Date/Time: Wed, 30 Oct 2024 22:56:10 +0000
Volume on 1 Minute
View Count: 140
[2024-08-01 14:53:16] |
Artieb60 - Posts: 9 |
These small changes that take place for no reason are so frustrating. Now my vloume on my 1 minute is 2 bars bouncing back and forth instead of the volume on the top red bars and on the bottom green . Instead it is just 2 long bars, one green and one red. How doI get it back to normal please thank you
[2024-08-01 15:57:27] |
Now I have downloading continuous contract data stuck Comon...... |
[2024-08-01 20:09:15] |
Sierra_Chart Engineering - Posts: 16764 |
Verified trading account ending date: 2024-07-31
This is the problem. So at this time you are receiving Rithmic data and you are no longer receiving data from the Denali Data Feed.The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported Trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. ----- Once you start receiving data from the Denali Data Feed re-download the data for the last few days: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
