Date/Time: Thu, 19 Sep 2024 22:18:32 +0000
TRADING DOME POSITION
View Count: 967
[2014-08-28 11:33:21] |
User28317 - Posts: 149 |
WHEN I SET THE TARGET FOR 3 CONTRACT SIZE MY TARGET 2 IS 4 TICKS "TARGET: MARKET IF TOUCHED" AND TARGET 1 8 TICKS. WHEN I SET THE 6 CONTRACT SIZE I SET IT FOR 4 AND 2 RESPECTFULLY. WHEN I GOT BACK TO 3 CONTRACTS SIZE AND THEN SWITCH BACK TO SIX THE CONTRACT TARGETS GO BACK TO 3 AND 3. HOW DO I SET THE DEFAULT TO 4 AND 2? I WANT TO DO THE SAME FOR 9 CONTRACTS, 6 AND 3. I SWITCH BACK AND FORWARD IN SPLIT SECONDS AND DON'T HAVE TIME TO RESET MY PARAMETERS FOR THE TARGETS. |
[2014-08-28 17:11:08] |
For each Order Quantity that you want to use, you need to save a different Trade Window configuration that you can switch between: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
