Date/Time: Sun, 08 Sep 2024 00:14:06 +0000
Data feed on Quote board
View Count: 119
[2024-07-25 16:20:59] |
User292609 - Posts: 2 |
Hello I have been trying to have my quote board populated on DOM Sim1 but can't for some reason. I have typed in the latest features codes particularly for CBOT but is still showing zeros. I have also performed symbols roll over but no bids or offers coming up. Could you please help me resolve this. Thank You in advance T. |
[2024-07-25 16:22:56] |
What is the symbol, exactly as you have entered it?
[2024-07-31 12:18:01] |
Hi, Thank you for your response. These are the symbols i have entered: ZNU24, ZNZ24,ZNH25 Thanks |
[2024-07-31 12:59:48] |
Sierra_Chart Engineering - Posts: 16292 |
First you are running an old version of Sierra Chart. You must update to the current version. Instructions: Software Download: Fast Update This is mandatory. And then the symbols you are using are not complete. You are not going to get data for those. Use the symbols found in File >> Find Symbol. Also refer to: Getting Quotes: Setting Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-31 13:00:43
