Date/Time: Wed, 30 Oct 2024 22:56:10 +0000
How can i keep windows without banner
View Count: 122
[2024-08-01 13:58:24]
Poparocks - Posts: 15
I have attached an image to this support request. I want to keep my windows, even when selected, like the right window. Without the top header. I am trading between 2 different windows and it constantly requires me to click the window to activate then click the order i want. I would prefer a setting where i can just click the order on the window without having to click the window to activate first.
imageSierra Windows.PNG / V - Attached On 2024-08-01 13:58:10 UTC - Size: 17.82 KB - 46 views
[2024-08-01 15:49:07]
Sierra_Chart Engineering - Posts: 16764
You can remove the title bar from a chart:
Chart Menu: Show Title Bar (Chart menu)
However, you can left click anywhere within a chart window to activate it.
[2024-08-01 16:09:03]
Is there a way to keep the title bar hidden, even when the window is activated ? The image i provided shows that i already have the title bar hidden but it only works on windows that are not active, as soon as i click the window the title bar comes back.
[2024-08-01 20:10:34]
Disable this option:
General Settings Window: Auto Hide Charts Title Bar And Scrollbar (Global Settings >> General Settings >> GUI >> Application GUI)
