2024-08-14 17:17:46.397 | HD Server | Thread:14108 (0) | CloseSocket call.
2024-08-14 17:17:46.397 | HD Server | Thread:14108 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:46.397 | HD Server | Thread:14108 (4) | Closed.
2024-08-14 17:17:46.502 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:14108
2024-08-14 17:17:46.502 | HD Server Manager | Current server count=1
2024-08-14 17:17:46.502 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:9192
2024-08-14 17:17:46.502 | HD Server Manager | Current server count=0
2024-08-14 17:17:47.452 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:47.452 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:47.453 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:47.453 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:47.453 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:47.492 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:47.492 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:47.492 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:47.492 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:47.616 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:47.616 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:47.616 | Historical data download ID 121860 not found when removing ID from outstanding request set.
2024-08-14 17:17:47.616 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:47.616 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:47.616 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:47.616 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:47.616 | Historical data download ID 121861 not found when removing ID from outstanding request set.
2024-08-14 17:17:47.616 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:47.616 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:47.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:47.654 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:47.654 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:47.654 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:47.654 | DTC Client socket (4) | Closed.
2024-08-14 17:17:47.654 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:47.655 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:47.655 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:47.655 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:48.841 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:48.842 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:17:48.854 | HD Server | Thread:19732 (4) | Creating socket.
2024-08-14 17:17:48.854 | HD Server | Thread:19732 (4) | New receive buffer size: 262144
2024-08-14 17:17:48.854 | HD Server | Thread:19732 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:48.854 | HD Server | Setting DTC encoding to Binary VLS | Thread:19732
2024-08-14 17:17:48.855 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19732
2024-08-14 17:17:48.855 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19732
2024-08-14 17:17:48.856 | HD Server | HD Request #4274 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4274 | Username: DAVID SUDDUTH JR. | Thread:19732
2024-08-14 17:17:48.856 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4274 | Username: DAVID SUDDUTH JR. | Thread:19732
2024-08-14 17:17:48.857 | HD Server | Thread:19732 (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:48.857 | HD Server | Thread:19732 (4) | CloseSocket call.
2024-08-14 17:17:48.857 | HD Server | Thread:19732 (0) | CloseSocket call.
2024-08-14 17:17:48.857 | HD Server | Thread:19732 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:48.857 | HD Server | Thread:19732 (4) | Closed.
2024-08-14 17:17:48.858 | HD Server | Thread:19732 (0) | CloseSocket call.
2024-08-14 17:17:48.860 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:17:48.861 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:17:48.873 | HD Server | Thread:9320 (4) | Creating socket.
2024-08-14 17:17:48.873 | HD Server | Thread:9320 (4) | New receive buffer size: 262144
2024-08-14 17:17:48.873 | HD Server | Thread:9320 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:17:48.874 | HD Server | Setting DTC encoding to Binary VLS | Thread:9320
2024-08-14 17:17:48.875 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:9320
2024-08-14 17:17:48.875 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:9320
2024-08-14 17:17:48.876 | HD Server | HD Request #4275 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4275 | Username: DAVID SUDDUTH JR. | Thread:9320
2024-08-14 17:17:48.876 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4275 | Username: DAVID SUDDUTH JR. | Thread:9320
2024-08-14 17:17:48.877 | HD Server | Thread:9320 (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:48.877 | HD Server | Thread:9320 (4) | CloseSocket call.
2024-08-14 17:17:48.877 | HD Server | Thread:9320 (0) | CloseSocket call.
2024-08-14 17:17:48.877 | HD Server | Thread:9320 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:48.877 | HD Server | Thread:9320 (4) | Closed.
2024-08-14 17:17:48.878 | HD Server | Thread:9320 (0) | CloseSocket call.
2024-08-14 17:17:49.003 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:9320
2024-08-14 17:17:49.003 | HD Server Manager | Current server count=1
2024-08-14 17:17:49.003 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19732
2024-08-14 17:17:49.003 | HD Server Manager | Current server count=0
2024-08-14 17:17:49.646 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:49.646 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:49.646 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:49.647 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:49.647 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:49.690 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:49.690 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:49.690 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:49.690 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:49.814 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:49.814 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:49.814 | Historical data download ID 121862 not found when removing ID from outstanding request set.
2024-08-14 17:17:49.814 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:49.814 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:49.814 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:49.814 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:49.814 | Historical data download ID 121863 not found when removing ID from outstanding request set.
2024-08-14 17:17:49.814 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:49.814 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:49.814 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:49.857 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:49.858 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:49.858 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:49.858 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:49.858 | DTC Client socket (4) | Closed.
2024-08-14 17:17:49.858 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:49.858 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:49.858 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:49.858 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:51.859 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:51.859 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:51.859 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:51.859 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:51.859 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:51.899 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:51.899 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:51.899 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:51.899 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:52.024 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:52.024 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:52.024 | Historical data download ID 121864 not found when removing ID from outstanding request set.
2024-08-14 17:17:52.024 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:52.024 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:52.024 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:52.024 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:52.024 | Historical data download ID 121865 not found when removing ID from outstanding request set.
2024-08-14 17:17:52.024 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:52.024 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:52.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:52.066 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:52.066 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:52.066 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:52.066 | DTC Client socket (4) | Closed.
2024-08-14 17:17:52.066 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:52.066 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:52.066 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:52.066 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:54.075 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:54.075 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:54.076 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:54.076 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:54.076 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:54.114 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:54.114 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:54.114 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:54.114 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:54.236 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:54.236 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:54.236 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:54.236 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:54.237 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:54.237 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:54.237 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:54.237 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:54.237 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:54.237 | Historical data download ID 121866 not found when removing ID from outstanding request set.
2024-08-14 17:17:54.237 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:54.237 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:54.237 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:54.237 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:54.237 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:54.237 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:54.237 | Historical data download ID 121867 not found when removing ID from outstanding request set.
2024-08-14 17:17:54.237 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:54.237 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:54.237 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:54.278 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:54.279 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:54.279 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:54.279 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:54.279 | DTC Client socket (4) | Closed.
2024-08-14 17:17:54.280 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:54.280 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:54.280 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:54.280 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:56.267 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:56.267 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:56.267 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:56.268 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:56.268 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:56.306 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:56.306 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:56.306 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:56.306 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:56.425 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:56.425 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:56.425 | Historical data download ID 121868 not found when removing ID from outstanding request set.
2024-08-14 17:17:56.425 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:56.425 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:56.425 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:56.426 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:56.426 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:56.426 | Historical data download ID 121869 not found when removing ID from outstanding request set.
2024-08-14 17:17:56.426 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:56.426 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:56.426 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:56.467 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:17:56.468 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:56.468 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:56.468 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:56.468 | DTC Client socket (4) | Closed.
2024-08-14 17:17:56.468 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:56.469 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:56.469 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:56.469 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:58.462 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:17:58.462 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:17:58.463 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:17:58.463 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:17:58.463 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:17:58.500 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:17:58.500 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:17:58.501 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:17:58.501 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:17:58.625 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:17:58.625 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:17:58.625 | Historical data download ID 121870 not found when removing ID from outstanding request set.
2024-08-14 17:17:58.625 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:17:58.625 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:17:58.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:17:58.625 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:17:58.625 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:17:58.626 | Historical data download ID 121871 not found when removing ID from outstanding request set.
2024-08-14 17:17:58.626 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:17:58.626 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:17:58.626 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:17:58.668 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:17:58.668 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:17:58.669 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:17:58.669 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:17:58.669 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=96
2024-08-14 17:17:58.669 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:17:58.669 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:17:58.669 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:17:58.669 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:17:58.709 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:17:58.709 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:17:58.709 | DTC Client socket (4) | Closed.
2024-08-14 17:18:00.660 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:00.660 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:00.661 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:00.661 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:00.661 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:00.703 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:00.703 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:00.703 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:00.703 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:00.831 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:00.831 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:00.831 | Historical data download ID 121872 not found when removing ID from outstanding request set.
2024-08-14 17:18:00.831 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:00.831 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:00.831 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:00.831 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:00.831 | Historical data download ID 121873 not found when removing ID from outstanding request set.
2024-08-14 17:18:00.831 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:00.831 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:00.831 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:00.873 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:00.873 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:00.873 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:00.873 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:00.873 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=96
2024-08-14 17:18:00.873 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:00.873 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:00.873 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:00.873 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:00.915 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:18:00.915 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:00.915 | DTC Client socket (4) | Closed.
2024-08-14 17:18:02.867 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:02.867 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:02.868 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:02.868 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:02.868 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:02.906 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:02.906 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:02.906 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:02.906 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:03.037 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:03.037 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:03.037 | Historical data download ID 121874 not found when removing ID from outstanding request set.
2024-08-14 17:18:03.037 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:03.037 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:03.037 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:03.037 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:03.037 | Historical data download ID 121875 not found when removing ID from outstanding request set.
2024-08-14 17:18:03.037 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:03.037 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:03.037 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:03.079 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:18:03.080 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:03.080 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:03.080 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:03.080 | DTC Client socket (4) | Closed.
2024-08-14 17:18:03.081 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:03.081 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:03.081 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:03.081 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:05.088 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:05.088 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:05.089 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:05.089 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:05.089 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:05.129 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:05.129 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:05.129 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:05.129 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:05.255 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:05.255 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:05.255 | Historical data download ID 121876 not found when removing ID from outstanding request set.
2024-08-14 17:18:05.255 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:05.255 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:05.255 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:05.255 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:05.255 | Historical data download ID 121877 not found when removing ID from outstanding request set.
2024-08-14 17:18:05.255 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:05.255 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:05.255 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:05.298 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:05.298 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:05.298 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:05.298 | DTC Client socket (4) | Closed.
2024-08-14 17:18:05.299 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:05.299 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:05.299 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:05.299 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:06.697 | ESU4.CME [CBV] #1 | Reloading chart.
2024-08-14 17:18:06.697 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:06.697 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:06.697 | Historical data download ID 121878 not found when removing ID from outstanding request set.
2024-08-14 17:18:06.698 | ESU4.CME [CBV] #1 | Performing continuous chart historical Daily data download for symbol ESU4.CME starting at last date in file.
2024-08-14 17:18:06.698 | Starting DelayedDownloadMonitoringTimer
2024-08-14 17:18:06.698 | Starting HDTimeoutTimer
2024-08-14 17:18:06.699 | Added historical Daily data request for ESU4.CME to the queue.
2024-08-14 17:18:06.700 | Triggering next historical data download in queue.
2024-08-14 17:18:06.701 | Enabling compression for file: D:\SierraChart\Data\ESU4.CME.dly
2024-08-14 17:18:06.707 | ESU4.CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 121879,
2024-08-14 17:18:06.717 | Loading DLL: D:\SierraChart\Data\ECIDiv.dll (ECIDiv_2151_64.dll). Handle: 7ff98cb30000
2024-08-14 17:18:07.410 | Loading DLL: D:\SierraChart\Data\MGannSwing.dll (MGannSwing_64.dll). Handle: 65380000
2024-08-14 17:18:07.655 | Loading DLL: D:\SierraChart\Data\MBoxWaveXE.dll (MBoxWaveXE_64.dll). Handle: 6fbc0000
2024-08-14 17:18:07.660 | Loading DLL: D:\SierraChart\Data\AverageDailyRange.dll (AverageDailyRange_2151_64.dll). Handle: 7ff979b30000
2024-08-14 17:18:07.681 | Loading DLL: D:\SierraChart\Data\ECIVwapV1.5_EWR.dll (ECIVwapV1.5_EWR_64.dll). Handle: 66000000
2024-08-14 17:18:07.690 | Loading DLL: D:\SierraChart\Data\sudduth.dll (sudduth_2151_64.dll). Handle: 7ff979af0000
2024-08-14 17:18:07.714 | ESU4.CME [CB] 30 Min #2 | Reloading chart.
2024-08-14 17:18:07.714 | Rithmic Direct - DTC | Using primary service for historical data for ESZ1.CME
2024-08-14 17:18:07.714 | Historical data service client indicated that downloads are not enabled. Symbol: ESZ1.CME. Data Type: Intraday data.
2024-08-14 17:18:07.714 | Historical data download ID 121880 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.714 | Real-time Intraday chart data file updates started for ESZ1.CME
2024-08-14 17:18:07.714 | Intraday chart data file opened for ESZ1.CME
2024-08-14 17:18:07.716 | Rithmic Direct - DTC | Using primary service for historical data for ESH2.CME
2024-08-14 17:18:07.716 | Historical data service client indicated that downloads are not enabled. Symbol: ESH2.CME. Data Type: Intraday data.
2024-08-14 17:18:07.716 | Historical data download ID 121881 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.716 | Real-time Intraday chart data file updates started for ESH2.CME
2024-08-14 17:18:07.716 | Intraday chart data file opened for ESH2.CME
2024-08-14 17:18:07.717 | Rithmic Direct - DTC | Using primary service for historical data for ESM2.CME
2024-08-14 17:18:07.717 | Historical data service client indicated that downloads are not enabled. Symbol: ESM2.CME. Data Type: Intraday data.
2024-08-14 17:18:07.717 | Historical data download ID 121882 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.718 | Real-time Intraday chart data file updates started for ESM2.CME
2024-08-14 17:18:07.718 | Intraday chart data file opened for ESM2.CME
2024-08-14 17:18:07.726 | Rithmic Direct - DTC | Using primary service for historical data for ESU2.CME
2024-08-14 17:18:07.726 | Historical data service client indicated that downloads are not enabled. Symbol: ESU2.CME. Data Type: Intraday data.
2024-08-14 17:18:07.726 | Historical data download ID 121883 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.726 | Real-time Intraday chart data file updates started for ESU2.CME
2024-08-14 17:18:07.726 | Intraday chart data file opened for ESU2.CME
2024-08-14 17:18:07.727 | ESU4.CME [CB] 30 Min #2 | Performing continuous chart historical Daily data download for symbol ESU2.CME starting at last date in file.
2024-08-14 17:18:07.727 | Added historical Daily data request for ESU2.CME to the queue.
2024-08-14 17:18:07.727 | Rithmic Direct - DTC | Using primary service for historical data for ESZ2.CME
2024-08-14 17:18:07.727 | Historical data service client indicated that downloads are not enabled. Symbol: ESZ2.CME. Data Type: Intraday data.
2024-08-14 17:18:07.727 | Historical data download ID 121885 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.727 | Real-time Intraday chart data file updates started for ESZ2.CME
2024-08-14 17:18:07.727 | Intraday chart data file opened for ESZ2.CME
2024-08-14 17:18:07.729 | Rithmic Direct - DTC | Using primary service for historical data for ESH3.CME
2024-08-14 17:18:07.729 | Historical data service client indicated that downloads are not enabled. Symbol: ESH3.CME. Data Type: Intraday data.
2024-08-14 17:18:07.729 | Historical data download ID 121886 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.729 | Real-time Intraday chart data file updates started for ESH3.CME
2024-08-14 17:18:07.729 | Intraday chart data file opened for ESH3.CME
2024-08-14 17:18:07.742 | Rithmic Direct - DTC | Using primary service for historical data for ESU3.CME
2024-08-14 17:18:07.742 | Historical data service client indicated that downloads are not enabled. Symbol: ESU3.CME. Data Type: Intraday data.
2024-08-14 17:18:07.742 | Historical data download ID 121887 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.742 | Real-time Intraday chart data file updates started for ESU3.CME
2024-08-14 17:18:07.742 | Intraday chart data file opened for ESU3.CME
2024-08-14 17:18:07.751 | Rithmic Direct - DTC | Using primary service for historical data for ESH4.CME
2024-08-14 17:18:07.751 | Historical data service client indicated that downloads are not enabled. Symbol: ESH4.CME. Data Type: Intraday data.
2024-08-14 17:18:07.751 | Historical data download ID 121888 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.751 | Real-time Intraday chart data file updates started for ESH4.CME
2024-08-14 17:18:07.751 | Intraday chart data file opened for ESH4.CME
2024-08-14 17:18:07.752 | ESU4.CME [CB] 30 Min #2 | Performing continuous chart historical Daily data download for symbol ESH4.CME starting at last date in file.
2024-08-14 17:18:07.752 | Added historical Daily data request for ESH4.CME to the queue.
2024-08-14 17:18:07.752 | Rithmic Direct - DTC | Using primary service for historical data for ESM4.CME
2024-08-14 17:18:07.752 | Historical data service client indicated that downloads are not enabled. Symbol: ESM4.CME. Data Type: Intraday data.
2024-08-14 17:18:07.752 | Historical data download ID 121890 not found when removing ID from outstanding request set.
2024-08-14 17:18:07.752 | Real-time Intraday chart data file updates started for ESM4.CME
2024-08-14 17:18:07.752 | Intraday chart data file opened for ESM4.CME
2024-08-14 17:18:07.753 | ESU4.CME [CB] 30 Min #2 | Performing continuous chart historical Daily data download for symbol ESM4.CME starting at last date in file.
2024-08-14 17:18:07.753 | Added historical Daily data request for ESM4.CME to the queue.
2024-08-14 17:18:07.759 | Enabling compression for file: D:\SierraChart\Data\ESM4.CME.dly
2024-08-14 17:18:07.768 | Enabling compression for file: D:\SierraChart\Data\ESH4.CME.dly
2024-08-14 17:18:07.775 | Enabling compression for file: D:\SierraChart\Data\ESZ3.CME.dly
2024-08-14 17:18:07.784 | Enabling compression for file: D:\SierraChart\Data\ESU3.CME.dly
2024-08-14 17:18:07.793 | Enabling compression for file: D:\SierraChart\Data\ESM3.CME.dly
2024-08-14 17:18:07.802 | Enabling compression for file: D:\SierraChart\Data\ESH3.CME.dly
2024-08-14 17:18:07.811 | Enabling compression for file: D:\SierraChart\Data\ESZ2.CME.dly
2024-08-14 17:18:07.820 | Enabling compression for file: D:\SierraChart\Data\ESU2.CME.dly
2024-08-14 17:18:07.824 | Enabling compression for file: D:\SierraChart\Data\ESM2.CME.dly
2024-08-14 17:18:07.833 | Enabling compression for file: D:\SierraChart\Data\ESH2.CME.dly
2024-08-14 17:18:07.842 | Enabling compression for file: D:\SierraChart\Data\ESZ1.CME.dly
2024-08-14 17:18:07.850 | ESU4.CME [CB] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 121879, 121884, 121889, 121891,
2024-08-14 17:18:08.110 | ESU4.CME #3 | Reloading chart.
2024-08-14 17:18:08.136 | Loading DLL: D:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ff952b60000
2024-08-14 17:18:08.140 | Loading DLL: D:\SierraChart\Data\CustomDailyOhlcSinglePoint.dll (CustomDailyOhlcSinglePoint_2151_64.dll). Handle: 7ff979ac0000
2024-08-14 17:18:08.176 | CLU4.NYMEX [CB] 1000 Volume #4 | Reloading chart.
2024-08-14 17:18:08.177 | Rithmic Direct - DTC | Using primary service for historical data for CLN4.NYMEX
2024-08-14 17:18:08.177 | Historical data service client indicated that downloads are not enabled. Symbol: CLN4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:08.177 | Historical data download ID 121892 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.177 | Real-time Intraday chart data file updates started for CLN4.NYMEX
2024-08-14 17:18:08.177 | Intraday chart data file opened for CLN4.NYMEX
2024-08-14 17:18:08.178 | CLU4.NYMEX [CB] 1000 Volume #4 | Performing continuous chart historical Daily data download for symbol CLN4.NYMEX starting at last date in file.
2024-08-14 17:18:08.178 | Added historical Daily data request for CLN4.NYMEX to the queue.
2024-08-14 17:18:08.178 | Rithmic Direct - DTC | Using primary service for historical data for CLQ4.NYMEX
2024-08-14 17:18:08.178 | Historical data service client indicated that downloads are not enabled. Symbol: CLQ4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:08.178 | Historical data download ID 121894 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.178 | Real-time Intraday chart data file updates started for CLQ4.NYMEX
2024-08-14 17:18:08.178 | Intraday chart data file opened for CLQ4.NYMEX
2024-08-14 17:18:08.179 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:08.179 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:08.179 | Historical data download ID 121895 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.180 | Enabling compression for file: D:\SierraChart\Data\CLU4.NYMEX.dly
2024-08-14 17:18:08.184 | Enabling compression for file: D:\SierraChart\Data\CLQ4.NYMEX.dly
2024-08-14 17:18:08.188 | Enabling compression for file: D:\SierraChart\Data\CLN4.NYMEX.dly
2024-08-14 17:18:08.191 | CLU4.NYMEX [CB] 1000 Volume #4 | Waiting for historical downloads to complete with the IDs: 121893,
2024-08-14 17:18:08.194 | Enabling compression for file: D:\SierraChart\Data\ESU24_FUT_CME.dly
2024-08-14 17:18:08.237 | ESU24_FUT_CME [CBV] Daily #5 | Reloading chart.
2024-08-14 17:18:08.237 | ESU24_FUT_CME [CBV] Daily #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2024-08-14 17:18:08.237 | ESU24_FUT_CME [CBV] Daily #5 | There are no continuous futures contract symbols. Loading data normally.
2024-08-14 17:18:08.289 | ESU4.CME [CB] 500000 Volume #6 | Reloading chart.
2024-08-14 17:18:08.330 | ESU4.CME [CB] 500000 Volume #6 | Waiting for historical downloads to complete with the IDs: 121879, 121889, 121891,
2024-08-14 17:18:08.386 | ESU4.CME [CB] 150000 Volume #7 | Reloading chart.
2024-08-14 17:18:08.441 | ESU4.CME [CB] 150000 Volume #7 | Waiting for historical downloads to complete with the IDs: 121879, 121889, 121891,
2024-08-14 17:18:08.486 | ESU4.CME [CB] 50000 Volume #8 | Reloading chart.
2024-08-14 17:18:08.539 | ESU4.CME [CB] 50000 Volume #8 | Waiting for historical downloads to complete with the IDs: 121879, 121889, 121891,
2024-08-14 17:18:08.552 | ESU4.CME [CB] 30 Min #9 | Reloading chart.
2024-08-14 17:18:08.558 | ESU4.CME [CB] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 121879,
2024-08-14 17:18:08.573 | ESU4.CME [CB] 1 Day #10 | Reloading chart.
2024-08-14 17:18:08.573 | Rithmic Direct - DTC | Using primary service for historical data for ESU0.CME
2024-08-14 17:18:08.573 | Historical data service client indicated that downloads are not enabled. Symbol: ESU0.CME. Data Type: Intraday data.
2024-08-14 17:18:08.573 | Historical data download ID 121896 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.573 | Real-time Intraday chart data file updates started for ESU0.CME
2024-08-14 17:18:08.573 | Intraday chart data file opened for ESU0.CME
2024-08-14 17:18:08.576 | Rithmic Direct - DTC | Using primary service for historical data for ESZ0.CME
2024-08-14 17:18:08.576 | Historical data service client indicated that downloads are not enabled. Symbol: ESZ0.CME. Data Type: Intraday data.
2024-08-14 17:18:08.576 | Historical data download ID 121897 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.576 | Real-time Intraday chart data file updates started for ESZ0.CME
2024-08-14 17:18:08.576 | Intraday chart data file opened for ESZ0.CME
2024-08-14 17:18:08.578 | Rithmic Direct - DTC | Using primary service for historical data for ESH1.CME
2024-08-14 17:18:08.578 | Historical data service client indicated that downloads are not enabled. Symbol: ESH1.CME. Data Type: Intraday data.
2024-08-14 17:18:08.578 | Historical data download ID 121898 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.578 | Real-time Intraday chart data file updates started for ESH1.CME
2024-08-14 17:18:08.578 | Intraday chart data file opened for ESH1.CME
2024-08-14 17:18:08.579 | Rithmic Direct - DTC | Using primary service for historical data for ESM1.CME
2024-08-14 17:18:08.579 | Historical data service client indicated that downloads are not enabled. Symbol: ESM1.CME. Data Type: Intraday data.
2024-08-14 17:18:08.579 | Historical data download ID 121899 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.579 | Real-time Intraday chart data file updates started for ESM1.CME
2024-08-14 17:18:08.579 | Intraday chart data file opened for ESM1.CME
2024-08-14 17:18:08.580 | Rithmic Direct - DTC | Using primary service for historical data for ESU1.CME
2024-08-14 17:18:08.580 | Historical data service client indicated that downloads are not enabled. Symbol: ESU1.CME. Data Type: Intraday data.
2024-08-14 17:18:08.580 | Historical data download ID 121900 not found when removing ID from outstanding request set.
2024-08-14 17:18:08.580 | Real-time Intraday chart data file updates started for ESU1.CME
2024-08-14 17:18:08.580 | Intraday chart data file opened for ESU1.CME
2024-08-14 17:18:08.581 | Enabling compression for file: D:\SierraChart\Data\ESZ1.CME.scid
2024-08-14 17:18:08.582 | Enabling compression for file: D:\SierraChart\Data\ESH2.CME.scid
2024-08-14 17:18:08.583 | Enabling compression for file: D:\SierraChart\Data\ESM2.CME.scid
2024-08-14 17:18:08.585 | Enabling compression for file: D:\SierraChart\Data\ESZ2.CME.scid
2024-08-14 17:18:08.586 | Enabling compression for file: D:\SierraChart\Data\ESH3.CME.scid
2024-08-14 17:18:08.685 | Enabling compression for file: D:\SierraChart\Data\ESU1.CME.dly
2024-08-14 17:18:08.694 | Enabling compression for file: D:\SierraChart\Data\ESM1.CME.dly
2024-08-14 17:18:08.702 | Enabling compression for file: D:\SierraChart\Data\ESH1.CME.dly
2024-08-14 17:18:08.711 | Enabling compression for file: D:\SierraChart\Data\ESZ0.CME.dly
2024-08-14 17:18:08.719 | Enabling compression for file: D:\SierraChart\Data\ESU0.CME.dly
2024-08-14 17:18:08.728 | ESU4.CME [CB] 1 Day #10 | Waiting for historical downloads to complete with the IDs: 121879, 121884, 121889, 121891,
2024-08-14 17:18:08.785 | ESU4.CME [CB] 30 Min #11 | Reloading chart.
2024-08-14 17:18:08.791 | ESU4.CME [CB] 30 Min #11 | Waiting for historical downloads to complete with the IDs: 121879,
2024-08-14 17:18:08.797 | Loading DLL: D:\SierraChart\Data\EmaMult21-A.dll (EmaMult21-A_2151_64.dll). Handle: 7ff978e50000
2024-08-14 17:18:08.995 | Loading DLL: D:\SierraChart\Data\MBoxHistogram.dll (MBoxHistogram_64.dll). Handle: 65040000
2024-08-14 17:18:09.188 | Loading DLL: D:\SierraChart\Data\MCumulativeDelta.dll (MCumulativeDelta_64.dll). Handle: 6d6c0000
2024-08-14 17:18:09.396 | Loading DLL: D:\SierraChart\Data\sst_volume_dots.dll (sst_volume_dots_64.dll). Handle: 26e00000
2024-08-14 17:18:09.586 | Loading DLL: D:\SierraChart\Data\OrderFlowLabs.com.dll (OrderFlowLabs.com_64.dll). Handle: 7ff9747b0000
2024-08-14 17:18:09.798 | Loading DLL: D:\SierraChart\Data\BidAskImbalanceStacked_64 (1).dll (BidAskImbalanceStacked_64 (1).dll). Handle: 7ff973f20000
2024-08-14 17:18:09.807 | Loading DLL: D:\SierraChart\Data\CandleStickPatternsFinderColorBar.dll (CandleStickPatternsFinderColorBar_2151_64.dll). Handle: 7ff95ce80000
2024-08-14 17:18:09.817 | TSIndicators.dll is not 64-bit
2024-08-14 17:18:09.828 | Loading DLL: D:\SierraChart\Data\TSIndicators.dll (TSIndicators_64.dll). Handle: 71180000
2024-08-14 17:18:09.871 | Enabling compression for file: D:\SierraChart\Data\ESU24_FUT_CME.scid
2024-08-14 17:18:09.875 | ESU24_FUT_CME [CBV] 1 Min #12 | Reloading chart.
2024-08-14 17:18:09.875 | ESU24_FUT_CME [CBV] 1 Min #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2024-08-14 17:18:09.875 | ESU24_FUT_CME [CBV] 1 Min #12 | There are no continuous futures contract symbols. Loading data normally.
2024-08-14 17:18:10.182 | ESU4.CME [CBV] 1 Min #13 | Reloading chart.
2024-08-14 17:18:10.198 | ESU4.CME [CBV] 1 Min #13 | Waiting for historical downloads to complete with the IDs: 121879, 121891,
2024-08-14 17:18:10.203 | sst_FreeBundle.dll is not 64-bit
2024-08-14 17:18:10.203 | sst_FreeBundle_2151.dll is not 64-bit
2024-08-14 17:18:10.229 | Loading DLL: D:\SierraChart\Data\sst_FreeBundle.dll (sst_FreeBundle_64.dll). Handle: 7ff95c4d0000
2024-08-14 17:18:10.274 | ESU4.CME [CBV] 5000 Volume #14 | Reloading chart.
2024-08-14 17:18:10.289 | ESU4.CME [CBV] 5000 Volume #14 | Waiting for historical downloads to complete with the IDs: 121879, 121891,
2024-08-14 17:18:10.304 | ESU4.CME 10 Sec #15 | Reloading chart.
2024-08-14 17:18:10.311 | Loading market depth data.
2024-08-14 17:18:10.344 | ESU4.CME [CBV] 1 Min #16 | Reloading chart.
2024-08-14 17:18:10.351 | ESU4.CME [CBV] 1 Min #16 | Waiting for historical downloads to complete with the IDs: 121879,
2024-08-14 17:18:10.389 | ESU4.CME [CB] 1 Min #17 | Reloading chart.
2024-08-14 17:18:10.395 | ESU4.CME [CB] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 121879,
2024-08-14 17:18:10.422 | ESU4.CME 1 Min #19 | Reloading chart.
2024-08-14 17:18:10.429 | + Loading additional symbol data. | Number times message added: 1
2024-08-14 17:18:10.433 | Failed to open the file D:\SierraChart\Data\ADR-NYSE.scid for reading. Windows error code 2: The system cannot find the file specified. D:\SierraChart\Data\ADR-NYSE.scid *
2024-08-14 17:18:10.433 | + Loading additional symbol data.
2024-08-14 17:18:10.484 | ESU4.CME [CB] 30 Min #20 | Reloading chart.
2024-08-14 17:18:10.581 | ESU4.CME [CB] 30 Min #20 | Waiting for historical downloads to complete with the IDs: 121879, 121884, 121889, 121891,
2024-08-14 17:18:10.626 | ESU4.CME [CB] 4000 Volume #21 | Reloading chart.
2024-08-14 17:18:10.633 | ESU4.CME [CB] 4000 Volume #21 | Waiting for historical downloads to complete with the IDs: 121879,
2024-08-14 17:18:10.660 | ESU4.CME 1 Min #22 | Reloading chart.
2024-08-14 17:18:10.667 | + Loading additional symbol data. | Number times message added: 1
2024-08-14 17:18:10.668 | Failed to open the file D:\SierraChart\Data\ADR-NYSE.scid for reading. Windows error code 2: The system cannot find the file specified. D:\SierraChart\Data\ADR-NYSE.scid *
2024-08-14 17:18:10.668 | + Loading additional symbol data.
2024-08-14 17:18:10.690 | ESU4.CME 1 Min #18 | Reloading chart.
2024-08-14 17:18:10.697 | + Loading additional symbol data. | Number times message added: 2
2024-08-14 17:18:10.698 | Failed to open the file D:\SierraChart\Data\ADR-NYSE.scid for reading. Windows error code 2: The system cannot find the file specified. D:\SierraChart\Data\ADR-NYSE.scid *
2024-08-14 17:18:10.719 | ESU4.CME 1 Min #23 | Reloading chart.
2024-08-14 17:18:10.730 | + Loading additional symbol data. | Number times message added: 1
2024-08-14 17:18:10.730 | Failed to open the file D:\SierraChart\Data\ADR-NYSE.scid for reading. Windows error code 2: The system cannot find the file specified. D:\SierraChart\Data\ADR-NYSE.scid *
2024-08-14 17:18:10.738 | TICK-NYSE 1 Min #24 | Reloading chart.
2024-08-14 17:18:10.760 | ESU4.CME [CB] Daily #25 | Reloading chart.
2024-08-14 17:18:10.901 | ESU4.CME [CB] Daily #25 | Waiting for historical downloads to complete with the IDs: 121879, 121884, 121889, 121891,
2024-08-14 17:18:10.919 | ESU4.CME 1 Min #26 | Reloading chart.
2024-08-14 17:18:10.972 | ESU24_FUT_CME 1 Min #27 | Reloading chart.
2024-08-14 17:18:11.034 | ESU4.CME 1 Min #28 | Reloading chart.
2024-08-14 17:18:11.043 | + Loading additional symbol data. | Number times message added: 2
2024-08-14 17:18:11.043 | Failed to open the file D:\SierraChart\Data\ADR-NYSE.scid for reading. Windows error code 2: The system cannot find the file specified. D:\SierraChart\Data\ADR-NYSE.scid *
2024-08-14 17:18:11.082 | ESU4.CME [CBV] #29 | Reloading chart.
2024-08-14 17:18:11.089 | ESU4.CME [CBV] #29 | Waiting for historical downloads to complete with the IDs: 121879,
2024-08-14 17:18:11.160 | ESU4.CME 3000 Trades #30 | Reloading chart.
2024-08-14 17:18:11.180 | HD Request # 1 | Downloading Historical Daily chart data for ESU4.CME. Starting date: 2024-08-09. Service: rithmic.trading
2024-08-14 17:18:11.222 | ESU4.CME #3 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:11.232 | ESU4.CME #3 | Chart data loading complete.
2024-08-14 17:18:11.318 | ESU24_FUT_CME [CBV-D] Daily #5 | Chart data loading complete.
2024-08-14 17:18:11.329 | ESU24_FUT_CME [CBV-D] 1 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU24_FUT_CME.scid
2024-08-14 17:18:11.330 | ESU24_FUT_CME [CBV-D] 1 Min #12 | Chart data loading complete.
2024-08-14 17:18:11.338 | ESU4.CME 10 Sec #15 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.121 | ESU4.CME 10 Sec #15 | Chart data loading complete.
2024-08-14 17:18:12.129 | ESU4.CME 1 Min #19 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.129 | Starting DelayedDownloadMonitoringTimer
2024-08-14 17:18:12.129 | Starting HDTimeoutTimer
2024-08-14 17:18:12.129 | Added historical Intraday data request for TICK-NYSE to the queue.
2024-08-14 17:18:12.129 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'.
2024-08-14 17:18:12.131 | Triggering next historical data download in queue.
2024-08-14 17:18:12.131 | ESU4.CME 1 Min #19 | Started historical data download for additional symbol TICK-NYSE. Download ID: 121901
2024-08-14 17:18:12.350 | Added historical Intraday data request for ADR-NASDAQ to the queue.
2024-08-14 17:18:12.350 | Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'.
2024-08-14 17:18:12.350 | ESU4.CME 1 Min #19 | Started historical data download for additional symbol ADR-NASDAQ. Download ID: 121902
2024-08-14 17:18:12.350 | Added historical Intraday data request for ADR-NYSE to the queue.
2024-08-14 17:18:12.350 | Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'.
2024-08-14 17:18:12.350 | ESU4.CME 1 Min #19 | Started historical data download for additional symbol ADR-NYSE. Download ID: 121903
2024-08-14 17:18:12.351 | ESU4.CME 1 Min #19 | Chart data loading complete.
2024-08-14 17:18:12.357 | ESU4.CME 1 Min #22 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.360 | ESU4.CME 1 Min #22 | Chart data loading complete.
2024-08-14 17:18:12.364 | ESU4.CME 1 Min #18 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.367 | ESU4.CME 1 Min #18 | Chart data loading complete.
2024-08-14 17:18:12.372 | ESU4.CME 1 Min #23 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.375 | ESU4.CME 1 Min #23 | Chart data loading complete.
