Date/Time: Sun, 08 Sep 2024 00:01:38 +0000
Trailing Stop in increments
View Count: 90
[2024-07-25 16:26:04] |
ssangha84 - Posts: 114 |
Hello, I was wondering how to do a trailing stop so that the stop goes towards your take profit a certain amount when price goes in your direction by a set amount. For example, if price goes 50 ticks in my favor, then I want it to go to break even. Then when it goes 100 ticks, I want it to go to 50 ticks in profit, etc. There are so many options under the "type" menu for stop and take profit that I just have no idea which one would best suit my needs for doing this. Thanks
[2024-07-25 17:23:35] |
The following gives an example setup for this kind of situation: Attached Orders: Target with Move to Breakeven and Trail Stop Example For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
