Date/Time: Fri, 03 May 2024 15:55:11 +0000
[Sticky] [Locked] - Videos
View Count: 97147
[2019-11-25 20:57:33] |
J4yTr4der - Posts: 20 |
Although the default is a black background. Follow the instructions here to reset Sierra Chart to a default state:
https://www.sierrachart.com/index.php?page=doc/helpdetails39.html I'm confused by this statement. SC was never in a default state with a black background for me. Is this because I am an Infinity Futures (TransAct) customer? I have modified the colors myself to give me a black background but I definitely have missed certain elements at times which has been very frustrating. I would love to be able to set it to a "default" state with a black background. I don't see anything on that help page about doing this, and as I stated resetting to "defaults" did not set anything to a black background for me. Everything is on painfully-bright white. Date Time Of Last Edit: 2019-11-25 22:39:14
[2019-11-26 00:25:58] |
The answer is yes to your first question. You really should tell Infinity that everything is "painfully bright white". We completely agree. Their defaults are hurting your eyes. They should consider that. White is not a good background color for them to be using and they are making a major mistake. They should stop trying to please some people and use common sense. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-06 20:40:07] |
New video about study calculation times: https://videos.sierrachart.com/Study_Calculation_Time.webm We also plan to create a video about the Sierra Chart order routing service. Will try to do it over the weekend. If you are using studies with long calculation times we recommend using sub instances for those: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-13 01:33:38
[2020-03-15 09:44:02] |
New video about improving Sierra Chart performance: https://videos.sierrachart.com/Improving_Sierra_Chart_Performance.webm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-16 18:37:31
[2020-06-01 19:29:53] |
j4ytr4der_ - Posts: 918 |
There is no Youtube channel or anything if that's what you mean. I just downloaded them all individually so I'd have them for future reference.
[2020-06-01 20:33:59] |
We just have links here to the different videos. Maybe we should consolidate them into a single smaller list. Here is another new video we did: Customizable Header Fields for Trade DOM Video Videos are not meant to be our main documentation and some of them are older. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-01 20:34:07
[2020-06-07 18:11:50] |
User869657 - Posts: 31 |
The video you made on study calculation time doesn't seem to have sound ; could you please re-upload with sound ? Thanks https://videos.sierrachart.com/Study_Calculation_Time.webm Date Time Of Last Edit: 2020-07-13 05:59:21
[2020-06-07 21:33:31] |
It does have audio. You need to check your system for the problem.
[2020-06-08 22:31:45] |
JayShea - Posts: 92 |
I got the audio. It doesn't have closed captions.
[2020-06-12 07:39:34] |
New video for replaying market depth data: https://videos.sierrachart.com/SierraChartReplayingMarketDepthData.webm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-16 04:16:45
[2020-06-12 14:01:24] |
I was so excited by this video because it appeared that finally market depth replay was going to behave properly, since your video shows it replaying exactly as it did live. But for me, it doesn't do that. I still get the jerky updating every 1 second no matter what. Why is this? Is there some additional setting somewhere that isn't set right? Obviously it's possible to get "real time" replay since you showed it, but I just can't figure out how to make it work. I'm running 2118. Any pointers you can share? EDIT: Actually on closer examination, I think maybe your data is also playing back "in chunks" but since it's at 2x speed it's less obvious. I suppose the millisecond support that's been discussed as being in the works, is not quite ready yet? Date Time Of Last Edit: 2020-06-12 14:30:57
[2020-07-11 14:08:09] |
tommartin321 - Posts: 74 |
https://videos.sierrachart.com/Study_Calculation_Time.webm This is giving an Error 404 Date Time Of Last Edit: 2020-07-13 05:59:00
[2020-07-12 08:07:46] |
Sierra_Chart Engineering - Posts: 14201 |
We apologize for this. We will get this corrected.
[2020-07-13 01:34:24] |
Sierra Chart - Max - Posts: 5599 |
@tommartin321: Please use the updated link here: https://videos.sierrachart.com/Study_Calculation_Time.webm Sierra Chart Support |
[2021-02-17 03:01:03] |
Thank you.
[2021-02-17 16:15:43] |
Calculus - Posts: 86 |
If possible can you do more vids please. I've learnt a lot from the one's in this thread. Sierra is a great program, no doubt about that, but it's also got so many features and angles, more videos dealing with what/how etc would be tremendous. Make it a weekly habit, one video a week from x number on your team. And who better to explain things than the Developers. Great for Sierra, even better for the clients. |
[2021-03-17 13:44:59] |
These sets of vids are the best I've seen on Sierra, and I think there's more to come from the guy. https://www.youtube.com/watch?v=-HSa8_2b8lM |
[2021-03-17 14:14:58] |
Ackin - Posts: 1865 |
Diana Pena https://www.youtube.com/channel/UC9mZ5KrIhgQ7TKnqSGukU8w |
[2021-03-17 14:26:47] |
Trader Ticino (How-to Videos) https://www.youtube.com/playlist?list=PL4biLXu5iaFBmeZmJ6sOWy6nrr3_5mEQq |
[2021-07-24 00:53:43] |
@TRADE_YOUR_PLAN - Posts: 126 |
Lengthy Playlist of Sierra Chart How-To videos. These playlists show you guys how to build advanced and basic charts. I'd look outside of that folder too, as not every video for Sierra Chart is in the Sierra Chart Playlist: https://www.youtube.com/playlist?list=PLt8n4aE9vzeJOUU4y82_-aFkG_i9y5-0h Date Time Of Last Edit: 2021-07-27 05:22:51
[2021-11-25 15:35:53] |
New Video Library page: Video Library Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-25 09:57:03] |
User820368 - Posts: 8 |
please watch this https://rumble.com/vt5bdo-cabal-19-the-covid-great-awakening-...a-masterful-documentary-banned-on-mos.html |
[2022-01-25 16:36:34] |
Thank you for this. We will need to move that video to our Off-topic thread regarding the subject. We will do that, in the evening.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-25 16:36:47
[2022-05-27 18:13:35] |
Video for the new Settings Windows: https://videos.sierrachart.com/Settings_Windows_Interface.mp4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
