Date/Time: Sun, 08 Sep 2024 00:37:25 +0000
market depth
View Count: 79
[2024-07-24 14:27:12] |
p.a.c. - Posts: 2 |
BASICALLY, i have the maximum market depth for all ticks. done (1) i only want bid/ask stack for 10 ticks up and down current price and the cumulative of those, while also having all the market depth. (2) i want the cumulative yellow number to be in view. like 10 ticks above and 10 ticks below, but with market depth across all ticks |
[2024-07-24 15:18:57] |
1) Refer to the following: Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) 2) This depends on how you have your scaling as to whether you can view the sums on the DOM or not. But you can use the "Numbers Bars Calculated Values 2" study to display the sum of each side of the Pulling/Stacking. You can then use the "Text Display for Study" to display that information anywhere you want. Refer to the following: Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
