Date/Time: Wed, 27 Nov 2024 10:35:33 +0000
Using Volume Profile For Current Day But Separating Overnight
View Count: 1457
[2014-08-29 18:01:45] |
cmet - Posts: 552 |
I'm trying to use a Volume By Price for the current day only. Right now I'm able to have the full session profile show up on the right. What I'd like to do is show the Overnight Session profile separately. However, when I set the setting "use separate profile for evening session" to "Yes", nothing changes. It remains a single profile for the full session. Relevant Settings: One Period From Start Time to End Time Days 1 1 Use Separate Profile For Evening Session Can you please explain how I can accomplish the above? |
[2014-08-29 18:54:43] |
User93103 - Posts: 48 |
Hello: One way is to set: Profile time period length 480 Profile time period unit Minutes Number of TPO Profile period Multiple periods fixed by time This will give you automatic 3 separate sessions. You can change these settings the way you like. Also, you can right click on any letter on the TPO chart and click on split profile here. God Bless Ben |
[2014-08-30 00:03:07] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#DayEveningSeparateProfiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-30 01:04:13] |
cmet - Posts: 552 |
Thanks. With this setup, is there any way to have the day session profile stick to the right edge of the chart (align to far right) instead of the right edge of the current bar? |
