Date/Time: Thu, 19 Sep 2024 23:59:11 +0000
how to setup sierrachart version 3 with rithmic and get historical bid ask data from historical
View Count: 1049
[2014-08-28 07:54:52] |
User16478 - Posts: 2 |
How to setup sierrachart version 3 with rithmic and get historical bid ask data from historical sierra feed ? I have a rithmic datafeed from my broker that has NO historical bid ask data . The sierra chart historical data feed says it includes historical bid ask data . How do i setup sierra so this will work with historical bid ask data . I know i have to start 2 copies of sierra but i don't get it working Thanks |
[2014-08-29 00:04:02] |
Here are the set up instructions to use Rithmic: Rithmic Trading Platform Service: Setup Instructions To get historical data for Rithmic which includes bid volume and ask volume , requires that you use the Sierra Chart Real-time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-29 05:45:47] |
So i have to activate the data feed from sierra for $35 a month that is clear. But do i also have to activate the exchange feeds because i don't need realtime data just the historical bid/ask backfill and i already pay those fees from my broker account with rithmic . Can you explain this Thanks in advance |
[2014-08-29 07:16:19] |
With the way the data feed is designed and integrated with trading services and also based on exchange rules, you do have to activate the exchanges. If you are trading futures, typically this is going to be CME Group. It is only 3.5 USD a month. If you are trading ICE, that is a completely different issue and cost is very high. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-02 17:23:07] |
Futures Operator - Posts: 239 |
Is there any other lower cost combination/solution for access to trading ICE US, and using the SC feed or accurate bid/ask data including historical?
