Date/Time: Thu, 19 Sep 2024 22:16:37 +0000
MACD indicator sizing
View Count: 1015
[2014-08-28 17:55:30] |
User40725 - Posts: 5 |
I have place a macd indicator on the bottom of the price chart but would like to make it smaller. The indicator space takes up 40 to 50% of the chart and I would like to size the vertical space for the macd so that it only takes up 10-20% of the vertical space leaving the majority for the price bars. Thanks
[2014-08-28 18:14:26] |
vegasfoster - Posts: 444 |
The easiest way to set up lower indicators is F5>>Advanced Settings>>Display Region Dividing Lines (check box located at the very left top corner of the window) and then you can simply grab the white line on your chart with the pointer and move it up and down.
Date Time Of Last Edit: 2014-08-28 18:16:17
[2014-08-28 23:36:45] |
The procedure for adjusting chart regions is documented here: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartWindowandRegions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
