Date/Time: Sat, 23 Nov 2024 05:48:05 +0000
Question About Direct Referencing Code Example
View Count: 101
[2024-08-14 05:36:34] |
User413206 - Posts: 26 |
Example: Referencing Other Time Frames and Symbols When Using the ACSIL: Example Does the example reference the currently developing bar? If so, then if I want to reference the last completed bar and associated indicator value, do I simply update the code by changing sc.index
to sc.index - 1 ?
Date Time Of Last Edit: 2024-09-09 10:35:10
[2024-09-09 10:34:54] |
Sierra_Chart Engineering - Posts: 17145 |
Yes this is correct.
