Date/Time: Fri, 13 Nov 2026 14:04:51 +0000
Error message on chart
View Count: 536
[2024-07-24 05:57:57]
User314484 - Posts: 9
Dear Support,
My chart is blank after I have opened a chartbook. I receive an error message which you can see in the attached screenshot.
Could you please help me solve this issue?
Regards
W
imageScreenshot 2024-07-23 224212.png / V - Attached On 2024-07-24 05:42:43 UTC - Size: 80.54 KB - 251 views
[2024-07-24 14:42:06]
John - SC Support - Posts: 48520
You are on Package 5, which means that you can only have the setting for "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" set to one of the following:
- SC Data - All Services
- Trading Evaluator
- Trading Evaluator - Delayed
The symbols you are showing are for CQG. To set the symbols for the current service, select "Edit >> Translate Symbols to Current Service". Refer to the following:
Edit Menu: Edit >> Translate Symbols To Current Service
[2024-07-25 20:17:14]
Dear Suppport,
Thanks a lot for the feedback.
Regards,
W