2024-08-14 17:18:12.378 | ESU4.CME 1 Min #26 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.379 | ESU4.CME 1 Min #26 | Chart data loading complete.
2024-08-14 17:18:12.382 | Chart #24 has tagged chart #26 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:12.382 | TICK-NYSE 1 Min #24 | Chart data loading complete.
2024-08-14 17:18:12.384 | ESU24_FUT_CME 1 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU24_FUT_CME.scid
2024-08-14 17:18:12.385 | ESU24_FUT_CME 1 Min #27 | Chart data loading complete.
2024-08-14 17:18:12.389 | ESU4.CME 1 Min #28 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.411 | ESU4.CME 1 Min #28 | Chart data loading complete.
2024-08-14 17:18:12.414 | ESU4.CME 3000 Trades #30 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:12.439 | ESU4.CME 3000 Trades #30 | Chart data loading complete.
2024-08-14 17:18:12.489 | HD Request # 2 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc
2024-08-14 17:18:12.489 | HD Request # 2 | Download start date-time: 2024-02-10 16:18:12.000000. File last date-time: 2024-01-10 10:32:20.464002
2024-08-14 17:18:12.489 | HD Request # 2 | Using server: ds12.sierracharts.com port 10149
2024-08-14 17:18:12.575 | Socket (5) | Creating socket.
2024-08-14 17:18:12.576 | Socket (5) | New receive buffer size: 0
2024-08-14 17:18:12.576 | Socket (5) | Connecting to IP: 69.39.70.241.
2024-08-14 17:18:12.590 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:12.590 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:12.591 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:12.591 | DTC Client socket (6) | New receive buffer size: 0
2024-08-14 17:18:12.591 | DTC Client socket (6) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:12.628 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:12.628 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:12.628 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:12.628 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:12.687 | HD Request # 2 | Setting DTC encoding to Binary VLS
2024-08-14 17:18:12.687 | HD Request # 2 | Sending historical data logon request message.
2024-08-14 17:18:12.728 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:12.728 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:12.728 | Historical data download ID 121904 not found when removing ID from outstanding request set.
2024-08-14 17:18:12.728 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:12.728 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:12.753 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:12.753 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:12.753 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:12.753 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:12.753 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:12.753 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:12.753 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:12.753 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:12.753 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:12.754 | Historical data download ID 121905 not found when removing ID from outstanding request set.
2024-08-14 17:18:12.754 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:12.754 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:12.754 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:12.754 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:12.754 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:12.754 | Historical data download ID 121906 not found when removing ID from outstanding request set.
2024-08-14 17:18:12.754 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:12.754 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:12.754 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:12.754 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:12.754 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:12.754 | Historical data download ID 121907 not found when removing ID from outstanding request set.
2024-08-14 17:18:12.754 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:12.754 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:12.754 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:12.796 | DTC Client socket (6) | Socket gracefully closed by remote side.
2024-08-14 17:18:12.799 | DTC Client socket (6) | CloseSocket call.
2024-08-14 17:18:12.799 | DTC Client socket (6) | Max send buffers used during socket life: 3
2024-08-14 17:18:12.799 | DTC Client socket (6) | Max send buffer size during socket life: 735
2024-08-14 17:18:12.799 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:12.799 | DTC Client socket (6) | Closed.
2024-08-14 17:18:12.799 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:12.799 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:12.799 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:12.799 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:13.072 | HD Request # 1 | Requesting historical Daily data for ESU24 starting at 2024-08-08. SC External HD service.
2024-08-14 17:18:13.217 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-02-10 16:18:12. Record interval: 0. Symbol: TICK-NYSE
2024-08-14 17:18:13.267 | HD Request # 2 | Decompressing data.
2024-08-14 17:18:13.308 | HD Request # 1 | Receiving historical Daily data for ESU4.CME starting at 2024-08-09.
2024-08-14 17:18:13.308 | HD Request # 1 | Writing historical Daily data to the file ESU4.CME.dly.
2024-08-14 17:18:13.312 | HD Request # 1 | Bytes received: 303
2024-08-14 17:18:13.312 | HD Request # 1 | Received 5 Daily data records from 2024-08-09 00:00:00 to 2024-08-14 00:00:00 (6.0 days) and wrote 4 records for ESU4.CME
2024-08-14 17:18:13.312 | HD Request # 1 | Completion time: 2s.
2024-08-14 17:18:13.312 | HD Request # 1 | Daily data download complete for ESU4.CME. Unique request ID: 121879
2024-08-14 17:18:13.312 | Removing historical data download ID 121879.
2024-08-14 17:18:13.312 | Triggering next historical data download in queue.
2024-08-14 17:18:13.314 | HD Request # 3 | Downloading Historical Daily chart data for ESU2.CME. Starting date: 2022-07-28. Service: rithmic.trading
2024-08-14 17:18:13.346 | ESU4.CME [CBV] 1 Min #16 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:13.347 | ESU4.CME [CBV] 1 Min #16 | Reloading chart.
2024-08-14 17:18:13.359 | ESU4.CME [CBV] 1 Min #16 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:13.362 | ESU4.CME [CBV] 1 Min #16 | Chart data loading complete.
2024-08-14 17:18:13.392 | ESU4.CME [CB] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:13.392 | ESU4.CME [CB] 1 Min #17 | Reloading chart.
2024-08-14 17:18:13.412 | ESU4.CME [CB] 1 Min #17 | Chart data loading complete.
2024-08-14 17:18:13.424 | HD Request # 2 | Receiving Intraday data for TICK-NYSE starting at 2024-02-12 04:00:00.000000
2024-08-14 17:18:13.551 | ESU4.CME [CB] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:13.552 | ESU4.CME [CB] 30 Min #9 | Reloading chart.
2024-08-14 17:18:13.563 | ESU4.CME [CB] 30 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid
2024-08-14 17:18:13.564 | ESU4.CME [CB] 30 Min #9 | Chart data loading complete.
2024-08-14 17:18:13.582 | ESU4.CME [CBV] #29 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:13.582 | ESU4.CME [CBV] #29 | Reloading chart.
2024-08-14 17:18:13.606 | ESU4.CME [CBV] #29 | Chart data loading complete.
2024-08-14 17:18:13.629 | ESU4.CME [CB] 4000 Volume #21 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:13.629 | ESU4.CME [CB] 4000 Volume #21 | Reloading chart.
2024-08-14 17:18:13.653 | ESU4.CME [CB] 4000 Volume #21 | Chart data loading complete.
2024-08-14 17:18:13.691 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-02-12 04:00:00.000000.
2024-08-14 17:18:13.696 | ESU4.CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:13.697 | ESU4.CME [CBV] #1 | Reloading chart.
2024-08-14 17:18:13.723 | ESU4.CME [CBV] #1 | Chart data loading complete.
2024-08-14 17:18:13.802 | ESU4.CME [CB] 30 Min #11 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:13.803 | ESU4.CME [CB] 30 Min #11 | Reloading chart.
2024-08-14 17:18:13.812 | ESU4.CME [CB] 30 Min #11 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:13.813 | Chart #11 has tagged chart #18 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:13.813 | Chart #11 has tagged chart #19 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:13.813 | Chart #11 has tagged chart #22 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:13.813 | Chart #11 has tagged chart #23 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:13.813 | Chart #11 has tagged chart #28 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:13.818 | ESU4.CME [CB] 30 Min #11 | Chart data loading complete.
2024-08-14 17:18:13.847 | ESU4.CME [CBV] 1 Min #16 | Reloading chart.
2024-08-14 17:18:13.860 | ESU4.CME [CBV] 1 Min #16 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:13.861 | ESU4.CME [CBV] 1 Min #16 | Chart data loading complete.
2024-08-14 17:18:13.894 | ESU4.CME [CB] 1 Min #17 | Reloading chart.
2024-08-14 17:18:13.911 | ESU4.CME [CB] 1 Min #17 | Chart data loading complete.
2024-08-14 17:18:13.925 | ESU4.CME 1 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.049 | ESU4.CME 1 Min #28 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.061 | HD Request # 3 | Requesting historical Daily data for ESU22 starting at 2022-07-27. SC External HD service.
2024-08-14 17:18:14.062 | ESU4.CME [CB] 30 Min #9 | Reloading chart.
2024-08-14 17:18:14.081 | ESU4.CME [CB] 30 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid
2024-08-14 17:18:14.081 | ESU4.CME [CB] 30 Min #9 | Chart data loading complete.
2024-08-14 17:18:14.084 | ESU4.CME [CBV] #29 | Reloading chart.
2024-08-14 17:18:14.101 | ESU4.CME [CBV] #29 | Chart data loading complete.
2024-08-14 17:18:14.146 | ESU4.CME [CB] 4000 Volume #21 | Reloading chart.
2024-08-14 17:18:14.162 | ESU4.CME [CB] 4000 Volume #21 | Chart data loading complete.
2024-08-14 17:18:14.174 | ESU4.CME 1 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.191 | ESU4.CME [CBV] #1 | Reloading chart.
2024-08-14 17:18:14.222 | ESU4.CME [CBV] #1 | Chart data loading complete.
2024-08-14 17:18:14.232 | ESU4.CME 1 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.257 | HD Request # 3 | Receiving historical Daily data for ESU2.CME starting at 2022-07-28.
2024-08-14 17:18:14.257 | HD Request # 3 | Writing historical Daily data to the file ESU2.CME.dly.
2024-08-14 17:18:14.259 | HD Request # 3 | Bytes received: 2234
2024-08-14 17:18:14.259 | HD Request # 3 | Received 37 Daily data records from 2022-07-28 00:00:00 to 2022-09-16 00:00:00 (51.0 days) and wrote 36 records for ESU2.CME
2024-08-14 17:18:14.259 | HD Request # 3 | Completion time: 1s.
2024-08-14 17:18:14.259 | HD Request # 3 | Daily data download complete for ESU2.CME. Unique request ID: 121884
2024-08-14 17:18:14.259 | Removing historical data download ID 121884.
2024-08-14 17:18:14.259 | Triggering next historical data download in queue.
2024-08-14 17:18:14.260 | HD Request # 4 | Downloading Historical Daily chart data for ESH4.CME. Starting date: 2024-02-16. Service: rithmic.trading
2024-08-14 17:18:14.302 | ESU4.CME [CB] 30 Min #11 | Reloading chart.
2024-08-14 17:18:14.315 | ESU4.CME [CB] 30 Min #11 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:18:14.316 | Chart #11 has tagged chart #19 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.316 | Chart #11 has tagged chart #22 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.316 | Chart #11 has tagged chart #23 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.316 | Chart #11 has tagged chart #28 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.320 | ESU4.CME [CB] 30 Min #11 | Chart data loading complete.
2024-08-14 17:18:14.426 | ESU4.CME 1 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.559 | ESU4.CME 1 Min #28 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.669 | ESU4.CME 1 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.715 | ESU4.CME 1 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.726 | ESU4.CME 1 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:14.847 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:14.847 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:14.848 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:14.848 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:14.849 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:14.889 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:14.889 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:14.889 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:14.889 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:14.999 | HD Request # 4 | Requesting historical Daily data for ESH24 starting at 2024-02-15. SC External HD service.
2024-08-14 17:18:15.010 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:15.010 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:15.010 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:15.010 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:15.010 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:15.010 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:15.010 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:15.011 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:15.011 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:15.011 | Historical data download ID 121908 not found when removing ID from outstanding request set.
2024-08-14 17:18:15.011 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:15.011 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:15.011 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:15.011 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:15.011 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:15.011 | Historical data download ID 121909 not found when removing ID from outstanding request set.
2024-08-14 17:18:15.011 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:15.011 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:15.011 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:15.011 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:15.011 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:15.011 | Historical data download ID 121910 not found when removing ID from outstanding request set.
2024-08-14 17:18:15.011 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:15.011 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:15.011 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:15.054 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:15.070 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:15.070 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:18:15.070 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:15.070 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:15.070 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:15.070 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:18:15.070 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:15.070 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:15.070 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:15.096 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:18:15.096 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:15.096 | DTC Client socket (4) | Closed.
2024-08-14 17:18:15.115 | HD Request # 4 | Receiving historical Daily data for ESH4.CME starting at 2024-02-16.
2024-08-14 17:18:15.115 | HD Request # 4 | Writing historical Daily data to the file ESH4.CME.dly.
2024-08-14 17:18:15.117 | HD Request # 4 | Bytes received: 1252
2024-08-14 17:18:15.117 | HD Request # 4 | Received 21 Daily data records from 2024-02-16 00:00:00 to 2024-03-15 00:00:00 (29.0 days) and wrote 20 records for ESH4.CME
2024-08-14 17:18:15.117 | HD Request # 4 | Completion time: 1s.
2024-08-14 17:18:15.117 | HD Request # 4 | Daily data download complete for ESH4.CME. Unique request ID: 121889
2024-08-14 17:18:15.117 | Removing historical data download ID 121889.
2024-08-14 17:18:15.117 | Triggering next historical data download in queue.
2024-08-14 17:18:15.118 | HD Request # 5 | Downloading Historical Daily chart data for ESM4.CME. Starting date: 2024-06-10. Service: rithmic.trading
2024-08-14 17:18:15.867 | HD Request # 5 | Requesting historical Daily data for ESM24 starting at 2024-06-09. SC External HD service.
2024-08-14 17:18:15.982 | HD Request # 5 | Receiving historical Daily data for ESM4.CME starting at 2024-06-10.
2024-08-14 17:18:15.982 | HD Request # 5 | Writing historical Daily data to the file ESM4.CME.dly.
2024-08-14 17:18:15.985 | HD Request # 5 | Bytes received: 534
2024-08-14 17:18:15.985 | HD Request # 5 | Received 9 Daily data records from 2024-06-10 00:00:00 to 2024-06-21 00:00:00 (12.0 days) and wrote 9 records for ESM4.CME
2024-08-14 17:18:15.985 | HD Request # 5 | Completion time: 0s.
2024-08-14 17:18:15.985 | HD Request # 5 | Daily data download complete for ESM4.CME. Unique request ID: 121891
2024-08-14 17:18:15.985 | Removing historical data download ID 121891.
2024-08-14 17:18:15.985 | Triggering next historical data download in queue.
2024-08-14 17:18:15.985 | HD Request # 6 | Downloading Historical Daily chart data for CLN4.NYMEX. Starting date: 2024-06-10. Service: rithmic.trading
2024-08-14 17:18:15.986 | ESU4.CME [CB] 30 Min #20 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:15.988 | ESU4.CME [CB] 30 Min #20 | Reloading chart.
2024-08-14 17:18:16.059 | ESU4.CME [CB] 50000 Volume #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.060 | ESU4.CME [CB] 50000 Volume #8 | Reloading chart.
2024-08-14 17:18:16.120 | ESU4.CME [CB] 1 Day #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.122 | ESU4.CME [CB] 1 Day #10 | Reloading chart.
2024-08-14 17:18:16.222 | Enabling compression for file: D:\SierraChart\Data\ESU0.CME.scid
2024-08-14 17:18:16.223 | Enabling compression for file: D:\SierraChart\Data\ESZ0.CME.scid
2024-08-14 17:18:16.223 | Enabling compression for file: D:\SierraChart\Data\ESH1.CME.scid
2024-08-14 17:18:16.223 | Enabling compression for file: D:\SierraChart\Data\ESM1.CME.scid
2024-08-14 17:18:16.223 | Enabling compression for file: D:\SierraChart\Data\ESU1.CME.scid
2024-08-14 17:18:16.276 | ESU4.CME [CBV] 1 Min #13 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.282 | ESU4.CME [CBV] 1 Min #13 | Reloading chart.
2024-08-14 17:18:16.336 | ESU4.CME [CB] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.339 | ESU4.CME [CB] 30 Min #2 | Reloading chart.
2024-08-14 17:18:16.435 | ESU4.CME [CB] Daily #25 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.436 | ESU4.CME [CB] Daily #25 | Reloading chart.
2024-08-14 17:18:16.516 | ESU4.CME [CBV] 5000 Volume #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.523 | ESU4.CME [CBV] 5000 Volume #14 | Reloading chart.
2024-08-14 17:18:16.553 | ESU4.CME [CB] 500000 Volume #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.554 | ESU4.CME [CB] 500000 Volume #6 | Reloading chart.
2024-08-14 17:18:16.559 | + Loading additional symbol data.
2024-08-14 17:18:16.596 | Added historical Daily data request for TICK-NYSE to the queue.
2024-08-14 17:18:16.596 | Triggering next historical data download in queue.
2024-08-14 17:18:16.598 | ESU4.CME [CB] Daily #25 | Chart data loading complete.
2024-08-14 17:18:16.614 | ESU4.CME [CB] 150000 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:16.616 | ESU4.CME [CB] 150000 Volume #7 | Reloading chart.
2024-08-14 17:18:16.666 | ESU4.CME [CB] 30 Min #20 | Reloading chart.
2024-08-14 17:18:16.933 | HD Request # 6 | Requesting historical Daily data for CLN24 starting at 2024-06-09. SC External HD service.
2024-08-14 17:18:16.973 | ESU4.CME [CB] 50000 Volume #8 | Reloading chart.
2024-08-14 17:18:17.092 | HD Request # 6 | Receiving historical Daily data for CLN4.NYMEX starting at 2024-06-10.
2024-08-14 17:18:17.092 | HD Request # 6 | Writing historical Daily data to the file CLN4.NYMEX.dly.
2024-08-14 17:18:17.102 | HD Request # 6 | Bytes received: 432
2024-08-14 17:18:17.102 | HD Request # 6 | Received 8 Daily data records from 2024-06-10 00:00:00 to 2024-06-20 00:00:00 (11.0 days) and wrote 8 records for CLN4.NYMEX
2024-08-14 17:18:17.102 | HD Request # 6 | Completion time: 2s.
2024-08-14 17:18:17.102 | HD Request # 6 | Daily data download complete for CLN4.NYMEX. Unique request ID: 121893
2024-08-14 17:18:17.102 | Removing historical data download ID 121893.
2024-08-14 17:18:17.102 | No download requests in the queue to start downloads for.
2024-08-14 17:18:17.112 | ESU4.CME [CB] 1 Day #10 | Reloading chart.
2024-08-14 17:18:17.515 | CLU4.NYMEX [CB] 1000 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-08-14 17:18:17.517 | CLU4.NYMEX [CB] 1000 Volume #4 | Reloading chart.
2024-08-14 17:18:17.597 | Enabling compression for file: D:\SierraChart\Data\CLQ4.NYMEX.scid
2024-08-14 17:18:17.613 | CLU4.NYMEX [CB] 1000 Volume #4 | Chart data loading complete.
2024-08-14 17:18:17.806 | ESU4.CME [CBV] 1 Min #13 | Reloading chart.
2024-08-14 17:18:17.854 | ESU4.CME [CB] 30 Min #2 | Reloading chart.
2024-08-14 17:18:18.127 | ESU4.CME [CB] Daily #25 | Reloading chart.
2024-08-14 17:18:18.420 | ESU4.CME [CBV] 5000 Volume #14 | Reloading chart.
2024-08-14 17:18:18.461 | + Loading additional symbol data.
2024-08-14 17:18:18.520 | ESU4.CME [CB] Daily #25 | Chart data loading complete.
2024-08-14 17:18:18.521 | ESU4.CME [CB] 500000 Volume #6 | Reloading chart.
2024-08-14 17:18:18.616 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:18.616 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:18.616 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:18.616 | DTC Client socket (6) | New receive buffer size: 0
2024-08-14 17:18:18.616 | DTC Client socket (6) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:18.617 | ESU4.CME [CB] 150000 Volume #7 | Reloading chart.
2024-08-14 17:18:18.752 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:18.752 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:18.752 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:18.752 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:18.936 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:18.936 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:18.936 | Historical data download ID 121912 not found when removing ID from outstanding request set.
2024-08-14 17:18:18.936 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:18.936 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:18.936 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:18.936 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:18.936 | Historical data download ID 121913 not found when removing ID from outstanding request set.
2024-08-14 17:18:18.936 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:18.936 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:18.936 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:18.936 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:18.936 | Historical data download ID 121914 not found when removing ID from outstanding request set.
2024-08-14 17:18:18.936 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:18.936 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:18.936 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:18.978 | DTC Client socket (6) | Socket gracefully closed by remote side.
2024-08-14 17:18:18.980 | DTC Client socket (6) | CloseSocket call.
2024-08-14 17:18:18.980 | DTC Client socket (6) | Max send buffers used during socket life: 3
2024-08-14 17:18:18.980 | DTC Client socket (6) | Max send buffer size during socket life: 735
2024-08-14 17:18:18.980 | DTC Client socket (6) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:18:18.980 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:18.981 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:18.981 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:18.981 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:19.004 | CLU4.NYMEX [CB] 1000 Volume #4 | Reloading chart.
2024-08-14 17:18:19.025 | DTC Client socket (6) | Write has completed. Shutdown being performed.
2024-08-14 17:18:19.025 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:19.025 | DTC Client socket (6) | Closed.
2024-08-14 17:18:19.105 | CLU4.NYMEX [CB] 1000 Volume #4 | Chart data loading complete.
2024-08-14 17:18:19.489 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:18:19.490 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:18:19.499 | HD Server | Thread:12716 (4) | Creating socket.
2024-08-14 17:18:19.499 | HD Server | Thread:12716 (4) | New receive buffer size: 262144
2024-08-14 17:18:19.499 | HD Server | Thread:12716 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:18:19.500 | HD Server | Setting DTC encoding to Binary VLS | Thread:12716
2024-08-14 17:18:19.500 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12716
2024-08-14 17:18:19.500 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12716
2024-08-14 17:18:19.500 | HD Server | HD Request #4276 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4276 | Username: DAVID SUDDUTH JR. | Thread:12716
2024-08-14 17:18:19.501 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4276 | Username: DAVID SUDDUTH JR. | Thread:12716
2024-08-14 17:18:19.501 | HD Server | Thread:12716 (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:19.501 | HD Server | Thread:12716 (4) | CloseSocket call.
2024-08-14 17:18:19.501 | HD Server | Thread:12716 (0) | CloseSocket call.
2024-08-14 17:18:19.501 | HD Server | Thread:12716 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:19.501 | HD Server | Thread:12716 (4) | Closed.
2024-08-14 17:18:19.508 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:18:19.508 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:18:19.518 | HD Server | Thread:11704 (4) | Creating socket.
2024-08-14 17:18:19.518 | HD Server | Thread:11704 (4) | New receive buffer size: 262144
2024-08-14 17:18:19.518 | HD Server | Thread:11704 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:18:19.518 | HD Server | Setting DTC encoding to Binary VLS | Thread:11704
2024-08-14 17:18:19.519 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11704
2024-08-14 17:18:19.519 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11704
2024-08-14 17:18:19.519 | HD Server | HD Request #4277 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4277 | Username: DAVID SUDDUTH JR. | Thread:11704
2024-08-14 17:18:19.520 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4277 | Username: DAVID SUDDUTH JR. | Thread:11704
2024-08-14 17:18:19.520 | HD Server | Thread:11704 (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:19.520 | HD Server | Thread:11704 (4) | CloseSocket call.
2024-08-14 17:18:19.520 | HD Server | Thread:11704 (0) | CloseSocket call.
2024-08-14 17:18:19.520 | HD Server | Thread:11704 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:19.520 | HD Server | Thread:11704 (4) | Closed.
2024-08-14 17:18:19.572 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11704
2024-08-14 17:18:19.572 | HD Server Manager | Current server count=1
2024-08-14 17:18:19.572 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12716
2024-08-14 17:18:19.572 | HD Server Manager | Current server count=0
2024-08-14 17:18:20.590 | ESU4.CME [CBV] 5000 Volume #14 | StartDateTimeForLoadingOrderFills: 2024-05-17 09:29:59
2024-08-14 17:18:20.661 | Chart: ESU4.CME [CBV] 5000 Volume #14 | Study: Acumulation/Distribution | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:20.661 | Chart: ESU4.CME [CBV] 5000 Volume #14 | Study: Volume Delta Histogram | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:20.705 | ESU4.CME [CBV] 5000 Volume #14 | Chart data loading complete.
2024-08-14 17:18:20.746 | Chart: ESU4.CME [CBV] 5000 Volume #14 | Study: Acumulation/Distribution | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:20.746 | Chart: ESU4.CME [CBV] 5000 Volume #14 | Study: Volume Delta Histogram | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:20.883 | ESU4.CME [CBV] 1 Min #13 | StartDateTimeForLoadingOrderFills: 2024-05-16 18:00:00
2024-08-14 17:18:20.990 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: ASK | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization *
2024-08-14 17:18:20.992 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: BID | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization *
2024-08-14 17:18:20.994 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Buy and Sell Zones | You are not authorized to use this study. Contact OrderFlow Labs LLC, orderflowlabs.com to discuss authorization. *
2024-08-14 17:18:24.056 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Acumulation/Distribution | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:24.057 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Volume Delta Histogram | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:24.425 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:24.425 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:24.425 | Chart #13 has tagged chart #22 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:24.425 | Chart #13 has tagged chart #23 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:24.425 | Chart #13 has tagged chart #28 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:24.481 | ESU4.CME [CBV] 1 Min #13 | Chart data loading complete.
2024-08-14 17:18:24.590 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: ASK | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization *
2024-08-14 17:18:24.591 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: BID | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization *
2024-08-14 17:18:24.591 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Buy and Sell Zones | You are not authorized to use this study. Contact OrderFlow Labs LLC, orderflowlabs.com to discuss authorization. *
2024-08-14 17:18:27.756 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Acumulation/Distribution | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:27.758 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Volume Delta Histogram | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:18:28.312 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:28.312 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:28.313 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:28.313 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:28.313 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:28.464 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:28.464 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:28.464 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:28.464 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:28.755 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:28.755 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:28.755 | Historical data download ID 121915 not found when removing ID from outstanding request set.
2024-08-14 17:18:28.755 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:28.755 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:28.755 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:28.755 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:28.755 | Historical data download ID 121916 not found when removing ID from outstanding request set.
2024-08-14 17:18:28.755 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:28.755 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:28.755 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:28.755 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:28.755 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:28.756 | Historical data download ID 121917 not found when removing ID from outstanding request set.
2024-08-14 17:18:28.756 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:28.756 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:28.756 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:28.800 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:28.812 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:28.812 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:28.812 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:28.812 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:28.812 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:28.812 | DTC Client socket (4) | Closed.
2024-08-14 17:18:28.812 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:28.812 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:28.812 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:30.812 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:30.813 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:30.813 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:30.813 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:30.813 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:30.866 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:30.866 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:30.866 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:30.866 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:31.035 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:31.035 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:31.035 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:31.035 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:31.035 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:31.035 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:31.035 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:31.035 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:31.036 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:31.036 | Historical data download ID 121918 not found when removing ID from outstanding request set.
2024-08-14 17:18:31.036 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:31.036 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:31.036 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:31.036 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:31.036 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:31.036 | Historical data download ID 121919 not found when removing ID from outstanding request set.
2024-08-14 17:18:31.036 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:31.036 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:31.036 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:31.036 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:31.036 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:31.036 | Historical data download ID 121920 not found when removing ID from outstanding request set.
2024-08-14 17:18:31.036 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:31.036 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:31.036 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:31.075 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:31.081 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:31.081 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:31.081 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:31.081 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:31.081 | DTC Client socket (4) | Closed.
2024-08-14 17:18:31.081 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:31.082 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:31.082 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:31.082 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:33.092 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:33.092 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:33.187 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:33.188 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:33.188 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:33.226 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:33.226 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:33.226 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:33.226 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:33.364 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:33.364 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:33.364 | Historical data download ID 121921 not found when removing ID from outstanding request set.
2024-08-14 17:18:33.364 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:33.364 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:33.364 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:33.365 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:33.365 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:33.365 | Historical data download ID 121922 not found when removing ID from outstanding request set.
2024-08-14 17:18:33.365 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:33.365 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:33.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:33.365 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:33.365 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:33.365 | Historical data download ID 121923 not found when removing ID from outstanding request set.
2024-08-14 17:18:33.365 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:33.365 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:33.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:33.422 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:33.428 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:33.428 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:33.428 | DTC Client socket (4) | Closed.
2024-08-14 17:18:33.429 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:33.429 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:33.429 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:33.429 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:35.423 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:35.423 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:35.423 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:35.424 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:35.424 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:35.462 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:35.462 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:35.462 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:35.462 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:35.584 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:35.584 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:35.584 | Historical data download ID 121924 not found when removing ID from outstanding request set.
2024-08-14 17:18:35.584 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:35.584 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:35.584 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:35.584 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:35.584 | Historical data download ID 121925 not found when removing ID from outstanding request set.
2024-08-14 17:18:35.584 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:35.584 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:35.584 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:35.584 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:35.584 | Historical data download ID 121926 not found when removing ID from outstanding request set.
2024-08-14 17:18:35.584 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:35.584 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:35.584 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:35.622 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:35.639 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:35.639 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:35.639 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:35.639 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:35.639 | DTC Client socket (4) | Closed.
2024-08-14 17:18:35.639 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:35.640 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:35.640 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:35.640 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:37.641 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:37.641 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:37.641 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:37.641 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:37.641 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:37.686 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:37.686 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:37.686 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:37.686 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:37.849 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:37.849 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:37.849 | Historical data download ID 121927 not found when removing ID from outstanding request set.
2024-08-14 17:18:37.849 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:37.849 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:37.849 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:37.849 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:37.849 | Historical data download ID 121928 not found when removing ID from outstanding request set.
2024-08-14 17:18:37.849 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:37.849 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:37.849 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:37.849 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:37.849 | Historical data download ID 121929 not found when removing ID from outstanding request set.
2024-08-14 17:18:37.849 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:37.849 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:37.849 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:37.894 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:37.902 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2024-08-14 17:18:37.908 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:37.908 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:37.908 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:37.909 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:37.909 | DTC Client socket (4) | Closed.
2024-08-14 17:18:37.909 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:37.909 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:37.909 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:37.909 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:39.919 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:39.919 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:39.920 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:39.920 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:39.920 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:39.962 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:39.962 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:39.962 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:39.962 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:40.102 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:40.102 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:40.102 | Historical data download ID 121930 not found when removing ID from outstanding request set.
2024-08-14 17:18:40.102 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:40.102 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:40.102 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:40.102 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:40.102 | Historical data download ID 121931 not found when removing ID from outstanding request set.
2024-08-14 17:18:40.102 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:40.102 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:40.102 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:40.102 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:40.102 | Historical data download ID 121932 not found when removing ID from outstanding request set.
2024-08-14 17:18:40.102 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:40.102 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:40.102 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:40.144 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:40.151 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:40.151 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:40.151 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:40.151 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:40.151 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:40.151 | DTC Client socket (4) | Closed.
2024-08-14 17:18:40.151 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:40.151 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:40.151 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:40.151 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:42.153 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:42.153 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:42.153 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:42.154 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:18:42.154 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:42.274 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:42.274 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:42.274 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:42.274 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:42.417 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:42.417 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:42.417 | Historical data download ID 121933 not found when removing ID from outstanding request set.
2024-08-14 17:18:42.417 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:42.417 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:42.417 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:42.417 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:42.417 | Historical data download ID 121934 not found when removing ID from outstanding request set.
2024-08-14 17:18:42.417 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:42.417 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:42.417 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:42.417 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:42.417 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:42.417 | Historical data download ID 121935 not found when removing ID from outstanding request set.
2024-08-14 17:18:42.417 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:42.418 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:42.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:42.460 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:42.468 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:18:42.468 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:18:42.468 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:18:42.468 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:18:42.468 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:42.468 | DTC Client socket (4) | Closed.
2024-08-14 17:18:42.468 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:18:42.473 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:42.473 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:42.473 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:42.473 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:44.392 | Socket (5) | CloseSocket call.
2024-08-14 17:18:44.392 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-08-14 17:18:44.392 | Historical data download thread signaled to stop.
2024-08-14 17:18:44.392 | HD Request # 2 | Received 7317217 Intraday data records from 2024-02-12 04:00:00.000000 to 2024-08-14 17:18:44.000000 (184.5 days. Delay: 0.4 seconds) and wrote 7317217 records for TICK-NYSE
2024-08-14 17:18:44.393 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-08-14 21:18:44.000000
2024-08-14 17:18:44.393 | Added 5 Time and Sales records to Intraday data file for TICK-NYSE after download.
2024-08-14 17:18:44.393 | HD Request # 2 | Completion time: 32s.
2024-08-14 17:18:44.393 | HD Request # 2 | Intraday data download complete for TICK-NYSE. Unique request ID: 121901
2024-08-14 17:18:44.393 | Removing historical data download ID 121901.
2024-08-14 17:18:44.393 | Real-time Intraday chart data file updates started for TICK-NYSE
2024-08-14 17:18:44.393 | Intraday chart data file opened for TICK-NYSE
2024-08-14 17:18:44.393 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2024-08-14 17:18:44.393 | ESU4.CME 1 Min #19 | Historical data download for additional symbol TICK-NYSE with ID 121901 has completed.
2024-08-14 17:18:44.393 | Triggering next historical data download in queue.
2024-08-14 17:18:44.393 | HD Request # 7 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc
2024-08-14 17:18:44.393 | HD Request # 7 | Download start date-time: 2024-02-10 16:18:44.000000. File last date-time: 2022-09-16 14:00:13.465000
2024-08-14 17:18:44.393 | HD Request # 7 | Using server: ds13-2.sierracharts.com port 10150
2024-08-14 17:18:44.450 | Socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:44.450 | Socket (5) | Closed.
2024-08-14 17:18:44.479 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:44.479 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:44.479 | Socket (4) | Creating socket.
2024-08-14 17:18:44.479 | Socket (4) | New receive buffer size: 0
2024-08-14 17:18:44.479 | Socket (4) | Connecting to IP: 64.158.105.203.
2024-08-14 17:18:44.479 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:44.479 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:18:44.479 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:44.523 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:44.523 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:44.523 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:44.523 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:44.619 | HD Request # 7 | Setting DTC encoding to Binary VLS
2024-08-14 17:18:44.619 | HD Request # 7 | Sending historical data logon request message.
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:44.645 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:44.645 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:44.645 | Historical data download ID 121936 not found when removing ID from outstanding request set.
2024-08-14 17:18:44.645 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:44.645 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:44.645 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:44.645 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:44.645 | Historical data download ID 121937 not found when removing ID from outstanding request set.
2024-08-14 17:18:44.645 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:44.645 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:44.645 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:44.645 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:44.645 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:44.646 | Historical data download ID 121938 not found when removing ID from outstanding request set.
2024-08-14 17:18:44.646 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:44.646 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:44.646 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:44.688 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:44.694 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:18:44.694 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:18:44.694 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:44.694 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:44.694 | DTC Client socket (5) | Closed.
2024-08-14 17:18:44.694 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:44.694 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:44.694 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:44.694 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:44.765 | Chart #24 has tagged chart #14 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:44.765 | Chart #24 has tagged chart #26 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:18:45.368 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-02-10 16:18:44. Record interval: 0. Symbol: ADR-NASDAQ
2024-08-14 17:18:45.424 | HD Request # 7 | Decompressing data.
2024-08-14 17:18:45.602 | HD Request # 7 | Receiving Intraday data for ADR-NASDAQ starting at 2024-02-12 04:00:00.000000
2024-08-14 17:18:45.894 | HD Request # 7 | Timestamp of first Intraday data file record written: 2024-02-12 04:00:00.000000.
2024-08-14 17:18:46.700 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:46.701 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:46.701 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:46.701 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:18:46.702 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:46.735 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:46.735 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:46.735 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:46.735 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:46.863 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:46.863 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:46.863 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:46.863 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:46.863 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:46.863 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:46.864 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:46.864 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:46.864 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:46.864 | Historical data download ID 121939 not found when removing ID from outstanding request set.
2024-08-14 17:18:46.864 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:46.864 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:46.864 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:46.864 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:46.864 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:46.864 | Historical data download ID 121940 not found when removing ID from outstanding request set.
