Date/Time: Thu, 19 Sep 2024 22:32:35 +0000
Span A and B, Ichimoku
View Count: 917
[2014-08-28 15:31:39] |
ripsdips - Posts: 143 |
is there any way I can fill the span and see the candle as it passes through the filled area?
[2014-08-28 16:59:59] |
Use the study named: Senkou Span A & B And set it to display under the main price graph by following these instructions: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DisplayStudyUnderMPG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
