Date/Time: Sun, 08 Sep 2024 00:10:07 +0000
One Period at End of Fixed Time Length - Auto-Skip Empty Days
View Count: 101
[2024-07-26 13:20:55] |
es10pt - Posts: 7 |
I'm going to use it in the RTH session profile chart. However, out of the VP and TPO charts, only the VP correctly applies the option (the TPO chart has an unknown calculation method). When I apply the same “One Period at End of Fixed Time Length - Auto-Skip Empty Days”, I get the following result VP set to 6-day shows data for exactly 6 profiles on the left, while TPO does not. What is the issue? |
[2024-07-26 18:09:01] |
We are not sure we are understanding the issue. It sounds like you have setup a Volume by Price study with the following Inputs: - Volume Graph Period Type: One Period at End of Fixed Time Length - Auto-Skip Empty Days - Time Period Type for 'Fixed Time': Days - Time Period Length for 'Fixed Time': 6 And then you are comparing this on a chart with daily Volume by Price profiles on it and another chart with daily TPO profiles on it. And you are stating that the chart with the TPO's is incorrect. But in the image you provide, there are only 5 days showing of the TPO. So there is no way to compare the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