2024-08-14 17:18:46.864 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:46.864 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:46.864 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:46.864 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:46.864 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:46.864 | Historical data download ID 121941 not found when removing ID from outstanding request set.
2024-08-14 17:18:46.864 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:46.864 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:46.864 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:46.910 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:46.911 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:18:46.912 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:46.912 | DTC Client socket (5) | Closed.
2024-08-14 17:18:46.912 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:46.912 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:46.912 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:46.912 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:46.972 | Opened cached Intraday file: D:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 15420
2024-08-14 17:18:48.917 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:48.917 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:48.918 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:48.918 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:18:48.918 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:48.957 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:48.957 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:48.957 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:48.957 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:49.083 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:49.083 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:49.083 | Historical data download ID 121942 not found when removing ID from outstanding request set.
2024-08-14 17:18:49.083 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:49.083 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:49.083 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:49.083 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:49.083 | Historical data download ID 121943 not found when removing ID from outstanding request set.
2024-08-14 17:18:49.083 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:49.083 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:49.083 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:49.083 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:49.083 | Historical data download ID 121944 not found when removing ID from outstanding request set.
2024-08-14 17:18:49.083 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:49.083 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:49.083 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:49.126 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:49.135 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:18:49.135 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:18:49.135 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:18:49.136 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:18:49.136 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:49.140 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:49.141 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:49.141 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:49.141 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:49.179 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:18:49.179 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:49.179 | DTC Client socket (5) | Closed.
2024-08-14 17:18:51.128 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:51.128 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:51.128 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:51.128 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:18:51.128 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:51.174 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:51.174 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:51.174 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:51.174 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:51.301 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:51.301 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:51.301 | Historical data download ID 121945 not found when removing ID from outstanding request set.
2024-08-14 17:18:51.301 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:51.301 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:51.301 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:51.301 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:51.301 | Historical data download ID 121946 not found when removing ID from outstanding request set.
2024-08-14 17:18:51.301 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:51.301 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:51.301 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:51.301 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:51.301 | Historical data download ID 121947 not found when removing ID from outstanding request set.
2024-08-14 17:18:51.301 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:51.301 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:51.301 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:51.346 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:51.360 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:18:51.360 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:18:51.360 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:18:51.360 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:51.360 | DTC Client socket (5) | Closed.
2024-08-14 17:18:51.360 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:51.360 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:51.360 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:51.360 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:53.391 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:53.391 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:53.391 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:53.391 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:18:53.391 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:53.428 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:53.428 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:53.428 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:53.428 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:53.565 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:53.565 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:53.565 | Historical data download ID 121948 not found when removing ID from outstanding request set.
2024-08-14 17:18:53.565 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:53.565 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:53.565 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:53.565 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:53.565 | Historical data download ID 121949 not found when removing ID from outstanding request set.
2024-08-14 17:18:53.565 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:53.565 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:53.565 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:53.565 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:53.565 | Historical data download ID 121950 not found when removing ID from outstanding request set.
2024-08-14 17:18:53.565 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:53.565 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:53.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:53.616 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:53.617 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2024-08-14 17:18:53.620 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:18:53.620 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:18:53.620 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:18:53.620 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=96
2024-08-14 17:18:53.620 | DTC Client socket (5) | Socket send error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-08-14 17:18:53.620 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:53.620 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:53.620 | DTC Client socket (5) | Closed.
2024-08-14 17:18:53.621 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:53.621 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:53.621 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:55.622 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:55.622 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:55.623 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:55.623 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:18:55.623 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:55.663 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:55.663 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:55.663 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:55.663 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:55.831 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:55.831 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:55.831 | Historical data download ID 121951 not found when removing ID from outstanding request set.
2024-08-14 17:18:55.831 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:55.831 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:55.831 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:55.831 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:55.831 | Historical data download ID 121952 not found when removing ID from outstanding request set.
2024-08-14 17:18:55.831 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:55.831 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:55.831 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:55.831 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:55.831 | Historical data download ID 121953 not found when removing ID from outstanding request set.
2024-08-14 17:18:55.831 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:55.831 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:55.831 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:55.874 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:55.877 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:18:55.877 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:55.877 | DTC Client socket (5) | Closed.
2024-08-14 17:18:55.877 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:55.878 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:55.878 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:55.878 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:18:57.908 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:18:57.908 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:18:57.908 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:18:57.909 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:18:57.909 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:18:57.982 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:18:57.982 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:18:57.982 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:18:57.982 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:18:58.100 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:18:58.100 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:18:58.100 | Historical data download ID 121954 not found when removing ID from outstanding request set.
2024-08-14 17:18:58.100 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:18:58.100 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:18:58.100 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:18:58.100 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:18:58.100 | Historical data download ID 121955 not found when removing ID from outstanding request set.
2024-08-14 17:18:58.100 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:18:58.100 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:18:58.100 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:18:58.100 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:18:58.100 | Historical data download ID 121956 not found when removing ID from outstanding request set.
2024-08-14 17:18:58.100 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:18:58.100 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:18:58.100 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:18:58.142 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:18:58.146 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:18:58.146 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:18:58.146 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:18:58.146 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:18:58.146 | DTC Client socket (5) | Closed.
2024-08-14 17:18:58.146 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:18:58.147 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:18:58.147 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:18:58.147 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:00.150 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:00.151 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:00.151 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:00.151 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:00.151 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:00.195 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:00.195 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:00.195 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:00.195 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:00.340 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:00.340 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:00.340 | Historical data download ID 121957 not found when removing ID from outstanding request set.
2024-08-14 17:19:00.340 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:00.340 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:00.340 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:00.340 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:00.340 | Historical data download ID 121958 not found when removing ID from outstanding request set.
2024-08-14 17:19:00.340 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:00.340 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:00.340 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:00.340 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:00.340 | Historical data download ID 121959 not found when removing ID from outstanding request set.
2024-08-14 17:19:00.340 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:00.340 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:00.340 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:00.384 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:00.388 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:00.388 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:00.388 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:00.388 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:19:00.388 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:00.388 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:00.388 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:00.388 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:00.421 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:19:00.421 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:00.421 | DTC Client socket (5) | Closed.
2024-08-14 17:19:02.411 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:02.411 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:02.412 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:02.412 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:02.412 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:02.457 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:02.457 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:02.457 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:02.457 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:02.674 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:02.674 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:02.674 | Historical data download ID 121960 not found when removing ID from outstanding request set.
2024-08-14 17:19:02.674 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:02.674 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:02.674 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:02.674 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:02.674 | Historical data download ID 121961 not found when removing ID from outstanding request set.
2024-08-14 17:19:02.674 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:02.674 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:02.674 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:02.674 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:02.674 | Historical data download ID 121962 not found when removing ID from outstanding request set.
2024-08-14 17:19:02.674 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:02.674 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:02.674 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:02.716 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:02.718 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:02.718 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:02.718 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:02.718 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:19:02.718 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:02.722 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:02.723 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:02.723 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:02.723 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:02.781 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:19:02.781 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:02.781 | DTC Client socket (5) | Closed.
2024-08-14 17:19:03.446 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:03.446 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:19:03.456 | HD Server | Thread:1868 (5) | Creating socket.
2024-08-14 17:19:03.456 | HD Server | Thread:1868 (5) | New receive buffer size: 262144
2024-08-14 17:19:03.456 | HD Server | Thread:1868 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:03.456 | HD Server | Setting DTC encoding to Binary VLS | Thread:1868
2024-08-14 17:19:03.457 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:1868
2024-08-14 17:19:03.457 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:1868
2024-08-14 17:19:03.457 | HD Server | HD Request #4278 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4278 | Username: DAVID SUDDUTH JR. | Thread:1868
2024-08-14 17:19:03.457 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4278 | Username: DAVID SUDDUTH JR. | Thread:1868
2024-08-14 17:19:03.458 | HD Server | Thread:1868 (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:03.458 | HD Server | Thread:1868 (5) | CloseSocket call.
2024-08-14 17:19:03.458 | HD Server | Thread:1868 (0) | CloseSocket call.
2024-08-14 17:19:03.458 | HD Server | Thread:1868 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:03.458 | HD Server | Thread:1868 (5) | Closed.
2024-08-14 17:19:03.461 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:03.461 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:19:03.470 | HD Server | Thread:18044 (5) | Creating socket.
2024-08-14 17:19:03.470 | HD Server | Thread:18044 (5) | New receive buffer size: 262144
2024-08-14 17:19:03.470 | HD Server | Thread:18044 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:03.470 | HD Server | Setting DTC encoding to Binary VLS | Thread:18044
2024-08-14 17:19:03.471 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18044
2024-08-14 17:19:03.471 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18044
2024-08-14 17:19:03.471 | HD Server | HD Request #4279 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4279 | Username: DAVID SUDDUTH JR. | Thread:18044
2024-08-14 17:19:03.471 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4279 | Username: DAVID SUDDUTH JR. | Thread:18044
2024-08-14 17:19:03.471 | HD Server | Thread:18044 (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:03.471 | HD Server | Thread:18044 (5) | CloseSocket call.
2024-08-14 17:19:03.472 | HD Server | Thread:18044 (0) | CloseSocket call.
2024-08-14 17:19:03.472 | HD Server | Thread:18044 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:03.472 | HD Server | Thread:18044 (5) | Closed.
2024-08-14 17:19:03.595 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18044
2024-08-14 17:19:03.595 | HD Server Manager | Current server count=1
2024-08-14 17:19:03.595 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:1868
2024-08-14 17:19:03.595 | HD Server Manager | Current server count=0
2024-08-14 17:19:04.731 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:04.731 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:04.731 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:04.731 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:04.731 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:04.779 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:04.779 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:04.779 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:04.779 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:04.917 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:04.917 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:04.917 | Historical data download ID 121963 not found when removing ID from outstanding request set.
2024-08-14 17:19:04.917 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:04.917 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:04.917 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:04.917 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:04.917 | Historical data download ID 121964 not found when removing ID from outstanding request set.
2024-08-14 17:19:04.917 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:04.917 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:04.917 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:04.917 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:04.917 | Historical data download ID 121965 not found when removing ID from outstanding request set.
2024-08-14 17:19:04.917 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:04.917 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:04.917 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:04.960 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:04.964 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:04.964 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:04.965 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:04.965 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:19:04.965 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:04.965 | DTC Client socket (5) | Closed.
2024-08-14 17:19:04.965 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:04.968 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:04.968 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:04.968 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:04.968 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:06.576 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:06.576 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:19:06.586 | HD Server | Thread:4348 (5) | Creating socket.
2024-08-14 17:19:06.586 | HD Server | Thread:4348 (5) | New receive buffer size: 262144
2024-08-14 17:19:06.586 | HD Server | Thread:4348 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:06.586 | HD Server | Setting DTC encoding to Binary VLS | Thread:4348
2024-08-14 17:19:06.587 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:4348
2024-08-14 17:19:06.587 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:4348
2024-08-14 17:19:06.587 | HD Server | HD Request #4280 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4280 | Username: DAVID SUDDUTH JR. | Thread:4348
2024-08-14 17:19:06.587 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4280 | Username: DAVID SUDDUTH JR. | Thread:4348
2024-08-14 17:19:06.587 | HD Server | Thread:4348 (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:06.587 | HD Server | Thread:4348 (5) | CloseSocket call.
2024-08-14 17:19:06.588 | HD Server | Thread:4348 (0) | CloseSocket call.
2024-08-14 17:19:06.588 | HD Server | Thread:4348 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:06.588 | HD Server | Thread:4348 (5) | Closed.
2024-08-14 17:19:06.589 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:06.589 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:19:06.597 | HD Server | Thread:11072 (5) | Creating socket.
2024-08-14 17:19:06.597 | HD Server | Thread:11072 (5) | New receive buffer size: 262144
2024-08-14 17:19:06.597 | HD Server | Thread:11072 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:06.597 | HD Server | Setting DTC encoding to Binary VLS | Thread:11072
2024-08-14 17:19:06.598 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11072
2024-08-14 17:19:06.598 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11072
2024-08-14 17:19:06.598 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:4348
2024-08-14 17:19:06.598 | HD Server | HD Request #4281 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4281 | Username: DAVID SUDDUTH JR. | Thread:11072
2024-08-14 17:19:06.598 | HD Server Manager | Current server count=1
2024-08-14 17:19:06.598 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4281 | Username: DAVID SUDDUTH JR. | Thread:11072
2024-08-14 17:19:06.598 | HD Server | Thread:11072 (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:06.598 | HD Server | Thread:11072 (5) | CloseSocket call.
2024-08-14 17:19:06.599 | HD Server | Thread:11072 (0) | CloseSocket call.
2024-08-14 17:19:06.599 | HD Server | Thread:11072 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:06.599 | HD Server | Thread:11072 (5) | Closed.
2024-08-14 17:19:06.894 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11072
2024-08-14 17:19:06.894 | HD Server Manager | Current server count=0
2024-08-14 17:19:06.963 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:06.963 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:06.963 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:06.963 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:06.963 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:07.001 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:07.001 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:07.002 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:07.002 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:07.141 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:07.141 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:07.141 | Historical data download ID 121966 not found when removing ID from outstanding request set.
2024-08-14 17:19:07.141 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:07.141 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:07.141 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:07.141 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:07.141 | Historical data download ID 121967 not found when removing ID from outstanding request set.
2024-08-14 17:19:07.141 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:07.141 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:07.141 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:07.141 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:07.141 | Historical data download ID 121968 not found when removing ID from outstanding request set.
2024-08-14 17:19:07.141 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:07.141 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:07.141 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:07.183 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:07.184 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:07.184 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:07.184 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:07.184 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:19:07.184 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:19:07.184 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:07.189 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:07.189 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:07.189 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:07.189 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:07.234 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:19:07.234 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:07.234 | DTC Client socket (5) | Closed.
2024-08-14 17:19:09.191 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:09.191 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:09.191 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:09.191 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:09.191 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:09.233 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:09.233 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:09.233 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:09.233 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:09.391 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:09.391 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:09.391 | Historical data download ID 121969 not found when removing ID from outstanding request set.
2024-08-14 17:19:09.391 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:09.391 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:09.391 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:09.391 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:09.391 | Historical data download ID 121970 not found when removing ID from outstanding request set.
2024-08-14 17:19:09.391 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:09.391 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:09.391 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:09.391 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:09.391 | Historical data download ID 121971 not found when removing ID from outstanding request set.
2024-08-14 17:19:09.391 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:09.391 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:09.391 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:09.432 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:09.443 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:09.443 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:19:09.443 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:09.443 | DTC Client socket (5) | Closed.
2024-08-14 17:19:09.443 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:09.449 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:09.449 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:09.449 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:09.449 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:11.450 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:11.450 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:11.451 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:11.451 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:11.451 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:11.491 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:11.491 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:11.491 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:11.491 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:11.626 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:11.626 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:11.626 | Historical data download ID 121972 not found when removing ID from outstanding request set.
2024-08-14 17:19:11.626 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:11.626 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:11.626 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:11.626 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:11.626 | Historical data download ID 121973 not found when removing ID from outstanding request set.
2024-08-14 17:19:11.626 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:11.626 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:11.626 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:11.626 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:11.626 | Historical data download ID 121974 not found when removing ID from outstanding request set.
2024-08-14 17:19:11.626 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:11.626 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:11.626 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:11.668 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:11.672 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:11.672 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:11.672 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:11.672 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:19:11.672 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:11.672 | DTC Client socket (5) | Closed.
2024-08-14 17:19:11.672 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:11.676 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:11.677 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:11.677 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:11.677 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:13.676 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:13.676 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:13.676 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:13.676 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:13.676 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:13.717 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:13.717 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:13.717 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:13.717 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:13.843 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:13.843 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:13.843 | Historical data download ID 121975 not found when removing ID from outstanding request set.
2024-08-14 17:19:13.843 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:13.843 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:13.843 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:13.843 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:13.843 | Historical data download ID 121976 not found when removing ID from outstanding request set.
2024-08-14 17:19:13.843 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:13.843 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:13.843 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:13.843 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:13.843 | Historical data download ID 121977 not found when removing ID from outstanding request set.
2024-08-14 17:19:13.843 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:13.843 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:13.843 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:13.886 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:13.891 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:13.891 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:13.891 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:13.891 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:19:13.891 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:13.891 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:13.891 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:13.891 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:13.924 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:19:13.924 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:13.925 | DTC Client socket (5) | Closed.
2024-08-14 17:19:15.913 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:15.913 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:15.913 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:15.913 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:15.913 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:15.952 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:15.952 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:15.952 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:15.952 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:16.087 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:16.087 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:16.087 | Historical data download ID 121978 not found when removing ID from outstanding request set.
2024-08-14 17:19:16.087 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:16.087 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:16.087 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:16.087 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:16.087 | Historical data download ID 121979 not found when removing ID from outstanding request set.
2024-08-14 17:19:16.087 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:16.087 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:16.087 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:16.088 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:16.088 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:16.088 | Historical data download ID 121980 not found when removing ID from outstanding request set.
2024-08-14 17:19:16.088 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:16.088 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:16.088 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:16.131 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:16.135 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:16.135 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:16.135 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:16.135 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:16.135 | DTC Client socket (5) | Closed.
2024-08-14 17:19:16.135 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:16.135 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:16.135 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:16.135 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:18.133 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:18.133 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:18.133 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:18.134 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:18.134 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:18.176 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:18.176 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:18.176 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:18.176 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:18.304 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:18.304 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:18.304 | Historical data download ID 121981 not found when removing ID from outstanding request set.
2024-08-14 17:19:18.304 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:18.304 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:18.304 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:18.304 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:18.304 | Historical data download ID 121982 not found when removing ID from outstanding request set.
2024-08-14 17:19:18.304 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:18.304 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:18.304 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:18.304 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:18.304 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:18.305 | Historical data download ID 121983 not found when removing ID from outstanding request set.
2024-08-14 17:19:18.305 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:18.305 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:18.305 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:18.345 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:18.345 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:18.345 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:18.345 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:18.345 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:19:18.345 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:18.346 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:18.346 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:18.346 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:18.619 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:19:18.619 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:18.619 | DTC Client socket (5) | Closed.
2024-08-14 17:19:20.414 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:20.414 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:20.414 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:20.415 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:20.415 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:20.457 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:20.457 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:20.457 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:20.457 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:20.580 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:20.580 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:20.580 | Historical data download ID 121984 not found when removing ID from outstanding request set.
2024-08-14 17:19:20.580 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:20.580 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:20.580 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:20.580 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:20.580 | Historical data download ID 121985 not found when removing ID from outstanding request set.
2024-08-14 17:19:20.580 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:20.580 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:20.580 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:20.580 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:20.580 | Historical data download ID 121986 not found when removing ID from outstanding request set.
2024-08-14 17:19:20.580 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:20.580 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:20.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:20.619 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:20.629 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:20.629 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:20.629 | DTC Client socket (5) | Closed.
2024-08-14 17:19:20.629 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:20.630 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:20.630 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:20.630 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:22.633 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:22.634 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:22.634 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:22.634 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:19:22.634 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:22.676 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:22.676 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:22.676 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:22.676 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:22.802 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:22.802 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:22.802 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:22.802 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:22.802 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:22.802 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:22.802 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:22.802 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:22.802 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:22.802 | Historical data download ID 121987 not found when removing ID from outstanding request set.
2024-08-14 17:19:22.802 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:22.802 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:22.803 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:22.803 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:22.803 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:22.803 | Historical data download ID 121988 not found when removing ID from outstanding request set.
2024-08-14 17:19:22.803 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:22.803 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:22.803 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:22.803 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:22.803 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:22.803 | Historical data download ID 121989 not found when removing ID from outstanding request set.
2024-08-14 17:19:22.803 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:22.803 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:22.803 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:22.845 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:22.847 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:19:22.847 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:19:22.847 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:19:22.847 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:19:22.847 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:22.847 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:22.847 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:22.847 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:23.120 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:19:23.120 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:23.120 | DTC Client socket (5) | Closed.
2024-08-14 17:19:23.408 | Socket (4) | CloseSocket call.
2024-08-14 17:19:23.408 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-08-14 17:19:23.428 | Historical data download thread signaled to stop.
2024-08-14 17:19:23.428 | HD Request # 7 | Received 7316435 Intraday data records from 2024-02-12 04:00:00.000000 to 2024-08-14 17:19:24.000000 (184.5 days. Delay: -0.6 seconds) and wrote 7316368 records for ADR-NASDAQ
2024-08-14 17:19:23.428 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2024-08-14 21:19:24.000000
2024-08-14 17:19:23.428 | Added 1 Time and Sales records to Intraday data file for ADR-NASDAQ after download.
2024-08-14 17:19:23.428 | HD Request # 7 | Completion time: 39s.
2024-08-14 17:19:23.428 | HD Request # 7 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 121902
2024-08-14 17:19:23.428 | Removing historical data download ID 121902.
2024-08-14 17:19:23.428 | Real-time Intraday chart data file updates started for ADR-NASDAQ
2024-08-14 17:19:23.428 | Intraday chart data file opened for ADR-NASDAQ
2024-08-14 17:19:23.428 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2024-08-14 17:19:23.428 | ESU4.CME 1 Min #19 | Historical data download for additional symbol ADR-NASDAQ with ID 121902 has completed.
2024-08-14 17:19:23.428 | Triggering next historical data download in queue.
2024-08-14 17:19:23.429 | HD Request # 8 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc
2024-08-14 17:19:23.429 | HD Request # 8 | Download start date-time: 2024-02-10 16:19:23.000000. File last date-time: 00:00:00.000000
2024-08-14 17:19:23.429 | HD Request # 8 | Using server: ds4.sierracharts.com port 10149
2024-08-14 17:19:23.461 | Socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:23.461 | Socket (4) | Closed.
2024-08-14 17:19:23.504 | Socket (5) | Creating socket.
2024-08-14 17:19:23.505 | Socket (5) | New receive buffer size: 0
2024-08-14 17:19:23.505 | Socket (5) | Connecting to IP: 67.214.125.7.
2024-08-14 17:19:23.559 | Enabling compression for file: D:\SierraChart\Data\ADR-NYSE.scid
2024-08-14 17:19:23.601 | HD Request # 8 | Setting DTC encoding to Binary VLS
2024-08-14 17:19:23.601 | HD Request # 8 | Sending historical data logon request message.
2024-08-14 17:19:24.124 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-02-10 16:19:23. Record interval: 0. Symbol: ADR-NYSE
2024-08-14 17:19:24.169 | HD Request # 8 | Decompressing data.
2024-08-14 17:19:24.321 | HD Request # 8 | Receiving Intraday data for ADR-NYSE starting at 2024-02-12 04:00:00.000000
2024-08-14 17:19:24.590 | HD Request # 8 | Timestamp of first Intraday data file record written: 2024-02-12 04:00:00.000000.
2024-08-14 17:19:24.853 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:24.853 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:24.853 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:24.853 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:24.853 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:24.920 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:24.920 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:24.920 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:24.920 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:25.062 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:25.062 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:25.062 | Historical data download ID 121990 not found when removing ID from outstanding request set.
2024-08-14 17:19:25.062 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:25.062 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:25.062 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:25.062 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:25.062 | Historical data download ID 121991 not found when removing ID from outstanding request set.
2024-08-14 17:19:25.062 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:25.062 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:25.062 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:25.063 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:25.063 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:25.063 | Historical data download ID 121992 not found when removing ID from outstanding request set.
2024-08-14 17:19:25.063 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:25.063 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:25.063 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:25.110 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:25.113 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:25.113 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:25.113 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:25.113 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:19:25.113 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:25.113 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:19:25.113 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:25.114 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:25.114 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:25.114 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:25.152 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:19:25.152 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:25.152 | DTC Client socket (4) | Closed.
2024-08-14 17:19:27.111 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:27.111 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:27.112 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:27.112 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:27.112 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:27.152 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:27.152 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:27.152 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:27.152 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:27.285 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:27.285 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:27.285 | Historical data download ID 121993 not found when removing ID from outstanding request set.
2024-08-14 17:19:27.285 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:27.285 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:27.285 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:27.285 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:27.285 | Historical data download ID 121994 not found when removing ID from outstanding request set.
2024-08-14 17:19:27.285 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:27.285 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:27.285 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:27.285 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:27.285 | Historical data download ID 121995 not found when removing ID from outstanding request set.
2024-08-14 17:19:27.285 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:27.285 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:27.285 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:27.327 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:27.329 | Opened cached Intraday file: D:\SierraChart\Data\ADR-NASDAQ.scid. Thread ID: 15420
2024-08-14 17:19:27.331 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:27.331 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:19:27.332 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:27.332 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:27.332 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:27.332 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:27.332 | DTC Client socket (4) | Closed.
2024-08-14 17:19:27.332 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:27.332 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:27.332 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:29.336 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:29.336 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:29.337 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:29.337 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:29.337 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:29.380 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:29.380 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:29.380 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:29.380 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:29.523 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:29.523 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:29.523 | Historical data download ID 121996 not found when removing ID from outstanding request set.
2024-08-14 17:19:29.523 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:29.523 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:29.523 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:29.523 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:29.523 | Historical data download ID 121997 not found when removing ID from outstanding request set.
2024-08-14 17:19:29.523 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:29.523 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:29.523 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:29.523 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:29.523 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:29.524 | Historical data download ID 121998 not found when removing ID from outstanding request set.
2024-08-14 17:19:29.524 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:29.524 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:29.524 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:29.574 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:29.576 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:29.576 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:29.576 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:29.576 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:19:29.576 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:29.576 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:29.576 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:29.576 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:29.613 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:19:29.613 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:29.613 | DTC Client socket (4) | Closed.
2024-08-14 17:19:31.580 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:31.580 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:31.581 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:31.581 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:31.581 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:31.615 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:31.615 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:31.615 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:31.615 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:31.753 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:31.753 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:31.753 | Historical data download ID 121999 not found when removing ID from outstanding request set.
2024-08-14 17:19:31.753 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:31.753 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:31.753 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:31.753 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:31.753 | Historical data download ID 122000 not found when removing ID from outstanding request set.
2024-08-14 17:19:31.753 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:31.753 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:31.753 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:31.753 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:31.753 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:31.754 | Historical data download ID 122001 not found when removing ID from outstanding request set.
2024-08-14 17:19:31.754 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:31.754 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:31.754 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:31.801 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:31.804 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:31.804 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:31.804 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:31.804 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:19:31.804 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:19:31.804 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:31.810 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:31.810 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:31.810 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:31.810 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:31.840 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:19:31.840 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:31.840 | DTC Client socket (4) | Closed.
2024-08-14 17:19:33.811 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:33.811 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:33.811 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:33.811 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:33.811 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:33.855 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:33.855 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:33.855 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:33.855 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:33.993 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:33.993 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:33.993 | Historical data download ID 122002 not found when removing ID from outstanding request set.
2024-08-14 17:19:33.993 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:33.993 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:33.993 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:33.993 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:33.993 | Historical data download ID 122003 not found when removing ID from outstanding request set.
2024-08-14 17:19:33.993 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:33.993 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:33.993 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:33.993 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:33.993 | Historical data download ID 122004 not found when removing ID from outstanding request set.
2024-08-14 17:19:33.993 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:33.993 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:33.993 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:34.047 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:34.047 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:34.047 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:34.047 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:34.047 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:19:34.047 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:34.048 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:34.048 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:34.048 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:34.090 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:19:34.090 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:34.090 | DTC Client socket (4) | Closed.
2024-08-14 17:19:36.063 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:36.063 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:36.063 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:36.063 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:36.063 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:36.104 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:36.104 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:36.104 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:36.104 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:36.250 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:36.250 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:36.250 | Historical data download ID 122005 not found when removing ID from outstanding request set.
2024-08-14 17:19:36.250 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:36.250 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:36.250 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:36.250 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:36.250 | Historical data download ID 122006 not found when removing ID from outstanding request set.
2024-08-14 17:19:36.250 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:36.250 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:36.250 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:36.250 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:36.250 | Historical data download ID 122007 not found when removing ID from outstanding request set.
2024-08-14 17:19:36.250 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:36.250 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:36.250 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:36.296 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:36.300 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:36.300 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:36.300 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:36.300 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:36.300 | DTC Client socket (4) | Closed.
2024-08-14 17:19:36.300 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:36.300 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:36.300 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:36.300 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:37.824 | ESU4.CME [CB] 500000 Volume #6 | Chart data loading complete.
2024-08-14 17:19:38.300 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:38.300 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:38.301 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:38.301 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:38.301 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:38.340 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:38.340 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:38.340 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:38.340 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:38.482 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:38.482 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:38.482 | Historical data download ID 122008 not found when removing ID from outstanding request set.
2024-08-14 17:19:38.482 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:38.482 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:38.482 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:38.482 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:38.482 | Historical data download ID 122009 not found when removing ID from outstanding request set.
2024-08-14 17:19:38.482 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:38.482 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:38.482 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:38.482 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:38.482 | Historical data download ID 122010 not found when removing ID from outstanding request set.
2024-08-14 17:19:38.482 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:38.482 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:38.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:38.524 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:38.524 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:38.524 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:38.524 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:38.524 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:38.524 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:38.524 | DTC Client socket (4) | Closed.
2024-08-14 17:19:38.525 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:38.525 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:38.525 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:40.526 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:40.526 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:40.526 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:40.526 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:40.526 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:40.580 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:40.580 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:40.580 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:40.580 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:40.653 | Socket (5) | CloseSocket call.
2024-08-14 17:19:40.654 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-08-14 17:19:40.654 | Historical data download thread signaled to stop.
2024-08-14 17:19:40.654 | HD Request # 8 | Received 7316370 Intraday data records from 2024-02-12 04:00:00.000000 to 2024-08-14 17:19:41.000000 (184.5 days. Delay: -0.3 seconds) and wrote 7316370 records for ADR-NYSE
2024-08-14 17:19:40.654 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2024-08-14 21:19:41.000000
2024-08-14 17:19:40.654 | Added 1 Time and Sales records to Intraday data file for ADR-NYSE after download.
2024-08-14 17:19:40.654 | HD Request # 8 | Completion time: 17s.
2024-08-14 17:19:40.654 | HD Request # 8 | Intraday data download complete for ADR-NYSE. Unique request ID: 121903
2024-08-14 17:19:40.654 | Removing historical data download ID 121903.
2024-08-14 17:19:40.654 | Real-time Intraday chart data file updates started for ADR-NYSE
2024-08-14 17:19:40.654 | Intraday chart data file opened for ADR-NYSE
2024-08-14 17:19:40.654 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2024-08-14 17:19:40.654 | ESU4.CME 1 Min #19 | Historical data download for additional symbol ADR-NYSE with ID 121903 has completed.
2024-08-14 17:19:40.654 | Triggering next historical data download in queue.
2024-08-14 17:19:40.655 | HD Request # 9 | Downloading Historical Daily chart data for TICK-NYSE. Starting date: 2022-09-12. Service: statscalc
2024-08-14 17:19:40.655 | HD Request # 9 | Using server: ds12.sierracharts.com port 10150
2024-08-14 17:19:40.655 | Socket (6) | Creating socket.
2024-08-14 17:19:40.655 | Socket (6) | New receive buffer size: 0
2024-08-14 17:19:40.655 | Socket (6) | Connecting to IP: 69.39.70.241.
2024-08-14 17:19:40.700 | Socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:19:40.700 | Socket (5) | Closed.
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:40.727 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:40.727 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:40.727 | Historical data download ID 122011 not found when removing ID from outstanding request set.
2024-08-14 17:19:40.727 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:40.727 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:40.727 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:40.727 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:40.727 | Historical data download ID 122012 not found when removing ID from outstanding request set.
2024-08-14 17:19:40.727 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:40.727 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:40.727 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:40.727 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:40.727 | Historical data download ID 122013 not found when removing ID from outstanding request set.
2024-08-14 17:19:40.727 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:40.727 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:40.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:40.760 | HD Request # 9 | Setting DTC encoding to Binary VLS
2024-08-14 17:19:40.760 | HD Request # 9 | Sending historical data logon request message.
2024-08-14 17:19:40.765 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:40.778 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:40.778 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:40.778 | DTC Client socket (4) | Closed.
2024-08-14 17:19:40.778 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:40.778 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:40.778 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:40.778 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:41.047 | ESU4.CME 1 Min #19 | Reloading chart.
2024-08-14 17:19:41.058 | + Loading additional symbol data. | Number times message added: 2
2024-08-14 17:19:41.108 | ESU4.CME 1 Min #19 | StartDateTimeForLoadingOrderFills: 2024-07-31 14:41:40
2024-08-14 17:19:41.111 | ESU4.CME 1 Min #19 | Chart data loading complete.
2024-08-14 17:19:41.288 | HD Request # 9 | Requesting historical Daily data starting at 2022-09-12.
2024-08-14 17:19:41.333 | HD Request # 9 | Decompressing data.
2024-08-14 17:19:41.405 | HD Request # 9 | Receiving historical Daily data for TICK-NYSE starting at 2022-09-12.
2024-08-14 17:19:41.406 | HD Request # 9 | Writing historical Daily data to the file TICK-NYSE.dly.
2024-08-14 17:19:41.422 | Socket (6) | CloseSocket call.
2024-08-14 17:19:41.422 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-08-14 17:19:41.455 | Historical data download thread signaled to stop.
2024-08-14 17:19:41.455 | HD Request # 9 | Received 484 Daily data records from 2022-09-12 00:00:00 to 2024-08-14 00:00:00 (703.0 days) and wrote 484 records for TICK-NYSE
2024-08-14 17:19:41.455 | HD Request # 9 | Completion time: 1s.
2024-08-14 17:19:41.455 | HD Request # 9 | Daily data download complete for TICK-NYSE. Unique request ID: 121911
2024-08-14 17:19:41.455 | Removing historical data download ID 121911.
2024-08-14 17:19:41.455 | ESU4.CME [CB] Daily #25 | Historical data download for additional symbol TICK-NYSE with ID 121911 has completed.
2024-08-14 17:19:41.455 | No download requests in the queue to start downloads for.
2024-08-14 17:19:41.467 | Socket (6) | Socket gracefully closed by remote side.
2024-08-14 17:19:41.467 | Socket (6) | Closed.
2024-08-14 17:19:41.669 | ESU4.CME [CB] Daily #25 | Reloading chart.
2024-08-14 17:19:41.935 | + Loading additional symbol data.
2024-08-14 17:19:41.974 | ESU4.CME [CB] Daily #25 | Chart data loading complete.
2024-08-14 17:19:42.470 | Opened cached Intraday file: D:\SierraChart\Data\ADR-NYSE.scid. Thread ID: 15420
2024-08-14 17:19:42.560 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:42.560 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:19:42.567 | HD Server | Thread:19184 (4) | Creating socket.
2024-08-14 17:19:42.567 | HD Server | Thread:19184 (4) | New receive buffer size: 262144
2024-08-14 17:19:42.567 | HD Server | Thread:19184 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:42.568 | HD Server | Setting DTC encoding to Binary VLS | Thread:19184
2024-08-14 17:19:42.568 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19184
2024-08-14 17:19:42.568 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19184
2024-08-14 17:19:42.568 | HD Server | HD Request #4282 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4282 | Username: DAVID SUDDUTH JR. | Thread:19184
2024-08-14 17:19:42.568 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4282 | Username: DAVID SUDDUTH JR. | Thread:19184
2024-08-14 17:19:42.569 | HD Server | Thread:19184 (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:42.569 | HD Server | Thread:19184 (4) | CloseSocket call.
2024-08-14 17:19:42.569 | HD Server | Thread:19184 (0) | CloseSocket call.
2024-08-14 17:19:42.569 | HD Server | Thread:19184 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:42.569 | HD Server | Thread:19184 (4) | Closed.
2024-08-14 17:19:42.570 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:42.571 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:19:42.577 | HD Server | Thread:21216 (4) | Creating socket.
2024-08-14 17:19:42.577 | HD Server | Thread:21216 (4) | New receive buffer size: 262144
2024-08-14 17:19:42.577 | HD Server | Thread:21216 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:42.578 | HD Server | Setting DTC encoding to Binary VLS | Thread:21216
2024-08-14 17:19:42.578 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:19:42.578 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:19:42.578 | HD Server | HD Request #4283 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4283 | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:19:42.578 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4283 | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:19:42.579 | HD Server | Thread:21216 (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:42.579 | HD Server | Thread:21216 (4) | CloseSocket call.
