Date/Time: Wed, 30 Oct 2024 22:56:10 +0000
Market Facilitation Index Colored values spreadsheet
View Count: 118
[2024-08-02 09:29:47]
sabbers - Posts: 21
Hi All,
Question about the Market Facilitation Index Colored Study.
I noticed there are only "0" values in the spreadsheet columns for the different color bars SG2, SG3, SG4 and SG5. (See attachment)
Is it possible, for example, to assign a value of 1 if SG2 is valid, so it can be used in a condition formula ?
Regards,
Sabbers
imageMFI COLORED.png / V - Attached On 2024-08-02 09:29:12 UTC - Size: 108.1 KB - 29 views
[2024-08-02 16:50:46]
John - SC Support - Posts: 35639
Those subgraphs are just to assign the colors, they do not store the data (as you have seen).
Changing this is not something we can get to any time soon, which also means that it is a very low priority and not something we are likely to ever get to.
You can modify the source code for this study, as the source code is located in the "Studies8.cpp" file located in your "ACS_Source" folder under your main Sierra Chart installation folder. Refer to the following:
How to Build an Advanced Custom Study from Source Code
