Date/Time: Fri, 27 Dec 2024 09:49:13 +0000
Volume By Price Changes size?
View Count: 289
[2024-07-27 22:55:46]
anthonyvegas - Posts: 13
See attached images ( via links ). I have an NQ range chart with a 1 day and a 20 day Volume by price study on the right. They are setup to show delta ( and NOT your typical volume profile ). But, when I move the chart, the size of the delta bars changes as I move the chart. Not that when my chart / candlesticks are on screen and toward the right, then the delta bars are full size ( something like 30% of window ), but as I move the candles to the left, the bars shrink which makes comparing the size to each other more difficult. Please help.
https://www.sierrachart.com/image.php?Image=1722120789104.png
https://www.sierrachart.com/image.php?Image=172212085020.png
https://www.sierrachart.com/image.php?Image=1722120877525.png
Thanks,
Anthony
[2024-07-29 15:11:51]
John - SC Support - Posts: 36873
Please get us that chart by following these instructions:
[2024-07-30 02:45:24]
Charbook attached....
let me know what you find...
Thanks,
Anthony
attachmentCB_for_support.Cht - Attached On 2024-07-30 02:44:47 UTC - Size: 6.06 KB - 177 views
[2024-10-22 20:35:49]
We apologize for not having gotten back to this sooner, we were just busy with too many other items.
The issue you are having is caused by how Sierra Chart handles the Window Width internally, and it is seeing the window width changing as the bars are scrolling. This is because the Window Width is determined by finding the bar furthest to the right, which will be defined by the "Number of Forward Columns" defined in "Chart >> Chart Settings >> Display".
You will notice that as you scroll to the left, the times at the bottom of the screen start showing blanks to the right and this moves to the left. This is what is affecting the Window Width. You need to increase your "Number of Forward Columns" to a value where you will have enough columns displayed as you scroll.