2024-08-14 17:19:42.579 | HD Server | Thread:21216 (0) | CloseSocket call.
2024-08-14 17:19:42.579 | HD Server | Thread:21216 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:42.579 | HD Server | Thread:21216 (4) | Closed.
2024-08-14 17:19:42.668 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:19:42.668 | HD Server Manager | Current server count=1
2024-08-14 17:19:42.668 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19184
2024-08-14 17:19:42.668 | HD Server Manager | Current server count=0
2024-08-14 17:19:42.773 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:42.773 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:42.773 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:42.773 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:42.773 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:42.812 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:42.812 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:42.812 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:42.812 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:42.956 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:42.956 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:42.956 | Historical data download ID 122014 not found when removing ID from outstanding request set.
2024-08-14 17:19:42.956 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:42.956 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:42.956 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:42.956 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:42.956 | Historical data download ID 122015 not found when removing ID from outstanding request set.
2024-08-14 17:19:42.956 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:42.956 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:42.956 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:42.956 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:42.956 | Historical data download ID 122016 not found when removing ID from outstanding request set.
2024-08-14 17:19:42.956 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:42.956 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:42.956 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:42.995 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:43.003 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:43.003 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:43.003 | DTC Client socket (4) | Closed.
2024-08-14 17:19:43.003 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:43.003 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:43.003 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:43.003 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:45.010 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:45.010 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:45.010 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:45.010 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:45.010 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:45.048 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:45.048 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:45.048 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:45.048 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:45.180 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:45.180 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:45.180 | Historical data download ID 122017 not found when removing ID from outstanding request set.
2024-08-14 17:19:45.180 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:45.180 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:45.180 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:45.180 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:45.180 | Historical data download ID 122018 not found when removing ID from outstanding request set.
2024-08-14 17:19:45.180 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:45.180 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:45.180 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:45.180 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:45.180 | Historical data download ID 122019 not found when removing ID from outstanding request set.
2024-08-14 17:19:45.180 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:45.180 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:45.180 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:45.221 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:45.224 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:45.224 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:45.224 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:45.224 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:45.224 | DTC Client socket (4) | Closed.
2024-08-14 17:19:45.225 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:45.225 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:45.225 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:45.225 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:45.458 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:45.458 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:19:45.466 | HD Server | Thread:17580 (4) | Creating socket.
2024-08-14 17:19:45.466 | HD Server | Thread:17580 (4) | New receive buffer size: 262144
2024-08-14 17:19:45.466 | HD Server | Thread:17580 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:45.466 | HD Server | Setting DTC encoding to Binary VLS | Thread:17580
2024-08-14 17:19:45.467 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:17580
2024-08-14 17:19:45.467 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:17580
2024-08-14 17:19:45.467 | HD Server | HD Request #4284 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4284 | Username: DAVID SUDDUTH JR. | Thread:17580
2024-08-14 17:19:45.467 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4284 | Username: DAVID SUDDUTH JR. | Thread:17580
2024-08-14 17:19:45.468 | HD Server | Thread:17580 (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:45.468 | HD Server | Thread:17580 (4) | CloseSocket call.
2024-08-14 17:19:45.468 | HD Server | Thread:17580 (0) | CloseSocket call.
2024-08-14 17:19:45.468 | HD Server | Thread:17580 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:45.468 | HD Server | Thread:17580 (4) | Closed.
2024-08-14 17:19:45.472 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:19:45.472 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:19:45.481 | HD Server | Thread:18548 (4) | Creating socket.
2024-08-14 17:19:45.481 | HD Server | Thread:18548 (4) | New receive buffer size: 262144
2024-08-14 17:19:45.481 | HD Server | Thread:18548 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:19:45.481 | HD Server | Setting DTC encoding to Binary VLS | Thread:18548
2024-08-14 17:19:45.482 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18548
2024-08-14 17:19:45.482 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18548
2024-08-14 17:19:45.482 | HD Server | HD Request #4285 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4285 | Username: DAVID SUDDUTH JR. | Thread:18548
2024-08-14 17:19:45.482 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4285 | Username: DAVID SUDDUTH JR. | Thread:18548
2024-08-14 17:19:45.482 | HD Server | Thread:18548 (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:45.482 | HD Server | Thread:18548 (4) | CloseSocket call.
2024-08-14 17:19:45.482 | HD Server | Thread:18548 (0) | CloseSocket call.
2024-08-14 17:19:45.483 | HD Server | Thread:18548 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:45.483 | HD Server | Thread:18548 (4) | Closed.
2024-08-14 17:19:45.483 | HD Server | Thread:18548 (0) | CloseSocket call.
2024-08-14 17:19:45.491 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18548
2024-08-14 17:19:45.492 | HD Server Manager | Current server count=1
2024-08-14 17:19:45.492 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:17580
2024-08-14 17:19:45.492 | HD Server Manager | Current server count=0
2024-08-14 17:19:47.225 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:47.225 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:47.226 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:47.226 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:47.226 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:47.266 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:47.266 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:47.266 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:47.266 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:47.394 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:47.394 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:47.394 | Historical data download ID 122020 not found when removing ID from outstanding request set.
2024-08-14 17:19:47.394 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:47.394 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:47.394 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:47.394 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:47.394 | Historical data download ID 122021 not found when removing ID from outstanding request set.
2024-08-14 17:19:47.394 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:47.394 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:47.394 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:47.394 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:47.394 | Historical data download ID 122022 not found when removing ID from outstanding request set.
2024-08-14 17:19:47.394 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:47.394 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:47.394 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:47.447 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:47.451 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:47.451 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:47.451 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:47.451 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:19:47.451 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:47.451 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:47.451 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:47.451 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:47.452 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=368
2024-08-14 17:19:47.452 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:47.490 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:19:47.490 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:47.490 | DTC Client socket (4) | Closed.
2024-08-14 17:19:48.673 | ESU4.CME [CB] 50000 Volume #8 | Chart data loading complete.
2024-08-14 17:19:49.479 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:49.479 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:49.480 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:49.480 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:49.480 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:49.523 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:49.523 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:49.523 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:49.523 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:49.653 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:49.653 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:49.653 | Historical data download ID 122023 not found when removing ID from outstanding request set.
2024-08-14 17:19:49.653 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:49.653 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:49.653 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:49.653 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:49.653 | Historical data download ID 122024 not found when removing ID from outstanding request set.
2024-08-14 17:19:49.653 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:49.653 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:49.653 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:49.653 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:49.653 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:49.654 | Historical data download ID 122025 not found when removing ID from outstanding request set.
2024-08-14 17:19:49.654 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:49.654 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:49.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:49.696 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:49.698 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:49.698 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:19:49.699 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:49.699 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:49.699 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:49.699 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:49.699 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:49.699 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:49.699 | DTC Client socket (4) | Closed.
2024-08-14 17:19:49.699 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:51.696 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:51.696 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:51.696 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:51.696 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:51.696 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:51.734 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:51.734 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:51.734 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:51.734 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:51.873 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:51.873 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:51.873 | Historical data download ID 122026 not found when removing ID from outstanding request set.
2024-08-14 17:19:51.873 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:51.873 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:51.873 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:51.873 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:51.873 | Historical data download ID 122027 not found when removing ID from outstanding request set.
2024-08-14 17:19:51.873 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:51.873 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:51.873 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:51.873 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:51.873 | Historical data download ID 122028 not found when removing ID from outstanding request set.
2024-08-14 17:19:51.873 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:51.873 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:51.873 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:51.915 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:51.918 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:51.918 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:51.918 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:51.918 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:51.918 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:19:51.918 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:51.918 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:51.918 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:51.918 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:51.966 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:19:51.966 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:51.966 | DTC Client socket (4) | Closed.
2024-08-14 17:19:53.924 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:53.924 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:53.925 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:53.925 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:53.925 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:53.966 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:53.966 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:53.966 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:53.966 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:54.097 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:54.097 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:54.097 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:54.097 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:54.097 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:54.097 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:54.097 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:54.097 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:54.098 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:54.098 | Historical data download ID 122029 not found when removing ID from outstanding request set.
2024-08-14 17:19:54.098 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:54.098 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:54.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:54.098 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:54.098 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:54.098 | Historical data download ID 122030 not found when removing ID from outstanding request set.
2024-08-14 17:19:54.098 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:54.098 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:54.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:54.098 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:54.098 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:54.098 | Historical data download ID 122031 not found when removing ID from outstanding request set.
2024-08-14 17:19:54.098 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:54.098 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:54.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:54.140 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:54.146 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:54.146 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:19:54.147 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:54.147 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:54.147 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:54.147 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:54.147 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:54.147 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:54.147 | DTC Client socket (4) | Closed.
2024-08-14 17:19:54.147 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:56.155 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:56.155 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:56.155 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:56.156 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:56.156 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:56.196 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:56.196 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:56.196 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:56.196 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:56.319 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:56.319 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:56.319 | Historical data download ID 122032 not found when removing ID from outstanding request set.
2024-08-14 17:19:56.319 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:56.319 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:56.319 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:56.319 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:56.319 | Historical data download ID 122033 not found when removing ID from outstanding request set.
2024-08-14 17:19:56.319 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:56.319 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:56.319 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:56.319 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:56.319 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:56.320 | Historical data download ID 122034 not found when removing ID from outstanding request set.
2024-08-14 17:19:56.320 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:56.320 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:56.320 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:56.362 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:56.365 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:56.365 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:56.365 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:56.365 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:56.365 | DTC Client socket (4) | Closed.
2024-08-14 17:19:56.365 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:56.366 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:56.366 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:56.366 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:58.370 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:19:58.370 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:19:58.370 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:19:58.370 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:19:58.370 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:19:58.408 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:19:58.408 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:19:58.409 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:19:58.409 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:19:58.528 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:19:58.528 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:19:58.528 | Historical data download ID 122035 not found when removing ID from outstanding request set.
2024-08-14 17:19:58.528 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:19:58.528 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:19:58.528 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:19:58.528 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:19:58.528 | Historical data download ID 122036 not found when removing ID from outstanding request set.
2024-08-14 17:19:58.528 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:19:58.528 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:19:58.528 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:19:58.528 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:19:58.528 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:19:58.529 | Historical data download ID 122037 not found when removing ID from outstanding request set.
2024-08-14 17:19:58.529 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:19:58.529 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:19:58.529 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:19:58.570 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:19:58.572 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:19:58.573 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:19:58.573 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:19:58.573 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:19:58.573 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:19:58.573 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:19:58.573 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:19:58.573 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:19:58.612 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:19:58.612 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:19:58.612 | DTC Client socket (4) | Closed.
2024-08-14 17:20:00.563 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:00.564 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:00.564 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:00.564 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:00.564 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:00.611 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:00.611 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:00.611 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:00.611 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:01.027 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:01.027 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:01.027 | Historical data download ID 122038 not found when removing ID from outstanding request set.
2024-08-14 17:20:01.027 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:01.027 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:01.027 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:01.027 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:01.027 | Historical data download ID 122039 not found when removing ID from outstanding request set.
2024-08-14 17:20:01.027 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:01.027 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:01.027 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:01.027 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:01.027 | Historical data download ID 122040 not found when removing ID from outstanding request set.
2024-08-14 17:20:01.027 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:01.027 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:01.027 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:01.080 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:01.080 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:01.080 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:01.080 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:01.081 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:01.081 | DTC Client socket (4) | Closed.
2024-08-14 17:20:01.081 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:01.081 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:01.081 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:01.081 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:03.091 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:03.091 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:03.091 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:03.092 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:03.092 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:03.133 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:03.133 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:03.133 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:03.133 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:03.267 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:03.267 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:03.267 | Historical data download ID 122041 not found when removing ID from outstanding request set.
2024-08-14 17:20:03.267 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:03.267 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:03.267 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:03.267 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:03.267 | Historical data download ID 122042 not found when removing ID from outstanding request set.
2024-08-14 17:20:03.267 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:03.267 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:03.267 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:03.267 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:03.267 | Historical data download ID 122043 not found when removing ID from outstanding request set.
2024-08-14 17:20:03.267 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:03.267 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:03.267 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:03.313 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:03.313 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:03.313 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:03.313 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:03.313 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:03.313 | DTC Client socket (4) | Closed.
2024-08-14 17:20:03.313 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:03.314 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:03.314 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:03.314 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:05.318 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:05.318 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:05.318 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:05.318 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:05.318 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:05.356 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:05.356 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:05.356 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:05.356 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:05.517 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:05.517 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:05.517 | Historical data download ID 122044 not found when removing ID from outstanding request set.
2024-08-14 17:20:05.517 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:05.517 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:05.517 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:05.517 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:05.517 | Historical data download ID 122045 not found when removing ID from outstanding request set.
2024-08-14 17:20:05.517 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:05.517 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:05.517 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:05.517 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:05.517 | Historical data download ID 122046 not found when removing ID from outstanding request set.
2024-08-14 17:20:05.517 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:05.517 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:05.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:05.560 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:05.564 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:05.564 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:05.564 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:05.564 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:05.564 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:05.564 | DTC Client socket (4) | Closed.
2024-08-14 17:20:05.565 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:05.565 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:05.565 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:07.564 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:07.564 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:07.565 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:07.565 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:07.565 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:07.602 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:07.602 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:07.603 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:07.603 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:07.727 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:07.727 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:07.727 | Historical data download ID 122047 not found when removing ID from outstanding request set.
2024-08-14 17:20:07.727 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:07.727 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:07.727 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:07.727 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:07.727 | Historical data download ID 122048 not found when removing ID from outstanding request set.
2024-08-14 17:20:07.727 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:07.727 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:07.727 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:07.727 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:07.727 | Historical data download ID 122049 not found when removing ID from outstanding request set.
2024-08-14 17:20:07.727 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:07.727 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:07.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:07.770 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:07.773 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:07.773 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:07.773 | DTC Client socket (4) | Closed.
2024-08-14 17:20:07.773 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:07.774 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:07.774 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:07.774 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:09.773 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:09.773 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:09.773 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:09.774 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:09.774 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:09.811 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:09.811 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:09.811 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:09.811 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:09.935 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:09.935 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:09.935 | Historical data download ID 122050 not found when removing ID from outstanding request set.
2024-08-14 17:20:09.935 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:09.935 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:09.935 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:09.935 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:09.935 | Historical data download ID 122051 not found when removing ID from outstanding request set.
2024-08-14 17:20:09.935 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:09.935 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:09.935 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:09.935 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:09.935 | Historical data download ID 122052 not found when removing ID from outstanding request set.
2024-08-14 17:20:09.935 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:09.935 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:09.935 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:09.977 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:09.979 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:09.979 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:09.979 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:09.979 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:09.979 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:09.979 | DTC Client socket (4) | Closed.
2024-08-14 17:20:09.979 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:09.979 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:09.979 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:11.978 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:11.978 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:11.978 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:11.978 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:11.978 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:12.051 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:12.051 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:12.051 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:12.051 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:12.178 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:12.178 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:12.178 | Historical data download ID 122053 not found when removing ID from outstanding request set.
2024-08-14 17:20:12.178 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:12.178 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:12.178 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:12.178 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:12.178 | Historical data download ID 122054 not found when removing ID from outstanding request set.
2024-08-14 17:20:12.178 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:12.178 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:12.178 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:12.178 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:12.178 | Historical data download ID 122055 not found when removing ID from outstanding request set.
2024-08-14 17:20:12.178 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:12.178 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:12.178 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:12.219 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:12.221 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:12.221 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:12.221 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:12.221 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=96
2024-08-14 17:20:12.221 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:12.222 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:12.222 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:12.222 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:12.481 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:20:12.481 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:12.481 | DTC Client socket (4) | Closed.
2024-08-14 17:20:14.231 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:14.232 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:14.232 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:14.232 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:14.232 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:14.270 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:14.270 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:14.270 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:14.270 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:14.406 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:14.406 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:14.406 | Historical data download ID 122056 not found when removing ID from outstanding request set.
2024-08-14 17:20:14.406 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:14.406 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:14.406 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:14.406 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:14.406 | Historical data download ID 122057 not found when removing ID from outstanding request set.
2024-08-14 17:20:14.406 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:14.406 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:14.406 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:14.406 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:14.406 | Historical data download ID 122058 not found when removing ID from outstanding request set.
2024-08-14 17:20:14.406 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:14.406 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:14.406 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:14.450 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:14.453 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:14.453 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:14.453 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:14.453 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:14.453 | DTC Client socket (4) | Closed.
2024-08-14 17:20:14.453 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:14.454 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:14.454 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:14.454 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:16.452 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:16.452 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:16.461 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:16.462 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:16.462 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:16.504 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:16.504 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:16.505 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:16.505 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:16.635 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:16.635 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:16.635 | Historical data download ID 122059 not found when removing ID from outstanding request set.
2024-08-14 17:20:16.635 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:16.635 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:16.635 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:16.635 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:16.635 | Historical data download ID 122060 not found when removing ID from outstanding request set.
2024-08-14 17:20:16.635 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:16.635 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:16.635 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:16.635 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:16.635 | Historical data download ID 122061 not found when removing ID from outstanding request set.
2024-08-14 17:20:16.635 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:16.635 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:16.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:16.678 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:16.681 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:16.681 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:16.681 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:16.681 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:16.681 | DTC Client socket (4) | Closed.
2024-08-14 17:20:16.681 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:16.681 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:16.681 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:16.681 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:17.374 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:17.375 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:20:17.382 | HD Server | Thread:7220 (4) | Creating socket.
2024-08-14 17:20:17.382 | HD Server | Thread:7220 (4) | New receive buffer size: 262144
2024-08-14 17:20:17.382 | HD Server | Thread:7220 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:17.382 | HD Server | Setting DTC encoding to Binary VLS | Thread:7220
2024-08-14 17:20:17.382 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:7220
2024-08-14 17:20:17.382 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:7220
2024-08-14 17:20:17.383 | HD Server | HD Request #4286 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4286 | Username: DAVID SUDDUTH JR. | Thread:7220
2024-08-14 17:20:17.383 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4286 | Username: DAVID SUDDUTH JR. | Thread:7220
2024-08-14 17:20:17.383 | HD Server | Thread:7220 (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:17.383 | HD Server | Thread:7220 (4) | CloseSocket call.
2024-08-14 17:20:17.383 | HD Server | Thread:7220 (0) | CloseSocket call.
2024-08-14 17:20:17.383 | HD Server | Thread:7220 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:17.383 | HD Server | Thread:7220 (4) | Closed.
2024-08-14 17:20:17.384 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:17.385 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:20:17.391 | HD Server | Thread:15392 (4) | Creating socket.
2024-08-14 17:20:17.391 | HD Server | Thread:15392 (4) | New receive buffer size: 262144
2024-08-14 17:20:17.391 | HD Server | Thread:15392 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:17.391 | HD Server | Setting DTC encoding to Binary VLS | Thread:15392
2024-08-14 17:20:17.392 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:20:17.392 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:20:17.392 | HD Server | HD Request #4287 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4287 | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:20:17.392 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4287 | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:20:17.392 | HD Server | Thread:15392 (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:17.392 | HD Server | Thread:15392 (4) | CloseSocket call.
2024-08-14 17:20:17.393 | HD Server | Thread:15392 (0) | CloseSocket call.
2024-08-14 17:20:17.393 | HD Server | Thread:15392 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:17.393 | HD Server | Thread:15392 (4) | Closed.
2024-08-14 17:20:17.573 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:20:17.573 | HD Server Manager | Current server count=1
2024-08-14 17:20:17.573 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:7220
2024-08-14 17:20:17.573 | HD Server Manager | Current server count=0
2024-08-14 17:20:18.682 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:18.682 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:18.683 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:18.683 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:20:18.683 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:18.694 | ESU4.CME [CB] 30 Min #20 | StartDateTimeForLoadingOrderFills: 2022-06-12 18:00:00
2024-08-14 17:20:18.990 | ESU4.CME [CB] 30 Min #20 | Chart data loading complete.
2024-08-14 17:20:19.258 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:19.258 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:19.258 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:19.258 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:19.380 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:19.380 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:19.380 | Historical data download ID 122062 not found when removing ID from outstanding request set.
2024-08-14 17:20:19.380 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:19.380 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:19.380 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:19.381 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:19.381 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:19.381 | Historical data download ID 122063 not found when removing ID from outstanding request set.
2024-08-14 17:20:19.381 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:19.381 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:19.381 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:19.381 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:19.381 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:19.381 | Historical data download ID 122064 not found when removing ID from outstanding request set.
2024-08-14 17:20:19.381 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:19.381 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:19.381 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:19.420 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:20:19.422 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:20:19.422 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:19.422 | DTC Client socket (5) | Closed.
2024-08-14 17:20:19.422 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:19.422 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:19.422 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:19.422 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:20.051 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:20.051 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:20:20.059 | HD Server | Thread:20828 (4) | Creating socket.
2024-08-14 17:20:20.059 | HD Server | Thread:20828 (4) | New receive buffer size: 262144
2024-08-14 17:20:20.059 | HD Server | Thread:20828 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:20.059 | HD Server | Setting DTC encoding to Binary VLS | Thread:20828
2024-08-14 17:20:20.060 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:20828
2024-08-14 17:20:20.060 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:20828
2024-08-14 17:20:20.060 | HD Server | HD Request #4288 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4288 | Username: DAVID SUDDUTH JR. | Thread:20828
2024-08-14 17:20:20.060 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4288 | Username: DAVID SUDDUTH JR. | Thread:20828
2024-08-14 17:20:20.060 | HD Server | Thread:20828 (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:20.060 | HD Server | Thread:20828 (4) | CloseSocket call.
2024-08-14 17:20:20.060 | HD Server | Thread:20828 (0) | CloseSocket call.
2024-08-14 17:20:20.061 | HD Server | Thread:20828 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:20.061 | HD Server | Thread:20828 (4) | Closed.
2024-08-14 17:20:20.061 | HD Server | Thread:20828 (0) | CloseSocket call.
2024-08-14 17:20:20.067 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:20.067 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:20:20.074 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:20828
2024-08-14 17:20:20.074 | HD Server Manager | Current server count=1
2024-08-14 17:20:20.074 | HD Server | Thread:21164 (4) | Creating socket.
2024-08-14 17:20:20.074 | HD Server | Thread:21164 (4) | New receive buffer size: 262144
2024-08-14 17:20:20.074 | HD Server | Thread:21164 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:20.075 | HD Server | Setting DTC encoding to Binary VLS | Thread:21164
2024-08-14 17:20:20.075 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:21164
2024-08-14 17:20:20.075 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:21164
2024-08-14 17:20:20.075 | HD Server | HD Request #4289 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4289 | Username: DAVID SUDDUTH JR. | Thread:21164
2024-08-14 17:20:20.075 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4289 | Username: DAVID SUDDUTH JR. | Thread:21164
2024-08-14 17:20:20.076 | HD Server | Thread:21164 (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:20.076 | HD Server | Thread:21164 (4) | CloseSocket call.
2024-08-14 17:20:20.076 | HD Server | Thread:21164 (0) | CloseSocket call.
2024-08-14 17:20:20.076 | HD Server | Thread:21164 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:20.076 | HD Server | Thread:21164 (4) | Closed.
2024-08-14 17:20:20.305 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:21164
2024-08-14 17:20:20.305 | HD Server Manager | Current server count=0
2024-08-14 17:20:21.288 | ESU4.CME [CB] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2022-06-12 18:00:00
2024-08-14 17:20:21.777 | ESU4.CME [CB] 30 Min #2 | Chart data loading complete.
2024-08-14 17:20:22.318 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:22.318 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:22.318 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:22.318 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:22.318 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:22.390 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:22.390 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:22.390 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:22.390 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:22.511 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:22.511 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:22.511 | Historical data download ID 122065 not found when removing ID from outstanding request set.
2024-08-14 17:20:22.511 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:22.511 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:22.511 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:22.511 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:22.511 | Historical data download ID 122066 not found when removing ID from outstanding request set.
2024-08-14 17:20:22.511 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:22.511 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:22.511 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:22.511 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:22.511 | Historical data download ID 122067 not found when removing ID from outstanding request set.
2024-08-14 17:20:22.511 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:22.511 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:22.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:22.561 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:22.588 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:22.588 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:22.588 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:22.588 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:22.588 | DTC Client socket (4) | Closed.
2024-08-14 17:20:22.588 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:22.589 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:22.589 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:22.589 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:24.590 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:24.590 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:24.590 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:24.590 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:24.590 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:24.638 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:24.638 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:24.638 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:24.638 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:24.769 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:24.769 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:24.769 | Historical data download ID 122068 not found when removing ID from outstanding request set.
2024-08-14 17:20:24.769 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:24.769 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:24.769 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:24.769 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:24.769 | Historical data download ID 122069 not found when removing ID from outstanding request set.
2024-08-14 17:20:24.769 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:24.769 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:24.769 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:24.769 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:24.769 | Historical data download ID 122070 not found when removing ID from outstanding request set.
2024-08-14 17:20:24.769 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:24.769 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:24.769 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:24.811 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:24.836 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:24.836 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:20:24.836 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:24.836 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:24.836 | DTC Client socket (4) | Closed.
2024-08-14 17:20:24.836 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:20:24.836 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:24.836 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:24.836 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:25.679 | ESU4.CME [CB] 1 Day #10 | StartDateTimeForLoadingOrderFills: 2022-06-12 18:00:00
2024-08-14 17:20:25.690 | Chart #10 has tagged chart #11 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:25.690 | Chart #10 has tagged chart #18 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:25.690 | Chart #10 has tagged chart #19 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:25.690 | Chart #10 has tagged chart #22 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:25.690 | Chart #10 has tagged chart #23 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:25.690 | Chart #10 has tagged chart #28 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:25.690 | ESU4.CME [CB] 1 Day #10 | Chart data loading complete.
2024-08-14 17:20:26.839 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:26.839 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:26.839 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:26.839 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:26.839 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:26.878 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:26.878 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:26.878 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:26.878 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:27.017 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:27.017 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:27.017 | Historical data download ID 122071 not found when removing ID from outstanding request set.
2024-08-14 17:20:27.017 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:27.017 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:27.017 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:27.017 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:27.017 | Historical data download ID 122072 not found when removing ID from outstanding request set.
2024-08-14 17:20:27.017 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:27.017 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:27.017 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:27.017 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:27.017 | Historical data download ID 122073 not found when removing ID from outstanding request set.
2024-08-14 17:20:27.017 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:27.017 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:27.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:27.059 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:27.068 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:27.068 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:20:27.069 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:27.069 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:27.069 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:27.069 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:20:27.069 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:27.069 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:27.069 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:27.110 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:20:27.110 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:27.110 | DTC Client socket (4) | Closed.
2024-08-14 17:20:27.190 | ESU4.CME [CB] 150000 Volume #7 | Chart data loading complete.
2024-08-14 17:20:27.329 | ESU4.CME [CB] 30 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.330 | Chart #11 has tagged chart #18 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.330 | Chart #11 has tagged chart #19 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.330 | Chart #11 has tagged chart #22 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.330 | Chart #11 has tagged chart #23 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.330 | Chart #11 has tagged chart #28 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.336 | ESU4.CME [CBV] 5000 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.374 | Chart: ESU4.CME [CBV] 5000 Volume #14 | Study: Acumulation/Distribution | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:20:27.374 | Chart: ESU4.CME [CBV] 5000 Volume #14 | Study: Volume Delta Histogram | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:20:27.397 | Chart #14 has tagged chart #13 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.397 | ESU4.CME 1 Min #26 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.401 | ESU4.CME 1 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.405 | ESU4.CME 1 Min #28 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.490 | ESU4.CME 1 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.513 | ESU4.CME 1 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.519 | ESU4.CME 1 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.549 | ESU4.CME [CBV] 1 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:27.612 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: ASK | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization *
2024-08-14 17:20:27.612 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: BID | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization *
2024-08-14 17:20:27.612 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Buy and Sell Zones | You are not authorized to use this study. Contact OrderFlow Labs LLC, orderflowlabs.com to discuss authorization. *
2024-08-14 17:20:29.482 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Acumulation/Distribution | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:20:29.483 | Chart: ESU4.CME [CBV] 1 Min #13 | Study: Volume Delta Histogram | Trader Systems Invalid License. https://www.tradersystems.net *
2024-08-14 17:20:29.698 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.698 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.698 | Chart #13 has tagged chart #22 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.698 | Chart #13 has tagged chart #23 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.698 | Chart #13 has tagged chart #28 for full recalculation. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.796 | ESU4.CME 1 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.799 | ESU4.CME 1 Min #28 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.838 | ESU4.CME 1 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.852 | ESU4.CME 1 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:29.855 | ESU4.CME 1 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: APEX FUNDED.Cht
2024-08-14 17:20:30.151 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:30.151 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:30.151 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:30.151 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:30.151 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:30.216 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:30.216 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:30.216 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:30.216 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:30.466 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:30.466 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:30.466 | Historical data download ID 122074 not found when removing ID from outstanding request set.
2024-08-14 17:20:30.466 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:30.466 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:30.466 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:30.466 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:30.466 | Historical data download ID 122075 not found when removing ID from outstanding request set.
2024-08-14 17:20:30.466 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:30.466 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:30.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:30.466 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:30.466 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:30.467 | Historical data download ID 122076 not found when removing ID from outstanding request set.
2024-08-14 17:20:30.467 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:30.467 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:30.467 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:30.508 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:30.519 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:30.519 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:20:30.519 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:30.519 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:30.519 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:20:30.519 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:30.519 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:30.519 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:30.520 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:20:30.520 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:30.768 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:20:30.768 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:30.768 | DTC Client socket (4) | Closed.
2024-08-14 17:20:32.598 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:32.598 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:32.599 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:32.599 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:32.599 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:32.637 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:32.637 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:32.637 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:32.637 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:32.775 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:32.775 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:32.775 | Historical data download ID 122077 not found when removing ID from outstanding request set.
2024-08-14 17:20:32.775 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:32.775 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:32.775 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:32.775 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:32.775 | Historical data download ID 122078 not found when removing ID from outstanding request set.
2024-08-14 17:20:32.775 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:32.775 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:32.775 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:32.775 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:32.775 | Historical data download ID 122079 not found when removing ID from outstanding request set.
2024-08-14 17:20:32.775 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:32.775 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:32.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:32.818 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:32.827 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:32.827 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:20:32.827 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:32.827 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:32.827 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:32.827 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:20:32.827 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:32.828 | DTC Client socket (4) | Closed.
2024-08-14 17:20:32.828 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:32.828 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:32.828 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:34.825 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:34.825 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:34.825 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:34.825 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:34.825 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:34.864 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:34.864 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:34.864 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:34.864 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:34.991 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:34.991 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:34.991 | Historical data download ID 122080 not found when removing ID from outstanding request set.
2024-08-14 17:20:34.991 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:34.991 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:34.991 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:34.991 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:34.991 | Historical data download ID 122081 not found when removing ID from outstanding request set.
2024-08-14 17:20:34.991 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:34.991 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:34.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:34.991 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:34.991 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:34.992 | Historical data download ID 122082 not found when removing ID from outstanding request set.
2024-08-14 17:20:34.992 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:34.992 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:34.992 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:35.032 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:35.049 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:35.049 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:35.049 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:35.049 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:35.049 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:35.049 | DTC Client socket (4) | Closed.
2024-08-14 17:20:35.049 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:35.049 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:35.049 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:37.105 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:37.105 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:37.105 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:37.105 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:37.105 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:37.145 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:37.145 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:37.145 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:37.145 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:37.291 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:37.291 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:37.291 | Historical data download ID 122083 not found when removing ID from outstanding request set.
2024-08-14 17:20:37.291 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:37.291 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:37.291 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:37.291 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:37.291 | Historical data download ID 122084 not found when removing ID from outstanding request set.
2024-08-14 17:20:37.291 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:37.291 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:37.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:37.291 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:37.291 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:37.292 | Historical data download ID 122085 not found when removing ID from outstanding request set.
2024-08-14 17:20:37.292 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:37.292 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:37.292 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:37.332 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:37.333 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:37.333 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:37.333 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:37.333 | DTC Client socket (4) | Closed.
2024-08-14 17:20:37.334 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:37.334 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:37.334 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:39.341 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:39.341 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:39.341 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:39.342 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:39.342 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:39.384 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:39.384 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:39.384 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:39.384 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:39.517 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:39.517 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:39.517 | Historical data download ID 122086 not found when removing ID from outstanding request set.
2024-08-14 17:20:39.517 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:39.517 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:39.517 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:39.517 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:39.517 | Historical data download ID 122087 not found when removing ID from outstanding request set.
2024-08-14 17:20:39.517 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:39.517 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:39.517 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:39.517 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:39.517 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:39.518 | Historical data download ID 122088 not found when removing ID from outstanding request set.
2024-08-14 17:20:39.518 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:39.518 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:39.518 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:39.558 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:39.603 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:39.603 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:39.603 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:39.603 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:20:39.603 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:39.603 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2024-08-14 17:20:39.603 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:20:39.603 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:39.603 | DTC Client socket (4) | Closed.
2024-08-14 17:20:39.604 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:39.604 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:39.604 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:41.984 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:41.984 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:41.985 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:41.985 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:41.985 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:42.044 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:42.044 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:42.044 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:42.044 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:42.162 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:42.162 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:42.162 | Historical data download ID 122089 not found when removing ID from outstanding request set.
2024-08-14 17:20:42.162 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:42.162 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:42.162 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:42.162 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:42.162 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:42.162 | Historical data download ID 122090 not found when removing ID from outstanding request set.
2024-08-14 17:20:42.162 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:42.162 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:42.163 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:42.163 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:42.163 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:42.163 | Historical data download ID 122091 not found when removing ID from outstanding request set.
2024-08-14 17:20:42.163 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:42.163 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:42.163 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:42.205 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:42.218 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:42.218 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:20:42.218 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:42.218 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:42.218 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:42.218 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:42.218 | DTC Client socket (4) | Closed.
2024-08-14 17:20:42.218 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:42.218 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:42.218 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:44.214 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:44.214 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:44.215 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:44.215 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:44.215 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:44.255 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:44.255 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:44.255 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:44.255 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:44.380 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:44.380 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:44.380 | Historical data download ID 122092 not found when removing ID from outstanding request set.
2024-08-14 17:20:44.380 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:44.380 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:44.380 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:44.380 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:44.380 | Historical data download ID 122093 not found when removing ID from outstanding request set.
2024-08-14 17:20:44.380 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:44.380 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:44.380 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:44.380 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:44.380 | Historical data download ID 122094 not found when removing ID from outstanding request set.
2024-08-14 17:20:44.380 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:44.380 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:44.380 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:44.436 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:44.449 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:44.449 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:44.449 | DTC Client socket (4) | Closed.
2024-08-14 17:20:44.449 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:44.450 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:44.450 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:44.450 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:46.449 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:46.449 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:46.450 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:46.450 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:46.450 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:46.488 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:46.488 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:46.488 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:46.488 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:46.614 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:46.614 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:46.614 | Historical data download ID 122095 not found when removing ID from outstanding request set.
2024-08-14 17:20:46.614 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:46.614 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:46.614 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:46.614 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:46.614 | Historical data download ID 122096 not found when removing ID from outstanding request set.
2024-08-14 17:20:46.614 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:46.614 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:46.614 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:46.614 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:46.614 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:46.615 | Historical data download ID 122097 not found when removing ID from outstanding request set.
2024-08-14 17:20:46.615 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:46.615 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:46.615 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:46.658 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:46.665 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:46.665 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:46.665 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:46.665 | DTC Client socket (4) | Closed.
2024-08-14 17:20:46.665 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:46.665 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:46.665 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:48.658 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:48.658 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:48.659 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:48.659 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:48.659 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:48.698 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:48.698 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:48.698 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:48.698 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:48.837 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:48.837 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:48.837 | Historical data download ID 122098 not found when removing ID from outstanding request set.
2024-08-14 17:20:48.837 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:48.837 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:48.837 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:48.837 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:48.837 | Historical data download ID 122099 not found when removing ID from outstanding request set.
