Date/Time: Wed, 27 Nov 2024 10:30:04 +0000
Symbol for Loading Crude Oil from IQ Data Feed
View Count: 1022
[2014-08-29 17:39:00] |
User11877 - Posts: 1 |
Need to know what symbol I should be using to load Sierra Chart with front month for Crude Oil using the IQ data feed.
[2014-08-29 18:55:51] |
This is the symbol: QCL# You will find the symbol in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-29 18:56:10
