Date/Time: Sun, 08 Sep 2024 00:15:11 +0000
not getting any gasoil spreads (ICE/EU)
View Count: 89
[2024-07-26 10:37:42] |
User361842 - Posts: 1 |
Hey, I am trying to chart Calendar Spreads for Gasoil Which is on ICE Europe. When I click on 'get spreads', nothing happens. Is there any way by which I can get access to these spreads. Thank you in advance for your help! |
[2024-07-26 13:30:44] |
Sierra_Chart Engineering - Posts: 16292 |
Sierra Chart does not provide ICE spreads data. We made a change to the Symbol Settings so the Get Spreads button will be disabled since it is not supported for these exchanges. You could use IQ Feed to get this data: DTN IQ Feed Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-26 13:31:10
