Date/Time: Wed, 30 Oct 2024 22:56:10 +0000
Switch to sim (disable live trading) at time?
View Count: 211
[2024-08-01 20:25:46] |
joshtrader - Posts: 486 |
Is there a way to disable live trading, I guess by switching to sim mode, and back, and certain times of the day?
[2024-08-01 20:42:34] |
Sierra_Chart Engineering - Posts: 16764 |
We would need to add an ACSIL function to control this, and then you can change it with a custom study at any time you want.
[2024-08-04 01:49:50] |
ForgivingComputers.com - Posts: 952 |
No Need to switch to Sim. You can have the same effect by locking trading using the ACSIL function: sc.SetTradingLockState(1);
[2024-08-04 12:59:59] |
Yes that is true. We were going to post that function: sc.SetTradingLockState() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-05 01:16:37] |
Thank you, this will work perfectly, no need for that additional function.
