Date/Time: Fri, 18 Oct 2024 03:47:27 +0000
Unable to load data
View Count: 153
[2024-07-24 22:35:32] |
User987069 - Posts: 45 |
Hello, I'm attempting to load 250 days of the F.US.JMTU24 contract with Date Adjusted and Volume Adjusted continuous data. I have not been able to load any day beyond 24-6-9 on an intraday chart no matter what. What could be the issue?
[2024-07-25 07:36:53] |
Sierra_Chart Engineering - Posts: 16656 |
That symbol is for: Mini TOPIX - OSE You cannot create Continuous Futures Contract charts with CQG data. Do not use that option when using CQG data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-26 03:22:57] |
ok, so how do I load more days? No data comes through for any day beyond June 9th no matter what I change the 'days to load' to.
[2024-07-26 14:38:08] |
You probably cannot get any more history. But refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-26 21:36:47] |
I haven't loaded any excess amount of historical data this week, why would I not be able to load more data? That didn't really help much, my settings are already configured correctly. |
[2024-07-29 14:30:46] |
John - SC Support - Posts: 35333 |
That data comes from CQG, and they do not have historical data for previous contracts. So you can not get data any further back than what you already have.
