Date/Time: Fri, 22 Nov 2024 07:54:16 +0000
Market Profile
View Count: 2458
[2013-05-08 07:57:52] |
LukeScisl - Posts: 18 |
I can not find it in Analysis-->Studies I have package 3, should i expand it to package 5? |
[2013-05-08 08:00:08] |
Are you looking for the TPO Profile Chart study?
[2013-05-08 08:03:07] |
I'm looking for MARKET PROFILE data developed by J Peter Steidlmayer |
[2013-05-08 08:03:43] |
http://en.wikipedia.org/wiki/Market_profile
[2013-05-08 08:06:34] |
Yes this is it. Thank You
[2013-05-08 08:08:10] |
This is it bu however not working I have package 3, should i expand it to package 5? |
[2013-05-08 08:16:59] |
You will need package 5 and here is the documentation: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#BasicInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
