Date/Time: Tue, 22 Sep 2026 05:13:41 +0000
OEC Data Feed
View Count: 1857
| [2014-08-27 20:50:13] |
| User121729 - Posts: 37 |
Will this data feed give accurate bid/ask volume data to support numbers bars? |
| [2014-08-27 20:52:08] |
Not completely. So no.
| [2014-08-27 21:56:42] |
OK.. SO what is lacking and with what is lacking with the OEC data feed , is it of any value to use numbers bars at all? Which data feeds do you recommend for numbers bars other than IQ FEED? Thanks |
| [2014-08-27 23:31:15] |
We are not going to comment on the OEC data feed other than to say we have observed that it is not a perfect quality data feed. Whether it is of value to use with Numbers Bars, we cannot say. That ultimately is up to each individual user. We recommend using the Sierra Chart Real-time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-08-29 04:27:45] |
| WarriorTrader - Posts: 259 |
Will this data feed give accurate bid/ask volume data to support numbers bars? -------------------------------------------------------------------------------- YES. I have had complaints in the past, but something changed about 6 months ago. It is now pretty good. I don't know who fixed what. -WT |
| [2014-08-29 05:04:18] |
This is good to know.
