Date/Time: Wed, 27 Nov 2024 10:30:42 +0000
TransAct Data feed problem.
View Count: 1159
[2014-08-29 15:30:05]
Ignawin - Posts: 10
I am having an issue with TransAct datafeed and SierraChart. On the side of a broker is everything working fine. InfinityAT DOM is working ok,but data in Sierra are slow and not accurate.
[2014-08-29 15:48:09]
User28820 - Posts: 5
Same issue here, significant delay in sierra charts
[2014-08-29 16:25:01]
Are you noticing this problem at the present time?
[2014-08-29 16:28:13]
Yes I am still having delay
[2014-08-29 16:32:06]
Pls disregard previous message, looks like data feed is back on track
[2014-08-29 16:44:33]
If you are missing any data in your Intraday charts, refer to the instructions in help topic 7.1 here:
https://www.sierrachart.com/index.php?page=doc/helpdetails7.html#RetryDownloadDataInChart
[2014-08-29 18:16:52]
Ignawin - Posts: 10
I am not missing any data, I am still having the problem with the data feed (live account). When I tried my secondary data feed(AMP futures), everything worked fine. The problem is just between the TransAct and the SierraChart. TransAct is working fine on an another platform.
Date Time Of Last Edit: 2014-08-29 18:17:09
[2014-08-29 18:30:59]
So the data feed is "slow"?
Or what is the current problem?
[2014-08-29 19:25:18]
Ignawin - Posts: 10
Yes, and volume chart is not accurate.
[2014-08-29 23:11:08]
Refer to these help topics:
Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
