Date/Time: Mon, 02 Nov 2026 15:38:23 +0000
[Programming Help] - Extended Rectangle Properties Anchor Values
View Count: 689
| [2024-07-26 00:05:24] |
| User303857 - Posts: 200 |
Thank You
Date Time Of Last Edit: 2025-08-25 06:17:30
| [2024-07-26 17:02:17] |
| John - SC Support - Posts: 48383 |
There is a way to access the Anchors within the built-in studies in Sierra Chart. You need to use the "Spreadsheet Formula" to do this. Despite it's name, this study uses the Alert syntax, and drawing anchors can be accessed through the alerts. Refer to the following: Study/Chart Alerts And Scanning: Reference by Anchor Therefore, in the the Spreadsheet Formula study, you would enter something like the following: =UDID[107].A1 This will then give you the value of the A1 anchor in the Spreadsheet Formula subgraph. You can then use this however you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-26 21:40:11] |
Thank You
Date Time Of Last Edit: 2025-08-25 06:17:40
| [2024-07-29 14:32:18] |
You use the positive value of the number. So if the ID is -40, you enter the value of "40" in the formula, as you have shown.
| [2024-08-04 03:43:19] |
Thank You
Date Time Of Last Edit: 2025-08-25 06:17:50
