Date/Time: Wed, 30 Oct 2024 22:56:10 +0000
trial activation
View Count: 93
[2024-08-02 00:45:51]
User896655 - Posts: 1
i am trying to activate trial, but it gives me an error, says that it failed sending SMS, what should i do ?
[2024-08-02 02:16:44]
Sierra_Chart Engineering - Posts: 16764
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