2024-08-14 17:20:48.837 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:48.837 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:48.837 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:48.837 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:48.837 | Historical data download ID 122100 not found when removing ID from outstanding request set.
2024-08-14 17:20:48.837 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:48.837 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:48.837 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:48.879 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:48.880 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:20:48.883 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:48.887 | HD Server | Thread:7668 (5) | Creating socket.
2024-08-14 17:20:48.887 | HD Server | Thread:7668 (5) | New receive buffer size: 262144
2024-08-14 17:20:48.887 | HD Server | Thread:7668 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:48.887 | HD Server | Setting DTC encoding to Binary VLS | Thread:7668
2024-08-14 17:20:48.888 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:7668
2024-08-14 17:20:48.888 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:7668
2024-08-14 17:20:48.888 | HD Server | HD Request #4290 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4290 | Username: DAVID SUDDUTH JR. | Thread:7668
2024-08-14 17:20:48.888 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4290 | Username: DAVID SUDDUTH JR. | Thread:7668
2024-08-14 17:20:48.888 | HD Server | Thread:7668 (5) | Socket gracefully closed by remote side.
2024-08-14 17:20:48.888 | HD Server | Thread:7668 (5) | CloseSocket call.
2024-08-14 17:20:48.889 | HD Server | Thread:7668 (0) | CloseSocket call.
2024-08-14 17:20:48.889 | HD Server | Thread:7668 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:48.889 | HD Server | Thread:7668 (5) | Closed.
2024-08-14 17:20:48.892 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:48.892 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:48.892 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:48.892 | DTC Client socket (4) | Closed.
2024-08-14 17:20:48.893 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:48.893 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:48.893 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:48.922 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:48.922 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:20:48.930 | HD Server | Thread:7440 (4) | Creating socket.
2024-08-14 17:20:48.930 | HD Server | Thread:7440 (4) | New receive buffer size: 262144
2024-08-14 17:20:48.930 | HD Server | Thread:7440 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:48.930 | HD Server | Setting DTC encoding to Binary VLS | Thread:7440
2024-08-14 17:20:48.930 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:7440
2024-08-14 17:20:48.930 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:7440
2024-08-14 17:20:48.931 | HD Server | HD Request #4291 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4291 | Username: DAVID SUDDUTH JR. | Thread:7440
2024-08-14 17:20:48.931 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4291 | Username: DAVID SUDDUTH JR. | Thread:7440
2024-08-14 17:20:48.931 | HD Server | Thread:7440 (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:48.931 | HD Server | Thread:7440 (4) | CloseSocket call.
2024-08-14 17:20:48.931 | HD Server | Thread:7440 (0) | CloseSocket call.
2024-08-14 17:20:48.931 | HD Server | Thread:7440 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:48.931 | HD Server | Thread:7440 (4) | Closed.
2024-08-14 17:20:49.055 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:7440
2024-08-14 17:20:49.055 | HD Server Manager | Current server count=1
2024-08-14 17:20:49.055 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:7668
2024-08-14 17:20:49.055 | HD Server Manager | Current server count=0
2024-08-14 17:20:50.901 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:50.901 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:50.902 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:50.902 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:50.902 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:50.944 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:50.944 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:50.944 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:50.944 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:51.083 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:51.083 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:51.083 | Historical data download ID 122101 not found when removing ID from outstanding request set.
2024-08-14 17:20:51.083 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:51.083 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:51.083 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:51.083 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:51.083 | Historical data download ID 122102 not found when removing ID from outstanding request set.
2024-08-14 17:20:51.083 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:51.083 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:51.083 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:51.083 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:51.083 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:51.084 | Historical data download ID 122103 not found when removing ID from outstanding request set.
2024-08-14 17:20:51.084 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:51.084 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:51.084 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:51.121 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:51.128 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:51.128 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:51.128 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:51.128 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=368
2024-08-14 17:20:51.128 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:51.128 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:51.128 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:51.128 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:51.168 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:20:51.168 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:51.168 | DTC Client socket (4) | Closed.
2024-08-14 17:20:51.355 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:51.355 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:20:51.372 | HD Server | Thread:19404 (4) | Creating socket.
2024-08-14 17:20:51.372 | HD Server | Thread:19404 (4) | New receive buffer size: 262144
2024-08-14 17:20:51.372 | HD Server | Thread:19404 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:51.372 | HD Server | Setting DTC encoding to Binary VLS | Thread:19404
2024-08-14 17:20:51.373 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19404
2024-08-14 17:20:51.373 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19404
2024-08-14 17:20:51.373 | HD Server | HD Request #4292 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4292 | Username: DAVID SUDDUTH JR. | Thread:19404
2024-08-14 17:20:51.373 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4292 | Username: DAVID SUDDUTH JR. | Thread:19404
2024-08-14 17:20:51.374 | HD Server | Thread:19404 (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:51.374 | HD Server | Thread:19404 (4) | CloseSocket call.
2024-08-14 17:20:51.374 | HD Server | Thread:19404 (0) | CloseSocket call.
2024-08-14 17:20:51.374 | HD Server | Thread:19404 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:51.374 | HD Server | Thread:19404 (4) | Closed.
2024-08-14 17:20:51.404 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:20:51.404 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:20:51.404 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19404
2024-08-14 17:20:51.405 | HD Server Manager | Current server count=1
2024-08-14 17:20:51.423 | HD Server | Thread:15988 (4) | Creating socket.
2024-08-14 17:20:51.423 | HD Server | Thread:15988 (4) | New receive buffer size: 262144
2024-08-14 17:20:51.424 | HD Server | Thread:15988 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:20:51.424 | HD Server | Setting DTC encoding to Binary VLS | Thread:15988
2024-08-14 17:20:51.425 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15988
2024-08-14 17:20:51.425 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15988
2024-08-14 17:20:51.425 | HD Server | HD Request #4293 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4293 | Username: DAVID SUDDUTH JR. | Thread:15988
2024-08-14 17:20:51.425 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4293 | Username: DAVID SUDDUTH JR. | Thread:15988
2024-08-14 17:20:51.426 | HD Server | Thread:15988 (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:51.426 | HD Server | Thread:15988 (4) | CloseSocket call.
2024-08-14 17:20:51.426 | HD Server | Thread:15988 (0) | CloseSocket call.
2024-08-14 17:20:51.426 | HD Server | Thread:15988 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:51.426 | HD Server | Thread:15988 (4) | Closed.
2024-08-14 17:20:51.643 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15988
2024-08-14 17:20:51.643 | HD Server Manager | Current server count=0
2024-08-14 17:20:53.165 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:53.165 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:53.166 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:53.166 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:53.166 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:53.205 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:53.205 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:53.205 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:53.205 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:53.328 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:53.328 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:53.328 | Historical data download ID 122104 not found when removing ID from outstanding request set.
2024-08-14 17:20:53.328 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:53.328 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:53.328 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:53.328 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:53.328 | Historical data download ID 122105 not found when removing ID from outstanding request set.
2024-08-14 17:20:53.328 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:53.328 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:53.328 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:53.328 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:53.328 | Historical data download ID 122106 not found when removing ID from outstanding request set.
2024-08-14 17:20:53.328 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:53.328 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:53.328 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:53.370 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:53.393 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:53.393 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:20:53.394 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:53.394 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:53.394 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:53.394 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:20:53.394 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:20:53.394 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:53.394 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:53.394 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:53.642 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:20:53.642 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:53.642 | DTC Client socket (4) | Closed.
2024-08-14 17:20:55.398 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:55.398 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:55.398 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:55.398 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:55.398 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:55.438 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:55.438 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:55.438 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:55.438 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:55.567 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:55.567 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:55.567 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:55.567 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:55.567 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:55.567 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:55.567 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:55.567 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:55.567 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:55.568 | Historical data download ID 122107 not found when removing ID from outstanding request set.
2024-08-14 17:20:55.568 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:55.568 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:55.568 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:55.568 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:55.568 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:55.568 | Historical data download ID 122108 not found when removing ID from outstanding request set.
2024-08-14 17:20:55.568 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:55.568 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:55.568 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:55.568 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:55.568 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:55.568 | Historical data download ID 122109 not found when removing ID from outstanding request set.
2024-08-14 17:20:55.568 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:55.568 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:55.568 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:55.609 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:55.611 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:55.611 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:20:55.611 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:20:55.611 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:20:55.612 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=368
2024-08-14 17:20:55.612 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:55.612 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:55.612 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:55.612 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:55.655 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:20:55.655 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:55.655 | DTC Client socket (4) | Closed.
2024-08-14 17:20:57.652 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:57.652 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:57.652 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:57.653 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:57.653 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:57.691 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:57.691 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:57.691 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:57.691 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:20:57.818 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:20:57.818 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:20:57.818 | Historical data download ID 122110 not found when removing ID from outstanding request set.
2024-08-14 17:20:57.818 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:20:57.818 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:20:57.818 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:20:57.818 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:20:57.818 | Historical data download ID 122111 not found when removing ID from outstanding request set.
2024-08-14 17:20:57.818 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:20:57.818 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:20:57.818 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:20:57.818 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:20:57.818 | Historical data download ID 122112 not found when removing ID from outstanding request set.
2024-08-14 17:20:57.818 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:20:57.818 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:20:57.818 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:20:57.859 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:57.868 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:20:57.868 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:20:57.868 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:20:57.869 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:20:57.869 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:20:57.869 | DTC Client socket (4) | Closed.
2024-08-14 17:20:57.869 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:20:57.869 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:20:57.869 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:20:59.861 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:20:59.861 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:20:59.862 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:20:59.862 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:20:59.862 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:20:59.901 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:20:59.901 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:20:59.901 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:20:59.901 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:00.025 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:00.025 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:00.025 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:00.025 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:00.025 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:00.025 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:00.025 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:00.026 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:00.026 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:00.026 | Historical data download ID 122113 not found when removing ID from outstanding request set.
2024-08-14 17:21:00.026 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:00.026 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:00.026 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:00.026 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:00.026 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:00.026 | Historical data download ID 122114 not found when removing ID from outstanding request set.
2024-08-14 17:21:00.026 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:00.026 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:00.026 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:00.026 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:00.026 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:00.026 | Historical data download ID 122115 not found when removing ID from outstanding request set.
2024-08-14 17:21:00.026 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:00.026 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:00.026 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:00.067 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:00.085 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:00.085 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:21:00.086 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:00.086 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:00.086 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:00.086 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=368
2024-08-14 17:21:00.086 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:00.086 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:00.086 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:00.124 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:00.124 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:00.124 | DTC Client socket (4) | Closed.
2024-08-14 17:21:02.174 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:02.174 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:02.175 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:02.175 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:02.175 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:02.213 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:02.213 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:02.213 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:02.213 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:02.338 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:02.338 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:02.338 | Historical data download ID 122116 not found when removing ID from outstanding request set.
2024-08-14 17:21:02.338 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:02.338 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:02.338 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:02.338 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:02.338 | Historical data download ID 122117 not found when removing ID from outstanding request set.
2024-08-14 17:21:02.338 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:02.338 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:02.338 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:02.338 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:02.338 | Historical data download ID 122118 not found when removing ID from outstanding request set.
2024-08-14 17:21:02.338 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:02.338 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:02.338 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:02.380 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:02.395 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:02.395 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:21:02.396 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:02.396 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:02.396 | DTC Client socket (4) | Closed.
2024-08-14 17:21:02.396 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:02.396 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:02.396 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:02.396 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:04.404 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:04.404 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:04.404 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:04.405 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:04.405 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:04.442 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:04.442 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:04.443 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:04.443 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:04.564 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:04.564 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:04.564 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:04.564 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:04.564 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:04.564 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:04.564 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:04.564 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:04.564 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:04.564 | Historical data download ID 122119 not found when removing ID from outstanding request set.
2024-08-14 17:21:04.564 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:04.564 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:04.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:04.565 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:04.565 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:04.565 | Historical data download ID 122120 not found when removing ID from outstanding request set.
2024-08-14 17:21:04.565 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:04.565 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:04.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:04.565 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:04.565 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:04.565 | Historical data download ID 122121 not found when removing ID from outstanding request set.
2024-08-14 17:21:04.565 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:04.565 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:04.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:04.606 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:04.642 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:04.642 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:04.642 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:04.642 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:04.642 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:21:04.642 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:04.642 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:04.642 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:04.863 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:04.863 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:04.863 | DTC Client socket (4) | Closed.
2024-08-14 17:21:06.672 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:06.672 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:06.672 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:06.672 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:06.672 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:06.711 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:06.711 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:06.711 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:06.711 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:06.866 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:06.866 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:06.866 | Historical data download ID 122122 not found when removing ID from outstanding request set.
2024-08-14 17:21:06.866 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:06.866 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:06.866 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:06.866 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:06.866 | Historical data download ID 122123 not found when removing ID from outstanding request set.
2024-08-14 17:21:06.866 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:06.866 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:06.866 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:06.866 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:06.866 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:06.867 | Historical data download ID 122124 not found when removing ID from outstanding request set.
2024-08-14 17:21:06.867 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:06.867 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:06.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:06.908 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:06.909 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:06.910 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:06.910 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:06.910 | DTC Client socket (4) | Closed.
2024-08-14 17:21:06.910 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:06.910 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:06.910 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:08.908 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:08.908 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:08.909 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:08.909 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:08.909 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:08.947 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:08.947 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:08.947 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:08.947 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:09.080 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:09.080 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:09.080 | Historical data download ID 122125 not found when removing ID from outstanding request set.
2024-08-14 17:21:09.080 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:09.080 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:09.080 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:09.081 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:09.081 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:09.081 | Historical data download ID 122126 not found when removing ID from outstanding request set.
2024-08-14 17:21:09.081 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:09.081 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:09.081 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:09.081 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:09.081 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:09.081 | Historical data download ID 122127 not found when removing ID from outstanding request set.
2024-08-14 17:21:09.081 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:09.081 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:09.081 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:09.123 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:09.133 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:09.133 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:21:09.133 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:09.134 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:09.134 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:09.134 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=96
2024-08-14 17:21:09.134 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:09.134 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:09.134 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:09.171 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:09.171 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:09.171 | DTC Client socket (4) | Closed.
2024-08-14 17:21:11.185 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:11.185 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:11.186 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:11.186 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:11.186 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:11.224 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:11.224 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:11.224 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:11.224 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:11.356 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:11.356 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:11.356 | Historical data download ID 122128 not found when removing ID from outstanding request set.
2024-08-14 17:21:11.356 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:11.356 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:11.356 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:11.356 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:11.356 | Historical data download ID 122129 not found when removing ID from outstanding request set.
2024-08-14 17:21:11.356 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:11.356 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:11.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:11.357 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:11.357 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:11.357 | Historical data download ID 122130 not found when removing ID from outstanding request set.
2024-08-14 17:21:11.357 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:11.357 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:11.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:11.396 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:11.399 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:11.399 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:11.399 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:11.399 | DTC Client socket (4) | Closed.
2024-08-14 17:21:11.400 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:11.400 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:11.400 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:13.405 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:13.405 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:13.406 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:13.406 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:13.406 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:13.445 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:13.445 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:13.446 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:13.446 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:13.578 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:13.578 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:13.578 | Historical data download ID 122131 not found when removing ID from outstanding request set.
2024-08-14 17:21:13.578 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:13.578 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:13.578 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:13.578 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:13.578 | Historical data download ID 122132 not found when removing ID from outstanding request set.
2024-08-14 17:21:13.578 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:13.578 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:13.578 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:13.578 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:13.578 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:13.579 | Historical data download ID 122133 not found when removing ID from outstanding request set.
2024-08-14 17:21:13.579 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:13.579 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:13.579 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:13.621 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:13.643 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:13.643 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:13.643 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:13.643 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:13.643 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:13.644 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:21:13.644 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:13.644 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:13.644 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:13.644 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:13.879 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:13.879 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:13.879 | DTC Client socket (4) | Closed.
2024-08-14 17:21:15.686 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:15.686 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:15.686 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:15.687 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:15.687 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:15.724 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:15.724 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:15.724 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:15.724 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:15.881 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:15.881 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:15.881 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:15.881 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:15.881 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:15.881 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:15.881 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:15.881 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:15.881 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:15.882 | Historical data download ID 122134 not found when removing ID from outstanding request set.
2024-08-14 17:21:15.882 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:15.882 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:15.882 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:15.882 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:15.882 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:15.882 | Historical data download ID 122135 not found when removing ID from outstanding request set.
2024-08-14 17:21:15.882 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:15.882 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:15.882 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:15.882 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:15.882 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:15.882 | Historical data download ID 122136 not found when removing ID from outstanding request set.
2024-08-14 17:21:15.882 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:15.882 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:15.882 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:15.926 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:15.942 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:15.942 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:21:15.942 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:15.942 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:15.942 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:15.942 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:21:15.942 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:15.943 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:15.943 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:15.943 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:16.197 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:16.197 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:16.197 | DTC Client socket (4) | Closed.
2024-08-14 17:21:17.952 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:17.952 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:17.953 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:17.953 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:17.953 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:17.991 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:17.991 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:17.991 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:17.991 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:18.156 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:18.156 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:18.156 | Historical data download ID 122137 not found when removing ID from outstanding request set.
2024-08-14 17:21:18.156 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:18.156 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:18.156 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:18.156 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:18.156 | Historical data download ID 122138 not found when removing ID from outstanding request set.
2024-08-14 17:21:18.156 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:18.156 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:18.156 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:18.156 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:18.156 | Historical data download ID 122139 not found when removing ID from outstanding request set.
2024-08-14 17:21:18.156 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:18.156 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:18.156 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:18.200 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:18.202 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:18.202 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:21:18.202 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:18.203 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:18.203 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:18.203 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:18.203 | DTC Client socket (4) | Closed.
2024-08-14 17:21:18.203 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:18.203 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:18.203 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:20.198 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:20.198 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:20.198 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:20.198 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:20.198 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:20.244 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:20.244 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:20.244 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:20.244 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:20.244 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:20.244 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:21:20.259 | HD Server | Thread:10844 (5) | Creating socket.
2024-08-14 17:21:20.259 | HD Server | Thread:10844 (5) | New receive buffer size: 262144
2024-08-14 17:21:20.259 | HD Server | Thread:10844 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:20.259 | HD Server | Setting DTC encoding to Binary VLS | Thread:10844
2024-08-14 17:21:20.260 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:10844
2024-08-14 17:21:20.260 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:10844
2024-08-14 17:21:20.260 | HD Server | HD Request #4294 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4294 | Username: DAVID SUDDUTH JR. | Thread:10844
2024-08-14 17:21:20.261 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4294 | Username: DAVID SUDDUTH JR. | Thread:10844
2024-08-14 17:21:20.261 | HD Server | Thread:10844 (5) | Socket gracefully closed by remote side.
2024-08-14 17:21:20.261 | HD Server | Thread:10844 (5) | CloseSocket call.
2024-08-14 17:21:20.262 | HD Server | Thread:10844 (0) | CloseSocket call.
2024-08-14 17:21:20.262 | HD Server | Thread:10844 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:20.262 | HD Server | Thread:10844 (5) | Closed.
2024-08-14 17:21:20.265 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:20.265 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:21:20.285 | HD Server | Thread:18644 (5) | Creating socket.
2024-08-14 17:21:20.285 | HD Server | Thread:18644 (5) | New receive buffer size: 262144
2024-08-14 17:21:20.285 | HD Server | Thread:18644 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:20.285 | HD Server | Setting DTC encoding to Binary VLS | Thread:18644
2024-08-14 17:21:20.286 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18644
2024-08-14 17:21:20.286 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18644
2024-08-14 17:21:20.286 | HD Server | HD Request #4295 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4295 | Username: DAVID SUDDUTH JR. | Thread:18644
2024-08-14 17:21:20.287 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4295 | Username: DAVID SUDDUTH JR. | Thread:18644
2024-08-14 17:21:20.287 | HD Server | Thread:18644 (5) | Socket gracefully closed by remote side.
2024-08-14 17:21:20.287 | HD Server | Thread:18644 (5) | CloseSocket call.
2024-08-14 17:21:20.287 | HD Server | Thread:18644 (0) | CloseSocket call.
2024-08-14 17:21:20.287 | HD Server | Thread:18644 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:20.287 | HD Server | Thread:18644 (5) | Closed.
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:20.365 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:20.365 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:20.365 | Historical data download ID 122140 not found when removing ID from outstanding request set.
2024-08-14 17:21:20.365 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:20.365 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:20.365 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:20.365 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:20.365 | Historical data download ID 122141 not found when removing ID from outstanding request set.
2024-08-14 17:21:20.365 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:20.365 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:20.365 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:20.365 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:20.365 | Historical data download ID 122142 not found when removing ID from outstanding request set.
2024-08-14 17:21:20.365 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:20.365 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:20.365 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:20.414 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:20.432 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:20.432 | HD Server Manager | Started new historical data server. Count=3
2024-08-14 17:21:20.432 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:20.432 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:21:20.432 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:20.432 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:20.432 | DTC Client socket (4) | Closed.
2024-08-14 17:21:20.432 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:20.435 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:20.435 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:20.435 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:20.451 | HD Server | Thread:11232 (4) | Creating socket.
2024-08-14 17:21:20.451 | HD Server | Thread:11232 (4) | New receive buffer size: 262144
2024-08-14 17:21:20.451 | HD Server | Thread:11232 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:20.451 | HD Server | Setting DTC encoding to Binary VLS | Thread:11232
2024-08-14 17:21:20.452 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11232
2024-08-14 17:21:20.452 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11232
2024-08-14 17:21:20.452 | HD Server | HD Request #4296 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4296 | Username: DAVID SUDDUTH JR. | Thread:11232
2024-08-14 17:21:20.452 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4296 | Username: DAVID SUDDUTH JR. | Thread:11232
2024-08-14 17:21:20.453 | HD Server | Thread:11232 (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:20.453 | HD Server | Thread:11232 (4) | CloseSocket call.
2024-08-14 17:21:20.453 | HD Server | Thread:11232 (0) | CloseSocket call.
2024-08-14 17:21:20.453 | HD Server | Thread:11232 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:20.453 | HD Server | Thread:11232 (4) | Closed.
2024-08-14 17:21:20.650 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11232
2024-08-14 17:21:20.650 | HD Server Manager | Current server count=2
2024-08-14 17:21:20.650 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18644
2024-08-14 17:21:20.651 | HD Server Manager | Current server count=1
2024-08-14 17:21:20.651 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:10844
2024-08-14 17:21:20.651 | HD Server Manager | Current server count=0
2024-08-14 17:21:22.431 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:22.431 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:22.432 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:22.432 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:22.432 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:22.471 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:22.471 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:22.471 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:22.471 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:22.602 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:22.602 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:22.602 | Historical data download ID 122143 not found when removing ID from outstanding request set.
2024-08-14 17:21:22.602 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:22.602 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:22.602 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:22.602 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:22.602 | Historical data download ID 122144 not found when removing ID from outstanding request set.
2024-08-14 17:21:22.602 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:22.602 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:22.602 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:22.602 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:22.602 | Historical data download ID 122145 not found when removing ID from outstanding request set.
2024-08-14 17:21:22.602 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:22.602 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:22.602 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:22.644 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:22.646 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:22.646 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:21:22.646 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:22.646 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:22.646 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:22.646 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:21:22.646 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:22.646 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:22.646 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:22.686 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:22.686 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:22.686 | DTC Client socket (4) | Closed.
2024-08-14 17:21:22.747 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:22.748 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:21:22.764 | HD Server | Thread:18188 (4) | Creating socket.
2024-08-14 17:21:22.764 | HD Server | Thread:18188 (4) | New receive buffer size: 262144
2024-08-14 17:21:22.764 | HD Server | Thread:18188 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:22.764 | HD Server | Setting DTC encoding to Binary VLS | Thread:18188
2024-08-14 17:21:22.765 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18188
2024-08-14 17:21:22.765 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18188
2024-08-14 17:21:22.765 | HD Server | HD Request #4297 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4297 | Username: DAVID SUDDUTH JR. | Thread:18188
2024-08-14 17:21:22.766 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4297 | Username: DAVID SUDDUTH JR. | Thread:18188
2024-08-14 17:21:22.766 | HD Server | Thread:18188 (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:22.766 | HD Server | Thread:18188 (4) | CloseSocket call.
2024-08-14 17:21:22.766 | HD Server | Thread:18188 (0) | CloseSocket call.
2024-08-14 17:21:22.767 | HD Server | Thread:18188 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:22.767 | HD Server | Thread:18188 (4) | Closed.
2024-08-14 17:21:22.767 | HD Server | Thread:18188 (0) | CloseSocket call.
2024-08-14 17:21:22.820 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:22.821 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:21:22.833 | HD Server | Thread:8760 (4) | Creating socket.
2024-08-14 17:21:22.833 | HD Server | Thread:8760 (4) | New receive buffer size: 262144
2024-08-14 17:21:22.833 | HD Server | Thread:8760 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:22.833 | HD Server | Setting DTC encoding to Binary VLS | Thread:8760
2024-08-14 17:21:22.834 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:8760
2024-08-14 17:21:22.834 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:8760
2024-08-14 17:21:22.834 | HD Server | HD Request #4298 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4298 | Username: DAVID SUDDUTH JR. | Thread:8760
2024-08-14 17:21:22.835 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4298 | Username: DAVID SUDDUTH JR. | Thread:8760
2024-08-14 17:21:22.835 | HD Server | Thread:8760 (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:22.835 | HD Server | Thread:8760 (4) | CloseSocket call.
2024-08-14 17:21:22.835 | HD Server | Thread:8760 (0) | CloseSocket call.
2024-08-14 17:21:22.835 | HD Server | Thread:8760 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:22.835 | HD Server | Thread:8760 (4) | Closed.
2024-08-14 17:21:22.975 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:8760
2024-08-14 17:21:22.975 | HD Server Manager | Current server count=1
2024-08-14 17:21:22.975 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18188
2024-08-14 17:21:22.975 | HD Server Manager | Current server count=0
2024-08-14 17:21:24.680 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:24.680 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:24.681 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:24.681 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:24.681 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:24.720 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:24.720 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:24.720 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:24.720 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:24.862 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:24.862 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:24.862 | Historical data download ID 122146 not found when removing ID from outstanding request set.
2024-08-14 17:21:24.862 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:24.862 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:24.862 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:24.862 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:24.862 | Historical data download ID 122147 not found when removing ID from outstanding request set.
2024-08-14 17:21:24.862 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:24.862 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:24.862 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:24.862 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:24.862 | Historical data download ID 122148 not found when removing ID from outstanding request set.
2024-08-14 17:21:24.862 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:24.862 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:24.862 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:24.909 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:24.909 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:24.909 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:21:24.910 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:24.910 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:24.910 | DTC Client socket (4) | Closed.
2024-08-14 17:21:24.910 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:24.910 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:24.910 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:24.910 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:26.169 | The message log has been sent to support. *
2024-08-14 17:21:26.170 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:26.170 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | New receive buffer size: 0
2024-08-14 17:21:26.170 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 65.108.28.81.
2024-08-14 17:21:26.911 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:26.911 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:26.912 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:26.912 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:21:26.912 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:26.956 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:26.956 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:26.956 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:26.956 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:27.106 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:27.106 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:27.106 | Historical data download ID 122149 not found when removing ID from outstanding request set.
2024-08-14 17:21:27.106 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:27.106 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:27.106 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:27.106 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:27.106 | Historical data download ID 122150 not found when removing ID from outstanding request set.
2024-08-14 17:21:27.106 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:27.106 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:27.106 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:27.106 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:27.106 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:27.107 | Historical data download ID 122151 not found when removing ID from outstanding request set.
2024-08-14 17:21:27.107 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:27.107 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:27.107 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:27.148 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:21:27.174 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:21:27.174 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:21:27.174 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:21:27.175 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:27.175 | DTC Client socket (5) | Closed.
2024-08-14 17:21:27.175 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:27.175 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:27.175 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:27.175 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:28.340 | The Message Log was sent. Result: Message Log received. *
2024-08-14 17:21:28.811 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | CloseSocket call.
2024-08-14 17:21:28.812 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2024-08-14 17:21:28.967 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:28.968 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed.
2024-08-14 17:21:29.804 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:29.804 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:29.804 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:29.804 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:29.804 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:29.873 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:29.873 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:29.873 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:29.873 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:29.995 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:29.995 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:29.995 | Historical data download ID 122152 not found when removing ID from outstanding request set.
2024-08-14 17:21:29.995 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:29.995 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:29.995 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:29.995 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:29.995 | Historical data download ID 122153 not found when removing ID from outstanding request set.
2024-08-14 17:21:29.995 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:29.995 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:29.995 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:29.995 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:29.995 | Historical data download ID 122154 not found when removing ID from outstanding request set.
2024-08-14 17:21:29.995 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:29.995 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:29.995 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:30.037 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:30.054 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:30.054 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:30.054 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:30.054 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:30.054 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:30.054 | DTC Client socket (4) | Closed.
2024-08-14 17:21:30.054 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:30.055 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:30.055 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:30.055 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:32.051 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:32.051 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:32.051 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:32.052 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:32.052 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:32.101 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:32.101 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:32.101 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:32.101 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:32.225 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:32.225 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:32.225 | Historical data download ID 122155 not found when removing ID from outstanding request set.
2024-08-14 17:21:32.225 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:32.225 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:32.225 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:32.225 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:32.225 | Historical data download ID 122156 not found when removing ID from outstanding request set.
2024-08-14 17:21:32.225 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:32.225 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:32.225 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:32.225 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:32.225 | Historical data download ID 122157 not found when removing ID from outstanding request set.
2024-08-14 17:21:32.225 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:32.225 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:32.225 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:32.268 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:32.271 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:32.271 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:32.271 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:32.271 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:32.271 | DTC Client socket (4) | Closed.
2024-08-14 17:21:32.271 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:32.272 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:32.272 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:32.272 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:34.280 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:34.280 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:34.280 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:34.280 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:34.280 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:34.327 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:34.327 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:34.327 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:34.327 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:34.451 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:34.451 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:34.451 | Historical data download ID 122158 not found when removing ID from outstanding request set.
2024-08-14 17:21:34.451 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:34.451 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:34.451 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:34.451 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:34.451 | Historical data download ID 122159 not found when removing ID from outstanding request set.
2024-08-14 17:21:34.451 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:34.451 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:34.451 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:34.451 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:34.451 | Historical data download ID 122160 not found when removing ID from outstanding request set.
2024-08-14 17:21:34.451 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:34.451 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:34.451 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:34.493 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:34.494 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:34.494 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:34.494 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:34.494 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:34.494 | DTC Client socket (4) | Closed.
2024-08-14 17:21:34.494 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:34.494 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:34.494 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:34.494 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:36.490 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:36.491 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:36.491 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:36.491 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:36.491 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:36.530 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:36.530 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:36.530 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:36.530 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:36.721 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:36.721 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:36.721 | Historical data download ID 122161 not found when removing ID from outstanding request set.
2024-08-14 17:21:36.721 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:36.721 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:36.721 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:36.721 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:36.721 | Historical data download ID 122162 not found when removing ID from outstanding request set.
2024-08-14 17:21:36.721 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:36.721 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:36.721 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:36.721 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:36.721 | Historical data download ID 122163 not found when removing ID from outstanding request set.
2024-08-14 17:21:36.721 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:36.721 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:36.721 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:36.763 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:36.771 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:36.771 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:21:36.772 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:36.772 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:36.772 | DTC Client socket (4) | Closed.
2024-08-14 17:21:36.772 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:36.772 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:36.772 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:36.772 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:38.775 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:38.775 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:38.776 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:38.776 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:38.776 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:38.823 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:38.823 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:38.823 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:38.823 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:38.942 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:38.942 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:38.942 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:38.942 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:38.942 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:38.942 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:38.942 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:38.942 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:38.942 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:38.942 | Historical data download ID 122164 not found when removing ID from outstanding request set.
2024-08-14 17:21:38.942 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:38.943 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:38.943 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:38.943 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:38.943 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:38.943 | Historical data download ID 122165 not found when removing ID from outstanding request set.
2024-08-14 17:21:38.943 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:38.943 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:38.943 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:38.943 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:38.943 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:38.943 | Historical data download ID 122166 not found when removing ID from outstanding request set.
2024-08-14 17:21:38.943 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:38.943 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:38.943 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:38.984 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:39.005 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:39.005 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:21:39.005 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:39.005 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:39.005 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:39.005 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:21:39.005 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:39.005 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:39.005 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:39.043 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:39.043 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:39.044 | DTC Client socket (4) | Closed.
2024-08-14 17:21:41.015 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:41.015 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:41.016 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:41.016 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:41.016 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:41.054 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:41.054 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:41.054 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:41.054 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:41.184 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:41.184 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:41.184 | Historical data download ID 122167 not found when removing ID from outstanding request set.
2024-08-14 17:21:41.184 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:41.184 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:41.184 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:41.184 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:41.184 | Historical data download ID 122168 not found when removing ID from outstanding request set.
2024-08-14 17:21:41.184 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:41.184 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:41.184 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:41.184 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:41.184 | Historical data download ID 122169 not found when removing ID from outstanding request set.
2024-08-14 17:21:41.184 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:41.184 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:41.184 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:41.227 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:41.228 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:41.228 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:41.228 | DTC Client socket (4) | Closed.
2024-08-14 17:21:41.228 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:41.229 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:41.229 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:41.229 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:43.234 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:43.234 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:43.234 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:43.234 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:43.234 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:43.272 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:43.272 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:43.272 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:43.272 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:43.395 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:43.395 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:43.395 | Historical data download ID 122170 not found when removing ID from outstanding request set.
2024-08-14 17:21:43.395 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:43.395 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:43.395 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:43.395 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:43.395 | Historical data download ID 122171 not found when removing ID from outstanding request set.
2024-08-14 17:21:43.395 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:43.395 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:43.395 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:43.395 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:43.395 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:43.396 | Historical data download ID 122172 not found when removing ID from outstanding request set.
2024-08-14 17:21:43.396 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:43.396 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:43.396 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:43.438 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:43.444 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:43.444 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:43.444 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:43.444 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:43.444 | DTC Client socket (4) | Closed.
2024-08-14 17:21:43.445 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:43.445 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:43.445 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:45.450 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:45.450 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:45.451 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:45.451 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:45.451 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:45.490 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:45.490 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:45.490 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:45.490 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:45.635 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:45.635 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:45.635 | Historical data download ID 122173 not found when removing ID from outstanding request set.
2024-08-14 17:21:45.635 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:45.635 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:45.635 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:45.635 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:45.635 | Historical data download ID 122174 not found when removing ID from outstanding request set.
2024-08-14 17:21:45.635 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:45.635 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:45.635 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:45.635 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:45.635 | Historical data download ID 122175 not found when removing ID from outstanding request set.
2024-08-14 17:21:45.635 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:45.635 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:45.635 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:45.677 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:45.677 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:45.677 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:45.677 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:45.677 | DTC Client socket (4) | Closed.
2024-08-14 17:21:45.678 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:45.678 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:45.678 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:45.678 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:47.725 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:47.725 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:47.726 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:47.726 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:47.726 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:47.764 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:47.764 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:47.765 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:47.765 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:47.887 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:47.887 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:47.887 | Historical data download ID 122176 not found when removing ID from outstanding request set.
2024-08-14 17:21:47.887 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:47.887 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:47.887 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:47.887 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:47.887 | Historical data download ID 122177 not found when removing ID from outstanding request set.
2024-08-14 17:21:47.887 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:47.887 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:47.887 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:47.887 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:47.887 | Historical data download ID 122178 not found when removing ID from outstanding request set.
2024-08-14 17:21:47.887 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:47.887 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:47.887 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:47.927 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:47.927 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:47.927 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:47.927 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:47.927 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:47.927 | DTC Client socket (4) | Closed.
2024-08-14 17:21:47.927 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:47.928 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:47.928 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:47.928 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:49.925 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:49.925 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:49.925 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:49.925 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:49.925 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:49.965 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:49.965 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:49.965 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:49.965 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:50.085 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:50.085 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:50.085 | Historical data download ID 122179 not found when removing ID from outstanding request set.
