Date/Time: Sun, 08 Sep 2024 00:04:35 +0000
Manual daily standard deviation lines that roll over every day
View Count: 156
[2024-07-25 21:19:46] |
J DIDDY - Posts: 107 |
HI Support I want to add 'Manual' standard deviation lines (12 lines) (Per day - NY open to open) to a 15 min chart so that I can see previous days lines but each day I can add the new days one manually. But I dont wanna do this with drawing lines every day, so is there a way I can do this with a study and just input new price numbers each day....????? If you imagine how the rolling VWAP + bands works....each day it produces a new set of lines (Bands) but the older ones are still there to view (Except I wanna fix my own lines and do it within 1 study, not having to add a new copy of the study for every new day, preferably to view a months worth of these STD Deviations, although a week would suffice). I tried the STD deviation study, but these are fixed lines and cannot be adjusted. Thanks Date Time Of Last Edit: 2024-07-25 21:36:17
[2024-07-26 02:37:46] |
User303857 - Posts: 72 |
I played around with some lines
![]() Attachment Deleted. |
[2024-07-26 10:48:08] |
Is this a generic study in Sierra or something you made?
[2024-07-26 17:52:37] |
Refer to the following: Trading Levels - Local Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-26 18:13:15] |
Awesome thanks JOHN I'LL CHECK IT OUT!!!
