Date/Time: Sun, 08 Sep 2024 00:26:38 +0000
Time and Sales window vertical scroll bar
View Count: 157
[2024-07-25 01:04:56] |
User630795 - Posts: 89 |
i use Time and Sales window to monitor large volume trades and above/below ask/bid orders for aggressiveness of traders. volume is the only column i display in that windows and i have no need to stroll down because i am only interested in the trades as they happen. however, there is no way to get rid of the vertical scroll bar and i really don't like it. it uses valuable real estate on my screen, and it is districting. can you please please please add a switch to turn it off in the "setting" of that windows or you can place that switch wherever you want. can you add that switch that i can use to turn off the display of the vertical scroll bar for the Time and Sales window. don't just say it is not supported. please implement my request. Thank you. |
[2024-08-01 20:28:55] |
Sierra_Chart Engineering - Posts: 16292 |
Ok we will see about that. But not for a while. We need to first change the Time and Sales Settings window to the new format.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-01 20:29:32
[2024-08-09 03:07:04] |
also (in addition), the Time and Sales windows seem to have minimum width. it is too wide. can you allow me to adjust the width of the window narrower. i just need to display one column (volume column). i hope this makes sense. when i adjust the T&S window width and save and exit and then open the program again, the width of T&S window goes back to wider (minimum default??) width.
