Date/Time: Sun, 08 Sep 2024 00:01:43 +0000
Braket order depending on indicator
View Count: 106
[2024-07-25 14:28:13] |
User138457 - Posts: 38 |
Hi, is there a way to have a stop or target order depending on a indicator? i.e. not "+- 20 ticks", but "+- 1 ATR" or sth like that? thanks in advance for any advice |
[2024-07-25 15:15:00] |
Refer to the following study: Attached Orders: Study Controlled Targets and Stops For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