2024-08-14 17:21:50.085 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:50.085 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:50.085 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:50.085 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:50.085 | Historical data download ID 122180 not found when removing ID from outstanding request set.
2024-08-14 17:21:50.085 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:50.085 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:50.085 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:50.085 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:50.085 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:50.085 | Historical data download ID 122181 not found when removing ID from outstanding request set.
2024-08-14 17:21:50.086 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:50.086 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:50.086 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:50.128 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:50.128 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:50.128 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:50.128 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:50.128 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:21:50.128 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:50.128 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:50.128 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:50.128 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:50.169 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:21:50.169 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:50.169 | DTC Client socket (4) | Closed.
2024-08-14 17:21:51.863 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:51.864 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:21:51.871 | HD Server | Thread:19552 (4) | Creating socket.
2024-08-14 17:21:51.871 | HD Server | Thread:19552 (4) | New receive buffer size: 262144
2024-08-14 17:21:51.871 | HD Server | Thread:19552 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:51.871 | HD Server | Setting DTC encoding to Binary VLS | Thread:19552
2024-08-14 17:21:51.872 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19552
2024-08-14 17:21:51.872 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19552
2024-08-14 17:21:51.872 | HD Server | HD Request #4299 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4299 | Username: DAVID SUDDUTH JR. | Thread:19552
2024-08-14 17:21:51.873 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4299 | Username: DAVID SUDDUTH JR. | Thread:19552
2024-08-14 17:21:51.873 | HD Server | Thread:19552 (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:51.873 | HD Server | Thread:19552 (4) | CloseSocket call.
2024-08-14 17:21:51.873 | HD Server | Thread:19552 (0) | CloseSocket call.
2024-08-14 17:21:51.873 | HD Server | Thread:19552 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:51.873 | HD Server | Thread:19552 (4) | Closed.
2024-08-14 17:21:51.875 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:51.876 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:21:51.879 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19552
2024-08-14 17:21:51.881 | HD Server Manager | Current server count=1
2024-08-14 17:21:51.883 | HD Server | Thread:19888 (4) | Creating socket.
2024-08-14 17:21:51.883 | HD Server | Thread:19888 (4) | New receive buffer size: 262144
2024-08-14 17:21:51.883 | HD Server | Thread:19888 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:51.883 | HD Server | Setting DTC encoding to Binary VLS | Thread:19888
2024-08-14 17:21:51.883 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19888
2024-08-14 17:21:51.883 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19888
2024-08-14 17:21:51.884 | HD Server | HD Request #4300 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4300 | Username: DAVID SUDDUTH JR. | Thread:19888
2024-08-14 17:21:51.884 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4300 | Username: DAVID SUDDUTH JR. | Thread:19888
2024-08-14 17:21:51.884 | HD Server | Thread:19888 (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:51.884 | HD Server | Thread:19888 (4) | CloseSocket call.
2024-08-14 17:21:51.884 | HD Server | Thread:19888 (0) | CloseSocket call.
2024-08-14 17:21:51.884 | HD Server | Thread:19888 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:51.884 | HD Server | Thread:19888 (4) | Closed.
2024-08-14 17:21:52.132 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:52.133 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:52.133 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:52.133 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:52.133 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:52.178 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:52.178 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:52.178 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:52.178 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:52.193 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19888
2024-08-14 17:21:52.193 | HD Server Manager | Current server count=0
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:52.303 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:52.303 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:52.303 | Historical data download ID 122182 not found when removing ID from outstanding request set.
2024-08-14 17:21:52.303 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:52.303 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:52.303 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:52.303 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:52.303 | Historical data download ID 122183 not found when removing ID from outstanding request set.
2024-08-14 17:21:52.303 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:52.303 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:52.303 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:52.303 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:52.303 | Historical data download ID 122184 not found when removing ID from outstanding request set.
2024-08-14 17:21:52.303 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:52.303 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:52.303 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:52.345 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:52.345 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:52.345 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:21:52.345 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:21:52.345 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:52.345 | DTC Client socket (4) | Closed.
2024-08-14 17:21:52.346 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:52.346 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:52.346 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:52.346 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:54.351 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:54.351 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:54.352 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:54.352 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:54.352 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:54.389 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:54.389 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:54.389 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:54.389 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:54.442 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:54.442 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:21:54.457 | HD Server | Thread:12340 (5) | Creating socket.
2024-08-14 17:21:54.457 | HD Server | Thread:12340 (5) | New receive buffer size: 262144
2024-08-14 17:21:54.457 | HD Server | Thread:12340 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:54.458 | HD Server | Setting DTC encoding to Binary VLS | Thread:12340
2024-08-14 17:21:54.458 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12340
2024-08-14 17:21:54.458 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12340
2024-08-14 17:21:54.458 | HD Server | HD Request #4301 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4301 | Username: DAVID SUDDUTH JR. | Thread:12340
2024-08-14 17:21:54.459 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4301 | Username: DAVID SUDDUTH JR. | Thread:12340
2024-08-14 17:21:54.459 | HD Server | Thread:12340 (5) | Socket gracefully closed by remote side.
2024-08-14 17:21:54.459 | HD Server | Thread:12340 (5) | CloseSocket call.
2024-08-14 17:21:54.459 | HD Server | Thread:12340 (0) | CloseSocket call.
2024-08-14 17:21:54.460 | HD Server | Thread:12340 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:54.460 | HD Server | Thread:12340 (5) | Closed.
2024-08-14 17:21:54.460 | HD Server | Thread:12340 (0) | CloseSocket call.
2024-08-14 17:21:54.461 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:21:54.462 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:21:54.472 | HD Server | Thread:21216 (5) | Creating socket.
2024-08-14 17:21:54.472 | HD Server | Thread:21216 (5) | New receive buffer size: 262144
2024-08-14 17:21:54.472 | HD Server | Thread:21216 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:21:54.472 | HD Server | Setting DTC encoding to Binary VLS | Thread:21216
2024-08-14 17:21:54.472 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:21:54.472 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:21:54.473 | HD Server | HD Request #4302 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4302 | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:21:54.474 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4302 | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:21:54.474 | HD Server | Thread:21216 (5) | Socket gracefully closed by remote side.
2024-08-14 17:21:54.474 | HD Server | Thread:21216 (5) | CloseSocket call.
2024-08-14 17:21:54.474 | HD Server | Thread:21216 (0) | CloseSocket call.
2024-08-14 17:21:54.474 | HD Server | Thread:21216 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:54.474 | HD Server | Thread:21216 (5) | Closed.
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:54.511 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:54.511 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:54.511 | Historical data download ID 122185 not found when removing ID from outstanding request set.
2024-08-14 17:21:54.511 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:54.511 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:54.511 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:54.511 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:54.511 | Historical data download ID 122186 not found when removing ID from outstanding request set.
2024-08-14 17:21:54.511 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:54.511 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:54.511 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:54.511 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:54.511 | Historical data download ID 122187 not found when removing ID from outstanding request set.
2024-08-14 17:21:54.511 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:54.511 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:54.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:54.552 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:54.554 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:54.554 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:54.554 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:54.554 | DTC Client socket (4) | Closed.
2024-08-14 17:21:54.554 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:54.555 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:54.555 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:54.555 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:54.700 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:21216
2024-08-14 17:21:54.700 | HD Server Manager | Current server count=1
2024-08-14 17:21:54.700 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12340
2024-08-14 17:21:54.700 | HD Server Manager | Current server count=0
2024-08-14 17:21:56.556 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:56.556 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:56.557 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:56.557 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:56.557 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:56.594 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:56.594 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:56.594 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:56.594 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:56.716 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:56.716 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:56.716 | Historical data download ID 122188 not found when removing ID from outstanding request set.
2024-08-14 17:21:56.716 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:56.716 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:56.716 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:56.716 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:56.716 | Historical data download ID 122189 not found when removing ID from outstanding request set.
2024-08-14 17:21:56.716 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:56.716 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:56.716 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:56.716 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:56.716 | Historical data download ID 122190 not found when removing ID from outstanding request set.
2024-08-14 17:21:56.716 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:56.716 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:56.716 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:56.756 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:56.758 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:56.758 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:56.758 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:56.758 | DTC Client socket (4) | Closed.
2024-08-14 17:21:56.758 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:56.759 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:56.759 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:56.759 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:21:58.756 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:21:58.756 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:21:58.756 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:21:58.757 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:21:58.757 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:21:58.795 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:21:58.795 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:21:58.795 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:21:58.795 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:21:58.919 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:21:58.919 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:21:58.919 | Historical data download ID 122191 not found when removing ID from outstanding request set.
2024-08-14 17:21:58.919 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:21:58.919 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:21:58.919 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:21:58.919 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:21:58.919 | Historical data download ID 122192 not found when removing ID from outstanding request set.
2024-08-14 17:21:58.919 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:21:58.919 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:21:58.919 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:21:58.919 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:21:58.919 | Historical data download ID 122193 not found when removing ID from outstanding request set.
2024-08-14 17:21:58.919 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:21:58.919 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:21:58.919 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:21:58.960 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:21:58.962 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:21:58.962 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:21:58.962 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:21:58.962 | DTC Client socket (4) | Closed.
2024-08-14 17:21:58.962 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:21:58.963 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:21:58.963 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:21:58.963 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:00.967 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:00.967 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:00.967 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:00.967 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:00.967 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:01.006 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:01.006 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:01.006 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:01.006 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:01.126 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:01.126 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:01.126 | Historical data download ID 122194 not found when removing ID from outstanding request set.
2024-08-14 17:22:01.126 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:01.126 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:01.126 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:01.126 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:01.126 | Historical data download ID 122195 not found when removing ID from outstanding request set.
2024-08-14 17:22:01.126 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:01.126 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:01.126 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:01.126 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:01.126 | Historical data download ID 122196 not found when removing ID from outstanding request set.
2024-08-14 17:22:01.126 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:01.126 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:01.126 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:01.168 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:01.169 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:01.169 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:01.169 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:01.169 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:01.169 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:01.169 | DTC Client socket (4) | Closed.
2024-08-14 17:22:01.169 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:01.169 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:01.169 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:03.227 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:03.227 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:03.228 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:03.228 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:03.228 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:03.269 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:03.269 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:03.269 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:03.269 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:03.397 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:03.397 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:03.397 | Historical data download ID 122197 not found when removing ID from outstanding request set.
2024-08-14 17:22:03.397 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:03.397 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:03.397 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:03.397 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:03.397 | Historical data download ID 122198 not found when removing ID from outstanding request set.
2024-08-14 17:22:03.397 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:03.397 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:03.397 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:03.397 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:03.397 | Historical data download ID 122199 not found when removing ID from outstanding request set.
2024-08-14 17:22:03.397 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:03.397 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:03.397 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:03.438 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:03.438 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:03.439 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:03.439 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:03.439 | DTC Client socket (4) | Closed.
2024-08-14 17:22:03.439 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:03.440 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:03.440 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:03.440 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:05.441 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:05.441 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:05.442 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:05.442 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:05.442 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:05.485 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:05.485 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:05.485 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:05.485 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:05.605 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:05.605 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:05.605 | Historical data download ID 122200 not found when removing ID from outstanding request set.
2024-08-14 17:22:05.605 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:05.605 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:05.605 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:05.605 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:05.605 | Historical data download ID 122201 not found when removing ID from outstanding request set.
2024-08-14 17:22:05.605 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:05.605 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:05.605 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:05.605 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:05.605 | Historical data download ID 122202 not found when removing ID from outstanding request set.
2024-08-14 17:22:05.605 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:05.605 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:05.605 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:05.646 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:05.649 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:05.669 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:05.669 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:05.669 | DTC Client socket (4) | Closed.
2024-08-14 17:22:05.669 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:05.669 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:05.669 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:05.669 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:07.715 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:07.715 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:07.715 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:07.715 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:07.715 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:07.753 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:07.753 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:07.753 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:07.753 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:07.881 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:07.881 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:07.881 | Historical data download ID 122203 not found when removing ID from outstanding request set.
2024-08-14 17:22:07.881 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:07.881 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:07.881 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:07.881 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:07.881 | Historical data download ID 122204 not found when removing ID from outstanding request set.
2024-08-14 17:22:07.881 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:07.881 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:07.881 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:07.881 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:07.881 | Historical data download ID 122205 not found when removing ID from outstanding request set.
2024-08-14 17:22:07.881 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:07.881 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:07.881 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:07.921 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:07.928 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:07.928 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:07.928 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:07.928 | DTC Client socket (4) | Closed.
2024-08-14 17:22:07.928 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:07.929 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:07.929 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:07.929 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:09.938 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:09.938 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:09.938 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:09.939 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:09.939 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:09.982 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:09.982 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:09.982 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:09.982 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:10.104 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:10.104 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:10.104 | Historical data download ID 122206 not found when removing ID from outstanding request set.
2024-08-14 17:22:10.104 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:10.104 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:10.104 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:10.104 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:10.104 | Historical data download ID 122207 not found when removing ID from outstanding request set.
2024-08-14 17:22:10.104 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:10.104 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:10.104 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:10.104 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:10.104 | Historical data download ID 122208 not found when removing ID from outstanding request set.
2024-08-14 17:22:10.104 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:10.104 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:10.104 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:10.145 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:10.165 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:10.165 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:10.166 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:10.166 | DTC Client socket (4) | Closed.
2024-08-14 17:22:10.166 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:10.166 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:10.166 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:10.166 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:12.221 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:12.221 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:12.222 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:12.222 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:12.222 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:12.261 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:12.261 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:12.261 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:12.261 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:12.388 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:12.388 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:12.388 | Historical data download ID 122209 not found when removing ID from outstanding request set.
2024-08-14 17:22:12.388 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:12.388 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:12.388 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:12.388 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:12.388 | Historical data download ID 122210 not found when removing ID from outstanding request set.
2024-08-14 17:22:12.388 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:12.388 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:12.388 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:12.388 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:12.388 | Historical data download ID 122211 not found when removing ID from outstanding request set.
2024-08-14 17:22:12.388 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:12.388 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:12.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:12.430 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:12.431 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:12.431 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:12.431 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:12.431 | DTC Client socket (4) | Closed.
2024-08-14 17:22:12.431 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:12.432 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:12.432 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:12.432 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:14.437 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:14.437 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:14.438 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:14.438 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:14.438 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:14.473 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:14.473 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:14.473 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:14.473 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:14.594 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:14.594 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:14.594 | Historical data download ID 122212 not found when removing ID from outstanding request set.
2024-08-14 17:22:14.594 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:14.594 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:14.594 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:14.594 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:14.594 | Historical data download ID 122213 not found when removing ID from outstanding request set.
2024-08-14 17:22:14.594 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:14.594 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:14.594 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:14.594 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:14.595 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:14.595 | Historical data download ID 122214 not found when removing ID from outstanding request set.
2024-08-14 17:22:14.595 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:14.595 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:14.595 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:14.636 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:14.636 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:14.636 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:14.636 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:14.636 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:14.636 | DTC Client socket (4) | Closed.
2024-08-14 17:22:14.636 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:14.637 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:14.637 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:14.637 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:16.638 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:16.638 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:16.639 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:16.639 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:16.639 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:16.678 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:16.678 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:16.678 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:16.678 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:16.799 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:16.799 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:16.799 | Historical data download ID 122215 not found when removing ID from outstanding request set.
2024-08-14 17:22:16.799 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:16.799 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:16.799 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:16.799 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:16.799 | Historical data download ID 122216 not found when removing ID from outstanding request set.
2024-08-14 17:22:16.799 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:16.799 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:16.799 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:16.799 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:16.799 | Historical data download ID 122217 not found when removing ID from outstanding request set.
2024-08-14 17:22:16.799 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:16.799 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:16.799 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:16.839 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:16.845 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:16.845 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:16.845 | DTC Client socket (4) | Closed.
2024-08-14 17:22:16.845 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:16.846 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:16.846 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:16.846 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:18.846 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:18.846 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:18.846 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:18.847 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:18.847 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:18.895 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:18.895 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:18.895 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:18.895 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:19.016 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:19.016 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:19.016 | Historical data download ID 122218 not found when removing ID from outstanding request set.
2024-08-14 17:22:19.016 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:19.016 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:19.016 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:19.016 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:19.016 | Historical data download ID 122219 not found when removing ID from outstanding request set.
2024-08-14 17:22:19.016 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:19.016 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:19.016 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:19.017 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:19.017 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:19.017 | Historical data download ID 122220 not found when removing ID from outstanding request set.
2024-08-14 17:22:19.017 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:19.017 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:19.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:19.056 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:19.056 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:19.056 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:19.056 | DTC Client socket (4) | Closed.
2024-08-14 17:22:19.056 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:19.056 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:19.057 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:19.057 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:21.057 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:21.058 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:21.058 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:21.058 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:21.058 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:21.097 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:21.097 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:21.097 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:21.097 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:21.223 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:21.223 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:21.223 | Historical data download ID 122221 not found when removing ID from outstanding request set.
2024-08-14 17:22:21.223 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:21.223 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:21.223 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:21.223 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:21.223 | Historical data download ID 122222 not found when removing ID from outstanding request set.
2024-08-14 17:22:21.223 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:21.223 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:21.223 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:21.223 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:21.223 | Historical data download ID 122223 not found when removing ID from outstanding request set.
2024-08-14 17:22:21.223 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:21.223 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:21.223 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:21.265 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:21.266 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:21.266 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:21.266 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:21.266 | DTC Client socket (4) | Closed.
2024-08-14 17:22:21.266 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:21.267 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:21.267 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:21.267 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:23.281 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:23.281 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:23.282 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:23.282 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:23.282 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:23.320 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:23.320 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:23.320 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:23.320 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:23.447 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:23.447 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:23.447 | Historical data download ID 122224 not found when removing ID from outstanding request set.
2024-08-14 17:22:23.447 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:23.447 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:23.447 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:23.447 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:23.447 | Historical data download ID 122225 not found when removing ID from outstanding request set.
2024-08-14 17:22:23.447 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:23.447 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:23.447 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:23.447 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:23.447 | Historical data download ID 122226 not found when removing ID from outstanding request set.
2024-08-14 17:22:23.447 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:23.447 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:23.447 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:23.489 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:23.489 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:23.489 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:23.489 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:23.489 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:22:23.489 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:23.490 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:23.490 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:23.490 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:23.531 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:22:23.531 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:23.531 | DTC Client socket (4) | Closed.
2024-08-14 17:22:24.316 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:24.317 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:22:24.333 | HD Server | Thread:18220 (4) | Creating socket.
2024-08-14 17:22:24.333 | HD Server | Thread:18220 (4) | New receive buffer size: 262144
2024-08-14 17:22:24.333 | HD Server | Thread:18220 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:24.333 | HD Server | Setting DTC encoding to Binary VLS | Thread:18220
2024-08-14 17:22:24.334 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:18220
2024-08-14 17:22:24.334 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:18220
2024-08-14 17:22:24.334 | HD Server | HD Request #4303 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4303 | Username: DAVID SUDDUTH JR. | Thread:18220
2024-08-14 17:22:24.335 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4303 | Username: DAVID SUDDUTH JR. | Thread:18220
2024-08-14 17:22:24.336 | HD Server | Thread:18220 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:24.336 | HD Server | Thread:18220 (4) | CloseSocket call.
2024-08-14 17:22:24.336 | HD Server | Thread:18220 (0) | CloseSocket call.
2024-08-14 17:22:24.336 | HD Server | Thread:18220 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:24.336 | HD Server | Thread:18220 (4) | Closed.
2024-08-14 17:22:24.338 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:24.339 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:22:24.347 | HD Server | Thread:21292 (4) | Creating socket.
2024-08-14 17:22:24.347 | HD Server | Thread:21292 (4) | New receive buffer size: 262144
2024-08-14 17:22:24.347 | HD Server | Thread:21292 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:24.347 | HD Server | Setting DTC encoding to Binary VLS | Thread:21292
2024-08-14 17:22:24.348 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:21292
2024-08-14 17:22:24.348 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:21292
2024-08-14 17:22:24.348 | HD Server | HD Request #4304 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4304 | Username: DAVID SUDDUTH JR. | Thread:21292
2024-08-14 17:22:24.348 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4304 | Username: DAVID SUDDUTH JR. | Thread:21292
2024-08-14 17:22:24.349 | HD Server | Thread:21292 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:24.349 | HD Server | Thread:21292 (4) | CloseSocket call.
2024-08-14 17:22:24.349 | HD Server | Thread:21292 (0) | CloseSocket call.
2024-08-14 17:22:24.349 | HD Server | Thread:21292 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:24.349 | HD Server | Thread:21292 (4) | Closed.
2024-08-14 17:22:24.416 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:21292
2024-08-14 17:22:24.416 | HD Server Manager | Current server count=1
2024-08-14 17:22:24.416 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:18220
2024-08-14 17:22:24.416 | HD Server Manager | Current server count=0
2024-08-14 17:22:25.493 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:25.493 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:25.493 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:25.494 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:25.494 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:25.533 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:25.533 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:25.533 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:25.533 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:25.661 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:25.661 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:25.661 | Historical data download ID 122227 not found when removing ID from outstanding request set.
2024-08-14 17:22:25.661 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:25.661 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:25.661 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:25.661 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:25.661 | Historical data download ID 122228 not found when removing ID from outstanding request set.
2024-08-14 17:22:25.661 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:25.661 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:25.661 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:25.661 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:25.661 | Historical data download ID 122229 not found when removing ID from outstanding request set.
2024-08-14 17:22:25.661 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:25.661 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:25.661 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:25.703 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:25.712 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:25.712 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:22:25.713 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:25.713 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:25.713 | DTC Client socket (4) | Closed.
2024-08-14 17:22:25.714 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:25.714 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:25.714 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:25.714 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:26.839 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:26.839 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:22:26.857 | HD Server | Thread:15392 (4) | Creating socket.
2024-08-14 17:22:26.857 | HD Server | Thread:15392 (4) | New receive buffer size: 262144
2024-08-14 17:22:26.857 | HD Server | Thread:15392 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:26.858 | HD Server | Setting DTC encoding to Binary VLS | Thread:15392
2024-08-14 17:22:26.858 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:22:26.858 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:22:26.858 | HD Server | HD Request #4305 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4305 | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:22:26.859 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4305 | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:22:26.859 | HD Server | Thread:15392 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:26.859 | HD Server | Thread:15392 (4) | CloseSocket call.
2024-08-14 17:22:26.860 | HD Server | Thread:15392 (0) | CloseSocket call.
2024-08-14 17:22:26.860 | HD Server | Thread:15392 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:26.860 | HD Server | Thread:15392 (4) | Closed.
2024-08-14 17:22:26.864 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:26.864 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:22:26.880 | HD Server | Thread:16600 (4) | Creating socket.
2024-08-14 17:22:26.880 | HD Server | Thread:16600 (4) | New receive buffer size: 262144
2024-08-14 17:22:26.880 | HD Server | Thread:16600 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:26.880 | HD Server | Setting DTC encoding to Binary VLS | Thread:16600
2024-08-14 17:22:26.880 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:16600
2024-08-14 17:22:26.880 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:16600
2024-08-14 17:22:26.881 | HD Server | HD Request #4306 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4306 | Username: DAVID SUDDUTH JR. | Thread:16600
2024-08-14 17:22:26.881 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4306 | Username: DAVID SUDDUTH JR. | Thread:16600
2024-08-14 17:22:26.881 | HD Server | Thread:16600 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:26.881 | HD Server | Thread:16600 (4) | CloseSocket call.
2024-08-14 17:22:26.882 | HD Server | Thread:16600 (0) | CloseSocket call.
2024-08-14 17:22:26.882 | HD Server | Thread:16600 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:26.882 | HD Server | Thread:16600 (4) | Closed.
2024-08-14 17:22:26.924 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:16600
2024-08-14 17:22:26.924 | HD Server Manager | Current server count=1
2024-08-14 17:22:26.924 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15392
2024-08-14 17:22:26.924 | HD Server Manager | Current server count=0
2024-08-14 17:22:27.750 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:27.750 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:27.751 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:27.751 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:27.751 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:27.789 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:27.789 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:27.789 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:27.789 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:27.919 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:27.919 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:27.919 | Historical data download ID 122230 not found when removing ID from outstanding request set.
2024-08-14 17:22:27.919 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:27.919 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:27.919 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:27.919 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:27.919 | Historical data download ID 122231 not found when removing ID from outstanding request set.
2024-08-14 17:22:27.919 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:27.919 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:27.919 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:27.919 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:27.919 | Historical data download ID 122232 not found when removing ID from outstanding request set.
2024-08-14 17:22:27.919 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:27.919 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:27.919 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:27.959 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:27.959 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:27.959 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:27.959 | DTC Client socket (4) | Closed.
2024-08-14 17:22:27.959 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:27.959 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:27.959 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:27.959 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:29.964 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:29.964 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:29.965 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:29.965 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:29.965 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:30.003 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:30.003 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:30.003 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:30.003 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:30.123 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:30.123 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:30.123 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:30.123 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:30.123 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:30.123 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:30.123 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:30.123 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:30.123 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:30.123 | Historical data download ID 122233 not found when removing ID from outstanding request set.
2024-08-14 17:22:30.124 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:30.124 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:30.124 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:30.124 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:30.124 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:30.124 | Historical data download ID 122234 not found when removing ID from outstanding request set.
2024-08-14 17:22:30.124 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:30.124 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:30.124 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:30.124 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:30.124 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:30.124 | Historical data download ID 122235 not found when removing ID from outstanding request set.
2024-08-14 17:22:30.124 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:30.124 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:30.124 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:30.166 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:30.166 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:30.166 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:30.166 | DTC Client socket (4) | Closed.
2024-08-14 17:22:30.166 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:30.166 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:30.166 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:30.166 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:32.171 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:32.171 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:32.172 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:32.172 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:32.172 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:32.213 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:32.213 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:32.213 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:32.213 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:32.335 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:32.335 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:32.335 | Historical data download ID 122236 not found when removing ID from outstanding request set.
2024-08-14 17:22:32.335 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:32.335 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:32.335 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:32.335 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:32.335 | Historical data download ID 122237 not found when removing ID from outstanding request set.
2024-08-14 17:22:32.335 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:32.335 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:32.335 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:32.335 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:32.335 | Historical data download ID 122238 not found when removing ID from outstanding request set.
2024-08-14 17:22:32.335 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:32.335 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:32.335 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:32.373 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:32.378 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:32.378 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:32.378 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:32.378 | DTC Client socket (4) | Closed.
2024-08-14 17:22:32.379 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:32.379 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:32.379 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:34.377 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:34.377 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:34.377 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:34.377 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:34.377 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:34.415 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:34.415 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:34.415 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:34.415 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:34.552 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:34.552 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:34.552 | Historical data download ID 122239 not found when removing ID from outstanding request set.
2024-08-14 17:22:34.552 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:34.552 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:34.552 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:34.552 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:34.552 | Historical data download ID 122240 not found when removing ID from outstanding request set.
2024-08-14 17:22:34.552 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:34.552 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:34.552 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:34.552 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:34.552 | Historical data download ID 122241 not found when removing ID from outstanding request set.
2024-08-14 17:22:34.552 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:34.552 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:34.552 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:34.594 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:34.595 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:34.595 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:34.595 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:34.595 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:34.595 | DTC Client socket (4) | Closed.
2024-08-14 17:22:34.596 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:34.596 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:34.596 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:36.598 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:36.598 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:36.599 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:36.599 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:36.599 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:36.637 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:36.637 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:36.637 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:36.637 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:36.756 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:36.756 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:36.756 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:36.757 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:36.757 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:36.757 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:36.757 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:36.757 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:36.757 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:36.757 | Historical data download ID 122242 not found when removing ID from outstanding request set.
2024-08-14 17:22:36.757 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:36.757 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:36.757 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:36.757 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:36.757 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:36.757 | Historical data download ID 122243 not found when removing ID from outstanding request set.
2024-08-14 17:22:36.757 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:36.757 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:36.757 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:36.757 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:36.757 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:36.757 | Historical data download ID 122244 not found when removing ID from outstanding request set.
2024-08-14 17:22:36.757 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:36.757 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:36.757 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:36.799 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:36.799 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:36.799 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:36.799 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:36.799 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:36.799 | DTC Client socket (4) | Closed.
2024-08-14 17:22:36.799 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:36.800 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:36.800 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:36.800 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:38.812 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:38.812 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:38.813 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:38.813 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:38.813 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:38.855 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:38.855 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:38.855 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:38.855 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:38.978 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:38.978 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:38.978 | Historical data download ID 122245 not found when removing ID from outstanding request set.
2024-08-14 17:22:38.978 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:38.978 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:38.978 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:38.978 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:38.978 | Historical data download ID 122246 not found when removing ID from outstanding request set.
2024-08-14 17:22:38.978 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:38.978 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:38.978 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:38.978 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:38.978 | Historical data download ID 122247 not found when removing ID from outstanding request set.
2024-08-14 17:22:38.978 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:38.978 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:38.978 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:39.018 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:39.019 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:39.020 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:39.020 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:39.020 | DTC Client socket (4) | Closed.
2024-08-14 17:22:39.020 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:39.021 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:39.021 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:39.021 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:41.030 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:41.030 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:41.031 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:41.031 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:41.031 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:41.069 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:41.069 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:41.069 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:41.069 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:41.197 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:41.197 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:41.197 | Historical data download ID 122248 not found when removing ID from outstanding request set.
2024-08-14 17:22:41.197 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:41.197 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:41.197 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:41.197 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:41.197 | Historical data download ID 122249 not found when removing ID from outstanding request set.
2024-08-14 17:22:41.197 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:41.197 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:41.197 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:41.197 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:41.197 | Historical data download ID 122250 not found when removing ID from outstanding request set.
2024-08-14 17:22:41.197 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:41.197 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:41.197 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:41.235 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:41.241 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:41.241 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:41.241 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:41.241 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:41.241 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=368
2024-08-14 17:22:41.242 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:41.242 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:41.242 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:41.282 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:22:41.282 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:41.282 | DTC Client socket (4) | Closed.
2024-08-14 17:22:43.270 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:43.270 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:43.271 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:43.271 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:43.271 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:43.309 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:43.309 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:43.309 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:43.309 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:43.430 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:43.430 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:43.430 | Historical data download ID 122251 not found when removing ID from outstanding request set.
2024-08-14 17:22:43.430 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:43.430 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:43.430 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:43.430 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:43.430 | Historical data download ID 122252 not found when removing ID from outstanding request set.
2024-08-14 17:22:43.430 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:43.430 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:43.430 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:43.430 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:43.430 | Historical data download ID 122253 not found when removing ID from outstanding request set.
2024-08-14 17:22:43.430 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:43.430 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:43.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:43.472 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:43.472 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:43.472 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:43.472 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:43.472 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:43.472 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:43.472 | DTC Client socket (4) | Closed.
2024-08-14 17:22:43.473 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:43.473 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:43.473 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:45.481 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:45.481 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:45.482 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:45.482 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:45.482 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:45.525 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:45.525 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:45.525 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:45.525 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:45.647 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:45.647 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:45.647 | Historical data download ID 122254 not found when removing ID from outstanding request set.
2024-08-14 17:22:45.647 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:45.647 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:45.647 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:45.647 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:45.647 | Historical data download ID 122255 not found when removing ID from outstanding request set.
2024-08-14 17:22:45.647 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:45.647 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:45.647 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:45.647 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:45.647 | Historical data download ID 122256 not found when removing ID from outstanding request set.
2024-08-14 17:22:45.647 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:45.647 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:45.647 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:45.689 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:45.709 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:45.709 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:45.709 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:45.709 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:22:45.709 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:45.709 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:45.709 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:45.709 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:45.746 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:22:45.746 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:45.746 | DTC Client socket (4) | Closed.
2024-08-14 17:22:47.745 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:47.745 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:47.746 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:47.746 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:47.746 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:47.784 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:47.784 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:47.784 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:47.784 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:47.913 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:47.913 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:47.913 | Historical data download ID 122257 not found when removing ID from outstanding request set.
2024-08-14 17:22:47.913 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:47.913 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:47.913 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:47.913 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:47.913 | Historical data download ID 122258 not found when removing ID from outstanding request set.
2024-08-14 17:22:47.913 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:47.913 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:47.913 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:47.913 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:47.913 | Historical data download ID 122259 not found when removing ID from outstanding request set.
2024-08-14 17:22:47.913 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:47.913 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:47.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:47.953 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:47.954 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:47.955 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:47.955 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:47.955 | DTC Client socket (4) | Closed.
2024-08-14 17:22:47.955 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:47.955 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:47.955 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:47.955 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:49.963 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:49.964 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:49.964 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:49.964 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:49.964 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:50.002 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:50.002 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:50.002 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:50.002 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:50.125 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:50.125 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:50.125 | Historical data download ID 122260 not found when removing ID from outstanding request set.
2024-08-14 17:22:50.125 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:50.125 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:50.125 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:50.125 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:50.125 | Historical data download ID 122261 not found when removing ID from outstanding request set.
2024-08-14 17:22:50.125 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:50.125 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:50.125 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:50.125 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:50.125 | Historical data download ID 122262 not found when removing ID from outstanding request set.
2024-08-14 17:22:50.125 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:50.125 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:50.125 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:50.163 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:50.163 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:50.164 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:50.164 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:50.164 | DTC Client socket (4) | Closed.
2024-08-14 17:22:50.164 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:50.164 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:50.164 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:52.170 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:52.171 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:52.171 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:52.171 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:52.171 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:52.227 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:52.227 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:52.227 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:52.227 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:52.344 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:52.344 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:52.344 | Historical data download ID 122263 not found when removing ID from outstanding request set.
2024-08-14 17:22:52.344 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:52.344 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:52.344 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:52.344 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:52.344 | Historical data download ID 122264 not found when removing ID from outstanding request set.
2024-08-14 17:22:52.344 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:52.344 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:52.344 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:52.344 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:52.344 | Historical data download ID 122265 not found when removing ID from outstanding request set.
2024-08-14 17:22:52.344 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:52.344 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:52.344 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:52.387 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:52.394 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:52.394 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:22:52.394 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:52.394 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:52.394 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:52.394 | DTC Client socket (4) | Closed.
2024-08-14 17:22:52.394 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:52.394 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:52.394 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:54.406 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:54.406 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:54.406 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:54.406 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:54.406 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:54.444 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:54.444 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:54.444 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:54.444 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:54.570 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:54.570 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:54.570 | Historical data download ID 122266 not found when removing ID from outstanding request set.
2024-08-14 17:22:54.570 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:54.570 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:54.570 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:54.570 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:54.570 | Historical data download ID 122267 not found when removing ID from outstanding request set.
2024-08-14 17:22:54.570 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:54.570 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:54.570 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:54.570 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:54.570 | Historical data download ID 122268 not found when removing ID from outstanding request set.
2024-08-14 17:22:54.570 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:54.570 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:54.570 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:54.614 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:54.614 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:54.614 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:54.614 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:54.614 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:54.614 | DTC Client socket (4) | Closed.
2024-08-14 17:22:54.614 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:54.614 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:54.614 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:54.614 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:56.056 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:56.056 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:22:56.073 | HD Server | Thread:6828 (4) | Creating socket.
2024-08-14 17:22:56.073 | HD Server | Thread:6828 (4) | New receive buffer size: 262144
2024-08-14 17:22:56.073 | HD Server | Thread:6828 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:56.073 | HD Server | Setting DTC encoding to Binary VLS | Thread:6828
2024-08-14 17:22:56.074 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:6828
2024-08-14 17:22:56.074 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:6828
2024-08-14 17:22:56.074 | HD Server | HD Request #4307 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4307 | Username: DAVID SUDDUTH JR. | Thread:6828
2024-08-14 17:22:56.075 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4307 | Username: DAVID SUDDUTH JR. | Thread:6828
2024-08-14 17:22:56.075 | HD Server | Thread:6828 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:56.075 | HD Server | Thread:6828 (4) | CloseSocket call.
2024-08-14 17:22:56.076 | HD Server | Thread:6828 (0) | CloseSocket call.
