Date/Time: Fri, 18 Oct 2024 03:53:51 +0000
Bug report
View Count: 150
[2024-07-26 23:48:35] |
User740504 - Posts: 103 |
Activity Log: Window->Always On Top It doesn't always work. Quite often I have to un-toggle and then re-toggle the "Always On Top" feature, even though it's already checked. The window works as expected after the re-toggle. I noticed this usually happens after I open Sierra Chart, but it doesn't always have the issue. After it's un-toggled and re-toggled as per above, it will always fix it and I will not have any more issues with it until I close Sierra Chart. Date Time Of Last Edit: 2024-07-26 23:50:11
[2024-07-27 16:12:21] |
Sierra_Chart Engineering - Posts: 16656 |
We will look into this.
