Date/Time: Fri, 18 Oct 2024 03:57:07 +0000
Continous Futures Contract Charts
View Count: 196
[2024-07-26 01:25:21] |
BigBagel - Posts: 40 |
Im using rithmic data feed for my funded accounts, but I also have a denali package with paid data. Am I able to use the continuous contract charts? Also, what is the recommended days to load for a futures chart?
[2024-07-26 01:50:28] |
Nevermind. I went ahead and followed the instructions on the website. Everything seems to be looking and working fine. I can turn on automatically rollover futures symbols and I wont have to worry about that too right?
[2024-07-26 17:04:30] |
John - SC Support - Posts: 35333 |
We are not sure what you are asking in regards to the "Automatically Rollover Futures Symbols" option. Refer to the information on this at the following link: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-26 17:11:00] |
Thanks!, I have a question in regards to the numbers bar chart. When the footprint candle is forming, is there anyway to make the screen move with the candle? For Example, if the candle is bullish and volatility is coming in, it would move up fast then go off screen and I and manually click and drag to follow it.
[2024-07-26 18:34:43] |
Make sure the Scale is set to "Automatic". Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