2024-08-14 17:22:56.076 | HD Server | Thread:6828 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:56.076 | HD Server | Thread:6828 (4) | Closed.
2024-08-14 17:22:56.079 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:56.079 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:22:56.093 | HD Server | Thread:13552 (4) | Creating socket.
2024-08-14 17:22:56.093 | HD Server | Thread:13552 (4) | New receive buffer size: 262144
2024-08-14 17:22:56.093 | HD Server | Thread:13552 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:56.093 | HD Server | Setting DTC encoding to Binary VLS | Thread:13552
2024-08-14 17:22:56.094 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:13552
2024-08-14 17:22:56.094 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:13552
2024-08-14 17:22:56.094 | HD Server | HD Request #4308 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4308 | Username: DAVID SUDDUTH JR. | Thread:13552
2024-08-14 17:22:56.095 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4308 | Username: DAVID SUDDUTH JR. | Thread:13552
2024-08-14 17:22:56.095 | HD Server | Thread:13552 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:56.095 | HD Server | Thread:13552 (4) | CloseSocket call.
2024-08-14 17:22:56.096 | HD Server | Thread:13552 (0) | CloseSocket call.
2024-08-14 17:22:56.096 | HD Server | Thread:13552 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:56.096 | HD Server | Thread:13552 (4) | Closed.
2024-08-14 17:22:56.245 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:13552
2024-08-14 17:22:56.245 | HD Server Manager | Current server count=1
2024-08-14 17:22:56.245 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:6828
2024-08-14 17:22:56.245 | HD Server Manager | Current server count=0
2024-08-14 17:22:56.623 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:56.623 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:56.623 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:56.623 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:56.623 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:56.661 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:56.661 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:56.661 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:56.661 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:56.783 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:56.783 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:56.783 | Historical data download ID 122269 not found when removing ID from outstanding request set.
2024-08-14 17:22:56.783 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:56.783 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:56.783 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:56.783 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:56.783 | Historical data download ID 122270 not found when removing ID from outstanding request set.
2024-08-14 17:22:56.783 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:56.783 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:56.783 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:56.783 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:56.783 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:56.783 | Historical data download ID 122271 not found when removing ID from outstanding request set.
2024-08-14 17:22:56.783 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:56.784 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:56.784 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:56.827 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:56.827 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:56.827 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:22:56.827 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:22:56.827 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=368
2024-08-14 17:22:56.827 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:56.827 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:56.827 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:56.827 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:22:56.867 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:22:56.867 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:56.867 | DTC Client socket (4) | Closed.
2024-08-14 17:22:58.600 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:58.601 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:22:58.618 | HD Server | Thread:6380 (4) | Creating socket.
2024-08-14 17:22:58.618 | HD Server | Thread:6380 (4) | New receive buffer size: 262144
2024-08-14 17:22:58.618 | HD Server | Thread:6380 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:58.619 | HD Server | Setting DTC encoding to Binary VLS | Thread:6380
2024-08-14 17:22:58.619 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:6380
2024-08-14 17:22:58.619 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:6380
2024-08-14 17:22:58.620 | HD Server | HD Request #4309 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4309 | Username: DAVID SUDDUTH JR. | Thread:6380
2024-08-14 17:22:58.621 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4309 | Username: DAVID SUDDUTH JR. | Thread:6380
2024-08-14 17:22:58.621 | HD Server | Thread:6380 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:58.621 | HD Server | Thread:6380 (4) | CloseSocket call.
2024-08-14 17:22:58.622 | HD Server | Thread:6380 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:58.622 | HD Server | Thread:6380 (4) | Closed.
2024-08-14 17:22:58.622 | HD Server | Thread:6380 (0) | CloseSocket call. | Number times message added: 1
2024-08-14 17:22:58.639 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:22:58.640 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:22:58.656 | HD Server | Thread:16640 (4) | Creating socket.
2024-08-14 17:22:58.656 | HD Server | Thread:16640 (4) | New receive buffer size: 262144
2024-08-14 17:22:58.656 | HD Server | Thread:16640 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:22:58.656 | HD Server | Setting DTC encoding to Binary VLS | Thread:16640
2024-08-14 17:22:58.657 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:16640
2024-08-14 17:22:58.657 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:16640
2024-08-14 17:22:58.658 | HD Server | HD Request #4310 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4310 | Username: DAVID SUDDUTH JR. | Thread:16640
2024-08-14 17:22:58.659 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4310 | Username: DAVID SUDDUTH JR. | Thread:16640
2024-08-14 17:22:58.659 | HD Server | Thread:16640 (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:58.660 | HD Server | Thread:16640 (4) | CloseSocket call.
2024-08-14 17:22:58.660 | HD Server | Thread:16640 (0) | CloseSocket call.
2024-08-14 17:22:58.660 | HD Server | Thread:16640 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:58.660 | HD Server | Thread:16640 (4) | Closed.
2024-08-14 17:22:58.661 | HD Server | Thread:16640 (0) | CloseSocket call.
2024-08-14 17:22:58.751 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:16640
2024-08-14 17:22:58.751 | HD Server Manager | Current server count=1
2024-08-14 17:22:58.751 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:6380
2024-08-14 17:22:58.751 | HD Server Manager | Current server count=0
2024-08-14 17:22:58.815 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:22:58.815 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:22:58.815 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:22:58.816 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:22:58.816 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:22:58.854 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:22:58.854 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:22:58.854 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:22:58.854 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:22:58.991 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:22:58.991 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:22:58.991 | Historical data download ID 122272 not found when removing ID from outstanding request set.
2024-08-14 17:22:58.991 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:22:58.991 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:22:58.991 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:22:58.991 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:22:58.991 | Historical data download ID 122273 not found when removing ID from outstanding request set.
2024-08-14 17:22:58.991 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:22:58.991 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:22:58.991 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:22:58.991 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:22:58.991 | Historical data download ID 122274 not found when removing ID from outstanding request set.
2024-08-14 17:22:58.991 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:22:58.991 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:22:58.991 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:22:59.032 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:22:59.034 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:22:59.034 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:22:59.034 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:22:59.034 | DTC Client socket (4) | Closed.
2024-08-14 17:22:59.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:22:59.035 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:22:59.035 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:22:59.035 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:01.064 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:01.064 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:01.065 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:01.065 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:01.065 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:01.103 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:01.103 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:01.103 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:01.103 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:01.238 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:01.238 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:01.238 | Historical data download ID 122275 not found when removing ID from outstanding request set.
2024-08-14 17:23:01.238 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:01.238 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:01.238 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:01.238 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:01.238 | Historical data download ID 122276 not found when removing ID from outstanding request set.
2024-08-14 17:23:01.238 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:01.238 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:01.238 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:01.238 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:01.238 | Historical data download ID 122277 not found when removing ID from outstanding request set.
2024-08-14 17:23:01.238 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:01.238 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:01.238 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:01.279 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:01.280 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:01.280 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:01.280 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:01.280 | DTC Client socket (4) | Closed.
2024-08-14 17:23:01.280 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:01.281 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:01.281 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:01.281 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:03.269 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:03.269 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:03.269 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:03.270 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:03.270 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:03.315 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:03.315 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:03.315 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:03.315 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:03.433 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:03.433 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:03.433 | Historical data download ID 122278 not found when removing ID from outstanding request set.
2024-08-14 17:23:03.433 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:03.433 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:03.433 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:03.433 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:03.433 | Historical data download ID 122279 not found when removing ID from outstanding request set.
2024-08-14 17:23:03.433 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:03.433 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:03.433 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:03.433 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:03.433 | Historical data download ID 122280 not found when removing ID from outstanding request set.
2024-08-14 17:23:03.433 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:03.433 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:03.433 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:03.477 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:03.477 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:03.477 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:03.477 | DTC Client socket (4) | Closed.
2024-08-14 17:23:03.477 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:03.478 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:03.478 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:03.478 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:05.473 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:05.473 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:05.473 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:05.473 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:05.473 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:05.512 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:05.512 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:05.512 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:05.512 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:05.641 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:05.641 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:05.641 | Historical data download ID 122281 not found when removing ID from outstanding request set.
2024-08-14 17:23:05.641 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:05.641 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:05.641 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:05.642 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:05.642 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:05.642 | Historical data download ID 122282 not found when removing ID from outstanding request set.
2024-08-14 17:23:05.642 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:05.642 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:05.642 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:05.642 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:05.642 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:05.642 | Historical data download ID 122283 not found when removing ID from outstanding request set.
2024-08-14 17:23:05.642 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:05.642 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:05.642 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:05.684 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:05.702 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:05.702 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:05.702 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:05.702 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:05.702 | DTC Client socket (4) | Closed.
2024-08-14 17:23:05.702 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:05.702 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:05.702 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:05.703 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:07.693 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:07.693 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:07.694 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:07.694 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:07.694 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:07.746 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:07.746 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:07.746 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:07.746 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:07.870 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:07.870 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:07.870 | Historical data download ID 122284 not found when removing ID from outstanding request set.
2024-08-14 17:23:07.870 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:07.870 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:07.870 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:07.870 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:07.870 | Historical data download ID 122285 not found when removing ID from outstanding request set.
2024-08-14 17:23:07.870 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:07.870 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:07.870 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:07.870 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:07.870 | Historical data download ID 122286 not found when removing ID from outstanding request set.
2024-08-14 17:23:07.870 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:07.870 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:07.870 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:07.912 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:07.912 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:07.912 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:07.912 | DTC Client socket (4) | Closed.
2024-08-14 17:23:07.912 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:07.913 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:07.913 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:07.913 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:09.917 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:09.917 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:09.918 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:09.918 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:09.918 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:09.960 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:09.960 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:09.960 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:09.960 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:10.080 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:10.080 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:10.080 | Historical data download ID 122287 not found when removing ID from outstanding request set.
2024-08-14 17:23:10.080 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:10.080 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:10.080 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:10.080 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:10.080 | Historical data download ID 122288 not found when removing ID from outstanding request set.
2024-08-14 17:23:10.080 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:10.080 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:10.080 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:10.080 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:10.080 | Historical data download ID 122289 not found when removing ID from outstanding request set.
2024-08-14 17:23:10.080 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:10.080 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:10.080 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:10.121 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:10.123 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:10.123 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:10.123 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:10.123 | DTC Client socket (4) | Closed.
2024-08-14 17:23:10.123 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:10.124 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:10.124 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:10.124 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:12.113 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:12.113 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:12.114 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:12.114 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:12.114 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:12.153 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:12.153 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:12.153 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:12.153 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:12.285 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:12.285 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:12.285 | Historical data download ID 122290 not found when removing ID from outstanding request set.
2024-08-14 17:23:12.285 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:12.285 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:12.285 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:12.285 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:12.285 | Historical data download ID 122291 not found when removing ID from outstanding request set.
2024-08-14 17:23:12.285 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:12.285 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:12.285 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:12.285 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:12.285 | Historical data download ID 122292 not found when removing ID from outstanding request set.
2024-08-14 17:23:12.285 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:12.285 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:12.285 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:12.327 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:12.337 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:12.337 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:23:12.338 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:12.338 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:12.338 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:12.338 | DTC Client socket (4) | Closed.
2024-08-14 17:23:12.338 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:12.338 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:12.338 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:14.340 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:14.340 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:14.340 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:14.340 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:14.340 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:14.380 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:14.380 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:14.380 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:14.380 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:14.511 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:14.511 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:14.511 | Historical data download ID 122293 not found when removing ID from outstanding request set.
2024-08-14 17:23:14.511 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:14.511 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:14.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:14.512 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:14.512 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:14.512 | Historical data download ID 122294 not found when removing ID from outstanding request set.
2024-08-14 17:23:14.512 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:14.512 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:14.512 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:14.512 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:14.512 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:14.512 | Historical data download ID 122295 not found when removing ID from outstanding request set.
2024-08-14 17:23:14.512 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:14.512 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:14.512 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:14.554 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:14.555 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:14.555 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:14.555 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:23:14.555 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:23:14.555 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:14.555 | DTC Client socket (4) | Closed.
2024-08-14 17:23:14.555 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:14.556 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:14.556 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:14.556 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:16.560 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:16.560 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:16.561 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:16.561 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:16.561 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:16.601 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:16.601 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:16.601 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:16.601 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:16.723 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:16.723 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:16.723 | Historical data download ID 122296 not found when removing ID from outstanding request set.
2024-08-14 17:23:16.723 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:16.723 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:16.723 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:16.723 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:16.723 | Historical data download ID 122297 not found when removing ID from outstanding request set.
2024-08-14 17:23:16.723 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:16.723 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:16.723 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:16.723 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:16.723 | Historical data download ID 122298 not found when removing ID from outstanding request set.
2024-08-14 17:23:16.723 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:16.723 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:16.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:16.765 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:16.790 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:16.791 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:16.791 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:16.791 | DTC Client socket (4) | Closed.
2024-08-14 17:23:16.791 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:16.791 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:16.791 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:18.406 | Sierra Chart account data changed. Requesting updated account information.
2024-08-14 17:23:18.815 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:18.815 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:18.815 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:18.816 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:18.816 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:18.854 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:18.854 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:18.855 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:18.855 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:18.983 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:18.983 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:18.983 | Historical data download ID 122299 not found when removing ID from outstanding request set.
2024-08-14 17:23:18.983 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:18.983 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:18.983 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:18.983 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:18.983 | Historical data download ID 122300 not found when removing ID from outstanding request set.
2024-08-14 17:23:18.983 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:18.983 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:18.983 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:18.983 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:18.983 | Historical data download ID 122301 not found when removing ID from outstanding request set.
2024-08-14 17:23:18.983 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:18.983 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:18.983 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:19.022 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:19.022 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:19.022 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:23:19.022 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:23:19.022 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:19.022 | DTC Client socket (4) | Closed.
2024-08-14 17:23:19.022 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:19.023 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:19.023 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:19.023 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:20.113 | Successfully processed Sierra Chart account data.
2024-08-14 17:23:20.113 | Requested user files to download.
2024-08-14 17:23:21.026 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:21.026 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:21.026 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:21.027 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:21.027 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:21.065 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:21.065 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:21.065 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:21.065 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:21.192 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:21.192 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:21.192 | Historical data download ID 122302 not found when removing ID from outstanding request set.
2024-08-14 17:23:21.192 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:21.192 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:21.192 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:21.192 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:21.192 | Historical data download ID 122303 not found when removing ID from outstanding request set.
2024-08-14 17:23:21.192 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:21.192 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:21.192 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:21.192 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:21.192 | Historical data download ID 122304 not found when removing ID from outstanding request set.
2024-08-14 17:23:21.192 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:21.192 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:21.192 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:21.233 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:21.235 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:21.235 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:21.235 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:21.235 | DTC Client socket (5) | Closed.
2024-08-14 17:23:21.235 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:21.235 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:21.235 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:21.235 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:23.239 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:23.239 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:23.239 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:23.239 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:23.239 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:23.295 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:23.295 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:23.295 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:23.295 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:23.413 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:23.413 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:23.413 | Historical data download ID 122305 not found when removing ID from outstanding request set.
2024-08-14 17:23:23.413 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:23.413 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:23.413 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:23.413 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:23.413 | Historical data download ID 122306 not found when removing ID from outstanding request set.
2024-08-14 17:23:23.413 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:23.413 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:23.413 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:23.413 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:23.413 | Historical data download ID 122307 not found when removing ID from outstanding request set.
2024-08-14 17:23:23.413 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:23.413 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:23.413 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:23.454 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:23.456 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:23.456 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:23.456 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:23.456 | DTC Client socket (4) | Closed.
2024-08-14 17:23:23.456 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:23.457 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:23.457 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:23.457 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:25.791 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:25.791 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:25.792 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:25.792 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:25.792 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:25.831 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:25.831 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:25.831 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:25.831 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:25.954 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:25.954 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:25.954 | Historical data download ID 122308 not found when removing ID from outstanding request set.
2024-08-14 17:23:25.954 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:25.954 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:25.954 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:25.954 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:25.954 | Historical data download ID 122309 not found when removing ID from outstanding request set.
2024-08-14 17:23:25.954 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:25.954 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:25.954 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:25.954 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:25.954 | Historical data download ID 122310 not found when removing ID from outstanding request set.
2024-08-14 17:23:25.954 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:25.954 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:25.954 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:25.997 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:25.999 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:25.999 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:23:26.000 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:26.000 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:23:26.000 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:23:26.000 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:23:26.000 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:26.000 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:26.000 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:26.040 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:23:26.040 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:26.040 | DTC Client socket (4) | Closed.
2024-08-14 17:23:27.779 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:27.779 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:23:27.797 | HD Server | Thread:21480 (4) | Creating socket.
2024-08-14 17:23:27.797 | HD Server | Thread:21480 (4) | New receive buffer size: 262144
2024-08-14 17:23:27.797 | HD Server | Thread:21480 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:27.797 | HD Server | Setting DTC encoding to Binary VLS | Thread:21480
2024-08-14 17:23:27.798 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:21480
2024-08-14 17:23:27.798 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:21480
2024-08-14 17:23:27.799 | HD Server | HD Request #4311 | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4311 | Username: DAVID SUDDUTH JR. | Thread:21480
2024-08-14 17:23:27.799 | HD Server | HD Request | Socket: 4 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4311 | Username: DAVID SUDDUTH JR. | Thread:21480
2024-08-14 17:23:27.799 | HD Server | Thread:21480 (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:27.799 | HD Server | Thread:21480 (4) | CloseSocket call.
2024-08-14 17:23:27.800 | HD Server | Thread:21480 (0) | CloseSocket call.
2024-08-14 17:23:27.800 | HD Server | Thread:21480 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:27.800 | HD Server | Thread:21480 (4) | Closed.
2024-08-14 17:23:27.862 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:27.862 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:23:27.873 | HD Server | Thread:8568 (4) | Creating socket.
2024-08-14 17:23:27.873 | HD Server | Thread:8568 (4) | New receive buffer size: 262144
2024-08-14 17:23:27.873 | HD Server | Thread:8568 (4) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:27.873 | HD Server | Setting DTC encoding to Binary VLS | Thread:8568
2024-08-14 17:23:27.874 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:8568
2024-08-14 17:23:27.874 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:8568
2024-08-14 17:23:27.874 | HD Server | HD Request #4312 | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4312 | Username: DAVID SUDDUTH JR. | Thread:8568
2024-08-14 17:23:27.875 | HD Server | HD Request | Socket: 4 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4312 | Username: DAVID SUDDUTH JR. | Thread:8568
2024-08-14 17:23:27.875 | HD Server | Thread:8568 (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:27.875 | HD Server | Thread:8568 (4) | CloseSocket call.
2024-08-14 17:23:27.875 | HD Server | Thread:8568 (0) | CloseSocket call.
2024-08-14 17:23:27.875 | HD Server | Thread:8568 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:27.875 | HD Server | Thread:8568 (4) | Closed.
2024-08-14 17:23:27.920 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:8568
2024-08-14 17:23:27.920 | HD Server Manager | Current server count=1
2024-08-14 17:23:27.920 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:21480
2024-08-14 17:23:27.920 | HD Server Manager | Current server count=0
2024-08-14 17:23:27.999 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:27.999 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:27.999 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:27.999 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:27.999 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:28.041 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:28.041 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:28.041 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:28.041 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:28.168 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:28.168 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:28.168 | Historical data download ID 122311 not found when removing ID from outstanding request set.
2024-08-14 17:23:28.168 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:28.168 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:28.168 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:28.168 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:28.168 | Historical data download ID 122312 not found when removing ID from outstanding request set.
2024-08-14 17:23:28.168 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:28.168 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:28.168 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:28.168 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:28.168 | Historical data download ID 122313 not found when removing ID from outstanding request set.
2024-08-14 17:23:28.168 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:28.168 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:28.168 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:28.211 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:28.242 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:28.242 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:23:28.242 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:28.242 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:28.242 | DTC Client socket (4) | Closed.
2024-08-14 17:23:28.243 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:28.243 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:28.243 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:28.243 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:30.238 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:30.238 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:30.239 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:30.239 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:30.239 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:30.346 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:30.346 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:30.346 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:30.346 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:30.370 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:30.371 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:23:30.388 | HD Server | Thread:5924 (5) | Creating socket.
2024-08-14 17:23:30.388 | HD Server | Thread:5924 (5) | New receive buffer size: 262144
2024-08-14 17:23:30.388 | HD Server | Thread:5924 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:30.388 | HD Server | Setting DTC encoding to Binary VLS | Thread:5924
2024-08-14 17:23:30.389 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:5924
2024-08-14 17:23:30.389 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:5924
2024-08-14 17:23:30.389 | HD Server | HD Request #4313 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4313 | Username: DAVID SUDDUTH JR. | Thread:5924
2024-08-14 17:23:30.390 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4313 | Username: DAVID SUDDUTH JR. | Thread:5924
2024-08-14 17:23:30.390 | HD Server | Thread:5924 (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:30.390 | HD Server | Thread:5924 (5) | CloseSocket call.
2024-08-14 17:23:30.390 | HD Server | Thread:5924 (0) | CloseSocket call.
2024-08-14 17:23:30.391 | HD Server | Thread:5924 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:30.391 | HD Server | Thread:5924 (5) | Closed.
2024-08-14 17:23:30.391 | HD Server | Thread:5924 (0) | CloseSocket call.
2024-08-14 17:23:30.394 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:5924
2024-08-14 17:23:30.394 | HD Server Manager | Current server count=0
2024-08-14 17:23:30.436 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:30.436 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:23:30.445 | HD Server | Thread:16328 (5) | Creating socket.
2024-08-14 17:23:30.445 | HD Server | Thread:16328 (5) | New receive buffer size: 262144
2024-08-14 17:23:30.445 | HD Server | Thread:16328 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:30.445 | HD Server | Setting DTC encoding to Binary VLS | Thread:16328
2024-08-14 17:23:30.446 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:16328
2024-08-14 17:23:30.446 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:16328
2024-08-14 17:23:30.446 | HD Server | HD Request #4314 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4314 | Username: DAVID SUDDUTH JR. | Thread:16328
2024-08-14 17:23:30.447 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4314 | Username: DAVID SUDDUTH JR. | Thread:16328
2024-08-14 17:23:30.447 | HD Server | Thread:16328 (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:30.447 | HD Server | Thread:16328 (5) | CloseSocket call.
2024-08-14 17:23:30.447 | HD Server | Thread:16328 (0) | CloseSocket call.
2024-08-14 17:23:30.447 | HD Server | Thread:16328 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:30.447 | HD Server | Thread:16328 (5) | Closed.
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:30.465 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:30.465 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:30.465 | Historical data download ID 122314 not found when removing ID from outstanding request set.
2024-08-14 17:23:30.465 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:30.465 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:30.465 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:30.465 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:30.465 | Historical data download ID 122315 not found when removing ID from outstanding request set.
2024-08-14 17:23:30.465 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:30.465 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:30.465 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:30.465 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:30.465 | Historical data download ID 122316 not found when removing ID from outstanding request set.
2024-08-14 17:23:30.465 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:30.465 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:30.465 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:30.507 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:30.510 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:30.510 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:23:30.510 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:30.510 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:30.510 | DTC Client socket (4) | Closed.
2024-08-14 17:23:30.510 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:30.510 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:30.510 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:30.510 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:30.676 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:16328
2024-08-14 17:23:30.676 | HD Server Manager | Current server count=0
2024-08-14 17:23:32.511 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:32.511 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:32.554 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:32.554 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:32.554 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:32.592 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:32.592 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:32.592 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:32.592 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:32.715 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:32.715 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:32.715 | Historical data download ID 122317 not found when removing ID from outstanding request set.
2024-08-14 17:23:32.715 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:32.715 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:32.715 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:32.715 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:32.715 | Historical data download ID 122318 not found when removing ID from outstanding request set.
2024-08-14 17:23:32.715 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:32.715 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:32.715 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:32.715 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:32.715 | Historical data download ID 122319 not found when removing ID from outstanding request set.
2024-08-14 17:23:32.715 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:32.715 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:32.715 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:32.755 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:32.769 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:32.769 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:32.769 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:32.769 | DTC Client socket (4) | Closed.
2024-08-14 17:23:32.769 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:32.769 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:32.769 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:34.853 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:34.853 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:34.995 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:34.995 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:34.995 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:35.033 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:35.033 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:35.033 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:35.033 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:35.158 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:35.158 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:35.158 | Historical data download ID 122320 not found when removing ID from outstanding request set.
2024-08-14 17:23:35.158 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:35.158 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:35.158 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:35.158 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:35.158 | Historical data download ID 122321 not found when removing ID from outstanding request set.
2024-08-14 17:23:35.158 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:35.158 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:35.158 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:35.158 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:35.158 | Historical data download ID 122322 not found when removing ID from outstanding request set.
2024-08-14 17:23:35.158 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:35.158 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:35.158 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:35.201 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:35.205 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:35.205 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:23:35.205 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:35.205 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:35.205 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:35.205 | DTC Client socket (4) | Closed.
2024-08-14 17:23:35.205 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:35.205 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:35.205 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:37.209 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:37.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:37.210 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:37.210 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:37.210 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:37.253 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:37.253 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:37.253 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:37.253 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:37.379 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:37.379 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:37.379 | Historical data download ID 122323 not found when removing ID from outstanding request set.
2024-08-14 17:23:37.379 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:37.379 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:37.379 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:37.379 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:37.379 | Historical data download ID 122324 not found when removing ID from outstanding request set.
2024-08-14 17:23:37.379 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:37.379 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:37.379 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:37.379 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:37.379 | Historical data download ID 122325 not found when removing ID from outstanding request set.
2024-08-14 17:23:37.379 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:37.379 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:37.379 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:37.421 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:37.421 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:37.421 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:23:37.422 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:37.422 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:37.422 | DTC Client socket (4) | Closed.
2024-08-14 17:23:37.422 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:37.422 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:37.422 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:39.420 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:39.420 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:39.421 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:39.421 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:39.421 | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:39.460 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:39.460 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:39.460 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:39.460 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:39.583 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:39.583 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:39.583 | Historical data download ID 122326 not found when removing ID from outstanding request set.
2024-08-14 17:23:39.583 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:39.583 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:39.583 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:39.583 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:39.583 | Historical data download ID 122327 not found when removing ID from outstanding request set.
2024-08-14 17:23:39.583 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:39.583 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:39.583 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:39.583 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:39.583 | Historical data download ID 122328 not found when removing ID from outstanding request set.
2024-08-14 17:23:39.583 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:39.583 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:39.583 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:39.626 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:39.642 | DTC Client socket (4) | CloseSocket call.
2024-08-14 17:23:39.642 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:23:39.642 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-08-14 17:23:39.643 | DTC Client socket (4) | Max send buffers used during socket life: 3
2024-08-14 17:23:39.643 | DTC Client socket (4) | Max send buffer size during socket life: 735
2024-08-14 17:23:39.643 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:23:39.643 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:39.643 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:39.643 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:39.684 | DTC Client socket (4) | Write has completed. Shutdown being performed.
2024-08-14 17:23:39.684 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:39.684 | DTC Client socket (4) | Closed.
2024-08-14 17:23:40.293 | Chat: Chat Window created. Connecting to server.
2024-08-14 17:23:40.296 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-08-14 17:23:40.379 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:40.379 | DTC Client socket (4) | New receive buffer size: 0
2024-08-14 17:23:40.379 | DTC Client socket (4) | Connecting to IP: 67.214.125.8.
2024-08-14 17:23:40.424 | Chat | Network connection to server complete.
2024-08-14 17:23:40.424 | Chat | Starting socket receive thread.
2024-08-14 17:23:40.424 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-08-14 17:23:40.572 | Chat | Setting DTC encoding to Binary VLS
2024-08-14 17:23:40.572 | Chat | Sending logon request message.
2024-08-14 17:23:41.093 | Chat | Received logon response.
2024-08-14 17:23:41.093 | Chat | Server Name: SC DTC Server. Build=50899M.
2024-08-14 17:23:41.093 | Chat | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:41.093 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-08-14 17:23:41.093 | Chat | Trading is not supported.
2024-08-14 17:23:41.093 | Chat | MarketDepthIsSupported: 1
2024-08-14 17:23:41.651 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:41.651 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:41.651 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:41.651 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:41.651 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:41.690 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:41.690 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:41.690 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:41.690 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:41.845 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:41.845 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:41.845 | Historical data download ID 122329 not found when removing ID from outstanding request set.
2024-08-14 17:23:41.845 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:41.845 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:41.845 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:41.845 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:41.845 | Historical data download ID 122330 not found when removing ID from outstanding request set.
2024-08-14 17:23:41.845 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:41.845 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:41.845 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:41.845 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:41.845 | Historical data download ID 122331 not found when removing ID from outstanding request set.
2024-08-14 17:23:41.845 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:41.845 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:41.845 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:41.885 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:41.887 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:41.887 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:23:41.887 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:23:41.887 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=280
2024-08-14 17:23:41.887 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:41.887 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:41.887 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:41.887 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:41.927 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:23:41.927 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:41.927 | DTC Client socket (5) | Closed.
2024-08-14 17:23:43.881 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:43.881 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:43.881 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:43.882 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:43.882 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:43.920 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:43.920 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:43.920 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:43.920 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:44.042 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:44.042 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:44.042 | Historical data download ID 122332 not found when removing ID from outstanding request set.
2024-08-14 17:23:44.042 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:44.042 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:44.042 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:44.042 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:44.042 | Historical data download ID 122333 not found when removing ID from outstanding request set.
2024-08-14 17:23:44.042 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:44.042 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:44.042 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:44.042 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:44.042 | Historical data download ID 122334 not found when removing ID from outstanding request set.
2024-08-14 17:23:44.042 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:44.042 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:44.042 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:44.084 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:44.086 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:44.086 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:44.086 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:44.086 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:44.086 | DTC Client socket (5) | Closed.
2024-08-14 17:23:44.086 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:44.086 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:44.086 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:44.086 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:46.084 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:46.084 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:46.085 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:46.085 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:46.085 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:46.122 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:46.122 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:46.122 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:46.122 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:46.254 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:46.254 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:46.254 | Historical data download ID 122335 not found when removing ID from outstanding request set.
2024-08-14 17:23:46.254 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:46.254 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:46.254 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:46.254 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:46.254 | Historical data download ID 122336 not found when removing ID from outstanding request set.
2024-08-14 17:23:46.254 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:46.254 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:46.254 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:46.254 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:46.254 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:46.255 | Historical data download ID 122337 not found when removing ID from outstanding request set.
2024-08-14 17:23:46.255 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:46.255 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:46.255 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:46.296 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:46.302 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:46.302 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:23:46.302 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:23:46.303 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:46.303 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:46.303 | DTC Client socket (5) | Closed.
2024-08-14 17:23:46.303 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:46.303 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:46.303 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:48.347 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:48.347 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:48.348 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:48.348 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:48.348 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:48.386 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:48.386 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:48.386 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:48.386 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:48.511 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:48.511 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:48.511 | Historical data download ID 122338 not found when removing ID from outstanding request set.
2024-08-14 17:23:48.511 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:48.511 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:48.511 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:48.511 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:48.511 | Historical data download ID 122339 not found when removing ID from outstanding request set.
2024-08-14 17:23:48.511 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:48.511 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:48.511 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:48.511 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:48.511 | Historical data download ID 122340 not found when removing ID from outstanding request set.
2024-08-14 17:23:48.511 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:48.511 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:48.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:48.555 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:48.558 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:48.559 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:48.559 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:48.559 | DTC Client socket (5) | Closed.
2024-08-14 17:23:48.559 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:48.559 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:48.559 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:48.559 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:50.563 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:50.563 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:50.563 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:50.564 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:50.564 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:50.601 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:50.601 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:50.601 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:50.601 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:50.723 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:50.723 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:50.723 | Historical data download ID 122341 not found when removing ID from outstanding request set.
2024-08-14 17:23:50.723 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:50.723 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:50.723 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:50.723 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:50.723 | Historical data download ID 122342 not found when removing ID from outstanding request set.
2024-08-14 17:23:50.723 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:50.723 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:50.723 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:50.723 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:50.723 | Historical data download ID 122343 not found when removing ID from outstanding request set.
2024-08-14 17:23:50.723 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:50.723 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:50.723 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:50.765 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:50.788 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:50.788 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:23:50.788 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:50.788 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:23:50.788 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:23:50.788 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:50.788 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:50.789 | DTC Client socket (5) | Closed.
2024-08-14 17:23:50.789 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:50.789 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:50.789 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:52.850 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:52.850 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:52.851 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:52.851 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:52.851 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:52.890 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:52.890 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:52.890 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:52.890 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:53.013 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:53.013 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:53.013 | Historical data download ID 122344 not found when removing ID from outstanding request set.
2024-08-14 17:23:53.013 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:53.013 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:53.013 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:53.013 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:53.013 | Historical data download ID 122345 not found when removing ID from outstanding request set.
2024-08-14 17:23:53.013 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:53.013 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:53.013 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:53.013 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:53.013 | Historical data download ID 122346 not found when removing ID from outstanding request set.
2024-08-14 17:23:53.013 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:53.013 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:53.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:53.054 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:53.059 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:53.059 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:23:53.059 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:53.059 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:53.059 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:53.059 | DTC Client socket (5) | Closed.
2024-08-14 17:23:53.059 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:53.059 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:53.059 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:55.059 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:55.059 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:55.060 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:55.060 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:55.060 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:55.100 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:55.100 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:55.100 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:55.100 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:55.223 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:55.223 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:55.223 | Historical data download ID 122347 not found when removing ID from outstanding request set.
2024-08-14 17:23:55.223 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:55.223 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:55.223 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:55.223 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:55.223 | Historical data download ID 122348 not found when removing ID from outstanding request set.
2024-08-14 17:23:55.223 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:55.223 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:55.223 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:55.223 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:55.223 | Historical data download ID 122349 not found when removing ID from outstanding request set.
2024-08-14 17:23:55.223 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:55.223 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:55.223 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:55.265 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:55.272 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:55.272 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:23:55.272 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:23:55.272 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:23:55.272 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:55.272 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:55.272 | DTC Client socket (5) | Closed.
2024-08-14 17:23:55.272 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:55.272 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:55.272 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:55.272 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:55.790 | Chat: Chat is not selected. *
2024-08-14 17:23:57.401 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:57.401 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:57.401 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:57.401 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:23:57.401 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:57.440 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:57.440 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:57.440 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:57.440 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:57.561 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:57.561 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:57.561 | Historical data download ID 122350 not found when removing ID from outstanding request set.
2024-08-14 17:23:57.561 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:57.561 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:57.561 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:57.561 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:57.561 | Historical data download ID 122351 not found when removing ID from outstanding request set.
2024-08-14 17:23:57.561 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:57.561 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:57.561 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:57.561 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:57.561 | Historical data download ID 122352 not found when removing ID from outstanding request set.
2024-08-14 17:23:57.561 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:57.561 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:57.561 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:57.604 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:57.615 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:23:57.615 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:23:57.615 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:23:57.615 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:57.615 | DTC Client socket (5) | Closed.
2024-08-14 17:23:57.615 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:57.616 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:57.616 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:57.616 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:59.595 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:59.595 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:23:59.613 | HD Server | Thread:20908 (5) | Creating socket.
2024-08-14 17:23:59.613 | HD Server | Thread:20908 (5) | New receive buffer size: 262144
2024-08-14 17:23:59.613 | HD Server | Thread:20908 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:59.614 | HD Server | Setting DTC encoding to Binary VLS | Thread:20908
2024-08-14 17:23:59.614 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:20908
2024-08-14 17:23:59.614 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:20908
2024-08-14 17:23:59.614 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:23:59.614 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:23:59.615 | HD Server | HD Request #4315 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4315 | Username: DAVID SUDDUTH JR. | Thread:20908
2024-08-14 17:23:59.615 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2024-08-14 17:23:59.615 | DTC Client socket (6) | New receive buffer size: 0
2024-08-14 17:23:59.615 | DTC Client socket (6) | Connecting to IP: 216.57.156.163.
