Date/Time: Sun, 08 Sep 2024 00:11:51 +0000
How to add the
View Count: 83
[2024-07-25 19:56:40] |
User354557 - Posts: 2 |
Hello, I'm used to Tradingview and tradovate and have just switched over to SC and am just looking to add the countdown timer for each chart such as 1 minute, 5 min etc.. I can see the price but I'm not finding a way to show how long until the candle closes per time frame. Thanks
[2024-07-25 20:13:03] |
Refer to the following: Countdown Timer Chart Studies: Adding/Modifying Chart Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
