Date/Time: Mon, 05 Oct 2026 00:11:40 +0000
[User Discussion] - Spreadsheet Help - Exit position based on entry bar High or Low
View Count: 489
| [2024-07-24 20:49:52] |
| User647607 - Posts: 20 |
Thank you for any help you may provide. I have all of the logic for entries and scale outs worked out in a spreadsheet. I'd like to be able to tell the system to automatically exit a long if price closes below the low of the entry bar for a long. Conversely, I'd like to be able to tell it to exit automatically if price closes above the high of the entry bar for a short. Any suggestions? |
| [2024-07-25 01:10:11] |
| Sawtooth - Posts: 4355 |
Create a persistent variable of the High and Low of the entry bar using this example in P3: =IF(K3,C3,IF(M3,D3,P4)) -then compare E3 with P3. |