2024-08-14 17:23:59.615 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4315 | Username: DAVID SUDDUTH JR. | Thread:20908
2024-08-14 17:23:59.616 | HD Server | Thread:20908 (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:59.616 | HD Server | Thread:20908 (5) | CloseSocket call.
2024-08-14 17:23:59.616 | HD Server | Thread:20908 (0) | CloseSocket call.
2024-08-14 17:23:59.616 | HD Server | Thread:20908 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:59.616 | HD Server | Thread:20908 (5) | Closed.
2024-08-14 17:23:59.618 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:59.619 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:23:59.631 | HD Server | Thread:12152 (5) | Creating socket.
2024-08-14 17:23:59.631 | HD Server | Thread:12152 (5) | New receive buffer size: 262144
2024-08-14 17:23:59.631 | HD Server | Thread:12152 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:59.631 | HD Server | Setting DTC encoding to Binary VLS | Thread:12152
2024-08-14 17:23:59.632 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:12152
2024-08-14 17:23:59.632 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:12152
2024-08-14 17:23:59.633 | HD Server | HD Request #4316 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4316 | Username: DAVID SUDDUTH JR. | Thread:12152
2024-08-14 17:23:59.633 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4316 | Username: DAVID SUDDUTH JR. | Thread:12152
2024-08-14 17:23:59.633 | HD Server | Thread:12152 (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:59.634 | HD Server | Thread:12152 (5) | CloseSocket call.
2024-08-14 17:23:59.634 | HD Server | Thread:12152 (0) | CloseSocket call.
2024-08-14 17:23:59.634 | HD Server | Thread:12152 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:59.634 | HD Server | Thread:12152 (5) | Closed.
2024-08-14 17:23:59.652 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:23:59.652 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:23:59.652 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:23:59.652 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:23:59.775 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:12152
2024-08-14 17:23:59.775 | HD Server Manager | Current server count=1
2024-08-14 17:23:59.775 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:20908
2024-08-14 17:23:59.775 | HD Server Manager | Current server count=0
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:23:59.775 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:23:59.775 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:23:59.775 | Historical data download ID 122353 not found when removing ID from outstanding request set.
2024-08-14 17:23:59.775 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:23:59.775 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:23:59.775 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:23:59.775 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:23:59.775 | Historical data download ID 122354 not found when removing ID from outstanding request set.
2024-08-14 17:23:59.775 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:23:59.775 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:23:59.775 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:23:59.775 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:23:59.775 | Historical data download ID 122355 not found when removing ID from outstanding request set.
2024-08-14 17:23:59.775 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:23:59.775 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:23:59.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:23:59.791 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:59.791 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:23:59.807 | HD Server | Thread:21392 (5) | Creating socket.
2024-08-14 17:23:59.807 | HD Server | Thread:21392 (5) | New receive buffer size: 262144
2024-08-14 17:23:59.807 | HD Server | Thread:21392 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:59.807 | HD Server | Setting DTC encoding to Binary VLS | Thread:21392
2024-08-14 17:23:59.808 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:21392
2024-08-14 17:23:59.808 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:21392
2024-08-14 17:23:59.808 | HD Server | HD Request #4317 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4317 | Username: DAVID SUDDUTH JR. | Thread:21392
2024-08-14 17:23:59.808 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4317 | Username: DAVID SUDDUTH JR. | Thread:21392
2024-08-14 17:23:59.809 | HD Server | Thread:21392 (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:59.809 | HD Server | Thread:21392 (5) | CloseSocket call.
2024-08-14 17:23:59.809 | HD Server | Thread:21392 (0) | CloseSocket call.
2024-08-14 17:23:59.810 | HD Server | Thread:21392 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:59.810 | HD Server | Thread:21392 (5) | Closed.
2024-08-14 17:23:59.810 | HD Server | Thread:21392 (0) | CloseSocket call.
2024-08-14 17:23:59.818 | DTC Client socket (6) | Socket gracefully closed by remote side.
2024-08-14 17:23:59.837 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:23:59.837 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:23:59.837 | DTC Client socket (6) | CloseSocket call.
2024-08-14 17:23:59.837 | DTC Client socket (6) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:23:59.837 | DTC Client socket (6) | Socket gracefully closed by remote side.
2024-08-14 17:23:59.839 | DTC Client socket (6) | Max send buffers used during socket life: 3
2024-08-14 17:23:59.839 | DTC Client socket (6) | Max send buffer size during socket life: 735
2024-08-14 17:23:59.839 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:59.839 | DTC Client socket (6) | Closed.
2024-08-14 17:23:59.842 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:23:59.842 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:23:59.843 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:23:59.847 | HD Server | Thread:6084 (5) | Creating socket.
2024-08-14 17:23:59.847 | HD Server | Thread:6084 (5) | New receive buffer size: 262144
2024-08-14 17:23:59.847 | HD Server | Thread:6084 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:23:59.847 | HD Server | Setting DTC encoding to Binary VLS | Thread:6084
2024-08-14 17:23:59.847 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:6084
2024-08-14 17:23:59.847 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:6084
2024-08-14 17:23:59.848 | HD Server | HD Request #4318 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4318 | Username: DAVID SUDDUTH JR. | Thread:6084
2024-08-14 17:23:59.848 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4318 | Username: DAVID SUDDUTH JR. | Thread:6084
2024-08-14 17:23:59.849 | HD Server | Thread:6084 (5) | Socket gracefully closed by remote side.
2024-08-14 17:23:59.849 | HD Server | Thread:6084 (5) | CloseSocket call.
2024-08-14 17:23:59.849 | HD Server | Thread:6084 (0) | CloseSocket call.
2024-08-14 17:23:59.849 | HD Server | Thread:6084 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:23:59.849 | HD Server | Thread:6084 (5) | Closed.
2024-08-14 17:24:00.104 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:6084
2024-08-14 17:24:00.105 | HD Server Manager | Current server count=1
2024-08-14 17:24:00.105 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:21392
2024-08-14 17:24:00.105 | HD Server Manager | Current server count=0
2024-08-14 17:24:01.709 | Chat: Contact is not selected. *
2024-08-14 17:24:01.856 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:01.856 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:01.857 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:01.857 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:01.857 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:01.895 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:01.895 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:01.895 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:01.895 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:02.029 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:02.029 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:02.029 | Historical data download ID 122356 not found when removing ID from outstanding request set.
2024-08-14 17:24:02.029 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:02.029 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:02.029 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:02.029 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:02.029 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:02.029 | Historical data download ID 122357 not found when removing ID from outstanding request set.
2024-08-14 17:24:02.029 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:02.030 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:02.030 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:02.030 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:02.030 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:02.030 | Historical data download ID 122358 not found when removing ID from outstanding request set.
2024-08-14 17:24:02.030 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:02.030 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:02.030 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:02.072 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:02.077 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:02.077 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:24:02.077 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:02.077 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:02.077 | DTC Client socket (5) | Closed.
2024-08-14 17:24:02.077 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:02.077 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:02.077 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:02.077 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:02.427 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:24:02.428 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:24:02.438 | HD Server | Thread:13268 (5) | Creating socket.
2024-08-14 17:24:02.438 | HD Server | Thread:13268 (5) | New receive buffer size: 262144
2024-08-14 17:24:02.439 | HD Server | Thread:13268 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:24:02.439 | HD Server | Setting DTC encoding to Binary VLS | Thread:13268
2024-08-14 17:24:02.439 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:13268
2024-08-14 17:24:02.439 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:13268
2024-08-14 17:24:02.440 | HD Server | HD Request #4319 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4319 | Username: DAVID SUDDUTH JR. | Thread:13268
2024-08-14 17:24:02.440 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4319 | Username: DAVID SUDDUTH JR. | Thread:13268
2024-08-14 17:24:02.440 | HD Server | Thread:13268 (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:02.440 | HD Server | Thread:13268 (5) | CloseSocket call.
2024-08-14 17:24:02.441 | HD Server | Thread:13268 (0) | CloseSocket call.
2024-08-14 17:24:02.441 | HD Server | Thread:13268 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:02.441 | HD Server | Thread:13268 (5) | Closed.
2024-08-14 17:24:02.443 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:24:02.443 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:24:02.458 | HD Server | Thread:15820 (5) | Creating socket.
2024-08-14 17:24:02.458 | HD Server | Thread:15820 (5) | New receive buffer size: 262144
2024-08-14 17:24:02.458 | HD Server | Thread:15820 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:24:02.460 | HD Server | Setting DTC encoding to Binary VLS | Thread:15820
2024-08-14 17:24:02.461 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:15820
2024-08-14 17:24:02.461 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:15820
2024-08-14 17:24:02.461 | HD Server | HD Request #4320 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4320 | Username: DAVID SUDDUTH JR. | Thread:15820
2024-08-14 17:24:02.462 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4320 | Username: DAVID SUDDUTH JR. | Thread:15820
2024-08-14 17:24:02.462 | HD Server | Thread:15820 (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:02.462 | HD Server | Thread:15820 (5) | CloseSocket call.
2024-08-14 17:24:02.462 | HD Server | Thread:15820 (0) | CloseSocket call.
2024-08-14 17:24:02.462 | HD Server | Thread:15820 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:02.462 | HD Server | Thread:15820 (5) | Closed.
2024-08-14 17:24:02.463 | HD Server | Thread:15820 (0) | CloseSocket call.
2024-08-14 17:24:02.715 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:15820
2024-08-14 17:24:02.715 | HD Server Manager | Current server count=1
2024-08-14 17:24:02.715 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:13268
2024-08-14 17:24:02.715 | HD Server Manager | Current server count=0
2024-08-14 17:24:04.077 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:04.077 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:04.077 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:04.077 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:04.077 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:04.115 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:04.115 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:04.116 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:04.116 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:04.238 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:04.238 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:04.238 | Historical data download ID 122359 not found when removing ID from outstanding request set.
2024-08-14 17:24:04.238 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:04.238 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:04.238 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:04.238 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:04.238 | Historical data download ID 122360 not found when removing ID from outstanding request set.
2024-08-14 17:24:04.238 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:04.238 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:04.238 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:04.238 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:04.238 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:04.239 | Historical data download ID 122361 not found when removing ID from outstanding request set.
2024-08-14 17:24:04.239 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:04.239 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:04.239 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:04.281 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:04.297 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:04.297 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:24:04.297 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:04.297 | DTC Client socket (5) | Closed.
2024-08-14 17:24:04.297 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:04.297 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:04.298 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:04.298 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:04.298 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:06.369 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:06.369 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:06.369 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:06.369 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:06.369 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:06.407 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:06.407 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:06.407 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:06.407 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:06.531 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:06.531 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:06.531 | Historical data download ID 122362 not found when removing ID from outstanding request set.
2024-08-14 17:24:06.531 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:06.531 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:06.531 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:06.531 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:06.531 | Historical data download ID 122363 not found when removing ID from outstanding request set.
2024-08-14 17:24:06.531 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:06.531 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:06.531 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:06.531 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:06.531 | Historical data download ID 122364 not found when removing ID from outstanding request set.
2024-08-14 17:24:06.531 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:06.531 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:06.531 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:06.575 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:06.577 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:06.577 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:24:06.577 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:06.578 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:06.578 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:06.578 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:06.578 | DTC Client socket (5) | Closed.
2024-08-14 17:24:06.578 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:06.578 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:06.578 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:08.568 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:08.568 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:08.569 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:08.569 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:08.569 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:08.611 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:08.611 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:08.611 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:08.611 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:08.745 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:08.745 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:08.745 | Historical data download ID 122365 not found when removing ID from outstanding request set.
2024-08-14 17:24:08.745 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:08.745 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:08.745 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:08.745 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:08.745 | Historical data download ID 122366 not found when removing ID from outstanding request set.
2024-08-14 17:24:08.745 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:08.745 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:08.745 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:08.745 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:08.745 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:08.746 | Historical data download ID 122367 not found when removing ID from outstanding request set.
2024-08-14 17:24:08.746 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:08.746 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:08.746 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:08.787 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:08.793 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:08.793 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:08.793 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:08.793 | DTC Client socket (5) | Closed.
2024-08-14 17:24:08.793 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:08.793 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:08.793 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:10.851 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:10.851 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:10.852 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:10.852 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:10.852 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:10.889 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:10.889 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:10.889 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:10.889 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:11.022 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:11.022 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:11.022 | Historical data download ID 122368 not found when removing ID from outstanding request set.
2024-08-14 17:24:11.022 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:11.022 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:11.022 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:11.022 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:11.022 | Historical data download ID 122369 not found when removing ID from outstanding request set.
2024-08-14 17:24:11.022 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:11.022 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:11.022 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:11.022 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:11.022 | Historical data download ID 122370 not found when removing ID from outstanding request set.
2024-08-14 17:24:11.022 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:11.022 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:11.022 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:11.064 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:11.068 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:11.068 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:11.068 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:11.068 | DTC Client socket (5) | Closed.
2024-08-14 17:24:11.068 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:11.068 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:11.068 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:13.076 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:13.076 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:13.076 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:13.076 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:13.076 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:13.112 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:13.112 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:13.112 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:13.112 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:13.236 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:13.236 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:13.236 | Historical data download ID 122371 not found when removing ID from outstanding request set.
2024-08-14 17:24:13.236 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:13.236 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:13.236 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:13.236 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:13.236 | Historical data download ID 122372 not found when removing ID from outstanding request set.
2024-08-14 17:24:13.236 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:13.236 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:13.236 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:13.236 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:13.236 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:13.237 | Historical data download ID 122373 not found when removing ID from outstanding request set.
2024-08-14 17:24:13.237 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:13.237 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:13.237 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:13.279 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:13.296 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:13.296 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:24:13.296 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:13.296 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:13.296 | DTC Client socket (5) | Closed.
2024-08-14 17:24:13.296 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:13.296 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:13.296 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:13.296 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:15.394 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:15.395 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:15.395 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:15.395 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:15.395 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:15.433 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:15.433 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:15.433 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:15.433 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:15.569 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:15.569 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:15.569 | Historical data download ID 122374 not found when removing ID from outstanding request set.
2024-08-14 17:24:15.569 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:15.569 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:15.569 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:15.569 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:15.569 | Historical data download ID 122375 not found when removing ID from outstanding request set.
2024-08-14 17:24:15.569 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:15.569 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:15.569 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:15.569 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:15.569 | Historical data download ID 122376 not found when removing ID from outstanding request set.
2024-08-14 17:24:15.569 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:15.569 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:15.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:15.610 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:15.615 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:15.615 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:15.615 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:15.615 | DTC Client socket (5) | Closed.
2024-08-14 17:24:15.615 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:15.615 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:15.615 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:17.621 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:17.621 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:17.621 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:17.621 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:17.621 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:17.662 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:17.662 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:17.662 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:17.662 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:17.798 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:17.798 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:17.798 | Historical data download ID 122377 not found when removing ID from outstanding request set.
2024-08-14 17:24:17.798 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:17.798 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:17.798 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:17.798 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:17.798 | Historical data download ID 122378 not found when removing ID from outstanding request set.
2024-08-14 17:24:17.798 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:17.798 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:17.798 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:17.798 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:17.798 | Historical data download ID 122379 not found when removing ID from outstanding request set.
2024-08-14 17:24:17.798 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:17.798 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:17.798 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:17.837 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:17.841 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:17.841 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:17.841 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:17.841 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:17.841 | DTC Client socket (5) | Closed.
2024-08-14 17:24:17.841 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:17.841 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:17.841 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:17.841 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:19.872 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:19.872 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:19.873 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:19.873 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:19.873 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:19.912 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:19.912 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:19.912 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:19.912 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:20.039 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:20.039 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:20.039 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:20.039 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:20.039 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:20.039 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:20.039 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:20.039 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:20.039 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:20.040 | Historical data download ID 122380 not found when removing ID from outstanding request set.
2024-08-14 17:24:20.040 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:20.040 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:20.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:20.040 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:20.040 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:20.040 | Historical data download ID 122381 not found when removing ID from outstanding request set.
2024-08-14 17:24:20.040 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:20.040 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:20.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:20.040 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:20.040 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:20.040 | Historical data download ID 122382 not found when removing ID from outstanding request set.
2024-08-14 17:24:20.040 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:20.040 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:20.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:20.082 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:20.107 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:20.107 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:24:20.107 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:20.107 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:20.108 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:20.108 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:20.108 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:24:20.108 | DTC Client socket (5) | Closed.
2024-08-14 17:24:20.108 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:20.108 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:20.108 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:22.099 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:22.099 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:22.100 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:22.100 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:22.100 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:22.147 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:22.147 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:22.147 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:22.147 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:22.275 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:22.275 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:22.275 | Historical data download ID 122383 not found when removing ID from outstanding request set.
2024-08-14 17:24:22.275 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:22.275 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:22.275 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:22.275 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:22.275 | Historical data download ID 122384 not found when removing ID from outstanding request set.
2024-08-14 17:24:22.275 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:22.275 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:22.275 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:22.275 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:22.275 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:22.276 | Historical data download ID 122385 not found when removing ID from outstanding request set.
2024-08-14 17:24:22.276 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:22.276 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:22.276 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:22.318 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:22.327 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:22.327 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:22.327 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:22.327 | DTC Client socket (5) | Closed.
2024-08-14 17:24:22.327 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:22.328 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:22.328 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:24.352 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:24.352 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:24.353 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:24.353 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:24.353 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:24.396 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:24.396 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:24.396 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:24.396 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:24.520 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:24.520 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:24.520 | Historical data download ID 122386 not found when removing ID from outstanding request set.
2024-08-14 17:24:24.520 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:24.520 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:24.520 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:24.520 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:24.520 | Historical data download ID 122387 not found when removing ID from outstanding request set.
2024-08-14 17:24:24.520 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:24.520 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:24.520 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:24.520 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:24.520 | Historical data download ID 122388 not found when removing ID from outstanding request set.
2024-08-14 17:24:24.520 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:24.520 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:24.520 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:24.562 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:24.567 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:24.567 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 144
2024-08-14 17:24:24.567 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:24.568 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:24.568 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:24.568 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:24.568 | DTC Client socket (5) | Closed.
2024-08-14 17:24:24.568 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:24.568 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:24.568 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:26.574 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:26.574 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:26.574 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:26.574 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:26.574 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:26.612 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:26.612 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:26.612 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:26.612 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:26.738 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:26.738 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:26.738 | Historical data download ID 122389 not found when removing ID from outstanding request set.
2024-08-14 17:24:26.738 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:26.738 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:26.738 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:26.738 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:26.738 | Historical data download ID 122390 not found when removing ID from outstanding request set.
2024-08-14 17:24:26.738 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:26.738 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:26.738 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:26.738 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:26.738 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:26.739 | Historical data download ID 122391 not found when removing ID from outstanding request set.
2024-08-14 17:24:26.739 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:26.739 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:26.739 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:26.780 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:26.781 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:26.781 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:26.781 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:26.781 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:26.781 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:26.781 | DTC Client socket (5) | Closed.
2024-08-14 17:24:26.782 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:26.782 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:26.782 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:28.775 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:28.775 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:28.775 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:28.775 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:28.775 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:28.825 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:28.826 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:28.826 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:28.826 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:28.940 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:28.940 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:28.940 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:28.940 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:28.940 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:28.940 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:28.940 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:28.940 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:28.940 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:28.940 | Historical data download ID 122392 not found when removing ID from outstanding request set.
2024-08-14 17:24:28.940 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:28.940 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:28.941 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:28.941 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:28.941 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:28.941 | Historical data download ID 122393 not found when removing ID from outstanding request set.
2024-08-14 17:24:28.941 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:28.941 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:28.941 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:28.941 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:28.941 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:28.941 | Historical data download ID 122394 not found when removing ID from outstanding request set.
2024-08-14 17:24:28.941 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:28.941 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:28.941 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:28.988 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:28.991 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:24:28.991 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:28.991 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:28.991 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:28.991 | DTC Client socket (5) | Closed.
2024-08-14 17:24:28.992 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:28.992 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:28.992 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:31.039 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:31.039 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:31.040 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:31.040 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:31.040 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:31.074 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:31.074 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:31.075 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:31.075 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:31.205 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:31.205 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:31.205 | Historical data download ID 122395 not found when removing ID from outstanding request set.
2024-08-14 17:24:31.205 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:31.205 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:31.205 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:31.205 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:31.205 | Historical data download ID 122396 not found when removing ID from outstanding request set.
2024-08-14 17:24:31.205 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:31.205 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:31.205 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:31.205 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:31.205 | Historical data download ID 122397 not found when removing ID from outstanding request set.
2024-08-14 17:24:31.205 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:31.205 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:31.205 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:31.247 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:31.249 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:31.249 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:31.249 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:31.249 | DTC Client socket (5) | Closed.
2024-08-14 17:24:31.250 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:31.250 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:31.250 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:31.568 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:24:31.568 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:24:31.584 | HD Server | Thread:3260 (5) | Creating socket.
2024-08-14 17:24:31.584 | HD Server | Thread:3260 (5) | New receive buffer size: 262144
2024-08-14 17:24:31.584 | HD Server | Thread:3260 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:24:31.584 | HD Server | Setting DTC encoding to Binary VLS | Thread:3260
2024-08-14 17:24:31.585 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:3260
2024-08-14 17:24:31.585 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:3260
2024-08-14 17:24:31.585 | HD Server | HD Request #4321 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4321 | Username: DAVID SUDDUTH JR. | Thread:3260
2024-08-14 17:24:31.586 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4321 | Username: DAVID SUDDUTH JR. | Thread:3260
2024-08-14 17:24:31.586 | HD Server | Thread:3260 (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:31.586 | HD Server | Thread:3260 (5) | CloseSocket call.
2024-08-14 17:24:31.586 | HD Server | Thread:3260 (0) | CloseSocket call.
2024-08-14 17:24:31.586 | HD Server | Thread:3260 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:31.586 | HD Server | Thread:3260 (5) | Closed.
2024-08-14 17:24:31.589 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:3260
2024-08-14 17:24:31.589 | HD Server Manager | Current server count=0
2024-08-14 17:24:31.596 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:24:31.597 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:24:31.609 | HD Server | Thread:19580 (5) | Creating socket.
2024-08-14 17:24:31.609 | HD Server | Thread:19580 (5) | New receive buffer size: 262144
2024-08-14 17:24:31.609 | HD Server | Thread:19580 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:24:31.609 | HD Server | Setting DTC encoding to Binary VLS | Thread:19580
2024-08-14 17:24:31.610 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:19580
2024-08-14 17:24:31.610 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:19580
2024-08-14 17:24:31.610 | HD Server | HD Request #4322 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4322 | Username: DAVID SUDDUTH JR. | Thread:19580
2024-08-14 17:24:31.610 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4322 | Username: DAVID SUDDUTH JR. | Thread:19580
2024-08-14 17:24:31.611 | HD Server | Thread:19580 (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:31.611 | HD Server | Thread:19580 (5) | CloseSocket call.
2024-08-14 17:24:31.611 | HD Server | Thread:19580 (0) | CloseSocket call.
2024-08-14 17:24:31.611 | HD Server | Thread:19580 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:31.611 | HD Server | Thread:19580 (5) | Closed.
2024-08-14 17:24:31.675 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:19580
2024-08-14 17:24:31.675 | HD Server Manager | Current server count=0
2024-08-14 17:24:33.247 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:33.247 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:33.248 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:33.248 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:33.248 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:33.286 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:33.286 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:33.286 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:33.286 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:33.419 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:33.419 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:33.419 | Historical data download ID 122398 not found when removing ID from outstanding request set.
2024-08-14 17:24:33.419 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:33.419 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:33.419 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:33.419 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:33.419 | Historical data download ID 122399 not found when removing ID from outstanding request set.
2024-08-14 17:24:33.419 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:33.419 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:33.419 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:33.419 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:33.419 | Historical data download ID 122400 not found when removing ID from outstanding request set.
2024-08-14 17:24:33.419 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:33.419 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:33.419 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:33.460 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:33.463 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:24:33.464 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:33.464 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:33.464 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:33.464 | DTC Client socket (5) | Closed.
2024-08-14 17:24:33.464 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:33.464 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:33.464 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:33.996 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:24:33.996 | HD Server Manager | Started new historical data server. Count=1
2024-08-14 17:24:34.006 | HD Server | Thread:4624 (5) | Creating socket.
2024-08-14 17:24:34.006 | HD Server | Thread:4624 (5) | New receive buffer size: 262144
2024-08-14 17:24:34.006 | HD Server | Thread:4624 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:24:34.006 | HD Server | Setting DTC encoding to Binary VLS | Thread:4624
2024-08-14 17:24:34.007 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:4624
2024-08-14 17:24:34.007 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:4624
2024-08-14 17:24:34.007 | HD Server | HD Request #4323 | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 20:16:27 | ClientReqID: 4323 | Username: DAVID SUDDUTH JR. | Thread:4624
2024-08-14 17:24:34.007 | HD Server | HD Request | Socket: 5 | Symbol: CLU4.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientReqID: 4323 | Username: DAVID SUDDUTH JR. | Thread:4624
2024-08-14 17:24:34.007 | HD Server | Thread:4624 (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:34.007 | HD Server | Thread:4624 (5) | CloseSocket call.
2024-08-14 17:24:34.007 | HD Server | Thread:4624 (0) | CloseSocket call.
2024-08-14 17:24:34.008 | HD Server | Thread:4624 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:34.008 | HD Server | Thread:4624 (5) | Closed.
2024-08-14 17:24:34.008 | HD Server | Thread:4624 (0) | CloseSocket call.
2024-08-14 17:24:34.017 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2024-08-14 17:24:34.017 | HD Server Manager | Started new historical data server. Count=2
2024-08-14 17:24:34.033 | HD Server | Thread:11404 (5) | Creating socket.
2024-08-14 17:24:34.033 | HD Server | Thread:11404 (5) | New receive buffer size: 262144
2024-08-14 17:24:34.033 | HD Server | Thread:11404 (5) | Allocated send buffers: 32 of 4096 bytes.
2024-08-14 17:24:34.033 | HD Server | Setting DTC encoding to Binary VLS | Thread:11404
2024-08-14 17:24:34.034 | HD Server | Received login. Requesting authorization. | Username: DAVID SUDDUTH JR. | Thread:11404
2024-08-14 17:24:34.034 | HD Server | Login has been authorized. | Username: DAVID SUDDUTH JR. | Thread:11404
2024-08-14 17:24:34.034 | HD Server | HD Request #4324 | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-08-14 18:41:40 | ClientReqID: 4324 | Username: DAVID SUDDUTH JR. | Thread:11404
2024-08-14 17:24:34.035 | HD Server | HD Request | Socket: 5 | Symbol: ESU4.CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 9 | ClientReqID: 4324 | Username: DAVID SUDDUTH JR. | Thread:11404
2024-08-14 17:24:34.035 | HD Server | Thread:11404 (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:34.035 | HD Server | Thread:11404 (5) | CloseSocket call.
2024-08-14 17:24:34.036 | HD Server | Thread:11404 (0) | CloseSocket call.
2024-08-14 17:24:34.036 | HD Server | Thread:11404 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:34.036 | HD Server | Thread:11404 (5) | Closed.
2024-08-14 17:24:34.188 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:11404
2024-08-14 17:24:34.188 | HD Server Manager | Current server count=1
2024-08-14 17:24:34.188 | HD Server | Server thread ending. Closing socket. | Username: DAVID SUDDUTH JR. | Thread:4624
2024-08-14 17:24:34.188 | HD Server Manager | Current server count=0
2024-08-14 17:24:35.457 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:35.457 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:35.458 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:35.458 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:35.458 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:35.504 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:35.504 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:35.504 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:35.504 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:35.627 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:35.627 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:35.627 | Historical data download ID 122401 not found when removing ID from outstanding request set.
2024-08-14 17:24:35.627 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:35.627 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:35.627 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:35.627 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:35.627 | Historical data download ID 122402 not found when removing ID from outstanding request set.
2024-08-14 17:24:35.627 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:35.627 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:35.627 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:35.627 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:35.627 | Historical data download ID 122403 not found when removing ID from outstanding request set.
2024-08-14 17:24:35.627 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:35.627 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:35.627 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:35.669 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:35.684 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:35.684 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:35.684 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:35.684 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:35.684 | DTC Client socket (5) | Closed.
2024-08-14 17:24:35.684 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:35.684 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:35.684 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:35.684 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:37.687 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:37.687 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:37.688 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:37.688 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:37.688 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:37.726 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:37.726 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:37.727 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:37.727 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:37.890 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:37.890 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:37.890 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:37.890 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:37.890 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:37.890 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:37.890 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:37.890 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:37.890 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:37.890 | Historical data download ID 122404 not found when removing ID from outstanding request set.
2024-08-14 17:24:37.890 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:37.891 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:37.891 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:37.891 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:37.891 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:37.891 | Historical data download ID 122405 not found when removing ID from outstanding request set.
2024-08-14 17:24:37.891 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:37.891 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:37.891 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:37.891 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:37.891 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:37.891 | Historical data download ID 122406 not found when removing ID from outstanding request set.
2024-08-14 17:24:37.891 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:37.891 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:37.891 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:37.933 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:37.936 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:37.936 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:37.936 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:37.936 | DTC Client socket (5) | Closed.
2024-08-14 17:24:37.936 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:37.936 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:37.936 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:39.954 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:39.954 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:39.954 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:39.954 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:39.954 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:40.017 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:40.017 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:40.017 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:40.017 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:40.140 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:40.140 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:40.140 | Historical data download ID 122407 not found when removing ID from outstanding request set.
2024-08-14 17:24:40.140 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:40.140 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:40.140 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:40.140 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:40.140 | Historical data download ID 122408 not found when removing ID from outstanding request set.
2024-08-14 17:24:40.140 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:40.140 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:40.140 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:40.140 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:40.140 | Historical data download ID 122409 not found when removing ID from outstanding request set.
2024-08-14 17:24:40.140 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:40.140 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:40.140 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:40.178 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:40.186 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:40.186 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:40.186 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:40.186 | DTC Client socket (5) | Closed.
2024-08-14 17:24:40.186 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:40.186 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:40.186 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:42.179 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:42.179 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:42.180 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:42.180 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:42.180 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:42.218 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:42.218 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:42.218 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:42.218 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:42.350 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:42.350 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:42.350 | Historical data download ID 122410 not found when removing ID from outstanding request set.
2024-08-14 17:24:42.350 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:42.350 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:42.350 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:42.350 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:42.350 | Historical data download ID 122411 not found when removing ID from outstanding request set.
2024-08-14 17:24:42.350 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:42.350 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:42.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:42.351 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:42.351 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:42.351 | Historical data download ID 122412 not found when removing ID from outstanding request set.
2024-08-14 17:24:42.351 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:42.351 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:42.351 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:42.392 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:42.394 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:42.394 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:42.394 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:42.394 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=184
2024-08-14 17:24:42.394 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:42.394 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:42.394 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:42.394 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:42.435 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:24:42.435 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:42.435 | DTC Client socket (5) | Closed.
2024-08-14 17:24:44.405 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:44.405 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:44.405 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:44.405 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:44.405 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:44.448 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:44.448 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:44.448 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:44.448 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:44.575 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:44.575 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:44.575 | Historical data download ID 122413 not found when removing ID from outstanding request set.
2024-08-14 17:24:44.575 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:44.575 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:44.575 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:44.575 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:44.575 | Historical data download ID 122414 not found when removing ID from outstanding request set.
2024-08-14 17:24:44.575 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:44.575 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:44.575 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:44.575 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:44.575 | Historical data download ID 122415 not found when removing ID from outstanding request set.
2024-08-14 17:24:44.575 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:44.575 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:44.575 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:44.618 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:44.620 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:44.620 | Rithmic Direct - DTC (Data) | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData
2024-08-14 17:24:44.620 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:44.620 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:44.620 | DTC Client socket (5) | Closed.
2024-08-14 17:24:44.620 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:44.620 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:44.620 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:44.620 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:46.613 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:46.613 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:46.614 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:46.614 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:46.614 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:46.654 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:46.654 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:46.654 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:46.654 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:46.786 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:46.786 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:46.787 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:46.787 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:46.787 | Historical data download ID 122416 not found when removing ID from outstanding request set.
2024-08-14 17:24:46.787 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:46.787 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:46.787 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:46.787 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:46.787 | Historical data download ID 122417 not found when removing ID from outstanding request set.
2024-08-14 17:24:46.787 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:46.787 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:46.787 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:46.787 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:46.787 | Historical data download ID 122418 not found when removing ID from outstanding request set.
2024-08-14 17:24:46.787 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:46.787 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:46.787 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:46.827 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:46.830 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:46.830 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:46.830 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:46.830 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-08-14 17:24:46.830 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:46.830 | DTC Client socket (5) | Closed.
2024-08-14 17:24:46.831 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:46.831 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:46.831 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:48.917 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2024-08-14 17:24:48.917 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50529
2024-08-14 17:24:48.917 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2024-08-14 17:24:48.918 | DTC Client socket (5) | New receive buffer size: 0
2024-08-14 17:24:48.918 | DTC Client socket (5) | Connecting to IP: 216.57.156.163.
2024-08-14 17:24:48.957 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-08-14 17:24:48.957 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-08-14 17:24:48.957 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-08-14 17:24:48.957 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Received logon response.
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Server Name: .
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-08-14 17:24:49.078 | Rithmic Direct - DTC | Using primary service for historical data for CLU4.NYMEX
2024-08-14 17:24:49.078 | Historical data service client indicated that downloads are not enabled. Symbol: CLU4.NYMEX. Data Type: Intraday data.
2024-08-14 17:24:49.078 | Historical data download ID 122419 not found when removing ID from outstanding request set.
2024-08-14 17:24:49.078 | Real-time Intraday chart data file updates started for CLU4.NYMEX
2024-08-14 17:24:49.078 | Intraday chart data file opened for CLU4.NYMEX
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLU4.NYMEX
2024-08-14 17:24:49.078 | Rithmic Direct - DTC | Using primary service for historical data for ESU24_FUT_CME
2024-08-14 17:24:49.078 | Historical data service client indicated that downloads are not enabled. Symbol: ESU24_FUT_CME. Data Type: Intraday data.
2024-08-14 17:24:49.078 | Historical data download ID 122420 not found when removing ID from outstanding request set.
2024-08-14 17:24:49.078 | Real-time Intraday chart data file updates started for ESU24_FUT_CME
2024-08-14 17:24:49.078 | Intraday chart data file opened for ESU24_FUT_CME
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU24_FUT_CME
2024-08-14 17:24:49.078 | Rithmic Direct - DTC | Using primary service for historical data for ESU4.CME
2024-08-14 17:24:49.078 | Historical data service client indicated that downloads are not enabled. Symbol: ESU4.CME. Data Type: Intraday data.
2024-08-14 17:24:49.078 | Historical data download ID 122421 not found when removing ID from outstanding request set.
2024-08-14 17:24:49.078 | Real-time Intraday chart data file updates started for ESU4.CME
2024-08-14 17:24:49.078 | Intraday chart data file opened for ESU4.CME
2024-08-14 17:24:49.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU4.CME. Market Depth data restarted.
2024-08-14 17:24:49.121 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:49.122 | DTC Client socket (5) | CloseSocket call.
2024-08-14 17:24:49.122 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 500
2024-08-14 17:24:49.123 | DTC Client socket (5) | Max send buffers used during socket life: 3
2024-08-14 17:24:49.123 | DTC Client socket (5) | Max send buffer size during socket life: 735
2024-08-14 17:24:49.123 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLU4.NYMEX
2024-08-14 17:24:49.123 | DTC Client socket (0) | CloseSocket call.
2024-08-14 17:24:49.123 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-08-14 17:24:49.123 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2024-08-14 17:24:49.123 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0
2024-08-14 17:24:49.123 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-08-14 17:24:49.391 | DTC Client socket (5) | Write has completed. Shutdown being performed.
2024-08-14 17:24:49.392 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-08-14 17:24:49.392 | DTC Client socket (5) | Closed.
[2024-08-14 21:50:16]
John - SC Support - Posts: 37226
Your problem is what is described at the following link:
Rithmic Trading Platform Service: Frequent Reconnections
We see at least one symbol that is incorrect in your log that will create this problem - ESU24_FUT_CME
