Date/Time: Sun, 08 Sep 2024 00:02:46 +0000
User Profit/Loss Management
View Count: 142
[2024-07-25 05:57:37] |
User143155 - Posts: 7 |
Hello, I recently followed the instructions from the video on the server side profit/loss management https://www.youtube.com/watch?v=iAAmJqltGSg . According to the video after committing the settings and pressing "UPDATE" I should see the corresponding read only values update, but they are all staying at their default settings despite a success message which makes me wonder if the settings are in fact in effect. I wasn't able to locate this window tab specifically in the documentation. Any help you can provide is appreciated. |
[2024-07-25 07:41:30] |
Sierra_Chart Engineering - Posts: 16292 |
Who is the clearing firm being used? So we can determine if it is supported with them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-25 07:41:52
[2024-07-25 07:44:55] |
Stage 5 / Dorman
[2024-07-25 08:57:38] |
This is not supported with Dorman at this time.
[2024-07-25 14:44:31] |
Is there a list of clearing firms that are supported?
[2024-07-25 22:07:43] |
It is just Advantage through Stage 5 at this time.
