Date/Time: Sun, 08 Sep 2024 00:07:20 +0000
issue with serveral instances and 2 trading systems at the same time
View Count: 114
[2024-07-26 11:08:57] |
User185210 - Posts: 64 |
Hello, I had an issue with the following situation: Setup: 4 different instances, each with 2 or 3 chart books. 1 instance has 2 chartbooks, each having a spreadsheet system for trading one for DAX, the other one for NQ. Made a test this morning and found out that the stops where flickering on/off (between the 2 different chartbooks!) So I had to close one chartbook in that instance. My question is: What is the right way to have these 2 systems working together? Could it be that I have to use different intances, one for each trading system chartbook? Or else? Thank you for your help. |
[2024-07-26 14:32:54] |
Sierra_Chart Engineering - Posts: 16292 |
This does not make any technical sense and is not a Sierra Chart issue: Made a test this morning and found out that the stops where flickering on/off (between the 2 different chartbooks!)
Every instance of Sierra Chart is fully isolated from others. But if you are using a common trading service in the background we have no control over whatever problems are there. Use Trade Simulation Mode for your testing: Trade Simulation You will see there are no problem and no conflicts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-26 14:33:01
