Date/Time: Fri, 18 Oct 2024 04:07:59 +0000
CME Datas Cheap
View Count: 144
[2024-07-25 12:02:08] |
User131975 - Posts: 73 |
Hello, I have already asked you how it can be that your CME data is so favorable and you said that it is the same everywhere. But here you can see for example that this Top of the Book CME data is much more expensive than yours. Why is that? https://get.dxfeed.com/orders/new/ |
Screenshot 2024-07-25 140132.png / V - Attached On 2024-07-25 12:01:46 UTC - Size: 61.11 KB - 41 views |
[2024-07-25 12:45:11] |
Sierra_Chart Engineering - Posts: 16656 |
We answered this question previously and we will provide no further information.: CME Datas And we never said it is the same everywhere. The cost is based upon what the exchange charges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-25 12:45:29
