Date/Time: Fri, 18 Oct 2024 04:00:56 +0000
How to make Volume Profile overlap the TPO
View Count: 113
[2024-07-24 16:02:07] |
BigBagel - Posts: 40 |
I wanted to know if you guys no longer have support for this or not, but ive attached a picture to show how this guy on yt has his volume profile overlapping his TPO on sierra
volume over.png / V - Attached On 2024-07-24 16:01:20 UTC - Size: 48.26 KB - 40 views |
[2024-07-25 10:20:52] |
ticinotrader - Posts: 389 |
@BigBagel When both the TPO study and a volume profile study are added to the same chart, the TPO study has a setting that controls the position of the volume profile. See the attached image for further explanation + an example. I think the confusion comes from the fact that this is an option that affects the Vol Profile, even though it is in the settings of the TPO Profile study and only takes effect/makes any sense when both studies are on the same chart. Hope this helps. |
20240725_121329.png / V - Attached On 2024-07-25 10:17:27 UTC - Size: 679.88 KB - 29 views 20240725_121950.png / V - Attached On 2024-07-25 10:20:26 UTC - Size: 112.54 KB - 25 views |
