Date/Time: Sun, 24 Nov 2024 00:17:22 +0000
Questions on Single Prints
View Count: 261
[2024-07-28 22:27:10]
User631345 - Posts: 34
I have a few questions on Single Prints. Can you please go through these and provide some remedies or feedback on the same?
1.Is there any way of displaying a Single Print on a 1 Min Chart?
2.Is there any way of having an Audio Alert when a Single Print is generated in the TPO Chart?
3.Is there any way of having separate color for a Single Print that breaks to the Upside Vs a Single Print that breaks to the downside?
4.Is it possible to automatically put a Date & Time Label on a Single Print.? E.g. if a Single Print was created on 25Th July 2024 at 11:30 AM EST then the TPO to show a Single Print with that specific Time & Date Label?
Kind Regards
[2024-07-29 16:23:24]
1. We are not sure what you are asking here. Singles are only available through the TPO study. You could set the "TPO Letter/Block Time Period Length" to 1 and the "TPO Letter/Block Time Period Length Unit" to "Minutes" to get 1 minute sub-periods.
2. No.
3. No.
4. No.
Date Time Of Last Edit: 2024-07-29 16:25:22
[2024-08-10 02:00:37]
Hi John,
Thanks for answering the above questions
Another question related to Single Prints
Is there any way of exporting Single Print Data to a TXT or excel file? Eg using Export Bar and Study Data
When I use this function currently I dont get the Single Print data in the exported file
Any ideas?
Kind Regards
[2024-08-12 13:57:47]
There is not a way to export the Singles information, as the information for where they are located is not made available.
[2024-11-06 15:35:56]
Thanks John,
There is not a way to export the Singles information, as the information for where they are located is not made available. => Is there any way at all using code etc to export this information or is this information just NOT made available anywhere in the Platform?
Thanks,
pd
[2024-11-06 17:05:19]
The information for Singles is not available in any way. It is not currently exposed through ACSIL.
